LTD02-VBSS + mini-marty UM18 + NEW iNuke + a Bulldog named Diesel - AVS Forum | Home Theater Discussions And Reviews
 137Likes
post #1 of 120 Old 06-02-2018, 05:34 PM - Thread Starter
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
Let me preface by saying this is 100% a home audio setup.
A few months ago I decided to purchase a UM18 and build a mini-marty cabinet for my home audio interests: https://www.avsforum.com/forum/155-di...d-diesel.html0
I enjoyed building a mini-marty and have been very impressed with the UM18, but for my home audio needs, the UM18 wasn't really doing what I needed. After more research, it was apparent that the VBSS setup was better for me, more specifically the 31hz version that @LTD02 developed. Again, this is strictly for a home audio setup. The UM18 in the mini-marty hits very low frequencies, enough to make me giggle, but... misses a lot of bass from my normal music.
Anyway, I'm starting the build process of a pair of 31hz tuned VBSS cabinets with the help of my bulldog, Diesel. I plan to power the dual VBSS's and the UM18 with the new Behringer amps when they are released. I'm using a pair of PA460s like the original VBSS design prescribed.
LTD02, gazzamongo, eng-399 and 3 others like this.
Craig S King is offline
post #2 of 120 Old 06-02-2018, 05:38 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
I decided to use the PL3x this time.
Rough fitting of the panels
ID:	2410958   Click image for larger version
filtor1, eng-399, Rcris and 3 others like this.
post #3 of 120 Old 06-02-2018, 06:27 PM
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Originally Posted by Craig S King View Post
I decided to us the PL3x this time.
//what driver for vbss?
Rcris is offline
post #4 of 120 Old 06-02-2018, 06:34 PM
smcmillan2's Avatar
Quoted: 819 Post(s)
Liked: 720
In the first post:
Original thread here: https://www.avsforum.com/forum/155-di...gn-thread.html
Craig S King likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #5 of 120 Old 06-02-2018, 06:50 PM
LTD02's Avatar
Quoted: 2920 Post(s)
Liked: 3626
port looks too small!
what plan are you using?
edit: looks like the slot port version of the VBSS.
port is only 1.5" tall in that one. normally, I'd make the port a little larger, but I was trying to copy the vbss as closely as possible, but make a slot port version.
never mind me. must be tired. :-)
Listen. It's All Good.
LTD02 is online now
post #6 of 120 Old 06-02-2018, 07:15 PM
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Coincidentally i started building 4 of these today @LTD02 wondering how can i lower the tune , extending the port by how much to have 30hz tune
LTD02 and biga6761 like this.
Rcris is offline
post #7 of 120 Old 06-03-2018, 07:45 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
I'm using the 18" PA460 woofer from Parts Express. I picked up a pair of them while they were on sale for $90. I'm thinking I might buy two more actually.... just to have.
Yes, I'm using your slot port version of the VBSS. I've never been a fan of round ports. Plus, since this is audio only, I'm going with the 31hz version. Thanks again for taking the time to develop this new design. It's funny looking at it, aside from the 16.75" baffle cutout, this cabinet is pretty much just scaled-down version of the mini-marty. The port is only 1.5" tall, and 10.5" deep.
Check out the VBSS thread, specifically post #789 by LTD02. He has the designs specs for both a 31hz and 22hz slot ported cabinet. Within that, you can stuff the ports to lower the tuning frequency. If you're looking for 30hz as opposed to 31hz tuned, I would guess its only a matter of adding 1-2" of length onto the port.
post #8 of 120 Old 06-03-2018, 07:59 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
And just for reference, in my Mini-Marty thread, I had planned on getting an iNuke3k. I ended up not buying one because I was considering other options, and then this dual VBSS setup got started. So at this point, a iNuke6k would be more likely, but I'm also holding out for the new Behringer amps to come out. Has anyone heard any more info on them? Parts Express doesn't have them yet.
