What do we have here.........An FP20000Q - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 131Likes
post #91 of 289 Old 06-20-2018, 02:28 AM
Quoted: 1005 Post(s)
Liked: 1253
Originally Posted by BBLV View Post
That's the exact config I plan on ordering, but won't be for a little bit so I'll sit back and enjoy watching you guinea pigs
I would suggest sendng them a picture of a cable with powercon 32A on one end and nema 6-30 or whatever plug you are going with on the other.
Pradeep2 is offline
post #92 of 289 Old 08-09-2018, 05:11 PM
notnyt's Avatar
Quoted: 3725 Post(s)
Liked: 3691
notnyt is offline
post #93 of 289 Old 08-09-2018, 08:04 PM - Thread Starter
johnson636's Avatar
Quoted: 1134 Post(s)
Liked: 654
Originally Posted by johnson636 View Post
Gave her a quick run and the 24s were really, really, moving to the point I had to back down in a hurry. The amp didn't clip and had more to give, but I'm not going there. I've never heard a FP14k before, but hands down it's more powerful than my FP10ks
Don't believe me, here it is from the man himself:
Originally Posted by notnyt View Post
XBS FP22000Q
This amp is serious business.
It can output 4kw per channel into 4 ohms. Overall power output is limited to 8kw. This is a lot of power, likely too much for any circuit this amp will ever be on. It will easily trip a 30a breaker if pushed to these levels.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #94 of 289 Old 08-09-2018, 08:31 PM - Thread Starter
johnson636's Avatar
Liked: 654
Some time next year I'll add 2 more 24's or 2 HST18's to the 2 available channels. After running the 24's on this bad boy was the first time I've been concerned about them. I may have to run a HPF now
post #95 of 289 Old 08-10-2018, 07:27 PM
BassThatHz's Avatar
Quoted: 3657 Post(s)
Liked: 4142
Or even melting the voice coil...
If using channel 1 and 3, the power supply is good for 5.0-5.2kW x2, more powerful than the amp-boards...
For the 22k with the capacitors, that jumps it up another +7.8kW to 17.8kW burst-power...
After the caps are drained I would imagine that it will drop down to 2.5kW x4 long-term, until something trips, overheats or explodes...
To sustain 10kW RMS you'd need a 50a 240V breaker, but the 240V model is only fused at 30A which is 3.6kW x2 or 1.8kW x4 (assuming 100% efficiency.)
BassThatHz is offline
post #96 of 289 Old 08-10-2018, 07:54 PM - Thread Starter
johnson636's Avatar
Liked: 654
Only fused to 30A If 1.8kw-2kw x4 sustained is not enough, then you need healing I'm not looking to melt any of my sub's coils
post #97 of 289 Old 09-13-2018, 03:59 AM
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
Busted
Ok, 20 of these
https://www.ctsounds.com/collections...ts/tropo-18-d2
They're on sale
Seriously it's really just a coincidence. I had been pondering the thought of a FP20k for some time now. XBS was the first I've seen that offered paypal as an option. As far as the PA460, my plan would have been just to build them without ever mentioning it. It seems as they are not popular by some when it comes to building tons of them
Just clicked hyperlink and CT sounds on sale one more day based on the web page. Glancing at specs looks like a decent buy. As good as a Dayton PA460? I love my 4 PAs!
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #98 of 289 Old 09-13-2018, 04:23 AM - Thread Starter
johnson636's Avatar
Liked: 654
If the specs are to be trusted, the Tropo 18 has twice the xmax of the PA460. I've debated on whether to purchase 4 more PA460's or try 4 of these Tropo 18.
post #99 of 289 Old 09-13-2018, 07:21 AM
BassThatHz's Avatar
Liked: 4142
When it comes to mid-bass, it is better to have more cone-area and coil-area than excursion.
Box modelling software doesn't take into account driver THD or thermal compression.
The 16 460's that I run are rated for 8kW continuous... there is a lot of magnets and coils and cone-area there,
and thanks to the fact that they are cheap, it didn't cost much either...
The only downside is more box and space consumed. You can only make a room get so loud before running into limits.
Pradeep2 and bebb like this.
post #100 of 289 Old 09-13-2018, 08:05 AM
MKtheater's Avatar
Quoted: 2326 Post(s)
Liked: 2272
I have the dayton pro 10s and 12s and they are fantastic. They have better clarity in the midrange(up to 2000hz), than most speakers I have owned! I am thinking of building an array of them for mains.
bebb likes this.
Audio Design Associates/Outlaw
Speakerpower SP1-4000
subs-Re audio XXX 18 IB(LT).
DIY speakers-mktheater-S10/S12s
MKtheater is offline
post #101 of 289 Old 09-13-2018, 04:16 PM
Quoted: 66 Post(s)
Liked: 50
Just an array of 10's for mains? No tweeter at all? Using eight 10 inch speakers for treble sounds like a BassThatHz idea 😀
bebb likes this.
