Sub changes HSTs Nearfield ds4’s ported - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 554Likes
post #211 of 575 Old 07-02-2018, 07:13 AM - Thread Starter
Jk7.2's Avatar
Quoted: 1408 Post(s)
Liked: 2576
Originally Posted by eng-399 View Post
The first port resonance started to get to low having the full width of the box when modeling it in winisd so it had to be shorten up a tad.
Thanks. I forgot that part.
Jk7.2 is online now
post #212 of 575 Old 07-02-2018, 07:16 AM
eng-399's Avatar
Quoted: 2419 Post(s)
Liked: 4965
Jtr even has there ulf 4000 Nearfield box port in the middle that doesn’t run across the entire bottom due to that to. To bad the port affects the box like that. It would be easier to run it across the entire bottom.
eng-399 is offline
post #213 of 575 Old 07-02-2018, 07:37 AM
JCJetta's Avatar
Quoted: 339 Post(s)
Liked: 672
Would it have been more favorable if the port width was narrower, and the length longer then? I realize that is not possible with this enclosure design, but I'm still wrapping my brain around the concept.
Jk7.2 likes this.
JCJetta is offline
post #214 of 575 Old 07-02-2018, 07:39 AM - Thread Starter
Jk7.2's Avatar
Liked: 2576
153.8 is the current designs first port resonance
eng-399 likes this.
Jk7.2 is online now
post #215 of 575 Old 07-02-2018, 08:06 AM
eng-399's Avatar
Liked: 4965
I tired everything with this box he needed the port port to fire from the front of the box and with the width being what it was it just didn’t look right on winisd. Side firing would of been great but then his mains would of blocked the port. Also when adjusting the port size making it taller it does help sometimes but not with this one. I like to see the and wish I remember were I read this before, but I like to keep the port length around 50 inches or less. When it starts to creep up to 60 inches long I could of swore I read somewhere there could be issues with compression in the port or something.
JCJetta and Jk7.2 like this.
eng-399 is offline
post #216 of 575 Old 07-02-2018, 08:15 AM - Thread Starter
Jk7.2's Avatar
Liked: 2576
Just a few more pics from the morning. This thing will be making noise by tomorrow for sure. It’s wired up, Tnuts installed, I made sure it’s sealed up from the inside, extra wood glue and some panel adhesive from a tube where needed, all I need to do today yet is screw on the top. I just want to give everything a couple hours before I do that.
Jk7.2 is online now
post #217 of 575 Old 07-02-2018, 05:38 PM
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
Obviously it's too late to change the cabinet design, and I don't want to beat a dead horse here, but has anyone experimented with doing dual ports? Like a port at the top of the cabinet and the bottom... like the whole width of the cabinet, but shorter ports obviously? Can ports still function that way?
Craig S King is offline
post #218 of 575 Old 07-02-2018, 05:39 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
I’m sure that’s possible. Harder to implement and build. So probably not worth it.
Jk7.2 is online now
post #219 of 575 Old 07-03-2018, 10:48 AM - Thread Starter
Jk7.2's Avatar
Liked: 2576
Today I got to hear the new box. I’m not immediately blown away, but that’s usually how it goes. The first time I fired up a titan I wasn’t immediately blown away. But anyway the issue I’m having now is port chuffing. It’s not super bad, but it’s an unmistakable sound. Not sure what to do. I know I could raise my high pass a bit but I don’t want to. The super deep sound of these hst’s is what I like most about them. I don’t want to loose that. I popped on the server room scene of pulse and cranked it up to reference and heard the chuffing. Not sure what I’m gonna do. Everything is a give and take. Is it worth having amazing mains and loose a bit of bass in these teens? Maybe. @VicTorious1 you heard it what would you do?
Options:
1 Build all four and see what it’s like. They’re all cut and ready to build.
2 scrap the four subs up front idea and just build two huge low tuned boxes that are better suited for the hst’s.
3 ???? What else is there to do?
LTD02 likes this.
