21" drivers with high excursion - AVS Forum | Home Theater Discussions And Reviews
 33Likes
post #1 of 63 Old 05-31-2018, 06:55 AM - Thread Starter
Quoted: 59 Post(s)
Hi,
what 21" with high (linear) excursion do you know?
In order to displace the same volume as a 18" driver with 19 mm Xmax the 21" needs 14 mm Xmax.
What 21" drivers with more than 14 mm Xmax do you know?
Greetings
Soldy is offline
post #2 of 63 Old 05-31-2018, 07:03 AM
johnson636's Avatar
Quoted: 1753 Post(s)
Liked: 1281
https://www.avsforum.com/forum/155-di...llt-build.html
https://www.avsforum.com/forum/155-di...-21-build.html
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #3 of 63 Old 05-31-2018, 07:32 AM - Thread Starter
Quoted: 59 Post(s)
Thank you, the B&C thread gave me the idea
I haven't heard of the Incriminator before and couldn't find any TSP. Do you happen to know them?
Soldy is offline
post #4 of 63 Old 05-31-2018, 07:34 AM
Quoted: 1012 Post(s)
Liked: 1263
Pierce Audio in WA has a few 21"s that will definitely exceed 14mm.
Pradeep2 is offline
post #5 of 63 Old 05-31-2018, 07:56 AM - Thread Starter
Quoted: 59 Post(s)
I just took a look at their homepage and couldn't find any TSP. It seems realy strange to me to not put those online...
Soldy is offline
post #6 of 63 Old 05-31-2018, 08:14 AM
Liked: 5
Try Mach 5 Audio
tbsmitty67 is offline
post #7 of 63 Old 05-31-2018, 08:23 AM - Thread Starter
Quoted: 59 Post(s)
Originally Posted by tbsmitty67 View Post
Try Mach 5 Audio
Thx. I am no expert, but it only has a 3" voicecoil, which seems too small compared to the 4" voice call its competiors have.
Soldy is offline
post #8 of 63 Old 05-31-2018, 09:13 AM
Liked: 1263
I believe they customise each driver based on your specific application, so you would need to contact them to get specific details (for example car audio SPL targeted specs will prob differ from a home theater focused unit)
tential likes this.
Pradeep2 is offline
post #9 of 63 Old 05-31-2018, 09:40 AM - Thread Starter
Quoted: 59 Post(s)
No offence to the company, but I would have to import it and if there is any problem with the custom built speakers I am screwed...
The 21DS115 seems pretty good, but are there no mass produced drivers with a little more Xmax?
Soldy is offline
post #10 of 63 Old 05-31-2018, 09:50 AM
BassThatHz's Avatar
Quoted: 4052 Post(s)
Liked: 4570
There is always the SAB-24 5"VC 4-10kW 4"p-p 160lbs $260
BassThatHz is offline
post #11 of 63 Old 05-31-2018, 09:56 AM - Thread Starter
Quoted: 59 Post(s)
Would you be so kind and post a link. I googled it and only found this: https://www.alibaba.com/product-deta...423130541.html
But no price and a 50 piece min. order.
Soldy is offline
post #12 of 63 Old 05-31-2018, 09:59 AM
Quoted: 66 Post(s)
Liked: 50
Lol ya bassthathathurtz but didn't it cost you like $500 to ship each driver!?!
corradizo likes this.
Acrjoey is offline
post #13 of 63 Old 05-31-2018, 10:27 AM - Thread Starter
Quoted: 59 Post(s)
I found the thread...
Thats nothing for me. If the drivers were well build and people had positive experinces with the manufacturer then maybe, but that is too much of a risk...
+ You need a crane to move it around....
Soldy is offline
post #14 of 63 Old 05-31-2018, 10:33 AM
Liked: 1263
The B&C 21s are more pro-audio focused and designed to be pretty bulletproof with huge power inputs, and high sensitivity. Pretty much all the HT focused 21s have more excursion for ultra deep bass.
Pradeep2 is offline
post #15 of 63 Old 05-31-2018, 10:45 AM - Thread Starter
Quoted: 59 Post(s)
But if all the HT ones are custom built, then it is to great of a risk for me...
Soldy is offline
post #16 of 63 Old 05-31-2018, 11:16 AM
uniquepattern's Avatar
Quoted: 810 Post(s)
Liked: 859
Why a 21"??
Look at StereoIntegrity... They make 24's and not a lot of risk (his drivers are very well made, and Nick stands behind his products - I am a biased owner of a pair of HS24's)
uniquepattern is offline
post #17 of 63 Old 05-31-2018, 11:27 AM - Thread Starter
Quoted: 59 Post(s)
Originally Posted by uniquepattern View Post
Why a 21"??
