LTD02-VBSS + mini-marty UM18 + NEW iNuke + a Bulldog named Diesel - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 137Likes
post #91 of 120 Old 09-26-2018, 02:48 PM
bscool's Avatar
Quoted: 889 Post(s)
Liked: 713
If you look at it from a ratio of $$ perspective. A mic is said $75-100. So on a $1000+ system that is 10% or less and fixing the low-end FR can give you a 50% improvement in sound SQ. That is a pretty small investment for the return.
Of course, my 50% improvement in SQ was just a random # but it can make a fairly substantial improvement getting the low end optimized.
rukus29 likes this.
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is offline
post #92 of 120 Old 09-26-2018, 03:25 PM
Quoted: 159 Post(s)
Liked: 248
Originally Posted by Craig S King View Post
No.
I agree, that makes sense. I was thinking about getting a mic, but that's a decent investment for a home audio setup in my office. Although, since I'd don't see this hobby going away anytime soon for myself, rather only getting bigger, perhaps I should more seriously consider a mic.
Dayton makes a cheap 3.5mm mic that I've been using. It comes with a calibration file as well.
lmidgitd is offline
post #93 of 120 Old 09-27-2018, 07:43 PM - Thread Starter
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
Is that the one that plugs into your cell phone?
Craig S King is offline
post #94 of 120 Old 09-28-2018, 04:19 AM
Quoted: 159 Post(s)
Liked: 248
Yup. Here's a link. I doubt it's accurate in the lower frequencies, but I was just looking for a relative comparison of subwoofer placements, which this microphone has given me. Granted I picked mine up on sale for around $15. The problem with plugging it into the phone is the inability to use REW. Some people suggest using Audiotool if using an android. I plug mine into my laptop use REW. If you have a traditional hard drive I might be worried that the spinning of the HD would affect the measurement.
https://www.ebay.com/p/Dayton-Audio-...6103061&chn=ps
lmidgitd is offline
post #95 of 120 Old 10-03-2018, 09:40 PM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
Thanks for the info. I wasn't aware of the NU amps having backwards phases. Hopefully that's not an issue with the NX amps. But I'll switch the phase
Just to follow up here - did you ever try messing with the phase? I actually tried my new NU3000D last weekend and at least channel A was properly in phase with everything else. So that’s good news/less confusing. Didn’t try channel B as I have two more MBM enclosures to buikd
rukus29 is offline
post #96 of 120 Old 10-04-2018, 07:47 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Rukus, I did mess around the phase a bit. I didn't notice much difference switching between 0 and 180 going through the UM18. I did notice a sound difference with the PA460s when I switched the phases. At the moment, I have it set to 180 for my PA460s. Although, I'm not sure how to tell which is "correct" ?
post #97 of 120 Old 10-04-2018, 08:17 PM
rukus29's Avatar
Quoted: 285 Post(s)
Liked: 147
I think the only sure fire way to tell is by measuring with mic/rew. I wasn’t able to tell by physically feeling the driver while playing the wav file posted in the inuke6k thread I linked to earlier. The unscientific way would be listening by ear to try and see if volume increases when you add the subs or volume decreases. I don’t know how you would do that and call it conclusive though. It would be odd though that the um18 would be in a different phase than the pa460s unless you tried them on different channels (or you wired one backwards). That said, setting it at 180 (ie reversed phase) seems to be what a lot of people have to do with the older inukes. I had to do it on one channel of my inuke6kdsp. I have only tested one channel of my nx3000d but it seemed fine based on my initial measurements (ie at 0 degrees).
rukus29 is offline
post #98 of 120 Old 06-04-2019, 09:40 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Quick update.... I bought two more PA460s. I’m going to build another set of 31hz-tuned VBSS. I’ll have a quad-PA460 setup for music. I’m going to upgrade to an NX6000D as well. Construction to start soon....
kagtha likes this.
post #99 of 120 Old 06-04-2019, 06:33 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Round 2 starting soon....
ID:	2576052   Click image for larger version
Name:	31hz vbss cutlist.jpg
4fit?, lmidgitd and kagtha like this.
post #100 of 120 Old 07-06-2019, 06:38 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
The Quad-VBSS setup is making more progress this weekend. Definitely need more power for a quad PA460 audio setup!
