Long overdue Builds Build - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 312Likes
post #241 of 548 Old 06-30-2018, 02:07 PM - Thread Starter
BassThatHz's Avatar
Quoted: 3678 Post(s)
Liked: 4170
Nope I didn't mess up, came together nicely.
I should be able to do some of the routing today.
biga6761 and Pradeep2 like this.
BassThatHz is offline
post #242 of 548 Old 06-30-2018, 03:20 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
The 5th panel is just drying now, then I'll add some braces. Nothing too crazy.
biga6761 likes this.
post #243 of 548 Old 06-30-2018, 05:23 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
Bracing and 6th panel is just drying now.
In about 45minutes I should be able to route the 1st panel of 3, and then take some more pictures.
I took all the stuffing out of my MBM's and never used it for the new MBM's so I'll put some of that in this box.
post #244 of 548 Old 06-30-2018, 06:27 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
Originally Posted by Shreds View Post
did you ever get a chance to run a close mic, full range measurement of a PA460 in your opposed sub array?
Originally Posted by Marc Alexander View Post
Can you post THD/compression sweeps at higher output levels? 100dB, 115dB, and MAX SPL would be nice.
8 of 16 NF, Compression Sweep
THD NF on the highest sweep:
All 16, EQ'ed @ LP (3m)
Not bad for $90 drivers in undersized sealed.
ID:	2422456   Click image for larger version
ID:	2422458   Click image for larger version
ID:	2422470   Click image for larger version
ID:	2422472   Click image for larger version
post #245 of 548 Old 06-30-2018, 06:48 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
post #246 of 548 Old 06-30-2018, 07:36 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
It started to rain so I had to abort the routing.
post #247 of 548 Old 06-30-2018, 09:13 PM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 671
Booooooooo!
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #248 of 548 Old 07-01-2018, 07:09 AM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 171
Lol!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is online now
post #249 of 548 Old 07-01-2018, 09:33 AM - Thread Starter
BassThatHz's Avatar
Liked: 4170
FML
I had to put it on a car blanket and drag it from my driveway to the back of the garage.
Then I had to dead lift it into a wheelbarrow
and now it's at the door of the HT
How do I get it out without dying?
ID:	2422726   Click image for larger version
ID:	2422728   Click image for larger version
Canadian Bronco and biga6761 like this.
post #250 of 548 Old 07-01-2018, 09:48 AM - Thread Starter
BassThatHz's Avatar
Liked: 4170
You know your driver is heavy when: it can suspend a heavy-duty wheelbarrow vertically by the lip...
My ankles, knees, back, elbows and wrists, and well everything... is killing me now. Excellent Smithers!
Shreds and biga6761 like this.
post #251 of 548 Old 07-01-2018, 10:15 AM - Thread Starter
BassThatHz's Avatar
Liked: 4170
Oh look a UM-15, how cute!
Oh look a LMS-18, how cute!
Oh look a MalX-21, how cute!
ID:	2422740   Click image for larger version
ID:	2422742   Click image for larger version
stegen, Nalleh and biga6761 like this.
post #252 of 548 Old 07-01-2018, 10:30 AM
tk123's Avatar
Quoted: 168 Post(s)
Liked: 138
You’re crazier than hell dude !!! I love it !!!
BassThatHz and biga6761 like this.
tk123 is offline
post #253 of 548 Old 07-01-2018, 10:31 AM
michael hurd's Avatar
Quoted: 635 Post(s)
Liked: 669
Discomfort is temporary, bass is forever.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #254 of 548 Old 07-01-2018, 11:51 AM - Thread Starter
BassThatHz's Avatar
Liked: 4170
Now have a hole and bracing.
I'm running out of time so I think I'll just clean up the saw dust, put the binding post in, throw some poly in it and run it up-firing for now.
Then look at adding the other 2 panels sometime in the next few months.
I want to see what it sounds like and see how well the fp20k pushes it.
post #255 of 548 Old 07-01-2018, 12:36 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
Knowing me it probably won't fit on the 1st try, so nylon threads to the rescue.
post #256 of 548 Old 07-01-2018, 01:51 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
Yep, made the hole a touch too small. Gotta pull it back out.
post #257 of 548 Old 07-01-2018, 02:54 PM
johnson636's Avatar
Liked: 671
Rookie
stegen likes this.
post #258 of 548 Old 07-01-2018, 03:08 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
Ok attempt # 2...
