Sub changes HSTs Nearfield ds4’s ported - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 554Likes
post #391 of 575 Old 08-10-2018, 09:01 AM
johnson636's Avatar
Quoted: 1112 Post(s)
Liked: 651
OK, I've been inspired to build new boxes for my 24s
Jk7.2 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #392 of 575 Old 08-10-2018, 09:03 AM
hd0823's Avatar
Quoted: 678 Post(s)
Liked: 1250
What are you running them in I'm about to start 2 30 cubic ft ported boxs
Sent from my SM-N950U using Tapatalk
hd0823 is online now
post #393 of 575 Old 08-10-2018, 09:09 AM
johnson636's Avatar
Liked: 651
I have them in 23cuft ported cabs at the moment. I'd love to build slimmer and taller enclosures, but I'm limited to 55" cuts. I have a Festool track saw, not a table saw.
post #394 of 575 Old 08-10-2018, 09:12 AM
hd0823's Avatar
Quoted: 678 Post(s)
Liked: 1250
I think I'm having a local lumber yard cut these they will be 48 wide 72 tall 18 deep 6 in tall slot port out the top. So how do you like the performance in the 23 cubic ft boxs. I really cant wait to start building them just have to finish the wifes library first
post #395 of 575 Old 08-10-2018, 09:16 AM
johnson636's Avatar
Liked: 651
Jeeezus Performance is great. My purpose for rebuilding would be to make room for what's to come
post #396 of 575 Old 08-10-2018, 09:22 AM
hd0823's Avatar
Quoted: 678 Post(s)
Liked: 1250
Lol yeah there going to be big is this to do with your new LCR
johnson636 and Jk7.2 like this.
post #397 of 575 Old 08-11-2018, 11:55 AM - Thread Starter
Jk7.2's Avatar
Quoted: 1375 Post(s)
Liked: 2518
As of now, I plan on sticking to the crossover in the titan. Matt has graciously helped me to tweak the design to boost the midrange a tad to keep up with the overall goal of my setup. I will measure the titans as fully stock speakers right before I add the second woofer modules. The cabs are all glued up and ready for sanding, round overs and duratex. I still need to cut my 5 sided boxes ( rear will not have a panel ) to load the mid/high waveguide into that will also support the upper bass bin. But progress is happening.
bscool likes this.
Jk7.2 is online now
post #398 of 575 Old 08-14-2018, 04:46 PM - Thread Starter
Jk7.2's Avatar
Liked: 2518
This is what the completed speakers will look like
imrf, johnson636, JCJetta and 4 others like this.
Jk7.2 is online now
post #399 of 575 Old 08-14-2018, 05:13 PM
Quoted: 171 Post(s)
Liked: 128
OK, I've been inspired to build new boxes for my 24[IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
What frequency are you going to plan to tune to at 30 cf? My 24's are supposed to be built this week. I haven't even built the sealed box i have all cut up and you guys are making me want to try ported.
I also really like the add on woofer for the titan. I like how they are turning out. I cant wait to see what you think of them. That is kinda of my dream set up right now.
rukus29 and Jk7.2 like this.
Randy_J is offline
post #400 of 575 Old 08-14-2018, 05:26 PM
johnson636's Avatar
Liked: 651
@Jk7.2 Will each component be modular or will you build them as a single enclosure like eng-399?
post #401 of 575 Old 08-14-2018, 05:31 PM - Thread Starter
Jk7.2's Avatar
Liked: 2518
They are the stock titan. With an additional 15” module added on top. I built a plywood box to house the waveguide and support the upper mid bass bin.
This will also come with some stock crossover tweaks. See my pic
corradizo likes this.
Jk7.2 is online now
post #402 of 575 Old 08-14-2018, 05:43 PM
johnson636's Avatar
Liked: 651
But will the additional 15" module be permanently affixed (glued) to the top or will it just sit on top giving you the ability to move each individual section?
post #403 of 575 Old 08-14-2018, 05:44 PM - Thread Starter
Jk7.2's Avatar
Liked: 2518
Individual.
Pradeep2 likes this.
Jk7.2 is online now
post #404 of 575 Old 08-14-2018, 05:46 PM
johnson636's Avatar
Liked: 651
Love it
Jk7.2 likes this.
post #405 of 575 Old 08-16-2018, 07:47 AM - Thread Starter
Jk7.2's Avatar
Liked: 2518
Love it
I looked through your qsc 2150 thread. Good idea. I can only imagine those bad boys with 18” duel woofers. Good plan!
johnson636 likes this.
Jk7.2 is online now
post #406 of 575 Old 08-16-2018, 08:01 AM
hd0823's Avatar
Quoted: 678 Post(s)
Liked: 1250
That will be right around a 15hz tune
post #407 of 575 Old 08-16-2018, 08:04 AM
johnson636's Avatar
Liked: 651
Well I thought I was all set on going with the original 2150 enclosure design until the mock of your enclosure. It would definetly be a more simpler build using Eric's Titans flat pack.
https://www.avsforum.com/forum/155-d...l#post56628070
ID:	2442400   Click image for larger version
post #408 of 575 Old 08-16-2018, 01:37 PM - Thread Starter
Jk7.2's Avatar
Liked: 2518
I’ve been gluing up the center modules over the past two days. All set to sand and roundover the edges. Then I’ll roll on a nice coat or two of duratex and be ready to get these behind the screen. For the centers I used stuff I had around. Some plywood, mdf, and particle board. Lol. Desperate times ya know? I am happy to report these speakers will be 6’ 4”. That’s 5 or 6” taller then me. I can’t wait to fire these up. @eng-399 please don’t do anymore stuff I have to copy! Your killing me!!!!! Lol.
