This seriously looks interesting.
Peerless by Tymphany STW-350F-188PR01-04 15" High Power Subwoofer
Product page:
https://www.parts-express.com/peerl...-188pr01-04-15-high-power-subwoofer--264-1652
Video review:
Optimum Cabinet Size
Highlights
90mm of "mechanical" excursion but published stat is just over 10mm.
Specs used for the attached WinISD file.
The first WinISD is with the published 10.4mm excursion.
The second WinISD is with excursion set to the 45mm mechanical limit.
https://www.tymphany.com/wp-content/themes/pathfinders/cache/pdfs/STW-350F188PR01-04.pdf
Product page:
Video review:
- Sealed Volume 2 ft.³'
- Sealed F3 42 Hz
- Vented Volume 2.88 ft.³
- Vented F3 24.2 Hz
Highlights
- Massive 7.4" voice coil produces extraordinary low power compression
- 2 Large aluminum shorting rings for better control and minimal harmonic distortion
- Dual 8 ohm voice coil allow multiple wiring configurations including dual amplifier designs
- Internal magnet structure provides more force from a smaller magnet
- Lower Vas and Fs with higher BL for unmatched low end capability from the smallest enclosures
- Extensive voice coil venting for quiet operation and increased power handling
- Over 90mm of mechanical excursion prevents failure under the most demanding conditions
