What do we have here.........An FP20000Q - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 131Likes
post #121 of 289 Old 10-08-2018, 07:05 PM - Thread Starter
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 671
Originally Posted by hd0823 View Post
Can you send the link the guy kept trying to have me get the twist locking I'm running 2 new lines doing 30amp that way I still have my 3 120v lines for other things
Sent from my SM-N950U using Tapatalk
Here you go. It should say 125v/250v I believe.
https://www.homedepot.com/p/Leviton-...-S00/300324450
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #122 of 289 Old 10-09-2018, 05:36 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Thanks man I'm going to pick up everything Today and run it tonight. Grabbed 250ft of 10/2 yesterday. Needed 125ft but from 100ft to 250ft roll it was only a 30 dollar difference
hd0823 is offline
post #123 of 289 Old 10-09-2018, 05:48 AM
Jk7.2's Avatar
Quoted: 1408 Post(s)
Liked: 2571
Didn’t you get 10/3? Two hots and a neutral?
Jk7.2 is offline
post #124 of 289 Old 10-09-2018, 07:00 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
10/2 240v dosent need a neutral
hd0823 is offline
post #125 of 289 Old 10-09-2018, 07:12 AM
Jk7.2's Avatar
Liked: 2571
Super interesting
Jk7.2 is offline
post #126 of 289 Old 10-09-2018, 07:42 AM - Thread Starter
johnson636's Avatar
Liked: 671
Cool man. Looks like you're well on your way Let us know how it goes.
post #127 of 289 Old 10-11-2018, 09:57 AM - Thread Starter
johnson636's Avatar
Liked: 671
Any updates?
post #128 of 289 Old 10-11-2018, 11:06 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Originally Posted by johnson636 View Post
Any updates?
So I got the receptacles in the wall and wired up wire ran back to behind my baffle wall but had to get back to work on my wifes library. Where about to have our first kid end of next month and that was the agreement if I got my theater she got her library and I'm suppose to get it done before I do more theater upgrades lol. Probally next week or so I'll get it wired up in the breaker box. I need to order a minidsp pronto. The tall opening is where the 44u middle Atlantic rack is going and the shorter one is a 200 bottle wine cooler
hd0823 is offline
post #129 of 289 Old 10-11-2018, 02:06 PM - Thread Starter
johnson636's Avatar
Liked: 671
Looks good man
First kid together or first kid period?
post #130 of 289 Old 10-14-2018, 02:18 PM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Looks good man
First kid period. Been together 6 years. We just figured it wasnt going to happen and than it did out of the blue.
Jk7.2, Pradeep2 and bebb like this.
hd0823 is offline
post #131 of 289 Old 10-14-2018, 03:13 PM
Jk7.2's Avatar
Liked: 2571
Jeremy I can’t wait to see if you have the same issues with amp hiss and hum I’m having. It’s a royal pita dealing with. Only one amp hooked up and it’s all good. Hook up both and it’s a mess.
Jk7.2 is offline
post #132 of 289 Old 10-14-2018, 04:08 PM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
I thought you pretty much eliminated it
hd0823 is offline
post #133 of 289 Old 10-14-2018, 04:10 PM
Jk7.2's Avatar
Liked: 2571
So did I. It’s still there and that drives me crazy.
Jk7.2 is offline
post #134 of 289 Old 10-17-2018, 04:30 PM
Jk7.2's Avatar
Liked: 2571
So now that I’m getting the whole ground lift thing done(it completely silences the amps)
I’m wondering, are there red clip lights on these amps? If so, I’ve pushed them and not seen a red light yet. Just wondering when clipping actually starts. Seems the front panel is marked -4 then clip.
Jk7.2 is offline
post #135 of 289 Old 10-17-2018, 04:38 PM - Thread Starter
johnson636's Avatar
Liked: 671
Mine does. Now that my gain structure is properly set, I don't often get to -4. The only time I've ever notice clipping is when I left the added low-shelf filters applied in the mini. The extra low-shelf are for the movies that have neutered bass.
post #136 of 289 Old 10-17-2018, 04:41 PM
Jk7.2's Avatar
Liked: 2571
Cool. I guess I’ll push these harder 🧐 I just gotta see the red. I’m feeling bad for my house with all this bass. And I know the amps can do more.
