Looking for sub circuit board help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-13-2018, 07:21 PM - Thread Starter
084runnerltd's Avatar
Quoted: 76 Post(s)
Liked: 43
I posted this in the “subwoofer” section and it was recommended that I post it over here....
I have a 12” powered sub from Monoprice that died while my SVS sub was on order, I have the new sub hooked up and decided to set up a 2 channel setup in our living room.
I figured I would try the Monoprice before throwing it in the garbage. I plugged it in and it turned on and played the appropriate amount of bass....I turned up the volume and it went into protection mode.
I should say that I assume it is protection mode, the green light on the back of the sub turns red and I get no volume. Unplug it and plug it back in, 95% of the time the light is red....but at times the sub will work as normal, until the volume is turned up too high, then cuts out.
I tore off the circuit board, thinking I might find a loose connection, nothing.
Looked for a fuse...couldn’t find anything.
Tested the speaker itself, it works fine.
So there is something jiggy with the board. I couldn’t find anything that looked burned on the board.
None of the capacitors appeared to be blown. I tested the diodes, that I could get to, and they all seemed to be working as normal.
Any ideas? Or is there a cheap board I can purchase to replace it?
It is a cheap sub, but for the money, I was very happy with it and would like to put it to use.
Lastly, I am not knowledgable on circuit boards (couldn’t find a schematic)....learned about diodes and capacitors while researching how to fix it...so please explain your answers as if I am a 5 yr old.
084runnerltd is offline
