Fi Audio 18" HT1 Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 223Likes
post #91 of 200 Old 05-24-2018, 05:37 PM - Thread Starter
Buddylee123's Avatar
Quoted: 904 Post(s)
Liked: 622
Originally Posted by CrusherW9 View Post
I'm planning on building 2 enclosures this weekend. The cutout for the driver needs to be 16.75" in diameter and the overall diameter of the driver is 18.5". So if I want to recess the driver, does that mean the recess needs to go an extra inch out so there's 1/8" extra or should I shoot for 1/4" extra? And how deep should it be?
EDIT: Sorry to hijack your thread but I figured this would be the best spot because you actually have one of the drivers and could be relevant to you as well.
Are you building enclosures for the HT1 subs that we are talking about here? Where did you get the measurements from?
Buddylee123 is online now
post #92 of 200 Old 05-24-2018, 05:42 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
This forum is running like a potato today
post #93 of 200 Old 05-24-2018, 06:10 PM
CrusherW9's Avatar
Quoted: 213 Post(s)
Liked: 127
Yep. Since the HT1 is based off the SSD and the HT2/3 are SP4, I looked at the dimensions on the Fi website and they're the same. So I figure I should be good to go with the 16.75" it says on their site.
CrusherW9 is offline
post #94 of 200 Old 05-24-2018, 06:28 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
That makes sense, but I won’t know for sure until this weekend. I am starting my boxes but I will do a quick test cut on some scrap wood to make sure 16.75 works. I am not going to inset mine but I did put a tape measure across the top and it was right at 18.5 inches wide
post #95 of 200 Old 05-25-2018, 12:17 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
And so it begins.......tomorrow morning
4fit?, filtor1, eng-399 and 3 others like this.
post #96 of 200 Old 05-26-2018, 12:16 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Got everything cut up. It's been a while so I hope it's all correct. I used 4 sheets of MDF instead of 3. Doing this allowed me to make about half of the cuts for both boxes at the same time by stacking the sheets on top of each other when using my skill saw. Did all the skill saw cuts first of course in order to get them to a manageable size for my small table saw. If you see any mistakes let me know.
JCJetta, Pradeep2 and bubbrik like this.
post #97 of 200 Old 05-29-2018, 01:13 AM
chrapladm's Avatar
Quoted: 1113 Post(s)
Liked: 449
Isnt this thing built yet??!!!
Looks good so far.
chrapladm is offline
post #98 of 200 Old 05-29-2018, 06:45 AM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Looks good so far.
Lol it's definitely taking longer than I thought it would. Should have them running this weekend and hopefully will get some videos up too.
post #99 of 200 Old 05-30-2018, 02:03 AM
eng-399's Avatar
Quoted: 2430 Post(s)
Liked: 5021
One trick for guys reading this thread when I build my boxes I make the sides 1/4 inch bigger than what they need to be so this way once you lay your top piece of mdf on top you can flush trim bit what ever is left over. The reason why 1/4 is because sometimes the front and back cuts are not exactly spot on and glue might add 1/32 and throw some stuff off every once in a while. It’s happened to me so having the sides be a tad bigger helps out.
eng-399 is offline
post #100 of 200 Old 05-30-2018, 06:47 AM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
This is great advice and I should have done this on my build. Luckily I did a dry test fit of the front baffle and it is a little too high which raised the top up. I was able too fix it by trimming a little off with my skill saw but that was not easy to do. I just picked up this jig to make the cut on the other baffle a little easier. Kreg KMA2685 Circular Saw Guide https://www.amazon.com/dp/B073PFYN4T..._lSQdBbTTCBM00
post #101 of 200 Old 06-03-2018, 03:16 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Why didn’t someone tell me that these things weigh as much as a refrigerator when they are completed . I made a few small mistakes but nothing 60 grit sandpaper and a little time couldn’t fix. I picked up some Forearm Forklifts from Home Depot but will have to wait until next Friday so my friend can help move them.
johnson636, 4fit?, notnyt and 9 others like this.
post #102 of 200 Old 06-03-2018, 03:24 PM
johnson636's Avatar
Quoted: 1235 Post(s)
Liked: 716
^^^^Niiiiiiice
Buddylee123 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #103 of 200 Old 06-03-2018, 08:35 PM
eng-399's Avatar
Liked: 5021
They look great! Looking forward to hearing how they sound!
eng-399 is offline
post #104 of 200 Old 06-04-2018, 12:15 AM
chrapladm's Avatar
Liked: 449
What was the tune of these cabinets?
