What do we have here.........An FP20000Q - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 131Likes
post #31 of 289 Old 06-11-2018, 04:54 PM
BassThatHz's Avatar
Quoted: 3679 Post(s)
Liked: 4173
To be to code you need the nema 6-15, not the nema TT 30 that you referenced:
Theoretically if the amp is 16a fused, then the 240v 15a breaker should trip before the fuse melts.
A nema 6-20 might cause the fuse to melt before the breaker trips.
and if the amp is truly 240v 30a fused then you need a 6-30 or 10-30.
You can also do the L versions, which is twistlock.
SVChucko likes this.
BassThatHz is offline
post #32 of 289 Old 06-11-2018, 05:42 PM
Quoted: 1012 Post(s)
Liked: 1261
Damn I know ordering a 220-240v appliance and receiving a 120V NEMA 5-15 plug would fill me with indescribable confidence that everything's going to be just dandy It does look like a big gauge cable though.
So apart from the 5kw+ burst what is the sustained output before the magic smoke comes out?
andyc56 likes this.
Pradeep2 is offline
post #33 of 289 Old 06-11-2018, 06:45 PM - Thread Starter
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 672
As it stands right now, the amp does not power up Very frustrated at the moment, so I'm going to walk away from troubleshooting and pick it back up tomorrow.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #34 of 289 Old 06-11-2018, 06:48 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3705
please tell me you didn't try to plug it into 120v
notnyt is offline
post #35 of 289 Old 06-11-2018, 07:00 PM
BassThatHz's Avatar
Liked: 4173
When you flick the switch what happens, nothing?
What socket and voltage did you plug it into so far?
Are you sure your breaker is on, and that there is "actual" voltage at the wallsocket contacts?
Are any of the fuses not 0-ohms? (You have to pull them out of their holders.)
There are fuses on each of the 4 amp boards, the power supply and the rectifier board.
Be careful, wear rubber gloves, the internals of this amp can kill a man...
Also wear safety glasses or a face shield, don't let your probe contacts touch or slip or you'll arc-weld the amp (blinding flash and zillion degree metal flying everywhere.)
After being energized, let the amp sit for a good 30 minutes before opening it.
Imagine this, but worse....
post #36 of 289 Old 06-11-2018, 07:29 PM - Thread Starter
johnson636's Avatar
Liked: 672
Nope. I've confirmed there is 120v on each prong of the plug (obviously except ground), yet absolutely nothing happens when I hit the power switch. I haven't checked any components in the amp; will have to wait until tomorrow.
post #37 of 289 Old 06-11-2018, 08:12 PM
BassThatHz's Avatar
Liked: 4173
Supposed to be 240v from hot to hot.
i.e. split-phase.
If you connected it to 120v x2 from the same leg you may have fried the amp (not sure...)
In any case that would be 0volts from hot to hot, so of course it won't power on!
0 volts = 0 watts.
240 volts = all the watts.
Testing 120V Hot to Neutral or Hot to Ground tells you nothing on a 240V circuit!
It's not just any two 120V hot wires, its two differential 120V hot wires.
How well do you know electricity really? Please say you already knew and fully understood everything I just said.
post #38 of 289 Old 06-11-2018, 08:34 PM
Iris Teng's Avatar
Liked: 0
Thank you for your support of our company!
Hello,Dear Sir,this is Iris from Sinbosen audio.
Thank you for your support!And thank you for your feedback. I will relay your message to our engineers to see if we have a better solution.
If there is any problem during use, you can directly contact the person who sold it to you. We will be responsible for it.
Best wishes!
Sinbosen Audio
Iris Teng is offline
post #39 of 289 Old 06-11-2018, 08:37 PM
Liked: 1261
Best case the amp is still waiting for 240V to be delivered to power up. Did you replace the 5-15 plug with that 120V 30A travel trailer one? And then rewire the socket for 240V?
Did you rewire like this?
http://www.electrical-online.com/how..._120v_to_240v/
Pradeep2 is offline
post #40 of 289 Old 06-11-2018, 08:43 PM
Iris Teng's Avatar
Liked: 0
Thumbs up Thank you for your support of our company!
[quote=johnson636;56327096]This FP20000Q is manufactured by XBS a.k.a. Sinbosen a.k.a. AOYUE. My first impression is it's heavy. Initial visual of the build is pretty good. The only questionable sign of poor workmanship is the messy application of heat sink compound on the one transistor in one of the pics. Now I have to switch one of my circuits to 240v and replace the power cord with the appropriate plug.
Best wishes!
Sinbosen Audio
post #41 of 289 Old 06-11-2018, 09:03 PM
BassThatHz's Avatar
Liked: 4173
They've found us! LOL
Another thing you can test (with the amp unplugged and discharged for a while), is the conductivity of each pin on the power cable to the solder point on the board. All three should measure 0-ohms, that will tell you if it's a bad cable job or not.
Beyond that I wouldn't have a clue, I'm not a amplifier maker...
stegen and Reddig like this.
post #42 of 289 Old 06-11-2018, 09:09 PM
Liked: 1261
Did you request a NEMA 5-15 because thats what your intended 240V outlet is wired as?
Pradeep2 is offline
post #43 of 289 Old 06-11-2018, 10:12 PM
BassThatHz's Avatar
Liked: 4173
It's a long story, so:
Spoiler!
