What do we have here.........An FP20000Q - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 131Likes
post #211 of 289 Old 11-09-2018, 08:59 PM
Quoted: 205 Post(s)
Liked: 203
Originally Posted by BassThatHz View Post
FYI: The 20k has twice the RMS power of the 14k. The 14k has 1 PSU, the 20k has 2 (one for ch 1-2, and another for ch 3-4).
That's why the 20k requires a 60a breaker, and the 14k only requires a 30a breaker.
Are you talking a 60a breaker on 120v? Or 240v?
Someone above said a 30a on 240v should be ok for the 20k. Just wanted to make sure before I go buy wiring tomorrow haha.
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva LPA-1 (Currently Fried) | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Dayton Ultimax 15 | Crown XPS1000
Living Room Duty- DIY Swope TMWW LCR
Currently Building- (3) Stereo Integrity HS-24 mkiii's
blister64 is offline
post #212 of 289 Old 11-09-2018, 09:19 PM
EndersShadow's Avatar
Quoted: 1171 Post(s)
Liked: 1429
If it is a dedicated breaker you could do 240V 20A. You just need a 240V wallsocket and breaker, and 240V custom plug on the clone. (<$100 at walmart or any hardware store...)
[and buy the 240V clone of course!]
120V is 1 hot (black) +120V, a ground (copper/green) 0V, and a neutral (white) 0V.
240V is 1 hot (black) +120V, a ground (copper/green) 0V, and a 2nd hot (white or red) -120V.
At least in USA and Canada it is...
"Technically" only a certified electrician should be doing the install.
Just make sure you have the mains-breaker turned off before working on the inside of the service panel.
For the same AWG of wire: 240V will provide 2x the watts.
All romex is rated for like 400-600v, so you're all-good there.
The breaker size MUST be the same value, you can't increase it.
The breaker protects the wire from melting, and thus indirectly protects the house, it doesn't protect the appliance nor the humans. Wires are current-limited, not voltage-limited.
The 240V wallsocket ensures Darwin's don't plug 120V appliances into them, for obvious fire/safety reasons.
(To be fair: Generally... you can't see/taste/smell radiation, carbon monoxide nor electricity. )
True but still fan noise... don’t have much if any with the XLS x 2 and EP4k
blister64 likes this.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #213 of 289 Old 11-09-2018, 09:22 PM
Liked: 1429
Also in my case I’m only driving multiples of the CS1214, so not crazy Xmas or Large drivers.
In theory I could even maybe get buy with a NX (whichever is the 4 channel version).
post #214 of 289 Old 11-10-2018, 08:11 AM - Thread Starter
johnson636's Avatar
Quoted: 1122 Post(s)
Liked: 653
Agreed. If the absence of fan noise is what you seek, then stay away from any clone.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #215 of 289 Old 11-10-2018, 08:28 AM
Liked: 1429
Yup, thats pretty much the single reason for it, otherwise they outperform my other amps down low where it matters by a fair margin.......
biga6761 likes this.
post #216 of 289 Old 11-16-2018, 02:09 PM
Quoted: 205 Post(s)
Liked: 203
Hmm... Just got a large, heavy package from Fed-ex. Sending address from China.... Wonder what's inside!
post #217 of 289 Old 11-16-2018, 03:20 PM - Thread Starter
johnson636's Avatar
Liked: 653
Probably something that will only promote early hearing loss. No need for you to go through that...I'll take it off your hands
post #218 of 289 Old 11-16-2018, 03:22 PM
hd0823's Avatar
Quoted: 680 Post(s)
Liked: 1253
Lol man nice early self Christmas gift. So quick question Johnson 636 did you take any pics of how you hooked up the plug I still have to cut off the old and put the 220 on
Sent from my SM-N950U using Tapatalk
hd0823 is offline
post #219 of 289 Old 11-16-2018, 03:31 PM - Thread Starter
johnson636's Avatar
Liked: 653
I'm afraid I don't. If you're referring to wiring, it's pretty simple. You connect the two hots to the prongs that are side by side and the other prong gets the ground.
post #220 of 289 Old 11-16-2018, 03:33 PM
hd0823's Avatar
Quoted: 680 Post(s)
Liked: 1253
Ok yeah I haven't cut off the old plug I wasnt sure if they did a good job labeling everything or at least red and black
hd0823 is offline
post #221 of 289 Old 11-16-2018, 03:40 PM - Thread Starter
johnson636's Avatar
Liked: 653
Man I really wish I could attend the G2G. That room of yours looks amazing! I'm sure when you have everything all hooked up you should be at 140db
post #222 of 289 Old 11-16-2018, 04:12 PM
hd0823's Avatar
Quoted: 680 Post(s)
Liked: 1253
Yeah it would be sweet if you could have made it. I'm thinking like probally 35 guys when all said and done. I'm really hoping to at least hit 140 eng 399 said he thinks I'll be like 142 to 143. Time will tell
hd0823 is offline
post #223 of 289 Old 11-16-2018, 08:31 PM
Jk7.2's Avatar
Quoted: 1390 Post(s)
Liked: 2537
Yeah you will be up that high. If your willing to set a house curve as aggressive as mikes. 45db hot? It’s possible. . . .
