What do we have here.........An FP20000Q - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 131Likes
post #61 of 289 Old 06-13-2018, 02:03 PM
BassThatHz's Avatar
Quoted: 3679 Post(s)
Liked: 4170
I got similar results on the Sanway 14k. About 155v rms no-load. Therefore the 20k has comparable (theoretical) burst power capabilities.
Reddig likes this.
BassThatHz is offline
post #62 of 289 Old 06-13-2018, 02:44 PM - Thread Starter
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 672
@147v there's no clipping. @148v clipping is present with a light shade of red. I was able to push the amp to 179v until I chickened out
BTW @BassThatHz will you please contact Dan Guo at XBS. They're bugging me about whether I know you. Tell him we don't have a FP7000. Do I know your real name.
Lady, no one knows his real name
VicTorious1 likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #63 of 289 Old 06-13-2018, 06:58 PM
Vince_B's Avatar
Quoted: 316 Post(s)
Liked: 209
What are you guys thoughts about heat management on the 20 vs the 14? Guessing it’s not advised to swap fans on these and so I’m wondering about 2x14k at a bit more money or the 20k with possibly more heat per rack unit.
I’ve read that the fans are noisy, but haven’t seen any comparisons to, say an inuke or something. Imagining that these are hovercraft class fan noise but?
Vince_B is offline
post #64 of 289 Old 06-13-2018, 07:05 PM - Thread Starter
johnson636's Avatar
Liked: 672
I've never owned a fp14k, so I can't speak on it. AFAIK, BTH will be the first to own both an fp14k and fp20k. As far as the fan noise comparison between the iNuke and the clones, it's not even close; clones are much, much louder.
post #65 of 289 Old 06-13-2018, 09:55 PM
BassThatHz's Avatar
Liked: 4170
The heat management on the 14k is very good. It rarely if ever gets above luke warm. But it's fans are twice as noisy as an inuke.
The inuke's are not very loud actually, they are about as loud as most projectors at idle.
With a fan mod they are very quiet as per vids on NotNyt's thread.
Under load the clone might actually be quieter because the fans rarely rev up past 10-50%.
The rails are probably 200V as per the cap values, but anything beyond clipping is unrealistic, you'll never reach that voltage with any load.
3850w rms @ 4ohm is 124v rms etc
The box should be here any day now...
bebb likes this.
post #66 of 289 Old 06-13-2018, 10:41 PM
acras13's Avatar
Quoted: 316 Post(s)
Liked: 292
For your remodel can lights popping out of the ceiling , the tabs should have holes in them where they lay against the can . With a little patience you can run self tapping screws through those into the housing to lock them in place .
johnson636 likes this.
Turn that $*!# UP!! --Beethoven
acras13 is offline
post #67 of 289 Old 06-14-2018, 06:55 AM - Thread Starter
johnson636's Avatar
Liked: 672
That's a great idea. I've since put duct tape over them and it seem to be working for now. I'll have to try your idea if the duct tape some how come loosen.
post #68 of 289 Old 06-16-2018, 01:02 PM - Thread Starter
johnson636's Avatar
Liked: 672
Now that I have the FP20k running the hs24's, that leaves me with 4 channels free on one of my FP10ks. My plan is to run 4 ported MBMs loaded with PA460 @4 ohms between 2 channels and 4 ported mofo 15 @ 4 ohms on the other two channels. The 4 mofo will be nearfield for my rear row of seats and the PA460 MBMs will be up front. That still leaves me with 2 channels free on the FP20k.
bebb likes this.
post #69 of 289 Old 06-16-2018, 01:52 PM
BassThatHz's Avatar
Liked: 4170
You might as well just have finished it off by saying: "Which I will add another 2 24's on." You know you want too! (and we know you will...)
Just do it!
-Nike
BTW: What LED have you got up to thus far in actual-use?
post #70 of 289 Old 06-16-2018, 01:59 PM - Thread Starter
johnson636's Avatar
Liked: 672
Just do it!
-Nike
No I'm not........Ok I want to
I can get two HS24's as they're currently on sale. But you really have me intrigued by the SAB24. I see they have a MOQ 1 option, but I'm not sure if it is the same one you have. And also, if they send me a dual 1 ohm then I'm screwed.
post #71 of 289 Old 06-16-2018, 09:04 PM
BassThatHz's Avatar
Liked: 4170
With both coils in series mine came out to be 3-ohm at 1-4hz and >5-ohms above 5hz, so their dual 1-ohm coils are not as "horrible a load" as it appears to be paper. (or my WT2 is broken... LOL! )
In any case, the 20k didn't turn off with 70v rms sinewave into their dual 1-ohm coils, sustained indefinitely.
post #72 of 289 Old 06-16-2018, 09:15 PM - Thread Starter
johnson636's Avatar
Liked: 672
Or I can take the $1800 I'd spend on 2 HS24s and purchase 20 more PA460s
BassThatHz and bebb like this.
post #73 of 289 Old 06-16-2018, 11:51 PM
BassThatHz's Avatar
Liked: 4170
That would be a wise choice me thinks!
Are you trying to clone my system or something?
First you bought the 20k the same day as me, blind risk, and now you want to add the zillion 460's that I also just recently added to my room to yours. I see a pattern here! (Not that copying me is bad per-se... perhaps minus the insanity though!)