Few more pictures from test fitting the panels and the leftover pieces I can use for ports, corner/edge supports and braces:
ID:	2411168   Click image for larger version
LTD02, filtor1, eng-399 and 2 others like this.
post #9 of 120 Old 06-03-2018, 08:08 AM
smcmillan2's Avatar
Quoted: 819 Post(s)
Liked: 720
Well, what else would they be for? Certainly not video...
Nobody has them yet from the searching I have done. But do note, I haven't seen mention of a DSP version in the new line either, so if you anticipate needing that (I know I do) the wait could be even longer.
post #10 of 120 Old 06-03-2018, 08:15 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Yes, I would want the DSP version.
I vaguely remember seeing a link a few weeks ago in another thread about the new iNuke replacements... I think there is a vendor that has them for sale, but maybe not as reputable of a vendor. Or maybe they were just taking preorders.
Either way, yes, I would want a DSP version and to be able to buy it from Parts Express or someone else similar in case I have issues with it.
post #11 of 120 Old 06-03-2018, 09:40 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Here's the thread I was referring to with the new Behringer power amps: https://www.avsforum.com/forum/90-rec...000-black.html
post #12 of 120 Old 06-03-2018, 04:55 PM
tk123's Avatar
Quoted: 168 Post(s)
Liked: 138
Lots of posts in that thread speculate that only the casing has changed- with internals being the same. We’ll have to wait until somebody gets one and is able to check into this for us. ☹️
tk123 is offline
post #13 of 120 Old 06-03-2018, 07:32 PM
eng-399's Avatar
Quoted: 2420 Post(s)
Liked: 4971
eng-399 is offline
post #14 of 120 Old 06-04-2018, 06:01 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Yeah, I came to that conclusion too... pretty much the same iNukes with just a different colored case.
Originally Posted by eng-399 View Post
Looking good Craig keep it going!
Thanks Mike! You've contributed to my projects too!
eng-399 likes this.
post #15 of 120 Old 06-04-2018, 06:05 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
I made some more progress. I used some scrap pieces to glue onto the bottom panels to help with corner/edge supports.
Can anyone see what I did wrong though?
Diesel helping me inspect the PA460s
ID:	2411968   Click image for larger version
ID:	2411970   Click image for larger version
post #16 of 120 Old 06-06-2018, 07:00 PM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
I made some more progress. It's a little more fun building these than the Mini-marty. Between the panels being smaller and easier to work with, and having more experience.
I made some 22" braces to keep the side panels square while the PL3x was clamping and drying
Gluing the port support in
Pre-painting the port
Ports glued in... these pieces are 10.5" long for the 31hz tune version
ID:	2412880   Click image for larger version
ID:	2412882   Click image for larger version
ID:	2412884   Click image for larger version
filtor1, eng-399, biga6761 and 1 others like this.
post #17 of 120 Old 06-06-2018, 08:02 PM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
Thanks for all the pictures and detail in your build progress! Funny enough, i am going through the same build process... i am in progress with 2 VBSS and will start on a mini or full marty this weekend. Your threads have helped!
Sent from my SM-G955U using Tapatalk
Equipment: Yamaha 3050, Oppo 103d, DIYSG HT12s (L,C,R), PSA mt 110s (SR,SL), 2 VBSS, Submaximus, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is online now
post #18 of 120 Old 06-10-2018, 07:57 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
You're welcome! Glad they've been helpful. I'm posting more pictures shortly!
post #19 of 120 Old 06-10-2018, 08:03 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Got some more work done. The PL3x definitely dries much faster than the liquid nails I used last time around. Although I'm not sure how much I like the wet/greasy look the PL3x leaves behind where you wipe it off.
