Amp upgrade options from Inuke6000 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By joebuddyguy
  • 2 Post By bear123
  • 1 Post By lukeamdman
post #1 of 9 Old 01-21-2018, 08:30 AM - Thread Starter
bear123's Avatar
Quoted: 2935 Post(s)
Liked: 4484
Ruling out clones for various reasons, I've been trying to wrap my head around viable amp upgrade options short of speaker power.
Priorities include substantially more power and substantially reduced fan noise. The Inuke6k's don't do well with fan mods. I know a few who don't have issues but many, including myself, had shut down issues.
It seems the PeaveyIPR7500/Crest 7.5 offer quite a bit more power, especially burst power which the Inuke's seem to lack, but they also have very loud fans. Do these amps perform well with fan mods? If so, it seems these might be worthwhile upgrades without jumping to the creme of the crop with Speakerpower.
The other option might be the Crown XLS2500, but seems they would have to be bridged in order to see a good power increase. These are about $600 each so $1200 for two vs. $1,000-$1050 for Peavey/Crest.
The Inuke just offers so much power for so little money. If only they worked better with quieter fans.
bear123 is online now
post #2 of 9 Old 01-21-2018, 08:35 AM
joebuddyguy's Avatar
Quoted: 110 Post(s)
Liked: 153
There is the crest cc5500 and cc4000 amps.... They will deliver their rated power and are 2ohm stable. I know @lukeamdman can vouch for them.
Sent from my F3113 using Tapatalk
lukeamdman likes this.
joebuddyguy is offline
post #3 of 9 Old 01-21-2018, 08:39 AM
Gorilla Killa's Avatar
Quoted: 1536 Post(s)
Liked: 2239
For the price of the Peavey you can get a sp1-6000, no fans. I guess if your ok with a plate amp that is
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is online now
post #4 of 9 Old 01-21-2018, 08:52 AM - Thread Starter
bear123's Avatar
Liked: 4484
This rules out the value aspect, since two would be needed.
post #5 of 9 Old 01-21-2018, 10:31 AM - Thread Starter
bear123's Avatar
Liked: 4484
According to Lukeamdman's amps tests on database, a pair of crown XLS2500 would offer great output for $1k for a 4 ohm load
lukeamdman and biga6761 like this.
post #6 of 9 Old 01-21-2018, 11:41 AM
lukeamdman's Avatar
Quoted: 1386 Post(s)
Liked: 2007
http://data-bass.ipbhost.com/topic/4...plifier-tests/
I have some tests for the iNuke, Crest CC amps, XLS 2500, and SpeakerPower SP2-12000 in that link.
biga6761 likes this.
lukeamdman is offline
post #7 of 9 Old 01-22-2018, 10:27 AM
zeus33's Avatar
Quoted: 1890 Post(s)
Liked: 1998
Didn't you have test results for the Crest 7.5 or the Peavey 7500 in that link at some point? I thought you had tested one of them.
zeus33 is offline
post #8 of 9 Old 01-22-2018, 10:31 AM
lukeamdman's Avatar
Liked: 2007
I tested a 7.5 early on in my testing when I was using subwoofers as the load and a pair of DMM to capture voltage and current. Not nearly as precise or detailed information.
By the time I got the scope and dummy load setup I had sold the 7.5 so I couldn't re-test.
post #9 of 9 Old 01-22-2018, 10:33 AM
zeus33's Avatar
Liked: 1998
The XLS2502 (2400 watts bridged into 4 ohms) is $487 at Amazon right now, so a pair would cost you $974.
https://smile.amazon.com/dp/B0129IKF...omp_smile_sav0
zeus33 is offline
