Alpine SWR-1540 Budget Build - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 6 Post By Mazza
post #1 of 3 Old 05-27-2018, 10:40 PM - Thread Starter
Mazza's Avatar
Quoted: 12 Post(s)
Liked: 38
Dear all,
I've been on a roll with Alpine budget builds of late and so felt I would post my most recent, which has also be a great success.
After having a terrific result with my previous SWR-1522D budget build (and smaller SWR-1243), I couldn't resist jumping on the earlier version of this great sub when one came up for sale used for a steal.
They model very similarly in a 97 liter box, slightly different port lengths, both tuned about 20hz
Specifications:
Single 4Ohm Coil
Re – 3.6
Le – 4.05mH @ 1Khz
Fs – 23Hz
Vas – 115l
Qms – 10.38
Qes – 0.48
Qts – 0.46
Xmax – 16.25mm (Linear)
Xmech – 68mm p-p
Hag/Hvc – 15/47.5mm
Sd – 754.77 cm2
Basket displacement – 8.86 lt
This sub came to me as a terminal patient. The roll surround was partially unglued and made some terrible noises as a result. Perfect for a budget build then!
I used some off cuts, cut to size, to carefully lift the cone once I had her all cleaned up...
Then I used this glue recommended for repairing rubber roll surrounds
And following the instructions laid up some glue to both mating surfaces, frame and under roll surround lip
The result came up great I think, it was really pleasing to get this done successfully
I was intrigued to see the magnetic structure of this driver so I unbooted her
For context - AA battery
The enclosure cut sheet in centimeters is as follows
Some obligatory build pics, I really like using this 30mm ply
Rounded end of the inside edges of slot port
SWR-1540 vs SWR-1522D - Looking beyond the cosmetic I can see a lot of similarities here, magnet, voice coil size, frame size. The 1540 weighs a little more ...
Installed in her new home
Measurement (this is how I did it)
Near field (20hz LR HPF & 80hz LPF)
At MLP (no filters)
How does she sound? Amazing.
Having the two 15's in my system has given it a BIG lift in impact. My system, I feel, also got a big lift from some eq after REW room measurements so that has helped too. The 15's just sound big and I couldn't be happier.
Hope this is helpful to other budget builders out there.
ID:	2408468   Click image for larger version
Name:	SWR-1540 at MLP.jpg
ID:	2408470   Click image for larger version
Name:	Lift blocks.jpg
ID:	2408472   Click image for larger version
ID:	2408474   Click image for larger version
Name:	Glued right.jpg
ID:	2408478   Click image for larger version
ID:	2408480   Click image for larger version
ID:	2408482   Click image for larger version
Name:	Glue applied.jpg
ID:	2408484   Click image for larger version
ID:	2408488   Click image for larger version
ID:	2408490   Click image for larger version
Name:	Unbooted context.jpg
ID:	2408492   Click image for larger version
ID:	2408494   Click image for larger version
ID:	2408498   Click image for larger version
ID:	2408502   Click image for larger version
Name:	Old and new.jpg
ID:	2408504   Click image for larger version
Name:	Old and new side.jpg
ID:	2408506   Click image for larger version
Name:	Old and new bottom.jpg
ID:	2408510   Click image for larger version
ID:	2408512   Click image for larger version
ID:	2408514   Click image for larger version
Name:	Lift close up.jpg
ID:	2408516   Click image for larger version
Name:	Cut sheet.PNG
ID:	2408522   Click image for larger version
Mazza is offline
post #2 of 3 Old 05-29-2018, 08:37 PM
bebb's Avatar
Quoted: 229 Post(s)
Liked: 165
Originally Posted by Mazza View Post
Dear all,
Specifications:
Single 4Ohm Coil
Re – 3.6
Le – 4.05mH @ 1Khz
Fs – 23Hz
Vas – 115l
Qms – 10.38
Qes – 0.48
Qts – 0.46
Xmech – 68mm p-p
Hag/Hvc – 15/47.5mm
Sd – 754.77 cm2
At MLP (no filters)
Wow! Ambitious to bring back a driver like that. I would not have thought to reglue the way you did. Great idea! One question. What amp are you using? Sorry if you said, I missed if you mentioned.
bebb is offline
post #3 of 3 Old 06-01-2018, 03:42 AM - Thread Starter
Mazza's Avatar
Quoted: 12 Post(s)
Liked: 38
I love Crown XLS Drivecore series amps
Thanks for the encouragement bebb.
Knowing how well the SWR-1522 and SWR-1243 are put together I figured there was little risk in taking on this driver at the price it was offered and executing a successful repair.
It's really very easy to do, just the process is a little nerve wracking!
Regarding amps, this should answer you question
Cheers
Mazza is offline
