What do we have here.........An FP20000Q - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 131Likes
post #151 of 289 Old 10-23-2018, 06:54 PM
notnyt's Avatar
Quoted: 3731 Post(s)
Liked: 3699
Originally Posted by BassThatHz View Post
Doing math is useless. But I can "try" to take the numbers right off your own measurement thread,
although you never tested the sustained figures for stereo 4-ohm vs bridge 4-ohm on the same model of fp14k (or if you did, you never posted it. i.e. for the 2-ohm stable one obviously.)
You only posted the burst figures, from the older model vs the newer model.
So that's all we have to go off of I guess...
Your posts aren't clear if that's 6kW or 3kW per channel. So again we have to make additional assumptions.
If it's 2x 3kW burst, then 13.1kW burst is more than double per cone.
If it's 2x 6kW burst, then 13.1kW burst is more than double per cone, still...
I'd imagine sustained won't be too much different, as far as making double power at least.
You never mentioned what the sustained power of the 2-ohm stable version was/is.
But based off the old one we could assume it's likely to be 2x [email protected] and 1x [email protected] based on your comments about sustained power of the old version in stereo mode.
You'd probably know more about the precise-figures, after all, you're the one who tested like 4 different variants of the fp14k.
Had you posted the burst and sustained powers for all variants, we wouldn't have to speculate or guess what the sustained power of the 2-ohm stable version is in stereo 4ohm vs 4ohm bridged. So: do tell...
Until then, I will continue to assume bridge-mode is "nearly double (or better...)" than stereo mode.
and additionally that: the bridge-mode of a 14k will "easily out-do" a single mono channel of a 10k, 20k or 14k LOL
I can't see how double the transistors into half the ohms won't produce WAY more power (for the models rated for running in that mode, I might add...)
Your problem is you make assumptions too readily and then go and post them as if they're fact. If you can't easily show the math, something is amiss.
You claimed the FP14k in bridged mode would sustain double what a single channel on the FP10K, 14K, or 20K could output. That's just not accurate. I don't even know why you're posting burst numbers as it's irrelevant, your claim was for "continuous" power.
The FP14K can sustain ~4kw out of a single channel into 4 ohms. The main limitation is the power supply. These amp modules are outputting between 180-190Vp. Going to bridged, your sustained numbers aren't going to vary by more than a fraction of a decibel.
The FP20K can do this as well.
I haven't tested the FP10K, so I can't comment on that, but for 2 out of 3, your statement was false.
notnyt is offline
post #152 of 289 Old 10-23-2018, 09:13 PM
BassThatHz's Avatar
Quoted: 3678 Post(s)
Liked: 4170
Ah yes, you are correct. I forgot how crippling the power supplies are in these things for continuous figures.
Also, the fuse and breaker wouldn't allow much over 3.6kW for very long without blowing or popping anyways, and then subtract another 5-30% for inefficiencies for the output side.
Even though the 20k and 22k has two power supplies and double the fuse values, that won't help get any additional continuous power to a single cone, only a pair.
My brain was clearly on auto-pilot here.
BassThatHz is offline
post #153 of 289 Old 10-28-2018, 06:13 AM
Jk7.2's Avatar
Quoted: 1408 Post(s)
Liked: 2571
Been using my amps for a while now.....
I just realized I have an issue. During a show off session I went to check on the amps, and I’ve got a channel showing clipping when it’s not even showing green lights up to the clip light. The red LED flashes before its own channel, or any of the other channels show close to full power.
It’s not the driver:
I tried several on this channel and other channels, the problem stays with the amp channel
It’s not the input:
I’ve tried several of the other inputs into this and other channels, the problem stays with this channel.
It’s not the dip switches:
Dip switches are set correctly (or at least all channels are the same, so there shouldn’t be any difference on this channel)
So bad amp channel? It must be. Funny I have this problem after I asked is there red LEDs on these amps? Well, yup. I see for myself there is!
