Another Modified VBSS build - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #1 of 40 Old 05-16-2018, 06:36 AM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
First off let me say, I did not copy smcmillian2's build. This is purely an coincidence.
So this is last weekends project. Was hoping to build both Saturday and Sunday and finish them during the week...that didn't work out. Started off as the PA360 VBSS nearfield to go beside the MLP, but turned out too big for my taste. So they are being moved to MBM duty and corner loaded. Only one I finished. Hopefully I can get started on the second one in a couple days. Hats off to Chad Smith for the advise on the design. This is my first post on this forum, not sure how to caption the pics. The series of pics of the top are the different colors used to paint it. I used DuPont automotive paint fof the top, MinWax for the cabinet.
ID:	2403374   Click image for larger version
ID:	2403376   Click image for larger version
ID:	2403378   Click image for larger version
ID:	2403380   Click image for larger version
ID:	2403384   Click image for larger version
ID:	2403386   Click image for larger version
ID:	2403388   Click image for larger version
ID:	2403390   Click image for larger version
ID:	2403394   Click image for larger version
ID:	2403396   Click image for larger version
ID:	2403398   Click image for larger version
ID:	2403400   Click image for larger version
ID:	2403404   Click image for larger version
ID:	2403406   Click image for larger version
ID:	2403408   Click image for larger version
ID:	2403410   Click image for larger version
tarponater is offline
post #2 of 40 Old 05-16-2018, 07:26 AM
MW6006's Avatar
Liked: 5
Turned out really good, nice job. The paint work on the top is impressive. I wish I had the patience and skill to do that.
-Receiver- Marantz 7009 running 5.2.4
-LCR- PSB Century 500i, PSB Century 100ci
-SL/SR- DIY Zaph B3S
-Atmos- Micca M8c
-Subs- VBSS w/inuke, Custom 12" HSU sub
MW6006 is offline
post #3 of 40 Old 05-16-2018, 07:47 AM
jcmccorm's Avatar
Quoted: 615 Post(s)
Liked: 466
Man that looks nice. Really nice work. Can you elaborate on the wood/finish/trim work that you did? Thanks.
jcmccorm is offline
post #4 of 40 Old 05-16-2018, 10:36 AM
Jungle Cruiser's Avatar
Quoted: 24 Post(s)
Liked: 36
You intended to say PA380, correct?
Jungle Cruiser is offline
post #5 of 40 Old 05-16-2018, 11:06 AM
asarose247's Avatar
Quoted: 1255 Post(s)
Liked: 1101
inspired and inspiring effort and results . .
.02 looks like birch in the stained portions
and the top is formica?
but IF? you did the "marbleing' /granitizing" "painting" on the the top, _
WOW! I've seen that done and it can be a true work of art . .
I'd love to see something like that done in a basic ruby red with bits of gold, aquamarine, deep green , some black, gold and silver threads . .
how does it play?
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #6 of 40 Old 05-16-2018, 12:43 PM
Brazle's Avatar
Quoted: 159 Post(s)
Liked: 196
The whole thing looks great, but Especially the top. Nice!
So it's ported right? What is it tuned to? Did you need to do any DSP?
HT setup: Vizio 50" 4K | Xbox & PS3 | Pioneer Elite VSX-94TX | Bose 701 towers (V1) | JBL S Center | Def Tech Reference SuperCube & DIY Nearfield cabinet ported UM18 dual ported PA380 ULF+MBM
Brazle is offline
post #7 of 40 Old 05-16-2018, 02:39 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
It doesnt actually take that long. About 4 hours from start to finish. Just a plastic bag.
Receiver: Onkyo TX-RZ730 (7.2.4) Onkyo M-5010 (Atmos)
Front Wall: DIYSG Fusion10 L&R, Hybrid DIYSG Fusion10 center
Atmos/Surround: 4 Polk TSX 150C(DIY) 4 Yamaha NS-333
Subwoofers: Three HS-24MKIII 11.5 ft^3 sealed NU12000, XLS2502, MINIDSP
post #8 of 40 Old 05-16-2018, 02:52 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
I used 3/4" Sande ply from Home Depot. I basically just built a regular enclosure, then ripped some plywood and trimmed the edges with cherry veneer to make the trim pieces on the edges. The satin is MinWax, dont remember the color. The finish on the cabinet is MinWax satin Polly urethane that I sprayed on at work. The top is just MDF painted to loom like granite. I used DuPont automotive paint, Base Coat / Clear Coat.
post #9 of 40 Old 05-16-2018, 02:53 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
Yes
post #10 of 40 Old 05-16-2018, 02:57 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
how does it play?
