2 UM18-22 slot ported build ''A New Level" tall boy build - AVS Forum | Home Theater Discussions And Reviews
 120Likes
post #1 of 103 Old 01-26-2018, 10:29 AM - Thread Starter
eng-399's Avatar
Quoted: 2476 Post(s)
Liked: 5162
'' A New Level'' Everyone know I like theme named boxes so these will be called tall boys A New Level.... This from a Pantera song I like and thought about when designing these. Cliff currently has one Monoprice Monolith 15 THX in his room and running that nearfield along with one Dayton 12'' driver up front. I tested his room and figured out where the best spot to place these new slot ported boxes that I'm building. When measured the monoprice sub and also got a response from that so these will bring his room to A New Level!
The box size is
66'' tall
24'' wide
18'' depth
The tune is 17hz
The port height is 3 inches tall and 42.25 long.
External cubic ft. external 14.28 cubic ft.
internal cubic ft before subtracting the driver, bracing and slot port. 13.85 cubic ft
after bracing and slot port it should be around 11.75 to 12 cubic ft.
both of these boxes need 5 sheets of 3/4 MDF total so they might have some weight to them. Having tall boxes there not cut sheet friendly when trying to fit all the cuts on a sheet so a lot of wood was wasted but the end result will be worth it.
Standing waves inside the box....... There very tall!!
Since the boxes are tall I might have some standing waves inside the box which I'll fix with a pillow. With a tall box the internal standing waves and create some problems. So you take the height 5.5 ft. times that by 2 and the equals 11ft.
1130FPS/11 equals roughly 102hz. and Cliff so far wants to cross these at 120 hz. so I do some more reading and figure out where to place them.
Name:	cliff box max spl.png
ID:	2353324   Click image for larger version
Name:	cliffs box air port v.png
gixerking, biga6761 and Raylon like this.
eng-399 is offline
post #2 of 103 Old 01-26-2018, 10:29 AM - Thread Starter
eng-399's Avatar
Liked: 5162
eng-399 is offline
post #3 of 103 Old 01-26-2018, 10:30 AM - Thread Starter
eng-399's Avatar
Liked: 5162
eng-399 is offline
post #4 of 103 Old 01-26-2018, 10:52 AM
SpinMonster's Avatar
Quoted: 540 Post(s)
Liked: 329
Originally Posted by eng-399 View Post
The box size is
66'' tall
24'' wide
18'' depth
Mine is bigger than your's...hehe
Mine are 75" tall and 24x24.
I'm chiming in to say that at over 400lbs each with 2 LMS-ultra drivers, the boxes do not 'walk' around on the floor. I've monitored that for the last year. The biggest advantage is that since the 18's are at different heights off the floor, it evens out the room response quite a bit. I was creative with internal damping to address standing waves inside the boxes.
I look forward to your results.
eng-399 likes this.
SpinMonster is offline
post #5 of 103 Old 01-26-2018, 10:54 AM - Thread Starter
eng-399's Avatar
Liked: 5162
Mine are 72" tall and 24x24.
400 lbs. wow that’s some weight! What height did you cut out your drivers? So far the plan is having the bottom of the hole for the driver being 10 inches above the port so let’s say 18” would be the center of the sub above the slot port.
eng-399 is offline
post #6 of 103 Old 01-26-2018, 11:07 AM
Quoted: 540 Post(s)
Liked: 329
It's evenly distributed between the top of the port and the top of the box. I think 7" down from the top for the top driver and 7" above the port. I'd say the top of the top 18 is about 5' 7" above the floor.
the TC's are 165lbs of the total weight
post #7 of 103 Old 01-26-2018, 11:10 AM
Quoted: 540 Post(s)
Liked: 329
Having a driver above the other seems to fill in the floor dip in the response.
