Which version of WinISD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-23-2018, 09:50 AM - Thread Starter
petethekiller's Avatar
Location: Blanchard OK (Moving to the Stockton CA area)
Quoted: 25 Post(s)
So I am making my first real attempt at designing an enclosure for a 4 driver, Dual Opposed subwoofer. Against all recommendation I bought 8 of the GRS 12SW-4 inch drivers at the low cost of 19.00 each pretty much as a learning experiment. Ive read they do well in IB form but I don't have that option. So I DL'd the latest version of WinISD and noticed it was a bit different from the older version....
Is one version better than another or is it just the user interface that has been cleaned up?
Any tips on using the software would be helpful...
petethekiller is offline
post #2 of 4 Old 04-23-2018, 03:37 PM
LTD02's Avatar
Quoted: 2950 Post(s)
Liked: 3678
the core should be the same. v0.7.0.900 doesn't allow direct input of port length but otherwise, i think it is the same (going from memory).
Listen. It's All Good.
LTD02 is offline
post #3 of 4 Old 04-23-2018, 03:47 PM
smcmillan2's Avatar
Quoted: 875 Post(s)
Liked: 782
I've been using 0.7.0.900 myself, but I do see a newer version on the linearteam.org website - 0.7.0.950. Time to play...
(Edited to correct new version number)
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #4 of 4 Old 04-25-2018, 12:33 PM
bebb's Avatar
Quoted: 229 Post(s)
Liked: 164
WinISD Beta version 0.44 allows the option of entering the box size and then it calculates "ideal" dimensions. For someone with ADD like me it makes determining the dimensions quicker.
bebb is offline