If you do, you'll have lots of "overwhelming bass" at-least.
bebb likes this.
post #74 of 289 Old 06-17-2018, 12:16 AM
chrapladm's Avatar
Quoted: 1100 Post(s)
Liked: 445
Still havent gotten a response back from the SAB 24" MOQ 1 vendor. Because I looked at exploring this option and if it worked out I would try a pair out. Then add a large clone amp for fun.
chrapladm is offline
post #75 of 289 Old 06-17-2018, 03:16 AM
Quoted: 1012 Post(s)
Liked: 1261
Or 56 12" JBL CS1214s
stngray72 and bebb like this.
Pradeep2 is offline
post #76 of 289 Old 06-17-2018, 05:13 AM - Thread Starter
johnson636's Avatar
Liked: 672
Busted
Ok, 20 of these
https://www.ctsounds.com/collections...ts/tropo-18-d2
They're on sale
Seriously it's really just a coincidence. I had been pondering the thought of a FP20k for some time now. XBS was the first I've seen that offered paypal as an option. As far as the PA460, my plan would have been just to build them without ever mentioning it. It seems as they are not popular by some when it comes to building tons of them
post #77 of 289 Old 06-18-2018, 02:12 PM - Thread Starter
johnson636's Avatar
Liked: 672
Although I use a 30A 240V plug, XBS gets extra points for sending me this at no cost to me.
Canadian Bronco and Reddig like this.
post #78 of 289 Old 06-19-2018, 07:37 AM
Jason kiDD's Avatar
Quoted: 52 Post(s)
Liked: 35
Sad to say that's still not a valid 240 voltage plug.. Be careful...
Jason kiDD is offline
post #79 of 289 Old 06-19-2018, 07:54 AM - Thread Starter
johnson636's Avatar
Liked: 672
Be careful of what
post #80 of 289 Old 06-19-2018, 08:07 AM
Jason kiDD's Avatar
Quoted: 52 Post(s)
Liked: 35
That's a normal 15amp H/N/G plug.
if you need more information see website:
http://waterheatertimer.org/How-to-w...t-outlets.html
post #81 of 289 Old 06-19-2018, 09:05 AM
Steve Kuester's Avatar
Quoted: 181 Post(s)
Liked: 325
Yep. That looks like a normal 120V 15A plug.
I turn the sharpness on my TV all the way up, because that's how I like my picture... real sharp.
Jumping into DIY - My 893, Volt 6, and UM18(x4) build
Steve Kuester is offline
post #82 of 289 Old 06-19-2018, 11:16 AM - Thread Starter
johnson636's Avatar
Liked: 672
Again I ask, be careful of what The amps don't come with a 30a 240V plug. I knew that going in. The first thing I did was replace the plug that came with the amp with a 30a 240V plug. I really don't get what you two are saying
post #83 of 289 Old 06-19-2018, 01:34 PM
Quoted: 181 Post(s)
Liked: 325
I guess I was just trying to point out that they sent you an additional plug that won't work with your amp. You obviously know this already.
Based on the email they sent to you...
"Hi James,
1. For my mistakes: I thought you need standard US plug, so we send 200V-240V amplifier with 30A standard US plug to you. We can provide another US plug (we call it industrial US plug), but I didn't confirm the plug picture to you. Sorry for the inconvenience.
(Please note that your amplifer working voltage is 200-240V, CAN NOT use at 90-130 V. If you want 110V, please contact us to change circuit)..."
They are saying that your amp will not work with 120VAC, but then send you a 120VAC plug.
I just thought this needed to be pointed out for not just you, but anyone else who may follow in your footsteps.
No worries on my end. You know what you're doing. Enjoy your amp.
post #84 of 289 Old 06-19-2018, 01:53 PM
BassThatHz's Avatar
Liked: 4170
So you asked for a 30a 240v plug and they send another 120v 15a plug (for a 240v amp).
Classic!
post #85 of 289 Old 06-19-2018, 02:03 PM - Thread Starter
johnson636's Avatar
Liked: 672
Good point. As for me, I said it in another thread, If the only concern with the amp is whether I receive the correct plug, then I'm winning
post #86 of 289 Old 06-19-2018, 02:04 PM - Thread Starter
johnson636's Avatar
Liked: 672
Classic!
Well this was your fault in the first place
post #87 of 289 Old 06-19-2018, 07:44 PM
chrapladm's Avatar
Liked: 445
So what are the final outcomes of this amp. Have we pushed it hard at all on four channels?
I wonder if one of these amps is ordered with the powercon option and 240vac it will actually be that. Not sure about my subs yet but may have someone I can get a sample from. Maybe ..
post #88 of 289 Old 06-19-2018, 08:08 PM - Thread Starter
johnson636's Avatar
Liked: 672
I haven't, as I don't have enough subs right now.
They have that option, but I'd recommend you to be relentless in your effort to get your point across to them.
post #89 of 289 Old 06-19-2018, 08:18 PM
BBLV's Avatar
Quoted: 97 Post(s)
Liked: 88
That's the exact config I plan on ordering, but won't be for a little bit so I'll sit back and enjoy watching you guinea pigs
BBLV is offline
post #90 of 289 Old 06-19-2018, 08:28 PM
chrapladm's Avatar
Liked: 445
Well I still have to get my subs first and take a trip to US. After that I will get back to ordering stuff I dont really need.
