Stormbreaker a B&C 21DS115 Subwoofer Solution - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 106Likes
post #121 of 146 Old 06-23-2019, 12:35 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Originally Posted by BP1Fanatic View Post
A lot people on diyaudio.com say those peaks are not present when measured and listened to.
This is looking good. Fits in my space perfectly, better than the DEV LFE. It is a serial 8th order bandpass. Climb should make it close to flat with room gain.
Purenv likes this.
Stormbreaker | Wisconsin Home Theater Meet Thread | B.M.D. (in progress)
You can always turn it down, but you can only turn it up so much (before you run out of power, excursion or structural integrity).
7.1.4 | Yamaha A3070 | Crown XLS 1502 | iNuke 3000 DSP | 2x Aphex 124A | 2x Bic EV15 | 7x Bic FH6 LCR | 2x Bic FH65-B | Sub 21" Stormbreaker | Epson 5010e | 120" DIY AT Screen
Red Five is offline
post #122 of 146 Old 06-24-2019, 06:46 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Exactly! Where is the 3rd port? Is it a BP8S where the thickness of wood is the middle port?
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #123 of 146 Old 06-24-2019, 07:32 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
It does not look as good since I was using my given to me laptop for running the CAD software, there are two square ish shaped ports on the baffle wall. There was not room for a slot port in there with the driver being a 21". Height does include the horizontal divider.
Name:	Port view chamber 1.JPG
ID:	2583802   Click image for larger version
Name:	Decimator current inputs 48H No access panel bracing.PNG
Red Five is offline
post #124 of 146 Old 06-24-2019, 07:40 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
NICE design! Be sure to post build pics!
post #125 of 146 Old 06-24-2019, 07:51 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Thanks! I will try to get more detailed info together over lunch. I have a few little tweaks left yet. When I get that together can you double check my math? I did most of this with a teething toddler going nuts so it was hard to focus lol.
Red Five is offline
post #126 of 146 Old 06-24-2019, 09:10 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Here is a bit more detailed view of the model.
Name:	Decimator with more measurements.JPG
Red Five is offline
post #127 of 146 Old 06-24-2019, 09:39 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
I'll check out the model after lunch.
post #128 of 146 Old 06-24-2019, 01:21 PM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
I'm checking out your BP8S model. The 1 and 3 port velocities look high. Will the bandpass crossovers lower the speeds?
post #129 of 146 Old 06-24-2019, 01:31 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
I forgot which one comes in just under 25m/s the best one is sitting at 22m/s. A 2nd order HPF at 21Hz should keep it in check.
Excursion sits at 20mm with the lossy Le enabled.
Red Five is offline
post #130 of 146 Old 06-24-2019, 01:37 PM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Exclamation
Here is your model. I bumped the power to 1,700 watts since that's what you said was required. As you can see, the port velocities get high near the tuning frequencies. I'm concerned about shuffling at high volumes.
All of your ports should be at least 1/3 of Sd.
1680cm2/3 = 560cm2.
Port 2 needs to be bigger.
Name:	B&C 21DS115-8 BP8S.jpg
post #131 of 146 Old 06-24-2019, 01:41 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
1680cm2/3 = 560cm2.
That was PureNV shooting for 1700 watts. This one is assuming a Nuke hitting 1500 watts into the load for a couple milliseconds. RMS is more in the 1200 range if not closer to 1100 watts.
Red Five is offline
post #132 of 146 Old 06-24-2019, 01:51 PM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Sorry about that guy! I say go for it! You might have the 1st BP8 build on AVS!
Red Five likes this.
post #133 of 146 Old 06-24-2019, 02:34 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
We will see when I can make the saw dust fly. I know of at least one project that will have to come first.
Sekosche and Purenv like this.
Red Five is offline
post #134 of 146 Old 06-25-2019, 07:11 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Going through a full page of math checks from the CAD, I found a few errors but all things should be correct now.
