Stuck in Analysis Paralysis - AVS Forum | Home Theater Discussions And Reviews
 31Likes
post #1 of 86 Old 12-12-2017, 06:07 AM - Thread Starter
joebuddyguy's Avatar
Quoted: 110 Post(s)
Liked: 153
Question Stuck in Analysis Paralysis
Hi, I currently have a LCR of Cheap Thrills speakers from diysoundgroup that Bill Waslo designed (here's the original design thread: http://www.hificircuit.com/community...12-dna360.197/) which are awesome but I'm looking to upgrade. I have a few ideas on what I want to do, but not sure what to do, lol.
My goals are something bigger with better pattern control lower and would really like something with sensitivity of 100/db watt or more. I'm currently looking at Titan 615lx, 1899s and also considering diy'ing some kind of JBL 4722 variant. I'm in Canada so I get screwed on driver prices a little and I enjoy woodworking, so I'm not afraid to build my own enclosures etc. At first I thought I would just get the Titans and enjoy, but I don't want to get the nagging feeling in the back of my mind that I should have went for something more crazy. I currently have 6 B&C 21SW152s and 1 Celestion NTR21-5010JD for subs. I'm still working on an enclosure design for the 21sw152s....going fairly large ported or using passive radiators after I try them out. Planning on tuning around ~17hz.
I like the idea of building a proven design since I know it will sound great but I'm also curious about trying to put something together myself and thought a diy JBL 4722 would be a nice way to ease into going a little off the beaten path. My idea for the DIY JBL 4722 involves using the 2384 horn mated to the 2453H-SL compression driver (thanks for doing all the legwork there and measurements @notnyt ) and then finding some 15s to work under the HF section. I have found some NEO B&C drivers that appear to be OEM'ed for Yorkville (model 15/219-8) that Long and McQuade are clearing out that model similarly to the JBL 265 drivers in the 4722. Here are their TS parameters:
Fs: 41
Re: 5.2
QMS: 6.31
QES: 0.38
QTS: 0.34
Vas: 199.24 l
Mms: 75.4g
Le: 1.27
Bl: 17.5
SPL: 99.56
Eff: 3.80%
Xmax: 4mm
PE: 400w RMS
They are a little more sensitive than the 265s but have less xmax and they are also less than half the price ($99 CDN) which adds up quick when you need to buy 6 drivers. I would think I would tune a 8cuft enclosure to 50hz or so with the two of the drivers per cab. My other idea is to turn the 4722 into an MTM with one 15 over and under the horn. Wouldn't that work better than the current 4722 implementation and might be a better configuration for smaller theatres that don't need the horn up so high? I have a couple Crown DSI amps so I could go active technically, but I was wondering how well the stock 4722 crossover would work.
Also, wondering if there is something else coming up in the DIYSOUNDGROUP skunkworks that would be up my alley. A MTM Titan would be awesome, hint hint :P @EricH
Any suggestions? Thanks in advance
joebuddyguy is offline
post #2 of 86 Old 12-12-2017, 09:04 AM
dtsdig's Avatar
Quoted: 1123 Post(s)
Liked: 1384
I heard some rumblings about a dual 12" TMWW Titan design in the past few weeks but haven't seen any details. I have not heard any of the Titans, but in my mind, I can't imagine wanting for more with 3 of those sitting in front of you.
To call out Erich, it's @Erich H
joebuddyguy likes this.
dtsdig is offline
post #3 of 86 Old 12-12-2017, 09:49 AM
Erich H's Avatar
Quoted: 1845 Post(s)
Liked: 2631
There is a dual Magnum-12 design that MTG90 did, but I'm not sure if it will be offered as a kit due to the overall price it would end up being. We haven't discussed it too much yet. A kit could be made up but I'm not sure about the flat packs.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #4 of 86 Old 12-12-2017, 10:26 AM
notnyt's Avatar
Quoted: 3719 Post(s)
Liked: 3686
I wouldn't use the stock 4722 crossover. You'd be better off going active. I'm putting something together soon with the minidsp pwr ice 250 plate amp. I'll see how it does.
notnyt is offline
post #5 of 86 Old 12-12-2017, 11:17 AM
BassThatHz's Avatar
Quoted: 3656 Post(s)
Liked: 4137
I have 3 gen1 ice 1000's. Their noisefloor and efficiency is quite good. SQ isn't too shabby considering gen1 class-D.
