WinISD - how to get max flat amplitude option? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By mtg90
  • 1 Post By 0100010
post #1 of 5 Old 04-24-2018, 08:43 AM - Thread Starter
0100010's Avatar
Quoted: 54 Post(s)
Liked: 50
Familiarizing myself with WinISD Pro 0.7.0.950; and when I create a new driver model and then create a new project, I am missing the closed enclosure drop down alignment option for 0.707 Max flat amplitude response, as seen in the image here.
If I use an existing .wdr file, that option is available.
Any ideas? Including the two WDR files as txt (if it helps).
File Type: txt Fi IB318 2 ohm.txt (844 Bytes, 5 views)
File Type: txt Fi IB318v2 4 ohm.txt (831 Bytes, 5 views)
Insert signature here.
LR : E65-C3 | HW-MS750 | SWA-W700
HT : ES 120" | JVC RS-520 | Oppo-203 | Denon X3400H 5.1.2 | ELAC A4.2 B6.2 C6.2 F6.2 & VTF-15MK2
0100010 is offline
post #2 of 5 Old 04-24-2018, 08:53 AM
mtg90's Avatar
Quoted: 766 Post(s)
Liked: 1580
Qts of the IB318v2 4ohm driver is higher then 0.707 so you can't achieve a max flat amplitude response with that driver even in an infinite baffle.
bebb likes this.
mtg90 is offline
post #3 of 5 Old 04-24-2018, 08:57 AM - Thread Starter
0100010's Avatar
Quoted: 54 Post(s)
Liked: 50
Well now, that just makes too much sense; no wonder I missed it.
0100010 is offline
post #4 of 5 Old 04-24-2018, 11:33 PM
LTD02's Avatar
Quoted: 2914 Post(s)
Liked: 3611
it can be done with EQ of course.
Listen. It's All Good.
LTD02 is offline
post #5 of 5 Old 04-25-2018, 07:55 AM - Thread Starter
0100010's Avatar
Quoted: 54 Post(s)
Liked: 50
Yup, was just more of an app behavior question though. I thought it was something wrong I had done creating the model for the driver, when the model was correct and the resultant behavior in the app was correct - just my expectation was wrong.
LTD02 likes this.
0100010 is offline