I was very pleased and impressed with how this corner fit together:
Cabinets coming together - test fitting the final panels, the baffles:
ID:	2414390   Click image for larger version
ID:	2414392   Click image for larger version
filtor1, biga6761 and kagtha like this.
post #20 of 120 Old 06-10-2018, 08:10 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Measuring baffle holes for the woofers:
For future VBSS builders, 16.75" is a little too BIG of a cutout in my opinion. There was a .125" gap around the entire circumference of the woofer. I think 16.625" would be better. Or measure 16.75", but cut inside your line.
Test fitting the baffles again with cutout:
ID:	2414396   Click image for larger version
ID:	2414398   Click image for larger version
ID:	2414400   Click image for larger version
johnson636, filtor1 and biga6761 like this.
post #21 of 120 Old 06-10-2018, 08:13 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
I got the pleasure of dealing with these little guys. Perhaps 2" brad nails were a little too much. That's what pliers and wood filler are for.
ID:	2414408   Click image for larger version
biga6761 likes this.
post #22 of 120 Old 06-10-2018, 08:17 AM
blake18's Avatar
Quoted: 630 Post(s)
Liked: 351
31hz is a pretty high tuning frequency for home theater subs, why not tune lower?
Lumenlab "Community driven video lab".
blake18 is online now
post #23 of 120 Old 06-10-2018, 08:17 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
After the cabinets were assembled, I spent some time thinking about bracing. I went with a modified window brace. I liked how the one brace turned out with the rounded windows in it. I had scrap pieces big enough to cut them out whole.
Installing them in the cabinet.
ID:	2414414   Click image for larger version
ID:	2414416   Click image for larger version
post #24 of 120 Old 06-10-2018, 08:20 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Blake, these are not HT subs. They are strictly music subs, hence the higher tune. Besides, I have this guy already for the ULF
jujuman200 and biga6761 like this.
post #25 of 120 Old 06-12-2018, 02:33 AM
jujuman200's Avatar
Quoted: 66 Post(s)
Liked: 86
That's WHY you DON'T wipe it off.... you let it DRY/CURE the way it is..... then get a chisel and SCRAPE it off. It comes off cleanly that way.
Juju
dunnkm2, biga6761 and Craig S King like this.
Wish List: LLT Sub Dual UM-18, 25 cuft 12Hz tune. Anthology http://www.speakerdesignworks.com/Anthology_1.html
DIY so far: LCR (RCF H100 3way) 2 - Full MARTY 460HO ( PIX from OLD profile) https://www.avsforum.com/forum/155-d...l#post39937738
2- VBSS and a DIY Bass Shaker
jujuman200 is offline
post #26 of 120 Old 06-16-2018, 09:04 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
Juju
Yeah, I'll try that next time. It just seemed easy to clean it off now, instead of forgetting about it and running my fingers through it a few minutes later when it was still wet.
post #27 of 120 Old 06-16-2018, 09:10 AM - Thread Starter
Quoted: 359 Post(s)
Liked: 510
The cabinets are pretty close to being finished now. I test fitted the PA460s and predrilled the screw holes in the baffle. I also finished the braces - I did vertical braces too.
I decided to do a 45 degree chamfer on the edges instead of rounded. I lined the inside with foam mattress topper.
After sanding the nail holes, all the excess PL3x off and the seams. I was very happy with how well some of the edges/seams came together, like this one:
ID:	2416762   Click image for larger version
ID:	2416764   Click image for larger version
ID:	2416766   Click image for larger version
ID:	2416768   Click image for larger version
post #28 of 120 Old 06-16-2018, 09:53 AM
jujuman200's Avatar
Quoted: 66 Post(s)
Liked: 86
It's all good.... we have ALL made that mistake......
Juju
post #29 of 120 Old 06-16-2018, 09:54 AM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
I'd be happy with that edge too! Nice job.
Oh, and I guess the glue left behind after wiping sanded off ok?
jcmccorm is offline
post #30 of 120 Old 06-16-2018, 09:55 AM
jujuman200's Avatar
Quoted: 66 Post(s)
Liked: 86
@Craig S King
Looking good bro.....
Juju
