The Periscope Subwoofer B&C 21DS115 - AVS Forum | Home Theater Discussions And Reviews
 254Likes
post #1 of 219 Old 12-26-2017, 06:03 PM - Thread Starter
corradizo's Avatar
Quoted: 1524 Post(s)
Liked: 1580
I recently sold my (2) HT18 sealed subwoofers along with the iNuke 3000 DSP amp. I also sold my (4) 1260w in sealed boxes that were in my living room. I also removed the htib subwoofer from my bedroom. Why? Because I decided I wanted to better contain and focus my hobby. (I may have been nudged by my wife to consolidate, so what..).
I took the money from the subs I sold and picked up a couple of new B&C 21DS115-4 (inspired by @eng-399 awesome subs) to pair with my recently rebuilt Fusion8's. All of it will go behind a used 120" AT screen from @brian6751 , a gorgeous silver ticket 120" and images will be provided by my Optoma GT1080 Darbee short throw projector.
For each box, I have 20" depth (22" but I want the driver to have room to move), 32" width and 96" height. I think I'll limit the height to 48" so I can add two Moaaar subs someday if I wish.
I'm working on a side firing slot design that will be externally tunable for these. Tune range will go from 14hzish to 20hzish.
Each box will end up somewhere in the 11.25 to 12ish cuft after driver and port are subtracted depending on if I go 30" wide or 32". I may keep it to 30" so I can upgrade to wider mains someday.
Pics and progress to follow..
Edit: I'm dropping the "tunable" part of this sub because...i'm lazy.
Edit: adding finished pics. I ended up building the subs, the center console/stand, speaker stands all from the 4 sheets of plywood I used for the sub build. The inwalls behind everything are the original monoprice setup that surrounded a 60" sharp LCD TV. I've left them in place as a reminder...
corradizo is online now
post #2 of 219 Old 12-26-2017, 06:04 PM - Thread Starter
corradizo's Avatar
Liked: 1580
Edit: scrapping the tunable part of this but retaining the side firing g design.
Externally tunable side firing slot bass reflex design.
48"T x 32"w x 20" deep. Double baffle. 3" tall slot port that runs up the side and fire out of the side. This keeps to the same design principals @eng-399 employed so as to not shake the screen. You remove tuning "plates" to raise the tune or keep them all in to get the lowest tune. After designing it this way it occurred to me that maybe fine tuning by 1hz is not that useful. I need to verify the effective port length with testing and measurements. My understanding is you add half the height of the port past the internal port inlet so that your actual tune matches winisd. Thus the actual port length is less.
LTD02, biga6761, bubbrik and 1 others like this.
post #3 of 219 Old 12-26-2017, 06:05 PM - Thread Starter
corradizo's Avatar
Liked: 1580
post #4 of 219 Old 12-26-2017, 06:07 PM
Jk7.2's Avatar
Quoted: 1408 Post(s)
Liked: 2571
Sounds like an awesome project. I will be following your progress! I was also inspired by the great eng-399 sub system. Can’t wait to see how these drivers work for you.
corradizo likes this.
Jk7.2 is offline
post #5 of 219 Old 12-26-2017, 06:18 PM
markg35's Avatar
Quoted: 344 Post(s)
Liked: 268
How will you power these?
markg35 is offline
post #6 of 219 Old 12-26-2017, 06:56 PM
eng-399's Avatar
Quoted: 2418 Post(s)
Liked: 4963
I'm soooooo excited for you! These subs in person is something to see.... there big! can't wait to see the box with multiple tunes and that's not by plugging one of the ports. Everyone will see soon
corradizo and Jan3 like this.
eng-399 is offline
post #7 of 219 Old 12-26-2017, 07:52 PM - Thread Starter
corradizo's Avatar
Liked: 1580
I have a iNuke 3000 DSP from the 1260w subs (better known as the sausage subs) that I didn't sell so right now I think I'm going to get another 3000 DSP and sun one amp bridged per sub. Or I guess I could sell the amp I have and just get a 6000DSP. Problem with the 6k is I'd have to deal on with the "power on thump" as I'd plan to use a smart power strips to turn it on. The third option is to look at another amp altogether as I do have an unbalanced minidsp in the arsenal as well. Not sure what that option should/could be yet. I think a clone would likely be more power than needed. I'll post more design stuff later like my SketchUp model and WinISD screenshots.
post #8 of 219 Old 12-26-2017, 07:54 PM - Thread Starter
corradizo's Avatar
Liked: 1580
Yeah they are definitely really nice up close. The quality is definitely there. The basket reminds me of the Lexus f-sport rims. Heck these are actually bigger than f-spot rims! I need to find some time to break them in free air and take some T/S measurements.
eng-399 likes this.
post #9 of 219 Old 12-27-2017, 05:10 AM
3ll3d00d's Avatar
Quoted: 2286 Post(s)
Liked: 2372
are you planning to make the port exit ever larger as you remove panels or are you going to move the panels up and block off the extra port length?
if the former, I wonder whether that sort of rapid expansion at the mouth would have any negative effects. You might be able to approximate that in hornresp by modelling the port as a horn though the segments it has may not be enough to adequately model that sort of expansion.
biga6761 likes this.