Should have some MDF dust flying later this weekend too.
4fit? likes this.
post #101 of 120 Old 07-06-2019, 12:25 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
In planning ahead, with the nx6000d, what would be my best configuring option for running 4 PA460s, and possibly still running the UM18 in the mini-marty?
I was thinking, wire both sets of the PA460s in parallel for 4ohms, then wire the sets in series for an 8ohm load into one channel on the 6000d? That way 1600w is going between the 4 PA460s? And then run the second channel to the UM18 at 4ohms? Can you do that?
Or is there another option?
Should I just disconnect the UM18 for now and run just the PA460s, 2 in parallel to both channels? I feel like that would be too much power?
post #102 of 120 Old 07-06-2019, 01:04 PM
smcmillan2's Avatar
Quoted: 819 Post(s)
Liked: 720
Sure can.
Note that the 6k only produces about 1300wpc @8 ohm so your PA460s will get a little over 300w each, max.
Roughly 2000wpc at 4 ohm on the other channel for the UM18.
Craig S King likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #103 of 120 Old 07-06-2019, 05:40 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Originally Posted by smcmillan2 View Post
Sure can.
Well, it sounds like my options are either to run it at 8ohms for ~1300w to all four PA460s, or 2000w per pair of PA460s if I take the UM18 out of the picture.
post #104 of 120 Old 07-06-2019, 06:22 PM
smcmillan2's Avatar
Quoted: 819 Post(s)
Liked: 720
I may have missed it, is this another music only system? If so, then yes, you could take the UM out of the mix and give the PA460s their rated max of 1000w by pairing them up on each channel.
If it's for movies as well, I would leave the UM in the mix. The PA460s are very efficient and will play very loud with ~300w on them. Try it, if you don't like it it's easy enough to re-wire (I think? Not sure what your situation is). I'm currently driving a pair of sealed UM18s off one channel of an nx3k, and a modified VBSS (17Hz tune) on the other. Still have to dial them in but the setup pounds our living room so far, and we're pretty happy with it. We don't listen at reference however, -10 or so max.
post #105 of 120 Old 07-06-2019, 06:26 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Yes, this is my strictly audio setup.
smcmillan2 likes this.
post #106 of 120 Old 07-06-2019, 06:32 PM
smcmillan2's Avatar
Quoted: 819 Post(s)
Liked: 720
Got it. Depending on the types of music you listen to I would still give it a try with the UM. If you don't listen to anything that digs into the lower 20s then it probably won't benefit your setup in this case.
Playing with different things is one of the great (and potentially very expensive!) things about this hobby
post #107 of 120 Old 07-10-2019, 06:31 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Making progress on another pair of 31hz VBSSs:
ID:	2589580   Click image for larger version
ID:	2589582   Click image for larger version
ID:	2589584   Click image for larger version
post #108 of 120 Old 07-10-2019, 06:38 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Getting the ports painted and put together.
And a special visit from the building inspector....
ID:	2589590   Click image for larger version
ID:	2589592   Click image for larger version
ID:	2589594   Click image for larger version
4fit?, chadsmith013 and andyc56 like this.
post #109 of 120 Old 07-11-2019, 07:30 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Got the braces going. Had to make sure they met Diesel's requirements. He has very strict guidelines for brace design.
Even though they will never be seen, I still opted for a chamfered on the braces.
ID:	2589926   Click image for larger version
ID:	2589928   Click image for larger version
ID:	2589930   Click image for larger version
andyc56 likes this.
post #110 of 120 Old 07-11-2019, 07:41 PM
cobr's Avatar
Quoted: 30 Post(s)
Very detailed braces. Please could you post the dimensions of the box and port. Thanks
Sent from my SM-N960U using Tapatalk
cobr is offline
post #111 of 120 Old 07-11-2019, 09:05 PM
Zarkoff500's Avatar
Quoted: 180 Post(s)
Liked: 138
Please could you post more pics of Diesel
Zarkoff500 is offline
post #112 of 120 Old 07-12-2019, 05:55 AM
chadsmith013's Avatar
Quoted: 2116 Post(s)
Liked: 2146
no offense..but Diesel is the real MVP of this build..his attention to detail is unmatched.
