New Peerless 15" STW-350F with 90mm mechanical excursion - Page 20 - AVS Forum | Home Theater Discussions And Reviews
 505Likes
post #571 of 598 Old 04-18-2019, 09:29 AM
Stereodude's Avatar
Quoted: 4368 Post(s)
Liked: 3104
Originally Posted by corradizo View Post
It certainly looked beefy.
Originally Posted by BP1Fanatic View Post
Yeah it does!
Unfortunately for them we listen to our subs not (just?) ogle the drivers.
Stereodude is offline
post #572 of 598 Old 04-18-2019, 02:39 PM
BP1Fanatic's Avatar
Quoted: 410 Post(s)
Liked: 382
Word!
BP1Fanatic is offline
post #573 of 598 Old 05-08-2019, 09:50 AM
notnyt's Avatar
Quoted: 3913 Post(s)
Liked: 3851
Well, real shocker here.
Ricci measured the driver and even free air couldn't provide enough voltage to reach claimed 45mm excursion.
https://data-bass.com/#/drivers/5cc9...3086?_k=ri7vt6
Realistically this is a 18 or 20mm Xmax driver with a cushion beyond that point and a bottomless design. The 10.4mm mathematical Xmax is under spec'd for sure, but any hopes of it being a 90mm peak to peak driver are unrealistic.
notnyt is offline
post #574 of 598 Old 05-08-2019, 12:33 PM
STL D's Avatar
Quoted: 451 Post(s)
Liked: 542
If Josh couldn't feed it enough voltage to reach 45mm in free air, then it's plain and simple not possible for that driver.
I still expect the sealed testing with that driver to be interesting either way.
STL D is offline
post #575 of 598 Old 05-08-2019, 12:40 PM
noah katz's Avatar
Quoted: 2528 Post(s)
Liked: 947
@Ricci
"Functionally this driver seems to be useful or relatively clean until somewhere around 20mm one way. The driver will keep producing more excursion beyond that point if more power is dumped into it, but it audibly degrades quickly from there."
Is this free-air or in a box?
Noah
noah katz is offline
post #576 of 598 Old 05-08-2019, 12:58 PM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 973
@Ricci
It was free air on the test stand.
I use a single channel of an old crest 8002 for this not the big amps. The rated voltage is 92v rms on a single channel or 2000w into 2ohms, 1400 into 4, 800 into 8 so I can only push the drivers so far with that. With that said perhaps the bridged K20 could Tesla coil it to 90mm peak to peak momentarily but Im doubtful. Maybe...Coils were in parallel.
BassThatHz, Gorilla Killa and 300z like this.
Ricci is offline
post #577 of 598 Old 05-08-2019, 08:32 PM
popalock's Avatar
Quoted: 1508 Post(s)
Liked: 2105
Welp, put that one to sleep...
popalock is offline
post #578 of 598 Old 05-09-2019, 03:34 AM
Chris Popovich's Avatar
Quoted: 368 Post(s)
Liked: 342
Well, good to know. Thanks for posting!
Chris Popovich is online now
post #579 of 598 Old 05-09-2019, 06:11 AM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 973
Ehhh I don't know. We'll see how it does in the GP testing.
Ricci is offline
post #580 of 598 Old 05-09-2019, 08:02 AM
noah katz's Avatar
Liked: 947
Did it do significantly worse than other drivers tested free-air at the same excursion?
I was under the impression that drivers that remain quiet over 20mm were rare.
I know that my Maelstrom 18's get noisy around then, but inaudible in use (sealed box).
Noah
post #581 of 598 Old 05-09-2019, 10:12 AM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 973
Depends on the driver, but yes most of them make a LOT of air noise from the motors once significant excursion is produced. Then you have your mechanical operational noises and then you have the sound. Also the remarks I made are an experienced estimate / comparison after 100 something drivers but not a strict measurement. When I mention that this or other drivers start sounding distorted I don't mean air-noise from the motor, I mean there is a change that occurs in the sound emanating from the cone and / or mechanical noises. Again this is commentary based on subjective opinion so take that for what it's worth. The GP testing will fill in a lot more of the picture.
noah katz likes this.
Ricci is offline
post #582 of 598 Old 05-11-2019, 10:10 AM
popalock's Avatar
Liked: 2105
You fully recovered from the Derby shenanigans?
Looking forward to see the GP test results!
popalock is offline
post #583 of 598 Old 10-21-2019, 06:19 PM
SpinMonster's Avatar
Quoted: 525 Post(s)
Liked: 324
Any results yet?
SpinMonster is offline
post #584 of 598 Old 10-21-2019, 06:25 PM
300z's Avatar
Liked: 0
Send a message via Skype™ to 300z
Originally Posted by SpinMonster View Post
Any results yet?
https://data-bass.com/#/drivers/5cc9...3086?_k=mz36ub
300z is offline
post #585 of 598 Old 10-21-2019, 07:20 PM
Bigus's Avatar
Quoted: 713 Post(s)
Liked: 625
Formatting on databass site could use some tweaking. Text in the left side of screen is clipped on my S8 both landscape and portrait.
Bigus is offline
post #586 of 598 Old 10-21-2019, 07:28 PM
Ricci's Avatar
Quoted: 423 Post(s)
Liked: 973
Any results yet?
Nah...I've had a hell of a summer. Had to put DB on the backburner. Looks like it may be next year before I get back to GP testing.
