PA460-8 18" NearField Sub Build From Newbie - AVS Forum | Home Theater Discussions And Reviews
 79Likes
post #1 of 108 Old 05-27-2018, 11:05 AM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
This is my first build thread. I'll be building a nearfield sub using PA 460 driver. A very very special thank to John aka @LTD02 who designed it for me and also provided tons of guide/advice. I'm going to put it all together. I know there are many threads showing how to build subs but may be not too many from those who are building the sub very first time. I thought a lot before I started this journey and was very sceptical about it. Didn't know if I'd be able to do it specially knowing that I had no prior wood work experience. So in this thread I'll try to put the information together for those who are willing to building their first sub.
Those who are reading this and planning to build the first time, go for it . Its a lot of fun.
So why build my own sub. This one is not exactly my very first DIY. I did 2 Mini Marty before this but in that case I purchased that flat packs and only had to glue them together. The only tools I needed for that was glue and clamps. When I built the Mini Marty, I was very happy to see that I put a sub together myself . I had to spent a lot of time later on to make it work perfectly but all that process made me learn a lot. I also got to know many other avs memebers here. @notnyt , @eng-399 among a few who helped me work out some issues I had. There are so many avs members with lots of in depth knowledge and ready to share with us. Building sub and getting to know all these amazing members is priceless. Plus, Its hard to explain the feelings but its just amazing when you put the efforts to build your own sub (or speaker) and hear your sub producing this amazing bass. I love my Mini Marty subs. They give me goose bumps. It does all I expected and more. But I wanted more midbass. Don't get me wrong, these subs produce super punchy bass and hits you hard in the chest but I kept on reading that nothing can come closo to what a NF sub can do. So, why not build one from scratch for NF sub right and here we are. I don't know if its going to be a successful build but I know for sure it will be a lot of fun. I also don't know if I'm going to end up using this sub as NF in my HT since I'm VERY satisfied with my mini Marty but I'm very curious to see what it can do.
After I decided that I wanted, I emailed LTD02 and he was kind enough to respond and then many more emails to follow. Finally, we decided that we'll go with PA460 dirver and desing a NF sub that fits the space I have in my room. Generally, subs are rectangular shape but not this one. You'll see the pics later that shows that its not all rectangular. Since it will be used NF and I have 55" of space b/w MLP and back door, I asked LTD02 to design the box to maximize the space usage. This sub narrows down as its going from bottom to top so that the bottom can be placed very to the bottom of seat and top is angulated 15 degrees so that the seat can easily be reclined. Here are some pics that LTD02 provided.
Driver
I purchased the driver, screws and port from part express
Driver: https://www.parts-express.com/dayton...oofer--295-036
Screws for Driver: https://www.parts-express.com/parts-...1nk00s3dy0005c
2 Ports: https://www.parts-express.com/precis...e-kit--268-352
As compared to UXL 18 driver I have in Mini Marty, this one is super light. I even placed it on top of the stand I use for my mic and had no issue . This assures that it will be very easy to move the box around. Awesome.
Update: Here is the final product. If you would like to see more pics of final product, here is the link
https://www.avsforum.com/forum/155-di...l#post56322404
Name:	Front to side.png
ID:	2408248   Click image for larger version
ID:	2408250   Click image for larger version
ID:	2408252   Click image for larger version
ID:	2408266   Click image for larger version
Name:	Tools from side angle.jpg
Name:	Stand and foam to cut on.jpg
ID:	2408270   Click image for larger version
ID:	2408272   Click image for larger version
Name:	Angle of Baffle wall.jpg
ID:	2408274   Click image for larger version
ID:	2408276   Click image for larger version
ID:	2408300   Click image for larger version
Name:	Driver from top.jpg
ID:	2408302   Click image for larger version
Name:	Driver from side.jpg
ID:	2408304   Click image for larger version
Name:	Driver from side 2.jpg
ID:	2408306   Click image for larger version
Name:	Front view complete.jpg
LTD02, 1st Cav, notnyt and 4 others like this.
harrisu is offline
post #2 of 108 Old 05-27-2018, 12:35 PM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Tools
As a starter, I was very concerned about making sure to cut the pieces straight. I started a thread to get some advice. Here is the thread https://www.avsforum.com/forum/155-di...-purcahse.html. Following are the tools I ended up getting
Circular Saw: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Circular Saw Guide: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Circular Saw Blade: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I could also get table saw but it seemed like an over-kill. I did have to spend some time with getting the saw to work well with guide (learning curve) but once I got the hang of it, together they made the cut easy and precise.