I dont remember if you said. I saw 17hz 10cuft somewhere but dont know if you built that or another design.
post #105 of 200 Old 06-04-2018, 06:46 AM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Should be 10cuft and 17hz as far as I know. I just build the minimarty cube that is on the first page of the FAQ thread. I will have to use the high pass filter of my Crown and it only goes down to 30hz, so I'm sure that will affect things until I get the miniDSP.
chrapladm likes this.
post #106 of 200 Old 06-06-2018, 12:16 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Thanks to @tential I have everything I need to complete this build. Saturday is going to be fun
eng-399, biga6761 and unretarded like this.
post #107 of 200 Old 06-06-2018, 12:36 PM
dtsdig's Avatar
Quoted: 1125 Post(s)
Liked: 1387
Is it Saturday yet??? Those are some sharp looking subs and that's what I am planning on purchasing for my brother's build this summer over the UM.
dtsdig is online now
post #108 of 200 Old 06-06-2018, 12:42 PM
JCJetta's Avatar
Quoted: 343 Post(s)
Liked: 688
Deer Creek Audio is a good guy; got my MiniDSP from him as well. I wonder if he is on AVS?
I too will be hopefully doing some tuning with the MiniDSP and REW this Saturday. Good luck and enjoy the process. Don't rush things (like me) and screw something up (like me).
JCJetta is offline
post #109 of 200 Old 06-06-2018, 12:58 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
You have me worried. What happened?
post #110 of 200 Old 06-06-2018, 01:07 PM
EndersShadow's Avatar
Quoted: 1254 Post(s)
Liked: 1525
Super quick short version, upload the plug in to the MiniDSP using your computer before connecting to amp or AVR.
JCJetta and Buddylee123 like this.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #111 of 200 Old 06-06-2018, 01:13 PM
JCJetta's Avatar
Quoted: 343 Post(s)
Liked: 688
Don't be worried!
Hahaha, well I talked about the issues I had mounting my subs on my thread... almost lost a finger! Gravity, close tolerances, heavy weight, and a lack of much to hold on to. What hardware are you using to mount your subs?
Then REW & MiniDSP is a learning process, but well worth it. Still scratching the surface with them myself. Absolutely amazing what these tools are capable of together.
biga6761 likes this.
JCJetta is offline
post #112 of 200 Old 06-06-2018, 01:46 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Thank you, I did not know that.
Don't be worried!
That does sound bad. I will just be using some wood screws, one box has wood blocks for reinforcement and the other does not. I'm not doing a recessed mount so I hope the 1.5 inches of MDF will work on the one without blocks.
post #113 of 200 Old 06-06-2018, 01:52 PM
JCJetta's Avatar
Quoted: 343 Post(s)
Liked: 688
And do the old zip-tie trick with a couple of the bolt holes when you are ready to mount. However, make sure you know the head of the zip tie isn't left on the underside of the basket after mounting, thus making a leak and sounding particularly flatulent at the 30Hz and below range. Another one of my lessons learned. But it was an easy fix.
JCJetta is offline
post #114 of 200 Old 06-06-2018, 05:11 PM
corradizo's Avatar
Quoted: 1537 Post(s)
Liked: 1599
On the MDF only just be careful to not over spin the screws. Go really slow with the drill and use a low torque setting. Pan head screws recommended. I used the kreg pan head screws because I had them on hand.
corradizo is offline
post #115 of 200 Old 06-07-2018, 11:22 AM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Got them up and running. They sound great to me but I think my wife thanks I’m crazy, she said it was rattling things in the kitchen. It did create one new problem for me, my screen. I was going to buy a new one soon but these things are so big that I now have to so things will work together space wise.
post #116 of 200 Old 06-07-2018, 12:55 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Also got an update on availability
johnson636, CrusherW9 and Pradeep2 like this.
post #117 of 200 Old 06-07-2018, 01:45 PM
4fit?'s Avatar
Quoted: 77 Post(s)
Liked: 48
Pics aren't showing for me.
edit: they do show when using my PC, just not on my phone.
Sent from my SM-G935V using Tapatalk
4fit? is offline
post #118 of 200 Old 06-07-2018, 02:10 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
That's weird, I hope it works for other people. I just used Taptalk to upload.
post #119 of 200 Old 06-09-2018, 08:19 AM
Quoted: 93 Post(s)
Works fine for me using Tapatalk on my phone
Sent from my Moto Z (2) using Tapatalk
Ortizer is offline
post #120 of 200 Old 06-14-2018, 02:44 PM - Thread Starter
Quoted: 904 Post(s)
Liked: 622
Should have the miniDSP hooked up tomorrow along with some REW results.