Acrjoey is offline
post #102 of 289 Old 09-13-2018, 04:43 PM - Thread Starter
johnson636's Avatar
Liked: 654
I plan to run dual PA460s in my SC-2150 LCR
post #103 of 289 Old 09-27-2018, 07:32 AM - Thread Starter
johnson636's Avatar
Liked: 654
Welcome to the club @hd0823 I think you made the right decision by selling the 110v version and buying two 220v version. Your room will be absolutely insane with your amp, woofer combo.
post #104 of 289 Old 09-27-2018, 07:43 AM
hd0823's Avatar
Quoted: 690 Post(s)
Liked: 1264
Yeah it's going to be so much less work also after talking to you and figuring out everything just change outlets and plugs cant wait to fire this up in a couple months and let a wall of bass hit me lol
Sent from my SM-N950U using Tapatalk
johnson636 and Jk7.2 like this.
hd0823 is online now
post #105 of 289 Old 09-27-2018, 05:25 PM - Thread Starter
johnson636's Avatar
Liked: 654
@Jk7.2 Welcome to the club. May you beat the hell out of those HST18s
Jk7.2 likes this.
post #106 of 289 Old 09-27-2018, 05:59 PM
hd0823's Avatar
Quoted: 690 Post(s)
Liked: 1264
I was there last weekend the amps a great pair with the hst 18s. It really gives them the power they want.
post #107 of 289 Old 09-27-2018, 06:18 PM - Thread Starter
johnson636's Avatar
Liked: 654
I may have missed it, but what breaker is the amp connected to?
post #108 of 289 Old 09-27-2018, 06:58 PM
hd0823's Avatar
Quoted: 690 Post(s)
Liked: 1264
He has a 30 amp 110v
post #109 of 289 Old 09-28-2018, 04:44 AM
Jk7.2's Avatar
Quoted: 1396 Post(s)
Liked: 2548
It’s 30A 120
I have two of those dedicated lines.
Jk7.2 is online now
post #110 of 289 Old 09-28-2018, 05:46 AM
VicTorious1's Avatar
Quoted: 580 Post(s)
Liked: 667
Originally Posted by Jk7.2 View Post
It’s 30A 120
Isn't that 110 the same thing as 120 for all intents and purposes? More specifically, isn't 120 just the nominal voltage for 110? US is 120v but people still refer to the older 110v standard.
VicTorious1 is offline
post #111 of 289 Old 09-28-2018, 05:50 AM - Thread Starter
johnson636's Avatar
Liked: 654
It’s 30A 120
Sweet. You now have enough power to bottom all four of those drivers.
post #112 of 289 Old 09-28-2018, 05:51 AM - Thread Starter
johnson636's Avatar
Liked: 654
Correct. You have any plans to do the eng399 mod on your Titans?
post #113 of 289 Old 09-28-2018, 06:12 AM
Quoted: 580 Post(s)
Liked: 667
Contemplating it. I've switched my front stage similar to Jared's old setup, so I'd have to build four new boxes for the front. I'm waiting on T/S specs for some Fi HT subs, which I may swap out for my DS4s. If the specs require new boxes, then I'll likely go a similar route to Jared and Mike with Titan towers. I'll see how the DS4s and my four other subs sound this weekend when I dial in the FP22kQ using my minidsp (which got delivered today).
Jk7.2 likes this.
post #114 of 289 Old 09-28-2018, 06:54 AM - Thread Starter
johnson636's Avatar
Liked: 654
Wow man, I didn't know you took the leap. Welcome to the club
post #115 of 289 Old 09-28-2018, 07:36 AM
MKtheater's Avatar
Liked: 2272
No, tweeter array as well.
post #116 of 289 Old 10-08-2018, 05:22 PM
hd0823's Avatar
Quoted: 690 Post(s)
Liked: 1264
I'm sure this has been talked about but what plug did you put on the amp.
post #117 of 289 Old 10-08-2018, 05:47 PM - Thread Starter
johnson636's Avatar
Liked: 654
Here you go
https://www.homedepot.com/p/Leviton-...-00T/202077657
post #118 of 289 Old 10-08-2018, 05:58 PM
hd0823's Avatar
Quoted: 690 Post(s)
Liked: 1264
Thanks man did you get the wall receptacle there to. All I could find where like the extension cord style ends
post #119 of 289 Old 10-08-2018, 06:00 PM - Thread Starter
johnson636's Avatar
Liked: 654
Sure did.
post #120 of 289 Old 10-08-2018, 06:29 PM
hd0823's Avatar
Quoted: 690 Post(s)
Liked: 1264
Sure did.
Can you send the link the guy kept trying to have me get the twist locking I'm running 2 new lines doing 30amp that way I still have my 3 120v lines for other things