Jk7.2 is online now
post #409 of 575 Old 08-16-2018, 01:41 PM
Jedi940's Avatar
Quoted: 260 Post(s)
Liked: 179
Nothing wrong with particle board. That's what I used to build my LCR when I didn't know any better and it certainly hasn't affected the sound quality.
Jk7.2 likes this.
Jedi940 is offline
post #410 of 575 Old 08-16-2018, 01:42 PM - Thread Starter
Jk7.2's Avatar
Liked: 2518
Yeah. That, and it’s just a holder for the waveguide. And support for the upper section. Not really a “box” but a shelf. I figured it would work.
Jk7.2 is online now
post #411 of 575 Old 08-16-2018, 02:12 PM
eng-399's Avatar
Quoted: 2404 Post(s)
Liked: 4947
I can’t promise anything I’m going to be building a V2 of the Titan 630’s starting very soon changing the internal design and waveguide area.... same tune same size box...
VicTorious1, Jk7.2 and Pradeep2 like this.
eng-399 is offline
post #412 of 575 Old 08-16-2018, 02:13 PM - Thread Starter
Jk7.2's Avatar
Liked: 2518
Well, I suppose I can allow that. Lol
Jk7.2 is online now
post #413 of 575 Old 08-16-2018, 02:15 PM
eng-399's Avatar
Liked: 4947
eng-399 is offline
post #414 of 575 Old 08-16-2018, 03:21 PM
Jedi940's Avatar
Quoted: 260 Post(s)
Liked: 179
What is this modification going to get you?
Sent from my SM-G950U using Tapatalk
Jedi940 is offline
post #415 of 575 Old 08-16-2018, 03:42 PM
eng-399's Avatar
Liked: 4947
Better air flow through the cabinet exiting the slot port, the waveguide box be designed a little different and have less depth to it. Bracing might be a little different to. This time I would also like to eq the box outside and get a baseline of it and then add eq to maximize the performance of the dual 15’s with maybe two different curves. One would be a boosted low end and another with a flat fq response. I don’t yet..
Jk7.2 and Mahuzz13 like this.
eng-399 is offline
post #416 of 575 Old 08-18-2018, 05:31 AM - Thread Starter
Jk7.2's Avatar
Liked: 2518
Last night I hooked up the bortech fp14000 clone. It made some noise. (Bass noise) Then pop! My 30a circuit blew and when I got it turned back on, the amp channel A was/is dead. Wasn’t pushing it super hard, I was kinda just getting everything plugged in and speakons re-wired for non bridged mode. (1+ positive and 1- negative)
So long story short, I have no clone amp. Emailed the seller about warranty. We shall see.
PS, if anyone knows a reset procedure that I’m missing, let me know. There was no smoke, nothing smelled weird, maybe the amp is just stuck in protection? The TEM light is on for channel A. What does that even mean?
Jk7.2 is online now
post #417 of 575 Old 08-18-2018, 06:38 AM
johnson636's Avatar
Liked: 651
Looks like you may have a blown fuse on channel A. You can verify this easily by opening it up and checking the board's fuses. But, if there's a warranty in place, I wouldn't bother trying to fix it...send it back and let them deal with it. Oh BTW, Notnyt tested the Bortec Labs FP14000 and the consensus is to stay away from Bortec Labs. The owner of Bortec Labs, at least he told me he was the owner, seemed a bit shiesty.
post #418 of 575 Old 08-18-2018, 07:21 AM - Thread Starter
Jk7.2's Avatar
Liked: 2518
Looks like you may have a blown fuse on channel A. You can verify these easily by opening it up and checking the board's fuses. But, if there's a warranty in place, I wouldn't bother trying to fix it...send it back and let them deal with it. Oh BTW, Notnyt tested the Bortec Labs FP14000 and the consensus is to stay away from Bortec Labs. The owner of Bortec Labs, at least he told me he was the owner, seemed a bit shiesty.
Nice to know. It was cheap though.
I did message @notnyt and asked what he knew about it. Maybe he can point me in the right direction.
And I’d love to know if these amps are 2 ohm stable.
Jk7.2 is online now
post #419 of 575 Old 08-18-2018, 09:09 AM
johnson636's Avatar
Liked: 651
Maybe he'll respond, but in the FP14000 clone thread he was adamant about not being messaged about these amps. I'd contact the seller.
post #420 of 575 Old 08-18-2018, 09:12 AM - Thread Starter
Jk7.2's Avatar
Liked: 2518
I have messaged the seller. I’ve never read through that thread. I hope I don’t offend him.
Jk7.2 is online now