I was trying to be smart and did less than SI listed on their site.
I figured it might be insufficient, but I just had to prove it to myself in my Aspie/Aut/OCD ways.
ID:	2422874   Click image for larger version
post #259 of 548 Old 07-01-2018, 03:18 PM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 171
Wow!
post #260 of 548 Old 07-01-2018, 03:48 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
After just over a year, the 24 is finally done-ish.
I guess I have more space back there than I though with only 1 row of seats. (i.e. time for more subwoofers! )
That's a full 8ft sheet resting against the front row, that's the drywall that I was gonna put on the door to make it ~1.25inches thicker and ~110lbs heavier etc.
post #261 of 548 Old 07-01-2018, 04:03 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
WT2 Box Results:
Buffer[2] Box Ver 7.01
Completed: Sun Jul 01 16:01:29 2018
Drive level 2.158% [75.601 uA]
Sine,LoZP(LV/LA)->Box,100 pts
Re = 0.0000 (box test)
flo = 0.0000, Zlo = 0.0000
fhi = 0.0000, Zhi = 0.0000
fm = 0.0000, Zmid = 0.0000
Fsb = 0.0000
Ha = 0.0000
Alpha = 1.0000
; Sealed Box Data
Re = 3.3541
Fbox = 42.0332
Flo = 30.2272
Fhi = 52.7614
Qbox =10000.0000
Qleak =10000.0000
Qmss = 5.0664 - Qms in sealed box
Qess = 0.7944 - Qes in sealed box
Qtss = 0.6868 - Qts in sealed box
Qtc = 0.7185 = Qts*Fbox/Fs
req dependent resistance
Erm = 751.537E-03 Rem=Krm*(2*pi*f)^Erm
Kxm = 69.392E-03 Henries Freq dependent reactance
Exm = 667.987E-03 Xem=Kxm*(2*pi*f)^Exm
10hz:
20hz:
There appears to be an air leak from 2 of the nylon threads killing the <20hz performance, gonna have to fetch them out somehow.
FYI: I was able to clip the fp20k 1ch @ 20hz with the SAB-24, even with the leak. Excursion was pretty crazy though...
ID:	2422898   Click image for larger version
ID:	2422900   Click image for larger version
Name:	SAB24 Sweep.jpg
post #262 of 548 Old 07-01-2018, 04:09 PM
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
Perhaps it was already mentioned, but what was your rationale for putting this into a very small sealed cabinet, as opposed to a ported cabinet? Just the sheer size the ported cabinet would've been?
stegen likes this.
Craig S King is offline
post #263 of 548 Old 07-01-2018, 04:28 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
I wanted lots of 1-10hz from it.
It would basically have to be an IB-sized box. LOL
post #264 of 548 Old 07-01-2018, 04:54 PM - Thread Starter
BassThatHz's Avatar
Liked: 4170
Nope I think it is the wood that is warped by a half mm that is causing the air leak.
Gonna have to add a 2nd panel FOR SURE now!
Oh well, I'll just use it as-is for now...
post #265 of 548 Old 07-02-2018, 05:56 AM
Quoted: 359 Post(s)
Liked: 510
Who makes this 24" sub? Is this the Stereo Integrity 24" ?
post #266 of 548 Old 07-02-2018, 09:34 AM - Thread Starter
BassThatHz's Avatar
Liked: 4170
JLD SAB-24
https://www.alibaba.com/product-deta...423130541.html
post #267 of 548 Old 07-02-2018, 09:58 AM
johnson636's Avatar
Liked: 671
Good luck trying to get one. JLD doesn't seem interested in selling less than their MOQ of 50.
post #268 of 548 Old 07-02-2018, 10:56 AM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 171
BTH, I'm shocked that you didn't go for the 32" sub!
post #269 of 548 Old 07-02-2018, 11:06 AM
Quoted: 21 Post(s)
Liked: 26
Quite a few times a sample is mentioned on this one, and min is 15 to order
https://www.alibaba.com/product-deta...13aa8d6a7osDTR
Dont know if theyre getting hopeful that someone wants this bad enough they buy a few or what, but I do see less offers of samples on the listings now as well.
Canadian Bronco is offline
post #270 of 548 Old 07-02-2018, 01:03 PM
Red Five's Avatar
Quoted: 388 Post(s)
Liked: 441
Clearly the bass meds have not been taken as directed
Craig S King likes this.
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is online now
