Stormbreaker a B&C 21DS115 Subwoofer Solution - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 106Likes
post #91 of 146 Old 12-05-2018, 10:42 AM
JESAL's Avatar
Quoted: 37 Post(s)
Liked: 35
Thanks for the cutlist @Red Five , this looks like a pretty easy build.
Red Five likes this.
JESAL is offline
post #92 of 146 Old 12-05-2018, 11:32 AM
JESAL's Avatar
Quoted: 37 Post(s)
Liked: 35
Hi @LTD02 , do these panels have to be solid, can we drill holes to lighten it up?
JESAL is offline
post #93 of 146 Old 12-05-2018, 12:31 PM
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Its a MARTYHORN!!!
strawberry likes this.
K9woofer is offline
post #94 of 146 Old 12-05-2018, 01:16 PM
Quoted: 175 Post(s)
Liked: 133
What about the BIG JOHN
Randy_J is online now
post #95 of 146 Old 12-05-2018, 01:23 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Those are both good ideas! The best thing I have got is John's Mid Bass Enforcement Module also the Johnny Horn. I have not been able to come up with something for JBAMF. Edit: John's Bass Assault Module Foxtrot
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
post #96 of 146 Old 12-05-2018, 01:27 PM
Quoted: 175 Post(s)
Liked: 133
Yeah the Johnny horn has a much better ring to it than say the Horny John
post #97 of 146 Old 12-05-2018, 01:36 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
You just wrecked that one
Red Five is offline
post #98 of 146 Old 12-05-2018, 02:07 PM
Gorilla Killa's Avatar
Quoted: 1330 Post(s)
Liked: 1835
Hybrid Horn by LTD, I shall put no Marty Horn in my home
chrapladm likes this.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is offline
post #99 of 146 Old 12-05-2018, 02:41 PM
Samps's Avatar
Quoted: 1222 Post(s)
Liked: 901
Horns should have expansion. Something without the word horn in it would be more appropriate.
Samps is offline
post #100 of 146 Old 12-05-2018, 04:42 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Red Five is offline
post #101 of 146 Old 12-05-2018, 04:51 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Google what does John mean. Short story, before the baby the wife and I were Googling names, meanings etc. Most of them had all these deep profound meanings, so I typed mine in. Needless to say I was a bit disappointed. Maybe John in the sub name is not the greatest idea lol.
Red Five is offline
post #102 of 146 Old 12-05-2018, 07:23 PM
LTD02's Avatar
Quoted: 2920 Post(s)
Liked: 3626
they do not have to be solid. holes are fine.
JESAL likes this.
Listen. It's All Good.
LTD02 is offline
post #103 of 146 Old 12-05-2018, 07:25 PM
LTD02's Avatar
Liked: 3626
Originally Posted by K9woofer View Post
Its a MARTYHORN!!!
you will have only yourself to blame now. ;-)
Gorilla Killa likes this.
LTD02 is offline
post #104 of 146 Old 12-05-2018, 07:59 PM
notfastenough's Avatar
Quoted: 174 Post(s)
Liked: 197
Hmmm 6thoBC21? Too literal, I know lol.
PortStacker21, 6thoRefrigerator, TwinPeaks
notfastenough is online now
post #105 of 146 Old 12-06-2018, 12:28 AM
Quoted: 398 Post(s)
Liked: 342
Is a 6th order considered a horn? I figured it was just a bandpass?
Trimlock is offline
post #106 of 146 Old 12-06-2018, 07:09 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
@Samps , I have a couple names that take your advice, they bring the dial it to 11 and become homeless vibe. Also have one obscure name, the sub sort of looks like one. Then there is Big John's Little Boom Box. Large lead acid batteries sold separate.
Red Five is offline
post #107 of 146 Old 12-06-2018, 07:18 AM
JESAL's Avatar
Quoted: 37 Post(s)
Liked: 35
Planning on building one of this soon for my BC21SW115-4
I have some Baltic Birch and OSB Plywood in the garage.
Use OSB just for the two large 48*30" panels
The rest in Baltic Birch.
Do you guys think this is a good idea?
JESAL is offline
post #108 of 146 Old 12-06-2018, 07:59 AM
Blue's Avatar
Quoted: 197 Post(s)
Liked: 81
A related question to the one above: If you're starting from scratch, is Baltic Birch or MDF preferred?
Formerly known as GatorBlues. The Spinal Tap Theater build:
https://www.avsforum.com/forum/19-ded...ter-build.html
Blue is offline
post #109 of 146 Old 12-06-2018, 08:29 AM
JESAL's Avatar
Quoted: 37 Post(s)
Liked: 35
I prefer baltic birch, more expensive but a better product.
Last time I worked with MDF, I got bronchitis, nasty stuff.
That was not fun, so get a good mask
My MDF cab did not last long, busted up corners.
JESAL is offline
post #110 of 146 Old 12-06-2018, 08:37 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1313
Baltic birch but on my last submaximus v3s horns I used this with really good results
https://www.homedepot.com/p/ARAUCO-P...9397/202677224
Sent from my SM-N950U using Tapatalk
Blue likes this.
hd0823 is offline
post #111 of 146 Old 12-06-2018, 09:25 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
The design thread is online
Red Five is offline
post #112 of 146 Old 05-21-2019, 10:21 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Thoughts on this, big enough upgrade? I am not interested in chasing a bigger amp than the 3000. The current subwoofer is 8 Ohms. Two of these will fit under the AT screen This is using the same 21DS115, just in a much larger cabinet, 1 watt comparison.
Red Five is offline
post #113 of 146 Old 06-16-2019, 11:43 PM
N8DOGG's Avatar
Quoted: 1298 Post(s)
Liked: 1529
Did the horns ever get built?
N8DOGG is online now
post #114 of 146 Old 06-17-2019, 04:10 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Devastator v1 I know of one build, the response is in the OP of that design thread. The LFE version I haven't had time to build just yet.
Red Five is offline
post #115 of 146 Old 06-20-2019, 06:12 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
@BP1Fanatic this is my home for ridiculous potential projects.
Can it handle 2000 watts and stay under 20mm?
Do you have a hand sketch of the fold/enclosure that I can turn into a model later?
Red Five is offline
post #116 of 146 Old 06-20-2019, 07:45 PM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 171
Cool
Well, the 21DS115-8 states 15mm Xmax.
This TH only needs 1,100wrms to reach 135db's @ 19hz.
Name:	B&C 21DS115-8 TH.jpg
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #117 of 146 Old 06-20-2019, 07:47 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Where do the 4 drivers in parallel come into play? Combo of room gain and loading off the wall?
The 21DS115 is good out to 20mm, no further. Josh had that in the review.
Red Five is offline
post #118 of 146 Old 06-20-2019, 09:41 PM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 171
Correct, 0.5pi.
post #119 of 146 Old 06-21-2019, 04:41 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Correct, 0.5pi.
I have to start running some of these numbers against each other. Now that peak just over 70Hz I will want to cross under that. It is a resonance that will color the sound above the peak for sure. The EV15s are already a sensitivity/power handling mismatch with the 21DS115 ported in that bass region. If I go this route I would have to seriously consider going with something potent for the L/R, Titans dual 15s It would be awhile that is for sure.
Red Five is offline
post #120 of 146 Old 06-21-2019, 09:34 AM
BP1Fanatic's Avatar
Quoted: 203 Post(s)
Liked: 171
A lot people on diyaudio.com say those peaks are not present when measured and listened to.