Jk7.2 is offline
post #154 of 289 Old 10-28-2018, 06:41 AM - Thread Starter
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 671
What do you have the VPL limiter set to? Have you tried changing the VPL dip switches to a different setting? Does it affect output? 4 ohm load? I understand you may have the limiters set the same for all channels, these are just common troubleshooting questions.
PS Man, you've had some bad luck with amps since switching from the Nukes
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #155 of 289 Old 10-28-2018, 06:43 AM
Jk7.2's Avatar
Liked: 2571
Yes 4 ohm load, the sub connected to the funky channel sounded distorted and crackely, as far as the limiters, I never set them different from factory setting.
Jk7.2 is offline
post #156 of 289 Old 10-28-2018, 07:31 AM
Jk7.2's Avatar
Liked: 2571
Is it me? It must just be me. Lol
Jk7.2 is offline
post #157 of 289 Old 10-28-2018, 07:55 AM - Thread Starter
johnson636's Avatar
Liked: 671
On the amp with the bad channel, are the same subs connected and receiving the same signal? I ask because according to the LEDs on the bottom amp, all four channels seem to be outputting the same, but the top amp's LEDs seem to show the four channels are not outputting at the same level. Is this on purpose?
post #158 of 289 Old 10-28-2018, 07:57 AM
Jk7.2's Avatar
Liked: 2571
Yes it’s on purpose. The top two channels of that amp are the nearfields. So they don’t need as much power. But the bottom two channels are the rears. They should be outputting close to the same as the front four subs, which are driven by the bottom amp.
Now as part of this issue, channel C and D should be exactly the same output levels, as the input signal is split from the same source into them. Obviously there’s an issue. I’ve tried different splitters, different sources, and so on. The problem is always there, always on channel C, and even at very low volume levels. The clip LED will light even before any of the green LEDs light up.
Jeremy has reached out to xbs, (he’s the one who bought these) and I’m expecting them to send me a replacement output board for me to swap. I’m very sure that will solve this issue.
Edit:
Sure enough they are sending me a new board. I’ll get it replaced with some pics and post the results.
Jk7.2 is offline
post #159 of 289 Old 10-29-2018, 07:05 AM
Jason kiDD's Avatar
Quoted: 52 Post(s)
Liked: 35
Can you try and switch the subs on channel C/D.. If the light follows the switch then its a wiring problem between amp and actual speaker.. If it stays the same then there maybe an internal problem with that one channel..
Jason kiDD is offline
post #160 of 289 Old 10-29-2018, 07:07 AM
Jk7.2's Avatar
Liked: 2571
Yep. Did that. The problem stays with the channel swapping the output and or input. I have a replacement channel C board coming. Pretty happy with the customer service. Let’s hope it fixes the problem!
Jk7.2 is offline
post #161 of 289 Old 10-29-2018, 07:08 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
He did this problem stayed with channel c. Xbs did a great job with standing behind there products and have a new channel c board on the way to him allready
Sent from my SM-N950U using Tapatalk
hd0823 is online now
post #162 of 289 Old 10-29-2018, 07:08 AM - Thread Starter
johnson636's Avatar
Liked: 671
Free of charge?
post #163 of 289 Old 10-29-2018, 07:09 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Lol you beat me you must have posted seconds before me
Jk7.2 likes this.
post #164 of 289 Old 10-29-2018, 07:09 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Free of charge?
The board was free shipping 24 bucks so not bad
post #165 of 289 Old 10-29-2018, 07:09 AM
Jk7.2's Avatar
Liked: 2571
Free of charge?
I paid 24 for shipping.
Jk7.2 is offline
post #166 of 289 Old 10-29-2018, 07:09 AM
Jk7.2's Avatar
Liked: 2571
Ok ok, now you beat me.
