DYI Help - Connections Speakon - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-22-2018, 06:21 PM - Thread Starter
JayDee78's Avatar
Quoted: 23 Post(s)
Hey guys,
New DYI'er here. I just picked up a Dayton Ultimax 15" sub a Behringer iNuke1000 DSP and I will be ordering a flat pack and the wiring components.
I'm completely new to XLR and Speakon. I have a Marrantz 6012 with dual RCA pre-out for LFE. Anyone want to point me to the right direction on what I need to convert the RCA pre to connect to the amp and the remainder of wiring needs. I will be bridging it into mono.
JayDee78 is offline
post #2 of 12 Old 04-22-2018, 06:53 PM
johnson636's Avatar
Quoted: 1239 Post(s)
Liked: 724
XLR Male to RCA Male Cable for amp input
You'd have to make or by your speakon cables. There are countless threads and postings detailing this info. Just do a forum search or google search. It appears you have a lot of reading to do.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #3 of 12 Old 04-23-2018, 04:51 AM
trilkb's Avatar
Quoted: 658 Post(s)
Liked: 336
Can also do 1/4" to RCA for amp input.
its confusing at first but it makes sense quickly.
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #4 of 12 Old 04-23-2018, 07:32 AM - Thread Starter
JayDee78's Avatar
Quoted: 23 Post(s)
Do I have to go to XLR? The amp input is speakon and I’m guessing it’s 2 pole.
Also, is the bridging internal or is it done with cables?
JayDee78 is offline
post #5 of 12 Old 04-23-2018, 09:36 AM
trilkb's Avatar
Quoted: 658 Post(s)
Liked: 336
" with combo XLR and 1/4" TRS inputs"
https://www.parts-express.com/parts-...apter--090-285
You can use that for the input with a sub/LFE/rca cable. Then you need to buy a 4 pole *speakon* cable and wire it up 1+ and 2+ to brige the amp. The 4 pole xlr has 1+ 1- 2+ 2-, you just connect to what the amp says to bridge.
https://www.parts-express.com/neutri...ector--092-190
Use that with some good quality speaker wire to go to your driver.
trilkb is offline
post #6 of 12 Old 04-23-2018, 12:15 PM
Wayne A. Pflughaupt's Avatar
Quoted: 435 Post(s)
Liked: 355
The inputs are not Speakon. The Berrie’s inputs will accept a 1/4" plug in the center of the XLR jacks. An RCA to 1/4" cable will probably be cheaper than RCA to XLR male cable.
Originally Posted by trilkb View Post
Then you need to buy a 4 pole XLR cable and wire it up 1+ and 2+ to brige the amp. The 4 pole xlr has 1+ 1- 2+ 2-, you just connect to what the amp says to bridge.
The amp’s output uses Speakon connectors, not XLR.
OP, if you buy an off-the-shelf Speakon, it will have to be wired 1+ and 2+ (most are wired 1+ and 1-). If you can’t find one like that, it’s easy to make you own with a pair of NL-4 connectors and speaker wire cable stock. Speakons work best with round pro-audio cable stock like this than the flat zip-cord speaker wire normally used for home audio.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is online now
post #7 of 12 Old 04-23-2018, 12:52 PM - Thread Starter
JayDee78's Avatar
Quoted: 23 Post(s)
Good stuff guys. I was not aware that the center could use a jack.
Correct me if I’m wrong but to bridge the Behringer I have to combine the channel A and B into one output that goes to a speakon connection to the speaker cabinet. I would wire the 2 voice coils to the speakon essentially in series. That would be an alternative to wiring the positive of one coil the the negative of the other.
I’m almost tempted to return the Behringer and go with a plate amp.
JayDee78 is offline
post #8 of 12 Old 04-23-2018, 01:08 PM - Thread Starter
JayDee78's Avatar
Quoted: 23 Post(s)
This what I’m thinking is needed.
https://www.parts-express.com/neutri...m_campaign=pla
That may not be exactly but a male 4 pole Speakon.
JayDee78 is offline
post #9 of 12 Old 04-23-2018, 01:17 PM
trilkb's Avatar
Quoted: 658 Post(s)
Liked: 336
No you just input to input A and then bridge output A with the 4 pole speakon to 1+ 2+ and it will bridge the amp. Or else its input/output B, I cant remember exactly how mine is setup but I bridge it with one output.
I think there's some youtube videos of how to do it.
trilkb is offline
post #10 of 12 Old 04-23-2018, 01:19 PM - Thread Starter
JayDee78's Avatar
Quoted: 23 Post(s)
Ok, verify and let me know. I’m still a few days out but I’d like to make a one shot order and start building.
It’s still just 2 wires from the output of the amp to the sub, correct and then series the two voice coils?
JayDee78 is offline
post #11 of 12 Old 04-23-2018, 02:27 PM
trilkb's Avatar
Quoted: 658 Post(s)
Liked: 336
A in a out.
trilkb is offline
post #12 of 12 Old 04-25-2018, 12:12 PM
Augerhandle's Avatar
Quoted: 1253 Post(s)
Liked: 1256
Yes, two wires, voice coils in series. Cheaper connectors with free shipping here:
https://www.markertek.com/product/nl...able-connector
https://www.markertek.com/product/nl...-chassis-mount
https://www.markertek.com/product/sp...-to-rca-female
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