3ll3d00d is offline
post #10 of 219 Old 12-27-2017, 05:30 AM
Quoted: 1012 Post(s)
Liked: 561
I assume you have to prevent "tune boards" from rattling. how will you do that?
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, Dual VBSS w Faital 18FH510
Kef LS50, Parasound New Classic, Focusrite 2i4 2nd Gen
donktard is offline
post #11 of 219 Old 12-27-2017, 11:44 AM - Thread Starter
corradizo's Avatar
Liked: 1580
It would get larger as boards are removed.
post #12 of 219 Old 12-27-2017, 11:48 AM - Thread Starter
corradizo's Avatar
Liked: 1580
If I don't get lazy and build it as designed, I think I would do tongue and groove between the planks and also on the sides. Open to ideas.
post #13 of 219 Old 12-27-2017, 11:58 AM
3ll3d00d's Avatar
Liked: 2372
it's hard to tell from the diagram exactly but the current model looks like it already expands from a 3" x 15" port into a mouth of 6" x 15", is that right? If so, is that intentional?
If each board is about 6" then the cross sectional area at the mouth will get big (relative to the port) very quickly. I don't know what effect, if any, this will have. The safe option would be to add some sort of extra piece to block off the extra port length. On the other hand, do you think you'll ever change the tune?
3ll3d00d is offline
post #14 of 219 Old 12-27-2017, 12:00 PM
Samps's Avatar
Quoted: 1220 Post(s)
Liked: 901
Not only do you need to make sure they don't vibrate, which will be no small task considering a subwoofers sole purpose in life is to create vibrations. But you also need to make sure all of those seams are 100% airtight. I applaud your creativity, but I think you'd be wise to pick a tune and be happy. Or come up with an easier path to multiple tunes.
Maybe that whole side of the box could be swapped out instead of little slugs? Gasket seal on the port rails and screw on the outside port panel? A big round port made with a sonotube could be easier. They are cheap in small sizes at Home Depot. Then you could just swap out the tube in different lengths.
Samps is offline
post #15 of 219 Old 12-27-2017, 12:01 PM
Liked: 561
Sounds fine, but I feel like you need to clamp them with some force at least.
I'd maybe do something like on this pic...
https://img.usaudiomart.com/uploads/...-condition.jpg
Would use those metal thingies I have no name for that you put in wood to hold the screws and just screw the boards on with some big head bolt screws.
donktard is offline
post #16 of 219 Old 12-27-2017, 12:16 PM - Thread Starter
corradizo's Avatar
Liked: 1580
Im not sure I follow you. I'll provide more detail. It is a 3" tall port the whole way and is the same width the whole way. The length is adjusted by removing the planks. I traced out the port length and labeled them. The planks are 6" tall and each plank corresponds approximately to the tune label next to it.
This is the SketchUp model if you want to check it out. https://www.dropbox.com/s/dnuxfcvalh...-20hz.skp?dl=0
post #17 of 219 Old 12-27-2017, 12:21 PM - Thread Starter
corradizo's Avatar
Liked: 1580
Thanks, you may be right in that I should just pick a tune. I'm actually just thinking to shoot for 16hz and call it a day. This would only require a single port brace down the middle and I'd have a 17" effective port width instead of 15.5".
Michael Mitten, Samps and biga6761 like this.
post #18 of 219 Old 12-27-2017, 12:27 PM
Quoted: 2370 Post(s)
Liked: 10113
I visualized something similar when I was designing my subs because of my indecision on tune, but eventually abandoned the idea to keep it simple. This design seems like a relatively simple solution, however.
Is this mostly just to be able to experiment when you first build them, and then settle on a tune and keep it there? If so, maybe you should use gasket tape while experimenting, but then once you settle on your tune actually glue the panels in place.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #19 of 219 Old 12-27-2017, 12:44 PM
3ll3d00d's Avatar
Liked: 2372
what I mean is that the mouth of each port is 15" wide and 6" tall so has a cross sectional area of 90 inch^2 whereas the cross sectional area of the port itself is 3" tall and 15" wide so has a CSA of 45inch^2, i.e. the port is expanding from 45 to 90 over the length of that opening. Perhaps this might illustrate
This is the volume of the port as it expands so the base is the main bit of your port (3x15) and the face is the mouth (in this example 12x15 because I was drawing it with 1 extra plank removed), the arc is the centerline of this area so is the "length" of this bit of the path. The lines radiating out are the slices of this volume to split it into segments for hornresp and the length of these lines would give you the cross sectional area for each segment as it expands from the 3" at the entrance to the 6 (or 12 or 18 or whatever) at the mouth.