The part that was most concerning for me was cutting the circles out in baffle wall. Most here have routers and it makes the job much easier. Since I already have Jigsaw, I decided to use that instead. To cut perfect circles, I purchased the Jigsaw guide for like $15. I had to spend some time to get the hang of it but with it, I was successfully able to cut the circles. Besides these, you'd need a marker (or pencil), a scaler, tap measurement, stands and foam to make table to cut on. Here is the pic of all the tools I used
harrisu is offline
post #3 of 108 Old 05-27-2018, 12:37 PM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Instructions given by LTD02 and plan to follow
front face of baffle 32.61" x 28.5" (15 degree angle on across the top and bottom)
total height is slightly higher with the 15 degree angle
see image for driver and port location
top 11.56" x 30.0"
bottom 20.0" x 30.0"
2 sides [trapezoidal] 20.0" (at the bottom) x 31.5" (height) x 11.56" (at the top)
back 28.5" x 31.5"
Here is the Baffle wall
more instructions from LTD02 regaring Front wall
If you look carefully, you can see the angled portion of the baffle on top. Since the baffle slopes back, the top rear of the panel is higher than the top front edge.
32.61" is the height of the front surface. The little nib that sticks up in the back will make the total height a little higher than that.
To cut accurately:
1. make a horizontal pass at 15 degrees cutting from left to right so the angle is going **under** the panel.
2. measure 32.61" and draw a line
3. make a horizontal pass at 15 degrees cutting from left to right again
Cutting the pieces
I wrote down the plan on a piece of paper to follow.
Cutting the Back,Bottom,Top and Front were straight. Front has a 15 degrees cut on top as well. Wasn't hard to get. Circular saw allows to angle it. All I had to do was to angle it to 15 degrees and cut it. One thing to keep in mind here though is to to first cut this 15 degrees angle and then cut all other sides. Its much easier this way.
Sides were a bit harder and took a few tries before I got them right.
Next up: cutting the circles in baffle wall. This was was the hardest for me. I don't have the router so I had to make sure that do it properly using Jigsaw. I used the guide that I purchased for Jigsaw but when I tried it, it didn't work very well at first. To make sure I don't screw up the Front baffle, I decided to try the guide on a sample. Guide assured to move jigsaw in circular shape but I was having trouble using it properly. It was getting out of track slowly. I purchased a few blades from home depot to use with jigsaw and guess what, I broke 2 of them . The reason was that I was forcing jigsaw to stay straight and I should have been forcing it to constantly stay in rotation. This forced the jigsaw to slowly get off the track and eventually the blade tilted enough and broke. Finally, I decided to put the guide away and try out purely using Jigsaw. I drew the circle (which was another challenge) and then slowly followed the line. While I was doing it, I realized that I had to constantly and very slowly rotate Jigsaw to follow the circle. Hmmm... may be I should have done that with the guide as well. After successfully cutting the circle, I decided to give another try to the guide and this time I decided to first draw the circle and the use the guide. Then I following the circle with guide on and there it is. Much better.
To draw the circle, I used a piece of wood. Pinned it in the center and made sure its length is equal to the diameter of circle and drew it.
Next challenge was to get the Jigsaw blade to the circle I drew. For that, I drilled a hole near the circle big enough to get the blade in and slowly moved it towards the circle and then angled it to follow the drawing.
After that, slowly follow the drawing. I used marker to draw since it makes it much easier to see and follow. I kept one hand on the back of jigsaw to constantly keep it in rotational angle.