I'm far from an authority on the topic. Perhaps more informed minds can chime in on the issue.
post #8 of 103 Old 01-26-2018, 08:32 PM - Thread Starter
eng-399's Avatar
Liked: 5162
eng-399 is offline
post #9 of 103 Old 01-27-2018, 09:30 AM - Thread Starter
eng-399's Avatar
Liked: 5162
eng-399 is offline
post #10 of 103 Old 01-27-2018, 09:54 AM
gixerking's Avatar
Quoted: 294 Post(s)
Liked: 476
Man you really are a building beast! I can’t even think about another build right now, and you just keep rolling on lol 🙂 👍
eng-399 likes this.
gixerking is offline
post #11 of 103 Old 01-27-2018, 10:15 AM - Thread Starter
eng-399's Avatar
Liked: 5162
Thanks man ya I keep going and going three more boxes to go after these two are are finished to go. Your 1899’s are unreal with the way they look! I looked at the pictures you posted and my mouth dropped.
gixerking likes this.
eng-399 is offline
post #12 of 103 Old 01-27-2018, 10:56 AM
gixerking's Avatar
Quoted: 294 Post(s)
Liked: 476
Jesus man, you are going to wear that saw out haha 🍻
eng-399 likes this.
post #13 of 103 Old 01-27-2018, 03:31 PM
Craig S King's Avatar
Quoted: 468 Post(s)
Liked: 570
Looking forward to watching the progression of this project!
The flare you are putting on the internal entrance of the port.... do you think that would yield any advantages doing the same with a mini-marty port?
Craig S King is offline
post #14 of 103 Old 01-27-2018, 07:37 PM - Thread Starter
eng-399's Avatar
Liked: 5162
My personal opinion on having flared ports is yes it would help but every 90 degrees bend would have to have a smooth angle on it. Mtg90 suggested this to me during the My B&C build when he sent me the 3D image of the box I built. I see car audio guys doing this all the time so anything that can help the air port velocity have a nice transition through the port from the beginning to out of the box helps. I wonder how I can test this?
eng-399 is offline
post #15 of 103 Old 01-27-2018, 07:51 PM
Quoted: 81 Post(s)
Liked: 63
I am planning on a sub box build in the future and was leaning towards a mini Marty. Do you prefer an angle transition over KERF? Seen KERF a lot in car audio but not as much on here so far.
soundwave_rider is offline
post #16 of 103 Old 01-27-2018, 11:09 PM - Thread Starter
eng-399's Avatar
Liked: 5162
I haven’t tried a kerf bend yet in any boxes but I’ve seen Seaton Audio have a really nice bend on the bottom slot port of one of his cabinets he sold. I think an angled bend on the wood is pretty easy to do with out scraping to much wood if you mess it up like I did on my buddy box I’m building in this thread. Try both out though and see how it works out it’s just wood.
eng-399 is offline
post #17 of 103 Old 01-28-2018, 04:55 PM
Kraqa's Avatar
Quoted: 56 Post(s)
Liked: 49
looks awesome. keep the pics coming.
eng-399 likes this.
Marantz 6012 | Dual Full Marty’s with UM18's | iNuke6000DSP | ViewSonic PJD7828HDL | 135” Elite Screen 16:9 | Dual 8” speakercraft LCR | AIM 7 Surrounds | 5.2.2 Currently
Kraqa is offline
post #18 of 103 Old 01-29-2018, 03:31 AM
JHanko's Avatar
Quoted: 23 Post(s)
Liked: 47
Nice work! I would love to hear them when they are finished. I could also be available for help if needed. I'm just a few minutes from you.
JHanko is offline
post #19 of 103 Old 01-29-2018, 05:17 AM - Thread Starter
eng-399's Avatar
Liked: 5162
Thanks these are going together pretty smooth so far last night I glued the baffle together so next up is the window bracing. The plan is to cut all the window bracing today or tomorrow which ever day I have time then glue this all together and start all the finish work on them. As for hearing the sub in the box as long as I have one of Cliffs um18 drivers when there done it shouldn’t be a problem but if he picks it up beforehand it’s up to him because there not mine I’m just building the box for him.
