Custom Volt-6 Center - Help w/ Resonance Issue - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By mtg90
  • 4 Post By moosifee
post #1 of 12 Old 05-20-2018, 10:35 AM - Thread Starter
Quoted: 2374 Post(s)
Liked: 10152
Design goals:
1. Less than 7" tall at the front (but able to accomodate a Volt-6), and less than 6" tall by the time it gets 5" deep (to fit under the TV)
2. Tuned at or below 70Hz to be able to crossover at 80Hz
3. Able to use a pair of the PE 1.5" dia. 4" long ports recommended by mtg to achieve that tune
Outside dimensions:
Height - 7" at front, 5.25" at back (tapered @ 13 degrees)
Width - 23.75"
Depth - 6.75"
The front is 3/4" birch plywood, the rest 1/2"
Inside volume comes out to 0.38 cf, tuning 70Hz
Edit: The resonance turned out to be a room issue and the speaker itself is perfect!
Spoiler!
CAD Drawings:
Dry Fit
Painted & Assembled
Crossover
Inside
Spectrogram (80Hz crossover with subs)
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #2 of 12 Old 05-21-2018, 10:39 AM - Thread Starter
Liked: 10152
Is it possible that a room mode could manifest as a resonance like this? One thing I did as a test was stuff the ports with thick socks the resonance was still there.
post #3 of 12 Old 05-21-2018, 11:59 AM
mtg90's Avatar
Quoted: 766 Post(s)
Liked: 1580
Move the speaker to a different location in the room like out in the middle of the floor and test it again. If it's the room then it should change with the speaker in a different position.
biga6761 likes this.
mtg90 is offline
post #4 of 12 Old 05-21-2018, 04:52 PM - Thread Starter
Liked: 10152
It was easy enough for me to bring it outside to test. I'm happy to report that the speaker itself shows no discernible resonances, and unhappy to report that it is thus a room issue which may be difficult or impossible for me to fix. I can't really move it or the MLP much at all.
post #5 of 12 Old 05-21-2018, 05:20 PM
smcmillan2's Avatar
Quoted: 813 Post(s)
Liked: 710
I am sorry the design isn't working in your room, but I do appreciate you posting the detailed specs of your build. I have been looking to get the HTM-10s for L/R, but require a smaller horizontal center and just thought of the Volt's coaxial drivers. This thread gives me food for thought, many thanks.
ETA: And now that I'm looking at the DIYSG site I see that the Volt-6 is out of stock. Oh well, back to the drawing board...
smcmillan2 is online now
post #6 of 12 Old 05-21-2018, 05:29 PM
moosifee's Avatar
Quoted: 93 Post(s)
Liked: 105
I wonder if it might be exciting the furniture it's sitting on? Is it on some pads or feet or anything to decouple it?
moosifee is offline
post #7 of 12 Old 05-21-2018, 05:43 PM - Thread Starter
Liked: 10152
Oh, don't get me wrong, it's working, and working very well! It is a slight nitpick, but overall, the speaker is fantastic.
Good thought. I wanted to angle the box up slightly, so I actually only put rubber feet on the front. I thought of this and actually lifted the back up while playing a 94 Hz test tone and I'm pretty sure it didn't change anything, but I'll double-check.
post #8 of 12 Old 05-21-2018, 06:10 PM
smcmillan2's Avatar
Quoted: 813 Post(s)
Liked: 710
That's great to hear. I hope you can find and remedy the cause of the ringing, and I'll have to keep my eyes open for the Volt-6s coming back.
Question for you (or anyone), if you don't mind:
I was thinking of getting 2 Volt-6 kits to build a center with both coaxial drivers (or just 1 kit and pick up the 2nd CX-06 and DNA-150 as separates, wired series then parallel) for a wider center speaker with greater dispersion as my room is a living room. As I am no speaker/crossover designer I wonder if you think this would work? I haven't run it through WinISD yet to get exact dimensions or porting but have no issues doing so, just wondering if my idea is completely off base or not.
Really do appreciate your input!
post #9 of 12 Old 05-21-2018, 06:36 PM - Thread Starter
Liked: 10152
The reason you never see this done is it will suffer from severe beaming as the two tweeters cancel each other out at certain frequencies.
post #10 of 12 Old 05-21-2018, 07:19 PM
VisionxOrb's Avatar
Quoted: 337 Post(s)
Liked: 222
The comb filtering would actually give you less dispersion.
2000 watts of power and climbing
-Fred
VisionxOrb is offline
post #11 of 12 Old 05-21-2018, 08:41 PM
moosifee's Avatar
Quoted: 93 Post(s)
Liked: 105
One wave source:
Two wave sources:
moosifee is offline
post #12 of 12 Old 05-22-2018, 03:18 PM
smcmillan2's Avatar
Quoted: 813 Post(s)
Liked: 710
Exactly the type of input I needed guys, thanks. Wondered why I hadn't seen it done that way.
And special thanks to @moosifee for the visual, exactly what my little brain needed to wrap around
Enough of my hijacking aron7awol's thread, as you were...