Here is after cutting the driver space
Now comes the ports. I followed the same instructions. Measure, mark and then cut.
and finally here is the complete baffle wall
Next up: Glue the pieces and work on bracing
Name:	Front Baffle.png
ID:	2408308   Click image for larger version
Name:	Side walls.jpg
ID:	2408310   Click image for larger version
Name:	how to cut holes for ports.jpg
ID:	2408312   Click image for larger version
Name:	Aligning jigsaw  to cut port circle.jpg
ID:	2408314   Click image for larger version
Name:	After perfect alignment of Jigsaw to cut the port circle.jpg
Name:	After cutting the driver and ports.jpg
ID:	2408318   Click image for larger version
Name:	Baffle wall circle side angle.jpg
ID:	2408320   Click image for larger version
Name:	baffle wall circle after cut.jpg
ID:	2408322   Click image for larger version
Name:	Measurements for  ports.jpg
ID:	2408324   Click image for larger version
Name:	Circle draw for port.jpg
LTD02, tiger8mush, BCRSS and 1 others like this.
harrisu is offline
post #4 of 108 Old 05-27-2018, 12:39 PM
notnyt's Avatar
Quoted: 3724 Post(s)
Liked: 3690
Looking good. Don't rely on those t-squares to be straight, though. Always measure your offset cuts from multiple places and connect them with a line.
LTD02 and bebb like this.
notnyt is offline
post #5 of 108 Old 05-27-2018, 12:47 PM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
I think I got lucky. I marked and measure and everything seemed spot on
harrisu is offline
post #6 of 108 Old 05-27-2018, 04:40 PM
LTD02's Avatar
Quoted: 2909 Post(s)
Liked: 3590
great post(s) and great job on the circle cutouts. i hope that you double checked all the sizes first!
many builds are by really advanced guys, so its nice to a see one from someone starting from scratch--helps to inspire other guys in the same boat.
Listen. It's All Good.
LTD02 is offline
post #7 of 108 Old 05-27-2018, 06:42 PM
Samps's Avatar
Quoted: 1219 Post(s)
Liked: 901
I have three T-squares and they're all crooked. Worse yet, I have 10 rulers that all vary a little bit. Key is to use the same one for everything. At least it will all be consistently off.
I cut all my driver holes freehand with the jigsaw. And I have a Jasper jig. The router just takes too damn long and makes a pile of dust. Following a line with the jigsaw is not very hard. And it's not like the hole needs to be perfect. My router is for edge work only now.
LTD02 likes this.
Samps is offline
post #8 of 108 Old 05-27-2018, 07:40 PM
jcmccorm's Avatar
Quoted: 587 Post(s)
Liked: 435
Echo the great job on the holes. How do you guys do it? My jigsaw holes look like a three-year-old's coloring book.
tiger8mush and bebb like this.
jcmccorm is offline
post #9 of 108 Old 05-28-2018, 06:27 AM
VegaMan's Avatar
Quoted: 102 Post(s)
Liked: 78
cutting out driver holes in mdf can be tough, if you use an aggressive blade it can get away from you in a hurry. I have had great success using metal blades for more control. Also, cheap jigsaws jump around and rattle a ton, one of those things I suggest spending a little extra on. Don't over extend, move the piece not yourself, and a nice steady pace should net decent results.
OP, great photos and progress, look forward to your results.
bebb likes this.
VegaMan is offline
post #10 of 108 Old 05-28-2018, 06:33 AM
jcmccorm's Avatar
Quoted: 587 Post(s)
Liked: 435
Thank you! I've got a decent jigsaw (DeWalt) but the blades I've used have all been aggressive; large teeth. And that's just it, it often "gets away" and I have to "make it back". Great tip on using a metal blade. Never would have thought of it.
You have to look really close at the OP's pictures for any evidence that it was a jigsaw that cut the holes. Great job.
jcmccorm is offline
post #11 of 108 Old 05-28-2018, 06:33 AM
Fabricator's Avatar
Quoted: 237 Post(s)
Liked: 136
LOL
have a good outline. then just go easy and pay attention to what your doing.
oh. i do router my holes. but i cut the straights with a circular saw free hand.
harrisu likes this.
BenQ HT1070 . Da-Lite HP 2.8 119"
ULTIMAX 18-22, 14cf ported, x2. 6000DSP.
XPA-3, PIONEER VSX-01TXH, SWANS 6.1 & C3
Fabricator is offline
post #12 of 108 Old 05-28-2018, 06:57 AM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
@LTD02 , @notnyt , I'll be using PL Pro Line 3x Premium glue that notnyt suggested when I was building Mini Marty. I have a question on gluing the side panel with bottom. Since side panel is a trapezoidal, I can only clamp it from back to bottom but the front part of side panel can't be clamped due to its angulation. Any suggestions on how to clamp the front part of it with bottom?
harrisu is offline
post #13 of 108 Old 05-28-2018, 07:09 AM
LTD02's Avatar
Liked: 3590
Originally Posted by harrisu View Post
@LTD02, @notnyt, I'll be using PL Pro Line 3x Premium glue that notnyt suggested when I was building Mini Marty. I have a question on gluing the side panel with bottom. Since side panel is a trapezoidal, I can only clamp it from back to bottom but the front part of side panel can't be clamped due to its angulation. Any suggestions on how to clamp the front part of it with bottom?
clamp in port cutouts?