I'm sure they've improved some in the last 10years since then...
BassThatHz is offline
post #6 of 86 Old 12-12-2017, 12:12 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Cool, I'm looking forward to it....is it going to have 2 15's as well? I think I remember seeing one of your posts referencing the build.
post #7 of 86 Old 12-12-2017, 12:13 PM
notnyt's Avatar
Liked: 3686
No, not for me. My front stage is active, but using dedicated components to achieve a ridiculously low noise floor. That said, hypex is coming out with some plate amps with dsp soonish. That will be interesting.
notnyt is offline
post #8 of 86 Old 12-12-2017, 12:15 PM
notnyt's Avatar
Liked: 3686
It's the minidsp that really increases the noise floor I think.
notnyt is offline
post #9 of 86 Old 12-12-2017, 12:27 PM
trilkb's Avatar
Quoted: 630 Post(s)
Liked: 322
the qsc 2150 clone is also pretty nice ;-)
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #10 of 86 Old 12-12-2017, 12:32 PM
BassThatHz's Avatar
Liked: 4137
Since you have a 6001, you should test the mini, i'm sure it's not anywhere near -145db with any or even no filters on...
post #11 of 86 Old 12-12-2017, 01:39 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Anyone have any experience with a dbx venue 360 for dsp? I have a minidsp hd... But I think the noise floor will be too high for full range use.
Sent from my F3113 using Tapatalk
post #12 of 86 Old 12-12-2017, 01:56 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Cool, I remember seeing that one during one of eng's gtgs. I certainly wouldn't need a flat pack... And if someone really wanted one they could buy two of the mbm flat packs. The enclosure for the mid section would be pretty easy to diy...the TMM configuration would be really easy as the titan bracket would work for that one.
post #13 of 86 Old 12-12-2017, 01:58 PM
notnyt's Avatar
Liked: 3686
I've heard good things, but haven't tested one myself.
notnyt is offline
post #14 of 86 Old 12-12-2017, 01:59 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Thanks, yah, that one is interesting too... I tried to buy a trio of kits from a member but I didn't hear back from him. Maybe I should try again lol.
post #15 of 86 Old 12-12-2017, 02:00 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Hmmm... I think @NWCgrad was using one... Maybe he can comment
post #16 of 86 Old 12-12-2017, 02:59 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
On a semi unrelated note, I just got an alert from camelcamelcamel about the price drop of the b&c 21sw152-4 for a really great price. I'm sure someone can make use of it:
https://www.amazon.com/gp/aw/d/B00HJ...oCL&ref=plSrch
Steve Hanna, LTD02 and kaiforce like this.
post #17 of 86 Old 12-13-2017, 11:38 AM
NWCgrad's Avatar
Quoted: 1283 Post(s)
Liked: 1330
I am using one. I have tried both the balanced and unbalanced miniDSP 2X4 units and sold both. The dbx unit is very cool, the ability to sit in the prime listening position and tweak crossover points/filter type and PEQ filters is extremely useful. I am finding that what measures the best is rarely what sounds the best, I am unsure why that is. The Venu360 has a lot of DSP horsepower. Sometimes I get a noticeable hiss from the HF driver (JBL CD on horn without L-pad or other attenuation), but when I adjust the gain stages I can get the hiss to where you have to be within a foot to hear it. Someone more skilled at setting proper gain structure would be able to do even better.
I doubt there is any unit at the price point of the dbx that is better.