No glue on these yet when I took this picture but here’s the hole cut out for it.
eng-399 is offline
post #20 of 103 Old 01-29-2018, 06:28 AM
JHanko's Avatar
Quoted: 23 Post(s)
Liked: 47
I have a couple UM18's here if you need borrow one for fitment/testing.
eng-399 likes this.
JHanko is offline
post #21 of 103 Old 02-03-2018, 11:17 AM - Thread Starter
eng-399's Avatar
Liked: 5162
Finally started back up in this project yesterday. Everything is cut so I started the assembly process. I first glued everything together with wood glue then followed with pl on all the seams. The pl was probably overkill since I glued everything together but it doesn’t hurt to be extra cautious I wish I wasn’t so sloppy with it but I guess no one will see it. I’ll line the inside of the box today with mattress topper and hopefully get the double baffle glued in and top piece on. Then off to sanding for that one.
eng-399 is offline
post #22 of 103 Old 02-03-2018, 01:25 PM
gixerking's Avatar
Quoted: 294 Post(s)
Liked: 476
I spy some little feet looking for the spot light 😉
post #23 of 103 Old 02-03-2018, 02:06 PM
Quoted: 1012 Post(s)
Liked: 565
Damn. I wish I did roundover on my ports before glueing everything together. Now I will stuff ports with sponges before routing if I don't want to end up with sub chuffing out MDF dust for a year.
Nice build btw.
eng-399 likes this.
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, Dual VBSS w Faital 18FH510
Kef LS50, Parasound New Classic, Focusrite 2i4 2nd Gen
donktard is offline
post #24 of 103 Old 02-03-2018, 02:43 PM
Quoted: 568 Post(s)
Liked: 474
Man those are tall!
Trimlock is online now
post #25 of 103 Old 02-03-2018, 02:55 PM - Thread Starter
eng-399's Avatar
Liked: 5162
@gixerking yep that’s my little helper he keeps me company during most of time while I’m building stuff I try to get him involved in it doing little things and teaching him what I’m doing. My dad when I was younger use to do that with me. Plus it’s better than him playing ps4 all day. @Trimlock dude there tall in person here’s a picture with my son next to it for size comparison.
ORIF, JCJetta, OJ Bartley and 3 others like this.
eng-399 is offline
post #26 of 103 Old 02-03-2018, 03:07 PM
Quoted: 157 Post(s)
Liked: 197
The box is looking really great! Just wondering why you went for window bracing instead of just cross bracing per the B&C build? Cheers!
Enviado desde mi SM-G920F mediante Tapatalk
monty6400 is offline
post #27 of 103 Old 02-03-2018, 06:15 PM - Thread Starter
eng-399's Avatar
Liked: 5162
To be honest every time I build a box I learn a new thing. The last box I built I didn’t make a thread for but did window bracing and figured out a fast and easy way of doing it. I wish I would of done window bracing in my B&C box but I do feel I braced the hell out of it so I’m good.
It’s so simple to do I have no idea why I didn’t think about this before. So the picture above is where I used scrap wood and basically made a window out of it.
1st thing I did was drill a hole through it.
2nd. Take my router with the flush trim bit and trim it out. Easy right!
3rd. Take a 3/8 round over bit and run that along the cut out after pulling the wood away from your window brace.
That’s really it.... super easy to do and covers all for sides of the box to reduce and resonances in the box.
jehlinge and monty6400 like this.
eng-399 is offline
post #28 of 103 Old 02-03-2018, 06:30 PM
dTorC4's Avatar
Quoted: 87 Post(s)
Liked: 147
That is looking fantastic!
eng-399 likes this.
dTorC4 is offline
post #29 of 103 Old 02-03-2018, 06:39 PM
hd0823's Avatar
Quoted: 945 Post(s)
Liked: 1796
Looks great as usual man
Sent from my SM-N950U using Tapatalk
eng-399 likes this.
hd0823 is offline
post #30 of 103 Old 02-03-2018, 06:53 PM - Thread Starter
eng-399's Avatar
Liked: 5162
eng-399 is offline