LTD02 is offline
post #14 of 108 Old 05-28-2018, 09:31 AM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Port cut outs are on baffle wall. Question is regarding side walls . Side walls have no cut outs.
harrisu is offline
post #15 of 108 Old 05-28-2018, 09:34 AM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Just to show that the measurements worked fine, I placed the driver and the port on the baffle wall to see how they fit. Here is a glimpse of final product. Hopefully all the pieces will come together properly
Name:	Baffle wall with Driver and Ports Test.jpg
ID:	2408684   Click image for larger version
Name:	Baffle Wall Side Angle with driver and ports test.jpg
LTD02 and tiger8mush like this.
harrisu is offline
post #16 of 108 Old 05-28-2018, 09:36 AM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Totally agreed. I practiced like 5 times before I cut the driver shape in baffle wall. Had it tired it right away, I would have screwed things up. Marking first is VERY IMPORTANT. Also make sure to use a thick marker. Makes it very easy to follow along. Pencil is just not thick enough.
harrisu is offline
post #17 of 108 Old 05-28-2018, 09:40 AM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Thx guys. I was very skeptical at first but things are turning out fine so far. To make sure the circle cut is clean, I practiced many times to make sure things go fine in the final cut . Also, don't rush into cutting it. Take your time and slowly move the jigsaw. Also, as I posted earlier, mark the circle first with a thick marker to follow the jigsaw on.
harrisu is offline
post #18 of 108 Old 05-28-2018, 12:17 PM
asarose247's Avatar
Quoted: 1178 Post(s)
Liked: 1041
this design really got my attention as i have similar issues wrt my recliner. right now behind it is a 24 x 18 x 72 BFM THTLP but the width at the top 24" limits the recline.
my question is what FR is this designed to put out?
the taper and 28 length - i could put 2 of them back there but I'd like them to dig a little deeper than the sub that's there. I can accommodate the 20" depth of the base.
the 31" height is also no issue as the seat measures 36: mostly upright. it's the taper that's would do the trick . .
for a 100 ft^2 room, getting "better' or even "good" sub response is a fools game but I think I could do some serious damage with an Inuke NU4 and a minidsp2x4 .
if a slight increase in volume gets me deeper then I could easily go up to 36" wide.
this is my current best bass REW response. pretty smooth but just runs out of steam, as they are designed to do. that's the lower limit on the sweep. I didn't want to cause any damage
for most music,techno, EDM and stuff on Hearts of Space, this is totally overpowering, even with just the 2 BASH amps (the other sub is a 30" THTLP in the front right corner.)
The dual PA460 MBM John designed for me kicks major but in my living room and
This build and its documentation has given me a springtime itch.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #19 of 108 Old 05-28-2018, 12:57 PM
notnyt's Avatar
Liked: 3690
brad nailer
rukus29 and bebb like this.
notnyt is offline
post #20 of 108 Old 05-28-2018, 01:09 PM
asarose247's Avatar
Liked: 1041
using 3/4" ply, I'd overdo it with Kreg screws on the back of the baffle into the sides, top and bottom.
and PL3X.
the brads could stabilize it . .
post #21 of 108 Old 05-28-2018, 04:23 PM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Alright guys, I got into an issue. I think I followed @LTD02 design up close but kinda messed up a bit. I decided to put the pieces together to see how the overall design is coming. Turned out that baffle wall is short by 1/8". Errrrr. So we have two options.
1 - Cut the baffle wall again (Very long process)
2 - Cut all the other walls by 1/8". (Much easier).
What's the issue if I go with 2nd option?