Jk7.2 is online now
post #224 of 289 Old 11-16-2018, 09:53 PM
hd0823's Avatar
Quoted: 680 Post(s)
Liked: 1253
We will at least first the g2g
Jk7.2 likes this.
hd0823 is offline
post #225 of 289 Old 11-18-2018, 12:31 AM
Quoted: 205 Post(s)
Liked: 203
Man that thing is a beefy amp... If I remember correctly, either the OP or someone else on here had the wrong plugin on theirs originally. I do too. Got the 240v version and the plug is a 15a 110v plug lol. Easy fix though. Unboxed everything and opened it up to look inside. Put a video of it on my build thread. I won't clog up your thread with a youtube link... Excited to use it once my sub upgrade arrives!!
post #226 of 289 Old 11-22-2018, 08:29 PM
Quoted: 171 Post(s)
Liked: 128
Hey question for you @johnson636 did i see earlier int the thread that you were running a fp10k before you gor the 20k? If so were you running your 24s with it? Was it enough power to start with? I am just planning to run 1 sub to start with here and when i get to do a dedicated room then use my pair of Hs-24 and upgrade the amp and maybe use the 10k for front stage duty. Just wondering if that is a reasonable idea.
Randy_J is online now
post #227 of 289 Old 11-23-2018, 08:40 AM - Thread Starter
johnson636's Avatar
Liked: 653
Well, the fp10k did drive the 24s, but nothing like the fp20k. If you already have the fp10k then use it, but you should get an amp that is beefier. Just my opinion
post #228 of 289 Old 11-23-2018, 07:42 PM
BBLV's Avatar
Quoted: 97 Post(s)
Liked: 88
What are you clone guys using to switch these on/off - DIY relay box? Wish they would give an option for a 12v trigger to make it easier for us HT guys, especially when running 240v 30A...
BBLV is offline
post #229 of 289 Old 11-24-2018, 07:48 AM
Jk7.2's Avatar
Liked: 2537
I use 2 relays made by Furmen. It’s only 20 amp. And I pop the breaker on it during heavy bass and above reference levels. But for 95% of the time, it’s great and they have 12V triggers.
Jk7.2 is online now
post #230 of 289 Old 11-24-2018, 08:19 AM - Thread Starter
johnson636's Avatar
Liked: 653
Find NONYT's power on proamps relay thread. That's what I used.
post #231 of 289 Old 11-25-2018, 11:08 AM
notnyt's Avatar
Quoted: 3724 Post(s)
Liked: 3690
notnyt is offline
post #232 of 289 Old 12-06-2018, 07:22 AM
Quoted: 171 Post(s)
Liked: 128
Well i sent them a email this morning asking for a quote. Is there anything i need to make sure to ask for? Also how long does it take for them to respond normally?
post #233 of 289 Old 12-06-2018, 07:40 AM
Jk7.2's Avatar
Liked: 2537
I’d ask for two. At least.
Jk7.2 is online now
post #234 of 289 Old 12-06-2018, 08:23 AM
hd0823's Avatar
Quoted: 680 Post(s)
Liked: 1253
Do you have WhatsApp I could give you one of there sales associates numbers. If your going 240v you can ask for the right plug but you probably won't get it lol but there cheap to put new ones on and +1 for asking for 2
hd0823 is offline
post #235 of 289 Old 12-06-2018, 08:32 AM
Jk7.2's Avatar
Liked: 2537
I’ll tell ya what. I’m happy with these amps. Even after blowing a channel for whatever reason, servicing the amp was painless especially with the replacement amp board delivered in like 3 days.
Jk7.2 is online now
post #236 of 289 Old 12-06-2018, 08:44 AM
hd0823's Avatar
Quoted: 680 Post(s)
Liked: 1253
Yeah I couldn't believe they got it here that quick almost as good as prime lol
hd0823 is offline
post #237 of 289 Old 12-06-2018, 10:09 AM
Quoted: 171 Post(s)
Liked: 128
Lol that would be nice but i currently have no use for a second. I am going to start off with one channel to one sub. I have 2 Hs-24 but only room for 1 at the moment. So once i have them both up and running i will still jave 2 channels left. Once i get a new room i am thinking of running fp10q for front mains and surrounds. I i think i see a need for more power at that point i would get it then so it still has a warranty. Or is there. Different reasons to
post #238 of 289 Old 12-06-2018, 10:14 AM
Quoted: 171 Post(s)
Liked: 128
I don't currently have that app but will go see if i can find it. as for the plug end i am not worried about that. I am a electrician so hopefully i can handle that. Finding enough breakers to feed it is possibly going to be the hardest part. So i may have to rig something up.
post #239 of 289 Old 12-06-2018, 11:59 AM
hd0823's Avatar
Quoted: 680 Post(s)
Liked: 1253
PM when you load the app in I'll get you here info. If on the east coast there's a 12 hr difference so I always try to get ahold of them at night
hd0823 is offline
post #240 of 289 Old 12-23-2018, 07:08 AM
Jk7.2's Avatar
Liked: 2537
I want to make a couple of the 12V remote wire operated relays for my two amps. From the powering on pro amps thread. I have two right now, but they are only 20A and they do trip every now and then. I can make mine 30A, same as the circuit they’re plugged into. Good idea, bad idea?
Jk7.2 is online now