Jk7.2 is offline
post #137 of 289 Old 10-18-2018, 06:21 PM
BassThatHz's Avatar
Quoted: 3678 Post(s)
Liked: 4170
No humming or hiss here with my 9 amplifiers.
I use real XLR, not fake XLR, and all of my stuff is well grounded to one spot, and my house is optical, not coax; all of which helps a lot...
You must have a grounding issue somewhere, could be in the house wiring or one or more bad amps, or some other source entirely (cable box connected to tv/projector/avr etc...)
The clones turn their red clip lights on during boot.
If you don't see them, then there is something massively wrong (i.e. you might be clipping it and don't know it.)
I've only clipped 1 of the 24 xbs channels, the one powering my SAB-24 @ 2-ohm, and that was only by sending it a continuous sinewave at almost full excursion. It did light up as expected.
Keep in mind that -infinity to -4db is the first 40% of the power from these amplifiers, the remaining 60% occurs between the -4db and VPL/CPL LED (which ever comes first..)
5th gear is brutal isn't it?
The first 1600watts happens up-to the -4db LED, and the remaining 2400watts happens on the -4db LED
or double that, for 2-ohm or bridge-mode
It has a BIG 5th gear...
Congratulations: you've sent the first 1600watts to it... now send another 2400watts to it!!! Why does it smell like burnt-coil in here?
The clone amps are sort of deceiving that way, you think you might be nearly clipping it, but you might not be...
That said: most pro amps only have a -6db and clip or -3db and clip, so that is pretty common actually...
The CPL and VPL are both clip LED's. the CPL is yellow/orange if I recall. Current vs Voltage.
blister64 and biga6761 like this.
BassThatHz is offline
post #138 of 289 Old 10-18-2018, 06:34 PM
Jk7.2's Avatar
Liked: 2571
My hum/noise is completely solved.
All I did was snip the #1 pin xlr wire and isolated the second amp. The 1st amp is still hooked up as it was. But now they are both dead silent. No noise, hiss, hum at all. I’ll have to actually look at the amp when they startup. I just don’t remember seeing a red led. I’m sure it’s there. Yeah these are very powerful amps. My screen and screen wall panels barely stay in place now during big bass. The screen gets super wavy. Lol. Still trying to find the systems limits and where I like it all tuned. I love the amps though.
Jk7.2 is offline
post #139 of 289 Old 10-19-2018, 07:31 AM
corradizo's Avatar
Quoted: 1524 Post(s)
Liked: 1580
:-) my screen does this twisty thing at full power like it's bunching up with just the two 21DS. Its most prevalent during the John wick 2 cave shootout scene. When he moves to the shotgun the real fun begins! It's pretty fun.
Gorilla Killa likes this.
corradizo is online now
post #140 of 289 Old 10-19-2018, 09:16 AM
BassThatHz's Avatar
Liked: 4170
Yeah these are very powerful amps. Still trying to find the systems limits and where I like it all tuned. I love the amps though.
If you ever need even more power... there is always a bridged 14k per cone!!! 4kW vs 14kW
post #141 of 289 Old 10-19-2018, 09:17 AM
Jk7.2's Avatar
Liked: 2571
Good idea.
Jk7.2 is offline
post #142 of 289 Old 10-19-2018, 10:00 AM
MKtheater's Avatar
Quoted: 2366 Post(s)
Liked: 2316
Yeah, but that 14k will last milliseconds, hardly useful.
Audio Design Associates/Outlaw
Speakerpower SP1-4000
subs-Re audio XXX 18 IB(LT).
