Horn center channel ideas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-04-2018, 11:52 AM - Thread Starter
Liked: 0
I am looking to build a center channel to go with my main's. The speakers I am currently using are basically some HTM-12 clones that I built and I can not run a vertical center due to space constraints. I would like to have at least a dual 10" drivers in the center. Any help would be greatly appreciated.
Neuht is offline
post #2 of 7 Old 01-04-2018, 12:03 PM
Raylon's Avatar
Quoted: 443 Post(s)
Liked: 585
Raylon is offline
post #3 of 7 Old 01-04-2018, 08:14 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 531 Post(s)
Liked: 642
Maybe it's too obvious, but the 88 Special is a pretty good team player with the HTM-12s as a center. See my room photos.
Cam Man is offline
post #4 of 7 Old 01-04-2018, 09:24 PM
asarose247's Avatar
Quoted: 1248 Post(s)
Liked: 1092
HTM12 and 88 all 15" SEOS horns, win-win - YMMV
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #5 of 7 Old 01-05-2018, 03:19 AM
Quoted: 566 Post(s)
Liked: 64
Do you have crossover design skills? Do you want a kit or are you capable of a custom design?
Tip24/96 is offline
post #6 of 7 Old 01-05-2018, 06:29 AM - Thread Starter
Liked: 0
As long as I have something to go by as far as the crossover goes then yes.. I am not apposed to using a kit but even the 88 wont fit in the area that I would like to use. I basically have enough room for a basic MTM center. I do however have about 55" in length to work with. I may just end up using something like the fusion series centers.
Neuht is offline
post #7 of 7 Old 01-05-2018, 07:39 AM
markg35's Avatar
Quoted: 353 Post(s)
Liked: 284
I have a Fusion 8 center, under my TV, in my living room.It's a great center channel, probably as good as almost any factory built center you can buy,at a fraction of the price.
However,If I had the room,I would have built a 1099 or 88 special.
markg35 is offline