Pradeep2 likes this.
post #44 of 289 Old 06-12-2018, 05:57 AM - Thread Starter
johnson636's Avatar
Liked: 672
Ok, after contracting the "first half of the day flu" I figured out what the problem was, a faulty breaker For the life of me I've never seen a faulty breaker...and it was new I didn't have another double pole 30a breaker to test, so I used two seperate 30 amp breakers(I know, I know) and she fired right up. Gave her a quick run and the 24s were really, really, moving to the point I had to back down in a hurry. The amp didn't clip and had more to give, but I'm not going there. I've never heard a FP14k before, but hands down it's more powerful than my FP10ks
post #45 of 289 Old 06-12-2018, 06:29 AM
Buddylee123's Avatar
Quoted: 874 Post(s)
Liked: 617
Nice glad you figured it out
johnson636 and Jk7.2 like this.
Buddylee123 is offline
post #46 of 289 Old 06-12-2018, 07:18 AM
BassThatHz's Avatar
Liked: 4173
Most Excellent!
Now... videos of the excursion and fan noise and rew sweep, or it didn't happen... hehe!
Not sure about the 20k, but the FP14k is supposed to be more powerful, and my 21's and 24 can take -4db all day long on it. It's possible there is enough power to damage it if you try hard enough.
chrapladm, Jk7.2 and Pradeep2 like this.
post #47 of 289 Old 06-12-2018, 07:59 AM - Thread Starter
johnson636's Avatar
Liked: 672
When I get home, I'll properly set my gains and take voltage readings and rerun Audyssey. Now I have to figure out how to prevent my canned lights from popping out. I used "old work" lights for this particular room and the little tabs that holds them in secure keep popping out. I swear that never happened with the fp10k.
Jk7.2 and notfastenough like this.
post #48 of 289 Old 06-12-2018, 12:20 PM
Liked: 1261
Ive had triple pole breakers that fail to manually move from open to closed and vice versa right from the box - SquareD iirc. That was for datacenter work though.
Glad your story had a happy ending
Edited to ask: so you have 10 gauge wire to a nema tt30 outlet and running it as 240v 30a?
Pradeep2 is offline
post #49 of 289 Old 06-12-2018, 12:45 PM - Thread Starter
johnson636's Avatar
Liked: 672
Yes.
post #50 of 289 Old 06-12-2018, 03:27 PM - Thread Starter
johnson636's Avatar
Liked: 672
Victim!
Victim!
post #51 of 289 Old 06-12-2018, 05:35 PM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1313
Victim!
That's awesome
Sent from my SM-N950U using Tapatalk
hd0823 is offline
post #52 of 289 Old 06-12-2018, 07:18 PM - Thread Starter
johnson636's Avatar
Liked: 672
I've set my channel gains so that at 0db AVR each outputted 121v @40Hz 0db signal. According to the oscilloscope the output looked clean up until 148v...Clip led was lit up.
post #53 of 289 Old 06-12-2018, 08:04 PM
VegaMan's Avatar
Quoted: 102 Post(s)
Liked: 78
I've set my channel gains so that each outputed 121v @40Hz 0db signal. According to the oscilloscope the output looked clean up until 148v...Clip led was lit up.
into what kind of load?
VegaMan is offline
post #54 of 289 Old 06-12-2018, 08:16 PM - Thread Starter
johnson636's Avatar
Liked: 672
No load. I don't have any means of a dummy load and no way am I going to have my subs connected while do this
post #55 of 289 Old 06-12-2018, 08:36 PM
VegaMan's Avatar
Quoted: 102 Post(s)
Liked: 78
c'mon, wheres your sense of adventure?
johnson636, andyc56 and bebb like this.
VegaMan is offline
post #56 of 289 Old 06-13-2018, 04:57 AM - Thread Starter
johnson636's Avatar
Liked: 672
I think we have a winner!
Guys based on posts I've made in this thread alone, I received the following email:
Hi James,
Wish you have a nice day when you read my email. This is Dan from Sinbosen.
We have saw your comments about our FP20000Q on avsforum. We apologize to you for our mistake.
1. For my mistakes: I thought you need standard US plug, so we send 200V-240V amplifier with 30A standard US plug to you. We can provide another US plug (we call it industrial US plug), but I didn't confirm the plug picture to you. Sorry for the inconvenience.
(Please note that your amplifer working voltage is 200-240V, CAN NOT use at 90-130 V. If you want 110V, please contact us to change circuit)
2. For workmanship, it is silica gel on the transistor, which plays an insulating role. You can wipe them if you think it don't look nice. And our wokers will pay attention to workmanship.
3. We can make powerCON connector if you need.
Please contact me if there is any problem. Our enginner will slove it and we will be responsible for it.
Regards
Dan
Could be a keeper guys
Fabricator, dtsdig, Reddig and 2 others like this.
post #57 of 289 Old 06-13-2018, 05:26 AM
chrapladm's Avatar
Quoted: 1100 Post(s)
Liked: 445
Wow happy to see them communicating on here. Although it may not mean anything still happy to see. Now if I could just get someone to message me back I would be in need for a few amplifiers.
bebb likes this.
chrapladm is offline
post #58 of 289 Old 06-13-2018, 07:03 AM - Thread Starter
johnson636's Avatar
Liked: 672
They're sending me a 240v cord so that's a very good start. Also, after seeing how nuts we are around here when it comes to bass, it may give them added incentive to take care of us Also, since I've purchased the FP20k, a number of China manufactures have reached out to me with offerings after seeing this thread.
PS. I've asked XBS if they offer 18" and 24" subwoofers.
Reddig and chrapladm like this.
post #59 of 289 Old 06-13-2018, 07:26 AM
Liked: 1261
I guess my only question is clearly they've sent it with a 15A 120V plug, and not 30A as they say. Unless they mean the power cord itself is good for 240V 30A?
Pradeep2 is offline
post #60 of 289 Old 06-13-2018, 07:33 AM - Thread Starter
johnson636's Avatar
Liked: 672
They sent the wrong plug; the cable seems ok.