DIY speakers-mktheater-S10/S12s
MKtheater is online now
post #143 of 289 Old 10-19-2018, 10:01 AM
MKtheater's Avatar
Liked: 2316
Oh, I think I am buying a 20k to try out. Link?
post #144 of 289 Old 10-21-2018, 05:52 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
http://m.sinbosen.com
hd0823 is offline
post #145 of 289 Old 10-22-2018, 06:06 PM
BassThatHz's Avatar
Liked: 4170
That depends.
But in any case, in that configuration it STILL HAS more-than double the continuous power of a single channel of a 10k or 14k or 20k.
(and a single channel of a 14k is no slouch to start with, so there you have it...)
post #146 of 289 Old 10-23-2018, 12:41 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3699
That depends.
uhm... wat?
show your math, rofl.
notnyt is offline
post #147 of 289 Old 10-23-2018, 12:59 PM
MKtheater's Avatar
Liked: 2316
Yeah, I am not technical with this stuff, I leave that for the guys like Notnyt. I just try many things for myself based on their work. That said I am pretty sure the bridged Sanway 14k and Smith 14k will do 4800 watts for 2 seconds and then 3800 watts, something like that. That is good stuff but 14k burst will not be useful in real life except for not clipping with a quick transient. At this stage of the game we should be building systems that won’t need a 14k millisecond burst. I would concentrate on the continuous power. The clones have great power, but with great power comes with great responsibility.
Reddig and Pradeep2 like this.
post #148 of 289 Old 10-23-2018, 02:02 PM
notnyt's Avatar
Liked: 3699
The 14k has 3-4db burst potential even at 20hz. That's still pretty nice.
notnyt is offline
post #149 of 289 Old 10-23-2018, 04:11 PM
MKtheater's Avatar
Liked: 2316
I agree, but calling it a 14k watt amp is misleading as it lasts very, very short, still very good protection as the other amps don’t burst like that. BUT, the other amps(speakerpower) have built in protection to begin with. I loved my clones and still might buy the 20k when I add two more XXX-18s. 2kx4 is pretty awesome in one package for the price. The price difference is pretty large, two of my sp1-4000 for $2000, triggers, warranty, protection, etc or one clone for $750 and without features. Hmmm.
post #150 of 289 Old 10-23-2018, 06:25 PM
BassThatHz's Avatar
Liked: 4170
Originally Posted by notnyt View Post
uhm... wat?
Doing math is useless. But I can "try" to take the numbers right off your own measurement thread,
although you never tested the sustained figures for stereo 4-ohm vs bridge 4-ohm on the same model of fp14k (or if you did, you never posted it. i.e. for the 2-ohm stable one obviously.)
You only posted the burst figures, from the older model vs the newer model.
So that's all we have to go off of I guess...
I just put one of my sanway fp14000s on the bench, the old version that isn't stable at 2 ohms.
(4.4) ohms at 40hz
With two channels running 116vrms/6kw
Your posts aren't clear if that's 6kW or 3kW per channel. So again we have to make additional assumptions.
burst numbers for the sanway fp14000 bridged into 4 (4.4) ohms
If it's 2x 3kW burst, then 13.1kW burst is more than double per cone.
If it's 2x 6kW burst, then 13.1kW burst is more than double per cone, still...
I'd imagine sustained won't be too much different, as far as making double power at least.
You never mentioned what the sustained power of the 2-ohm stable version was/is.
But based off the old one we could assume it's likely to be 2x [email protected] and 1x [email protected] based on your comments about sustained power of the old version in stereo mode.
You'd probably know more about the precise-figures, after all, you're the one who tested like 4 different variants of the fp14k.
Had you posted the burst and sustained powers for all variants, we wouldn't have to speculate or guess what the sustained power of the 2-ohm stable version is in stereo 4ohm vs 4ohm bridged. So: do tell...
Until then, I will continue to assume bridge-mode is "nearly double (or better...)" than stereo mode.
and additionally that: the bridge-mode of a 14k will "easily out-do" a single mono channel of a 10k, 20k or 14k LOL
I can't see how double the transistors into half the ohms won't produce WAY more power (for the models rated for running in that mode, I might add...)