Receiver : Pioneer Elite SC-95
Front Speakers: 3 DIYSG 1099's
Surround Speakers:2 DIYSG Volt 10's Atmos: 2 DIYSG Volt 6's
Subwoofers: Dual LaVoce SAN214.50 21's in Cyclops enclosures w/Inuke 6000 DSP
Nearfield: 2 Dayton HO 15's w/Inuke 6000DSP
chadsmith013 is offline
post #113 of 120 Old 07-12-2019, 07:41 PM
Quoted: 50 Post(s)
Liked: 4
I made some more progress. It's a little more fun building these than the Mini-marty. Between the panels being smaller and easier to work with, and having more experience.
I made some 22" braces to keep the side panels square while the PL3x was clamping and drying
Gluing the port support in
Pre-painting the port
Ports glued in... these pieces are 10.5" long for the 31hz tune version
I'm glad I came across this. I am building a pair of vbss and was having issues with the slot port on the first box I made. This visual is very helpful, and I'll use this method on the second box next week.
kingssoldier08 is online now
post #114 of 120 Old 07-13-2019, 07:08 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
I got all my info and dimensions from LTD02's post in the official VBSS thread.
Post #798 : https://www.avsforum.com/forum/155-d...thread-27.html
Originally Posted by Zarkoff500 View Post
Plea&#1 15;e could you po&#1 15;t more pic&#1 15; of Die&#1 15;el 🙂
Yeah, I've got some more coming soon.
None taken - he's a great supervisor. Definitely my #1 favorite woofer.
I'm glad it helped. I always paint the port area first since you can't get to it afterwards. And then I install the port rail first. You can nail/screw it from the bottom on the cabinet too. Then install the actual port panel. And then you can nail/screw the port panel to the port rail.
chadsmith013 likes this.
post #115 of 120 Old 07-13-2019, 07:14 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
I got the baffle traced out and cut out.
I also got the braces installed and foam stapled into the cabinets.
Being a VBSS construction supervisor is exhausting.
ID:	2590254   Click image for larger version
ID:	2590256   Click image for larger version
ID:	2590258   Click image for larger version
post #116 of 120 Old 07-13-2019, 08:04 AM
Quoted: 50 Post(s)
Liked: 4
My port goes up the back wall as well for the 20/15hz tuning, and I assembled the port first realizing too late that now I had to somehow clamp it to the bottom AND back of the enclosure. This way will make that MUCH easier. Just do the back and bottom rails like you did yours. I may use screws to speed up the process. Bracing was a bit tricky as well. Hoping the second sub comes together better.
post #117 of 120 Old 07-13-2019, 08:13 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
When I did my mini-marty, the port when up the back as well. I installed the bottom port rail first, then the back port rail. I drew centerlines on the outside of the bottom and back panels so I knew where to screw into the panels to catch the port rails. Then install the bottom port panel, secure it, then the back port panel.
As far as bracing, remember that the port and port rails act as braces for the bottom and most of the back of the cabinet as well.
Good luck with your build. Just remember to take your time and think your design/construction through first, before starting to glue/nail/screw.
post #118 of 120 Old 07-13-2019, 10:48 AM
Quoted: 50 Post(s)
Liked: 4
Thanks for the tips. I use a build thread here if you are interested in following along. I'm not as detailed as you with progress pictures and such though.
I do have another question regarding the wiring. Did you get a wiring connector to fit in the back of the speakon connector in the sub? There seems to be very little "how to's" with wiring diy speakon sub connections. At least I can't seem to find it. When you wire these up, you mind postng a picture of the back of the speakon connector in the sub?
post #119 of 120 Old 07-13-2019, 01:56 PM
Kpilk's Avatar
Quoted: 64 Post(s)
Liked: 69
Do I see a woodworking shop in the background? A bulldog and a shop? Unfair.
Kpilk is offline
post #120 of 120 Old 07-20-2019, 01:38 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
For the pair I'm building currently, I drilled a 1" hole in the front baffle near the corner and will install a SpeakOn connector. I'll have pictures of it soon.
Yes. It has its advantages and disadvantages. It's a great place to get work done and I have plenty of space and lighting. But it's not attached to my house, so I have to drive to it anytime I want to do any work. And when a project is done, I have to pack it up into my truck and transport it home.