The plywood is Sande ply from Home Depot. Not sure exactly what that means. Was looking for a tight grain, not the results I wanted but oh well. The top is MDF that I painted with automotive paint. Just a plastic bag and a bunch of different colors. Glued the top on last night, havent heard it yet. going to watch Ironman or Deadpool tonight.
post #11 of 40 Old 05-16-2018, 02:59 PM
jcmccorm's Avatar
Quoted: 615 Post(s)
Liked: 466
Yeah, they have the Sande plywood at my HD. I'm not sure what it is either but I've used it on a couple of shelving projects. At least it pretty's-up real well
jcmccorm is offline
post #12 of 40 Old 05-16-2018, 03:00 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
Thanks. The port is fired out the side on the bottom. It is tuned to about 26Hz. I havent listened to it yet. Once I finish the other 3, I will setup the DSP on the iNuke.
post #13 of 40 Old 05-16-2018, 03:03 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
The STAIN is MinWax
post #14 of 40 Old 05-16-2018, 03:06 PM
brian6751's Avatar
Quoted: 1707 Post(s)
Liked: 1704
looks great but you should remove the material covering the braces. Its blocking the air from the driver to the rest of the box and the port.
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is offline
post #15 of 40 Old 05-16-2018, 03:09 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
I think the next three I'll use Birch. I used Sande ply from Lowes and the grain was much tighter. This stuff looks more like Oak to me.
post #16 of 40 Old 05-16-2018, 03:13 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
I posted that question last night in my local group. I was wold air will pass through that material easily enough not to worry about it. The next one I will run some tests on without the top to see how it acts. If is flaps around violently, ill just wrap each brace.
post #17 of 40 Old 05-16-2018, 07:23 PM
smcmillan2's Avatar
Quoted: 943 Post(s)
Liked: 809
Great build @tarponater ! Love how you made it a piece to fit within your decor.
What method did you use for the top, if you don't mind sharing? That turned out exquisitely.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #18 of 40 Old 05-16-2018, 07:24 PM
smcmillan2's Avatar
Quoted: 943 Post(s)
Liked: 809
Not sure where the double post came from...
post #19 of 40 Old 05-16-2018, 08:25 PM
Craig S King's Avatar
Quoted: 427 Post(s)
Liked: 535
I'm not seeing how the port is actually venting?
Craig S King is offline
post #20 of 40 Old 05-17-2018, 08:47 AM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
Start by painting a solid color. Then start tinting that color in many directions, darker, lighter, more blue, more green, so on. All you do is apply each color with a crumpled up plastic shopping bag, just keep dabbing on color till you get what you like. Clear, sand smooth and clear again.
post #21 of 40 Old 05-17-2018, 08:48 AM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
The port is on the bottom left side. I didnt post any pics of it because its black and doesnt show up very good.
post #22 of 40 Old 05-17-2018, 08:52 AM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
That small piece on the bottom left is the port top. After I finished it, I cut the opening out with a router and a flush cutting bit, then rounded the opening. You can see how the right end of that panel is rounded.
chadsmith013 likes this.
post #23 of 40 Old 05-17-2018, 11:26 AM
smcmillan2's Avatar
Quoted: 943 Post(s)
Liked: 809
Good info, thanks. May have to try that on an upcoming project (although I typically loathe painting... )
tarponater likes this.
post #24 of 40 Old 05-17-2018, 12:49 PM
chadsmith013's Avatar
Quoted: 2329 Post(s)
Liked: 2370
great job Charles...cant wait to stop by and check those out...really top notch work..
@biliam1982 @Mattcc22 @filtor1 @Soundwave rider
filtor1 likes this.
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 2 DIYSG Volt 6's
Subwoofers: Dual LaVoce SAN214.50 21's in Cyclops enclosures w/Inuke 6000 DSP Channel A
Nearfield: 4 B-52 SP-1804 18s w/Inuke 6000DSP Channel B
chadsmith013 is online now
post #25 of 40 Old 05-17-2018, 01:04 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
Thanks Chad. You need to update your system information.
post #26 of 40 Old 05-17-2018, 01:09 PM
Liked: 2370
indeed I do...
post #27 of 40 Old 05-20-2018, 08:57 PM
bebb's Avatar
Quoted: 229 Post(s)
Liked: 164
FWIW looks excellent. Nice job.
bebb is offline
post #28 of 40 Old 05-21-2018, 05:22 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
This is the second of the two. I had to let the top dry a couple days before I could glue it on. Tomorrow I should be able to listen to them.
ID:	2405646   Click image for larger version
ID:	2405648   Click image for larger version
ID:	2405650   Click image for larger version
bubbrik and OJ Bartley like this.
post #29 of 40 Old 05-21-2018, 05:31 PM
smcmillan2's Avatar
Quoted: 943 Post(s)
Liked: 809
Excellent job, I love the builds that are made to look like furniture/blend in with the existing decor of a non-dedicated theater space. (the first pic looks eerily familiar... )
You haven't heard them yet?????
post #30 of 40 Old 05-21-2018, 08:18 PM - Thread Starter
tarponater's Avatar
Quoted: 144 Post(s)
Liked: 588
That is crazy, I swear I didn't copy yours, we posted our builds the same day. I listened to the first one over the weekend. Should be able to fire up the second tomorrow.