I haven't even considered 24".
But SI is too expensive for me. The may be great, but way too powerful. I was looking more in the 500-600$ price range
E: Is Nick here in the forum as well? Because his 18" look interesting.
Soldy is offline
post #18 of 63 Old 05-31-2018, 11:46 AM
SpinMonster's Avatar
Quoted: 542 Post(s)
Liked: 330
Nick's HST-18 has an Xmax around 38mm. That puts out far more than a 21" with a 15mm Xmax. They are on sale. It's in your price range.
http://stereointegrity.com/product/hst18-18-subwoofer/
EDIT: One thing to consider is that these pro drivers you are asking about are built for efficiency above 20hz but not home theater deep bass. To dig deep, you will need a seriously huge box in comparison to such an 18". The B&C 21's have stronger motors and light cones in comparison.
It would be far more efficient for us to help you if you give more information about your goals/constraints rather than give reasons why each suggestion doesn't work for you.
SpinMonster is offline
post #19 of 63 Old 05-31-2018, 11:57 AM
Quoted: 810 Post(s)
Liked: 859
Nick is on the forums, @Electrodynamic
Nick is a great guy to deal with, drop him a line and see what he has to say...
He may have other (not currently listed) options for you too.....
post #20 of 63 Old 05-31-2018, 03:40 PM
zora's Avatar
Quoted: 135 Post(s)
Liked: 161
Blindly discounting the FTW-21 is a huge mistake
zora is offline
post #21 of 63 Old 05-31-2018, 04:14 PM
BassThatHz's Avatar
Liked: 4570
High excursion drivers tend to suck at mid-bass and thus chest-kick.
Pro drivers tend to suck at ULF.
There is no free lunch.
You'll need lots of both if you desire serious bass.
I own 24's 21's 18's and 15's all in the same room at the same time.
The 24's make everything else look like toys... just sayin'
I could only imagine the 32's...
post #22 of 63 Old 05-31-2018, 04:33 PM
notnyt's Avatar
Quoted: 3918 Post(s)
Liked: 3854
not really
there are far better options.
lukeamdman, Freniata and bebb like this.
notnyt is offline
post #23 of 63 Old 05-31-2018, 06:40 PM
zora's Avatar
Quoted: 135 Post(s)
Liked: 161
Originally Posted by notnyt View Post
not really
We are all entitled to our opinions, even those who own/use some of the drivers under discussion
zora is offline
post #24 of 63 Old 05-31-2018, 06:59 PM
lukeamdman's Avatar
Quoted: 1387 Post(s)
Liked: 2009
Ha
notnyt and eng-399 like this.
lukeamdman is offline
post #25 of 63 Old 06-01-2018, 01:40 AM
Quoted: 542 Post(s)
Liked: 330
Deep bass, mid-bass, it's all easily accomplished with the right interconnects.
Or just get a 10" servo sub like Danny Ritchiie says. All these oversized plywood boxes are a waste
post #26 of 63 Old 06-01-2018, 02:06 AM - Thread Starter
Quoted: 59 Post(s)
Hi,
thx for all the answers (every now and then I think I come off to Canadian for this forum )
What I want: Lots of displacement for very little money (max. 450 $ - I forgot about shipping costs and taxes/customs).
I see the UM 18 as kind of a benchmark, since it has great performance for a reasonable price.
I have space for a 22 " wide/high box with 20" in depth. 24" would be acceptable, but the drive would have to be worth it.
Since the subwoofers will be between furniture, there is no space for a vented design (also the vents would take up to much enclosue volume).
Greetings
Soldy is offline
post #27 of 63 Old 06-01-2018, 02:09 AM - Thread Starter
Quoted: 59 Post(s)
I will take a look at it.
But basically it all comes down to the displaced volume and the electrial durability of the driver. So if you have a good alternative to large drivers, feel free to name it
Soldy is offline
post #28 of 63 Old 06-01-2018, 06:13 AM
johnson636's Avatar
Liked: 1281
Greetings
Well wouldn't that be great
jujuman200 likes this.
post #29 of 63 Old 06-01-2018, 06:19 AM - Thread Starter
Quoted: 59 Post(s)
You can't blame a guy for trying
18Hurts likes this.
Soldy is offline
post #30 of 63 Old 06-01-2018, 11:29 AM
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
ESPECIALLY those of us who USED some of the drivers under discussion.
bebb is offline