Name:	Current Decimator input.JPG
ID:	2584300   Click image for larger version
Name:	Decimator front black.JPG
ID:	2584302   Click image for larger version
Name:	Decimator wireframe.JPG
ID:	2584304   Click image for larger version
Name:	Decimator open side view.JPG
ID:	2584306   Click image for larger version
Name:	Decimator side view no bracing.JPG
Name:	Decimator rear view.JPG
ID:	2584310   Click image for larger version
Name:	Decimator SPL 87vinto5.1Ohm.JPG
Purenv likes this.
Red Five is offline
post #135 of 146 Old 06-25-2019, 08:16 AM
Purenv's Avatar
Quoted: 177 Post(s)
Liked: 119
Heck yeah!!! I know you have worked your rear off designing the Decimator. All the sims, tweaking it, and re-drawing it. Great job.... now get to building the darn thing.
Purenv is offline
post #136 of 146 Old 06-25-2019, 08:40 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Changes have been made to the post up there already. I made the length of the port rails on the front go all the way down, only .85 liters and lesser chance of resonance with that large of an area. I have to come up with a cut list and see what I need for 2x4"s. It will be 3 sheets of MDF and probably 5 2x4"s is my educated guess. A buddy is giving me his kids old play ground since they are too old for it, that will probably become the project I have to do before this build.
Red Five is offline
post #137 of 146 Old 06-25-2019, 09:40 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
@BP1Fanatic the two highlighted numbers on the roar, are those always constant small finite values to be used? I get the length of port being used as the length of the resonator and the cross sectional area since it is non flaring and stays constant. The 2nd chamber is just a Helmholtz resonator and the port controls the pass band for the most part.
Name:	ROAR question.JPG
Red Five is offline
post #138 of 146 Old 06-25-2019, 10:57 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Start 'em early! I see a miniature BP8 in the playhouse.
post #139 of 146 Old 06-25-2019, 11:05 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
Get a little 6.5 and throw it in there
The ROAR... if a Helmholtz resonator gets long enough it acts like a QW? Could I really get crazy and couple this in with an 8th order series? I have started sketching ideas down Would it even matter that much for a 21DS115? The suspension on it is strong... I saw dampening is better on a QW vs a Helmholtz. I am mostly thinking for music, but if I build Titans some day with dual 15s, the sub would not be needed at all for music reinforcement.
Red Five is offline
post #140 of 146 Old 06-25-2019, 11:13 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Thumbs up
For some reason l, I thought MMJ modeled his ROAR with the TH function, Vrc, Lrc, Ap, and Lpt.
Anyways, Vc1 & Lc1 have to be minimal in that model because Ap1 & Lp1 are the front volume and port together.
post #141 of 146 Old 06-25-2019, 11:20 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Lightbulb
Correct. That's how MMJ describes his ROAR.
Seeing how David McBean has added BP5 & BP7 to HR and seeing your BP8 sketches, I thought about a TH8 or THBP8S???
post #142 of 146 Old 06-25-2019, 11:29 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
I got a sim look pretty decent already for the 21DS115 6BPS. Response is a little flat, I would need to tweak it more or try an 8BPS?!?!
Red Five is offline
post #143 of 146 Old 06-25-2019, 04:06 PM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Thumbs up
I read on diyaudio.com that you can get away with smaller ports with BP6S & BP8S than BP6P & BP8P. I would stick with no smaller than 1/3 of Sd with any vented enclosure though.
post #144 of 146 Old 06-25-2019, 04:28 PM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
That would be a lot of redesign work. I know someone with a Devastator, he likes it and that is only running 362.9cm on the rear chamber vent.
Red Five is offline
post #145 of 146 Old 06-26-2019, 05:13 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Sawdust???
post #146 of 146 Old 06-26-2019, 06:08 AM - Thread Starter
Red Five's Avatar
Quoted: 399 Post(s)
Liked: 448
It will be a bit before I can start. There are 24 MDF pieces and 22 pieces of 2"x4" ouch.
Red Five is offline