Ricci is offline
post #587 of 598 Old 10-21-2019, 07:32 PM
EndersShadow's Avatar
Quoted: 1314 Post(s)
Liked: 1559
It’s a known issue since the new version rolled out.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #588 of 598 Old 11-16-2019, 05:08 PM
OsoSolitario's Avatar
Quoted: 111 Post(s)
Liked: 69
So, after reading the full 20 pages on this thread I can't extract any clear conclusion....
I have half a mind on a DIY sub disguised as a back table close to my main couch, so a driver like that STW would be the perfect match: small box profile, get ultra low frequency... But so much haters in these thread move away my initial excitement about this driver. It's actually that bad?
I must say that subwoofer/table project would complement a pair of SB16 Ultras placed on the front wall (with the main front speakers), so I want to get some extra "Slam and Oomph" on the very low bass on films (SB16 Ultras more oriented with stereo music only).
So don't you recommend that Tymphany STW-350? Would be better a simple Dayton UM18? Box size should be about 7ft3 and I'd like keep the SB16 low distortion/clean bass.
Any thoughts?
OsoSolitario is offline
post #589 of 598 Old 11-16-2019, 05:10 PM
Quoted: 368 Post(s)
Liked: 342
I'd rather a dayton UM18 in a sealed box with DSP. If you have 7ft3 available you have lots of options.
Craig S King likes this.
post #590 of 598 Old 11-16-2019, 05:15 PM
Quoted: 551 Post(s)
Liked: 465
Maybe SVS is low distortion for their price range but I just don't see them as an over all low distortion device. The UM18 will beat your SB16's in distortion.
The STW-350 won't give you improvements over the SB's either. They are roughly similar drivers with limited travel. What was found out in this thread is that they are intended to be used in ultra tiny boxes and have tons of power pumped into them.
If the UM18 is on your short list of comparable drivers I'd get that over this, 7cu/f box is big you could even make it smaller to 4cu/f for the UM18 if you wanted.
Chris Popovich and fill35U like this.
Trimlock is online now
post #591 of 598 Old 11-16-2019, 07:53 PM
Quoted: 368 Post(s)
Liked: 342
I mean, 7 cuft is big enough I'd start to think about two UM18's dual opposed with some healthy DSP.
Trimlock likes this.
post #592 of 598 Old 11-16-2019, 08:25 PM
Quoted: 525 Post(s)
Liked: 324
Any thoughts?
One of these 15's was sent along with a stereo integrity HST15 mkIII for Klippel testing. Hands down the HST is a better driver with spot on testing results that match its claims. The Peerless driver had linearity issues.
post #593 of 598 Old 12-05-2019, 09:32 PM
Liked: 0
So has anyone actually thrown one of these in a properly sized box and slapped 3500 watts at it?? Or is this just some pseudo-**** measuring argument?
Mechanical x- max doesn’t mean the speaker is going to operate desirably in that area... it just means it can move that far without bottoming out. Either I am retarded or others don’t understand what that measurement means.
IDIOTS LIVE HERE is offline
post #594 of 598 Old 12-07-2019, 10:28 AM
Quoted: 259 Post(s)
Liked: 254
Actually, that's exactly what Xmax means- the limit of (usefully) linear travel.
Xmech is the point where something bottoms out- either hits the backplate or the suspension can't stretch further.
https://en.wikipedia.org/wiki/Thiele...nal_parameters
Sources/processing: stack of stuff that if it isn't vintage now, it will be soon!
Amps: stacks and stacks of old iron
Main speakers: big DIYSG
Surrounds: Bose graveyard
Subs: a bunch
fill35U is offline
post #595 of 598 Old 12-13-2019, 02:20 PM
DarkEnigma's Avatar
Quoted: 168 Post(s)
Liked: 140
This was a very fun 20 page read lol. Should come here more often.
5.2.2 | Samsung KS8500 | Sony UBP-X800 | Yamaha RX-A1060 | SVS Ultra Center | SVS Ultra Towers | SVS Ultra Bookshelves | SVS Prime Elevations | 2x PB16-Ultra | Emotiva XPA-3 Gen3 | Emotiva BasX A-300 | 2x Crowson MA | 4x Buttkicker Advance | Nvidia Shield Pro
DarkEnigma is offline
post #596 of 598 Old 12-14-2019, 08:35 AM
BassThatHz's Avatar
Quoted: 4012 Post(s)
Liked: 4529
LOL
I figured if the LMS-18 is twice as expensive and has 4 slugs + the top plates and a much bigger basket and cone, and STILL barely reaches 44mm... then this driver stood zero chance.
Even my SAB-24 with 6.5inches of motor meat and a large tire surround, STILL barely manages 52mm's; the limiting factor being the basket I'm sure, and that subwoofer is one of the biggest/beefiest 24's around...
The peerless 15 is no RE XXX-15 as far as excursion goes.
Inductance though, that's a different topic...
give me an RF-19 or LMS-18 or SAB-24 any day over those.
Or even it's smaller brother, the SAB-18. MOQ of 1 too! ~$350 unshipped
BassThatHz is offline
post #597 of 598 Old 12-14-2019, 11:08 AM
noah katz's Avatar
Liked: 947
Originally Posted by BassThatHz View Post
...SAB-18. MOQ of 1 too!
What's MOQ?
Noah
post #598 of 598 Old 12-14-2019, 11:29 AM
notnyt's Avatar
Liked: 3851
What's MOQ?
minimum order quantity
notnyt is offline