This is where the Bottom of Baffle wall is
And this is what was needed (Measured from the top including the tap)
Name:	Baffle gap on top.jpg
ID:	2408820   Click image for larger version
Name:	baffle gap up close.jpg
ID:	2408822   Click image for larger version
Name:	How much off.jpg
ID:	2408824   Click image for larger version
Name:	Bottom of baffle.jpg
ID:	2408826   Click image for larger version
Name:	How much Bottom needs to be.jpg
harrisu is offline
post #22 of 108 Old 05-28-2018, 04:31 PM
eng-399's Avatar
Quoted: 2406 Post(s)
Liked: 4951
Go with option 2 or glue a piece of mdf inside the box to area where you have that gap and then fill the gap that's now blocked from the inside with bondo or drywall mud. Looks good so far
bebb likes this.
eng-399 is offline
post #23 of 108 Old 05-28-2018, 04:32 PM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Here you go. Its the top line in Bold for this box
Name:	PA 460 FR Comparison.png
harrisu is offline
post #24 of 108 Old 05-28-2018, 04:36 PM
Nalleh's Avatar
Quoted: 2386 Post(s)
Liked: 3039
Nice project and awsome job with the jigsaw. I recently did a similar enclosure job, only a sealed 4x12" design, but similar obstacles building the box.
You could do what i did, combining several clamps to hold down the side plates, like so:
LTD02 likes this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI-HT18v2 in 2xDO Sonos - 12x12" JBL GT-X1200 NF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873 - Harmony Ultimate.
Nalleh’s HT
Nalleh is online now
post #25 of 108 Old 05-28-2018, 05:21 PM
asarose247's Avatar
Liked: 1041
the tiny gaps at the sides and bottom, a PL3X bead on the inside will will easily swell, seal and cement the joint,
that's what it does and why many here consider it a go to for DIY slicers and dicers.
the top gap?
put in a temporary stop block or 2 to make sure it hits the mark
a huge bead on the inside, smushed into the gap with a disposable glove covered finger
and ditto on the outside.
after about and hour or so, use a putty knife to trim smooth a bit on the outside bead that is swelling up / squeezing out.
as a ported cab, the ports will be where any air wants to go most readily
that pic is just regular squeeze out
HTH
N8DOGG likes this.
post #26 of 108 Old 05-28-2018, 05:38 PM
LTD02's Avatar
Liked: 3590
if you choose to cut an 1/8 off the other panels, it won't impact performance in any way.
it looks like the 32.61" in the plan would have hit it perfect, so it was probably just a case of not compensating for the blade when cutting. no biggie.
bebb likes this.
LTD02 is offline
post #27 of 108 Old 05-28-2018, 05:39 PM
notnyt's Avatar
Liked: 3690
Cut an 1/8 strip to fit in there, glue it in place during assembly. not a big deal. Either that, or recut the baffle.
notnyt is offline
post #28 of 108 Old 05-28-2018, 07:16 PM
Samps's Avatar
Liked: 901
You might be able to find a piece of trim molding that will fit in that gap.
No point in trimming the other panels. If you're going to cut an 1/8 inch, it might as well only be one to fill the gap instead of all three panels.
Samps is offline
post #29 of 108 Old 05-28-2018, 09:29 PM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
Ok I cut the pieces. Looks much better. Still some very small gaps that I can either try to fix or just use some Filler may be to fill them??? See pics below. Should I try to fix these small gaps or use some filler? The problematic areas are top right front/back.
Update: Just saw this video on youtube. I even have this wood filler. Seems like it will do the job?
Sorry I saw your post after I had already cut them I actually did cut a very small piece to fill but wasn't very comfortable with a very tiny piece glued up. I'm sure that after gluing, it wouldn't have caused any issue but just felt better to cut the other pieces.
Front pic
Top right up close
Top right back
Since front baffle top is 15 degrees cut, from inside its completely sealed. I took this pic from inside pointing to top right which has gap from outside.
ID:	2408908   Click image for larger version
Name:	Top Right up close.jpg
ID:	2408910   Click image for larger version
Name:	Back left corner.jpg
ID:	2408912   Click image for larger version
Name:	Top right from inside.jpg
harrisu is offline
post #30 of 108 Old 05-28-2018, 09:32 PM - Thread Starter
Quoted: 923 Post(s)
Liked: 268
the top gap?
HTH
The gaps on sides and bottom is also because I didn't tide the clamp too much. I'm sure with PL3X, they will go away. What is that stuff coming out in the pic you uploaded?
harrisu is offline