______________________________________
Home Theater:
https://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #18 of 86 Old 12-13-2017, 12:26 PM
asarose247's Avatar
Quoted: 1178 Post(s)
Liked: 1041
You do realize that the driver listed is suitable for Submaximus V3 . .
no one has built it with a 21" driver --yet
twould be interesting to know if and how it might be "better"
but since you can get 2 UM-18 for the same price . . .
decisions, decisions
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is online now
post #19 of 86 Old 12-13-2017, 01:16 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Ok, now amazon is tempting me... 21sw152-4 down to $509. Someone scoop these up. These are ~$200 cheaper than anyone else right now.
https://www.amazon.com/gp/aw/ol/B00H...&condition=new
post #20 of 86 Old 12-13-2017, 01:37 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Thanks man, that's what I was hoping to hear. The specs look really promising.... I was also looking at the xilica XD 4080 but it is $$$ and boasts Fir filter capability. So you don't find it noisy then? What kind of avr/processor do you have feeding it signal?
post #21 of 86 Old 12-13-2017, 01:43 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Haha, I've been tempted to build one, but I think with 6 ported 21s I'll be ok for output lol... My ht is only 2300cuft
post #22 of 86 Old 12-14-2017, 07:09 AM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Hmmm.....maybe I should go full stupid crazy like @Scott Simonian and go with 2 of those B&C 15s above and below a Wayne Parham mid-horn/DNA360 combo, does a passive crossover exist between those two(mid-horn and HF)?....looking at the modeling, I would be ~ 104db/watt from 50hz - 20khz. Scott, how much trouble was that to put together EQ wise? Or I could keep it a 2-way with the JBL 2453H-SL on a 2384 in between two pairs of 15s.
post #23 of 86 Old 12-14-2017, 07:44 AM
FriscoDTM's Avatar
Quoted: 417 Post(s)
Liked: 387
SEOS30 with the Radian 950 Be crossed under 500Hz to a horn loaded woofer sounds like a fun project that might fit some of your goals
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #24 of 86 Old 12-14-2017, 08:21 AM
NWCgrad's Avatar
Liked: 1330
I looked at the Xilica processors when I was researching the dbx unit. In the end the models with FIR were above what I was willing to spend.
I run a Marantz AV7702. Amps are Crown DriveCore for HF and MF and Crown XLS1500 for LF.
If you go with Parham's midhorns I have a couple of the Eminence drivers I could send your way. I am running the hard to find JBL 2012H's in mine.
Home Theater:
NWCgrad is offline
post #25 of 86 Old 12-14-2017, 09:27 AM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
That does sound fun.....those compression drivers are pretty pricey but I've read good things about them. I have a decent amount to spend on this project, but that may be a little out of my price range. That's why I was looking at the JBL 2453h-sl and the 2384 horn as kind of a value based compromise. Thanks for the suggestion
post #26 of 86 Old 12-14-2017, 09:46 AM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Nice, I'm gravitating to the venue360 although I might be in good shape with the crown dsi amps I have....would just need to find one more. I have some crown xls 1502 and 1500 amps as well that I'm currently using.
How much would you want for the delta10 drivers shipped to 48060? When you decided to use Wayne's horn and before you decided to full active, was there a passive crossover for the H290/midhorn(I guess the top 2/3rds of the 7pii design)? I'm wondering if I could try that here to save an amp channel.
post #27 of 86 Old 12-15-2017, 08:14 AM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Hey @notnyt , I understand you are using FIR filters for your LCR....is it a huge difference audibly to IIR filters? I found a good deal on Ashly PEMA amps using protea dsp and it appears it can support FIR filters, but looks like it has 384 taps.....is that sufficient for eq?
post #28 of 86 Old 12-15-2017, 12:22 PM
notnyt's Avatar
Liked: 3686
384 taps is not enough.
FIR filtering is nice, as I can do very precise corrections and steep crossovers without affecting phase. As to audibility of linear vs minimum phase, I still need to do some testing, but research states no audible difference. I'd still like to confirm this first hand at some point, but too many projects atm.
notnyt is offline
post #29 of 86 Old 12-15-2017, 07:44 PM - Thread Starter
Quoted: 110 Post(s)
Liked: 153
Cool, thanks for feedback... Other than the limited Fir capability, the amp looks pretty solid dsp wise. Don't hear too much about Ashly amps here though
post #30 of 86 Old 12-18-2017, 10:34 AM
NWCgrad's Avatar
Liked: 1330
As I recall the top 2/3rds of the 7 Pi XO should allow you to save an amp channel.
Send me PM on the drivers, they are brand new and never hooked up. I am missing on of the boxes as I used it to send my JBL 2012H driver for re-coning and they returned it in a B&C box.
Home Theater:
NWCgrad is offline