Jk7.2 is online now
post #220 of 575 Old 07-03-2018, 11:54 AM
JCJetta's Avatar
Quoted: 339 Post(s)
Liked: 672
You 100% sure it's chuffing? Reason I ask is I have one of my PSIs that is not quite sealed as well as the other one, and when I run sine waves around 23Hz and below I hear a slight flatulence noise. As I get closer to the sub, I can feel the wisps of air around the bolt hole I failed to gasket properly. The other sub is dead silent, other than what it is supposed to be doing.
The difference is I don't really hear it during normal movie scenes. Hacksaw Ridge still sounds like WWII. It isn't until I get REW out and play that I notice the issue. So with that and the fact I'm not thrilled about pulling a driver out again, I've put of fixing it.
Jk7.2 likes this.
JCJetta is offline
post #221 of 575 Old 07-03-2018, 12:16 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
Yeah I’m sure. I put my hands all over the box and could not feel anything. I’m good at sealing up cabs. I install commercial glass for a living on high rise buildings and am very attentive to leaks of any kind. I torqued down the 1/4 20’s into their Tnuts and used the gasket as well. Mike is double checking the data soon. I wish I could post a video. It’s evident in a cell phone vid I took.
Jk7.2 is online now
post #222 of 575 Old 07-03-2018, 12:39 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
Ok I’m trying something new. Don’t laugh.
LTD02 and johnson636 like this.
Jk7.2 is online now
post #223 of 575 Old 07-03-2018, 12:58 PM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 672
Nerves of steel man....nerves of steel.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #224 of 575 Old 07-03-2018, 12:58 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
It’s rough at times.
Jk7.2 is online now
post #225 of 575 Old 07-03-2018, 01:48 PM
eng-399's Avatar
Liked: 4965
Box plan changed... the hst drivers are monsters down low now with a modified plan the port height is increased and the tune had to come up a tad. At least now there should be no chuffing with the air port velocity at 19.5 ms at 17hz. That’s were it peaks...
eng-399 is offline
post #226 of 575 Old 07-03-2018, 01:54 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
Thank you for all your time Mike! One scrapped box is a small price to pay for an amazing setup!
brian6751 likes this.
Jk7.2 is online now
post #227 of 575 Old 07-03-2018, 01:59 PM
eng-399's Avatar
Liked: 4965
Sorry about that box I really thought 23-to low 24 ms of air port velocity would be good but this was a good lesson I learned and the rest of the guys in here. The HTS drivers are monsters and move a ton of air, these seem to be different than the normal since the xmax on these are so high. If anyone see a problem with what the current air port velocity is please speak up now before Jarrod starts the build. The graph is above of it.
eng-399 is offline
post #228 of 575 Old 07-03-2018, 02:01 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
Maybe the guru @LTD02 can chime in. I don’t want to redo the design for air port velocity that is still audible.
Jk7.2 is online now
post #229 of 575 Old 07-03-2018, 02:54 PM
VicTorious1's Avatar
Quoted: 580 Post(s)
Liked: 668
Is the 19.5 m/s air velocity modeled at the max power rating for the HST?
VicTorious1 is offline
post #230 of 575 Old 07-03-2018, 02:54 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
Originally Posted by VicTorious1 View Post
Is the 19.5 m/s at the max power rating for the HST?
No. It’s at 2000 Watts I’m really trying to cram a lot into a small space I know. Not looking for ideal, but as is now the port noise is unbearable. Is 4 m/s lower really that much less audible is the question of the day.
Jk7.2 is online now
post #231 of 575 Old 07-03-2018, 02:59 PM
corradizo's Avatar
Quoted: 1524 Post(s)
Liked: 1580
What is the new port height? I'd do at least 3" tall. I went with 3.5" on my 21DS and could not measure any port compression. From what I've read (and partially* comprehended) the height is important because the air drags along the sides and accelerates through the middle. Going too narrow reduces the airs ability to accelerate through the middle. Ymmv.