Jk7.2 is offline
post #167 of 289 Old 10-29-2018, 07:13 AM - Thread Starter
johnson636's Avatar
Liked: 671
That's just great. I'll take that all day
post #168 of 289 Old 10-29-2018, 07:15 AM
Jason kiDD's Avatar
Quoted: 52 Post(s)
Liked: 35
Sorry must have missed it.. As a last fluke I would change all the dip switches on channel C. Put them all the way up and then back all the way down again. With the amp turned off of course..
post #169 of 289 Old 10-29-2018, 07:16 AM
Jk7.2's Avatar
Liked: 2571
I did that too. I ran the amp in almost every configuration
Jk7.2 is offline
post #170 of 289 Old 10-29-2018, 07:18 AM
Jason kiDD's Avatar
Quoted: 52 Post(s)
Liked: 35
Then you have covered all the bases... lol Good luck with the channel swap. Stay far away from caps as you are already know..
post #171 of 289 Old 10-29-2018, 07:19 AM
Jk7.2's Avatar
Liked: 2571
I swapped a board in a 14000 and it was very easy. I’ll be careful
Thanks for the ideas
Jk7.2 is offline
post #172 of 289 Old 10-29-2018, 07:36 AM
dtsdig's Avatar
Quoted: 1124 Post(s)
Liked: 1386
My hum/noise is completely solved.
All I did was snip the #1 pin xlr wire and isolated the second amp. The 1st amp is still hooked up as it was. But now they are both dead silent. No noise, hiss, hum at all. I’ll have to actually look at the amp when they startup. I just don’t remember seeing a red led. I’m sure it’s there. Yeah these are very powerful amps. My screen and screen wall panels barely stay in place now during big bass. The screen gets super wavy. Lol. Still trying to find the systems limits and where I like it all tuned. I love the amps though.
I feel bad for not having mentioned this on your thread weeks ago. When I moved to my Yamaha P7000S amps, I had a terrible ground hum. After researching, I had to do the same thing to the XLR cables I was using. After that, they were dead silent. I'm glad you got it figured out!
dtsdig is offline
post #173 of 289 Old 10-29-2018, 07:37 AM
Jk7.2's Avatar
Liked: 2571
Ha, I’m glad too! I wish I didn’t have to use the isolation transformers though
Jk7.2 is offline
post #174 of 289 Old 10-30-2018, 05:12 PM
BassThatHz's Avatar
Liked: 4170
I've seen your excursion videos... it's definitely you!
The good news is that if you double the number of subs and amps, you can reach the same spl as you have now but with only 1/4 of the amp stress per channel, and correspondingly less excursion and heat...
post #175 of 289 Old 10-31-2018, 03:54 AM
Jk7.2's Avatar
Liked: 2571
Sheesh I thought 8 18’s would be enough. I will have the new board tomorrow.
Jk7.2 is offline
post #176 of 289 Old 10-31-2018, 06:22 AM
VicTorious1's Avatar
Quoted: 580 Post(s)
Liked: 668
Is anything ever enough?
Pradeep2 likes this.
VicTorious1 is offline
post #177 of 289 Old 10-31-2018, 03:39 PM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Do it 16 hsts
post #178 of 289 Old 10-31-2018, 03:54 PM
Quoted: 1012 Post(s)
Liked: 1261
Its a good start
Wasnt there someone that was going with 8 hst up front and 8 in the back and he got the 8 front ones done and said yup thats enough?
Sent from my SM-N920V using Tapatalk
Pradeep2 is offline
post #179 of 289 Old 10-31-2018, 04:35 PM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Originally Posted by Pradeep2 View Post
Its a good start
There is someone with 16 but there sealed I believe it was the white oaks theater
post #180 of 289 Old 10-31-2018, 04:37 PM
Jk7.2's Avatar
Liked: 2571
Come on guys. 8 is enough. My house and neighbor situation would have to be different to add.
And I definitely would.
8 is a good start. Never ending
VicTorious1 and Pradeep2 like this.
Jk7.2 is offline