I think you could then model it in hornresp something like
and if you did then hornresp would complain that the expansion rate is too fast so the model may be inaccurate. If you accept that warning and proceed then it doesn't look like there is any issue however I have no idea whether there would be an issue in reality (i.e. what might lurk behind that warning). I thought it worth pointing it out as the possible issue though.
ID:	2336158   Click image for larger version
3ll3d00d is offline
post #20 of 219 Old 12-27-2017, 02:20 PM - Thread Starter
corradizo's Avatar
Liked: 1580
With all the planks in place it is basically a periscope. Are you saying it may act more like a horn as one would remove the planks? I'm sorry I'm having a major mental block here.
post #21 of 219 Old 12-27-2017, 02:36 PM
3ll3d00d's Avatar
Liked: 2372
No I'm not saying it is a horn. hornresp lets you model a bunch of stuff via those horn segments, in this case it's using the horn segments to model a flared port. This is the schematic of that port section alone (with 1 plank removed so it is a 12" opening)
that flare at the end is the expansion as the port opens out to the mouth
3ll3d00d is offline
post #22 of 219 Old 12-27-2017, 03:26 PM
Michael Mitten's Avatar
Quoted: 205 Post(s)
Liked: 215
IMO keep it simple. Do the 16hz tune and sit back and enjoy. I'd be surprised if you could build it and NOT get rattles.
chiquito3 and biga6761 like this.
Michael Mitten is offline
post #23 of 219 Old 12-27-2017, 04:03 PM - Thread Starter
corradizo's Avatar
Liked: 1580
Since the external tuning issues are reaching beyond my grasp, I'm thinking maybe to keep the external exit at 3" tall like the rest of the port and just make the inside board shorter and maybe make a way to tune it from the inside?
post #24 of 219 Old 12-27-2017, 04:16 PM
eng-399's Avatar
Liked: 4963
eng-399 is offline
post #25 of 219 Old 12-27-2017, 04:30 PM
Liked: 10113
Visualize the cross-sectional area that the air is moving through as it is exiting the port. As it reaches the last panel that you currently have in place, it is opening up to the room, but still has the barriers of the sub restricting it. As it gets further from the port opening, that cross-sectional area is increasing, similarly to how it would in a flared port. That similar flared port is what @3ll3d00d modeled in HornResp.
I am not an expert, but I don't expect this to actually cause any issues, as this isn't a much different situation from when a ported sub is placed with the port close to a wall. In fact, my ports are firing into a corner which is made up of two walls and an angled ceiling, so it is very much a flared port situation.
post #26 of 219 Old 12-27-2017, 07:21 PM - Thread Starter
corradizo's Avatar
Liked: 1580
I get it now. I wish I had the time to learn hornresp.
post #27 of 219 Old 12-29-2017, 10:40 AM - Thread Starter
corradizo's Avatar
Liked: 1580
Going to go with one port length and simplify. Updated first and second posts to reflect the changes. Can someone verify my port length assumptions? As is, i think it is a 14.6hz tune. I may shorten the inner board to up the tune and get some more spl.
Pete
Jk7.2 likes this.
post #28 of 219 Old 12-29-2017, 02:37 PM
eng-399's Avatar
Liked: 4963
Few questions you said three port dividers.
So the box is 20 inches wide right so let’s subtract 1.5 inches for the sides. Now you posted you have one slot port rail right? Please confirm
Also what are you putting In Winisd for a rough box size 12 cubic ft.
eng-399 is offline
post #29 of 219 Old 12-29-2017, 02:39 PM
eng-399's Avatar
Liked: 4963
SideFire Bass Reflex Subwoofer B&C 21DS115
If this is the case
12 cubic ft box
Slot port vent 3” high
17.75 inches wide because you subtract the sides 1.5 inches and the single port rail down the middle.
Slot port length 48” inches long will give you a 14.85 hz tune
Air port velocity is 18.741 at 14.37hz at its highest
And come excursion looks good up to 2,500 watts with a hp added into the mix
eng-399 is offline
post #30 of 219 Old 12-29-2017, 03:21 PM - Thread Starter
corradizo's Avatar
Liked: 1580
Double baffle so with one port divider it's 3" x 17" x 48". Since I am going to power reach with an iNuke 3k I'm modeling at 1800w but as @Ricci indicated in his write up with @MarkSeaton design the iNuke 3k seemingly can peak at 2kw. I figure with bracing and driver I am looking at 11.5cuft. I might shorten the inner port board by 10" to give me a 16hz tune and make up a panel and use the kreg jig to install it to extend the port internally if I want more extension.