LTD02 likes this.
corradizo is offline
post #232 of 575 Old 07-03-2018, 03:06 PM
eng-399's Avatar
Liked: 4965
3.5” doesn’t work because of the first port resonance. That was the issue the width of box’s port was wide and box size really needed to be bigger so there was compromises.
eng-399 is offline
post #233 of 575 Old 07-03-2018, 03:09 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
3” is the new height
Jk7.2 is online now
post #234 of 575 Old 07-03-2018, 03:27 PM
Quoted: 580 Post(s)
Liked: 668
When you model it, it should be modeled at the max power rating for the driver even if you're going to feed it less power. Port diameter (i.e., the height) can matter, but there are trade-offs. Try laying the subwoofer down on it's back or flipping it over so the port is not close to the floor. Do you still hear the port noise?
post #235 of 575 Old 07-03-2018, 03:30 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
Yes. I had the sub on its back pointed up to the ceiling and it still chuffed.
If I try and get it modeled at full power it would never work. I’m trying to find a happy medium. Vic is 19.5 so much better then 24?
Jk7.2 is online now
post #236 of 575 Old 07-03-2018, 04:09 PM
eng-399's Avatar
Liked: 4965
When I first modeled this the driver it was entered with 2,000 watts from what I remember. I always do that on every winisd build because of the air port velocity and cone excursion that need to be in check. I haven’t had any problems in the past with hearing chuffing at 23 ms like Jarrod is having. 2 inches high port isn’t enough for the hst having lots of xmax. The video loaded to I think is pulse? That’s super low and below port tune in the box but I could be wrong. Either way it chuffed with another movie going so these need to be changed ASAP.
Jk7.2 likes this.
eng-399 is offline
post #237 of 575 Old 07-03-2018, 04:52 PM
Quoted: 2378 Post(s)
Liked: 10183
Yes, 2" port height is likely a big part of the problem. Raising that to 3" or more and narrowing the width as necessary to keep cross-sectional area the same (which will keep port length and first port resonance the same) should help. As would rounding over the ends of the ports.
Really, the box is just undersized for that driver. That is why you are having trouble balancing port size to keep velocity down and port length to keep first port resonance up. As you increase box size, you can increase the port size and decrease the port length, bringing both constraints toward where you want them. Those drivers are incredible and can move a ton of air. They will be crippled in those boxes by these port constraints, which will kind of defeat the purpose of having them. They won't really be able to be pushed beyond what a cheaper driver could do in those boxes.
Your old boxes appeared to be quite a bit bigger. Do you still have them? What were they tuned?
LTD02, brian6751 and Jk7.2 like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #238 of 575 Old 07-03-2018, 04:57 PM
brian6751's Avatar
Quoted: 1686 Post(s)
Liked: 1676
This is a perfect build for these mdf corners I have. You have to measure them a different way. I have it in my PM’s with @LTD02
LTD02 likes this.
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #239 of 575 Old 07-03-2018, 07:07 PM
LTD02's Avatar
Quoted: 2919 Post(s)
Liked: 3624
you may want to run the router around the inside edge of the port. even some roundover can help take down port noise. tough to say if it will be be enough in your case, but might be worth a shot.
Jk7.2 likes this.
Listen. It's All Good.
LTD02 is offline
post #240 of 575 Old 07-03-2018, 07:09 PM - Thread Starter
Jk7.2's Avatar
Liked: 2576
I hear ya on everything your saying. The old boxes were not any bigger net volume but had 3” tall ports. Tune was higher on the old boxes too. I really pushed for 15hz tune which really upped the M/S of port velocity. There wasn’t any audible port chuffing in the old boxes. And no, I don’t have them anymore. The fix we have is to increase my port design to 3” tall and increase port length to within 4” of the box top. It will result in 19.5 m/s air velocity and 17.5 hz tune. This I will be happy with. My old boxes tuned in the 18’s were flat to around 12 hz in room. At nearly 125 dB. Just trying to split the difference and get respectable results. I wish I could increase box overall volume but I can’t!
Jk7.2 is online now
