JBL CX1200 Sealed Build - Planning phase - AVS Forum | Home Theater Discussions And Reviews
 28Likes
post #1 of 53 Old 06-29-2018, 12:57 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Bought around 19 of them during BBs black friday sale and after reviewing several members experience and builds, I think I should go with sealed sub using them.
I'm planning to build put 4 drivers on each front corner behind the AT screen, preferably 2 in a one cab so easily movable when needed.
I still have to measure available space left next to the LCR, but I need advice on optimum enclosure volume for these 12s.
Is 6 ft3 per 2 drivers be good enough?
Rcris is offline
post #2 of 53 Old 06-29-2018, 03:19 PM
Nalleh's Avatar
Quoted: 2404 Post(s)
Liked: 3134
3 cf pr driver should work just fine. But you don’t need that big. I run 12 of these (exact same as CS1214 and GTX1200) in ~ 1cf pr driver enclosures, and have reference SPL down to 10 Hz, with a little EQ. All run by one Inuke 6K.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is online now
post #3 of 53 Old 07-03-2018, 10:53 AM
rr14's Avatar
Quoted: 110 Post(s)
Liked: 31
make it happen! excited to see the progress!
rr14 is offline
post #4 of 53 Old 07-03-2018, 05:34 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
you got it
Rcris is offline
post #5 of 53 Old 07-03-2018, 05:37 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Finally decided to make a 6.5 cab to give 1.5 ft3 per driver
Outer dimensions of the box:
H= 60inch, W = 15.25, D=16.75. Single baffle only.
ID:	2424052   Click image for larger version
ID:	2424054   Click image for larger version
ID:	2424056   Click image for larger version
ID:	2424058   Click image for larger version
ID:	2424062   Click image for larger version
ID:	2424064   Click image for larger version
ID:	2424066   Click image for larger version
ID:	2424068   Click image for larger version
bubbrik likes this.
Rcris is offline
post #6 of 53 Old 07-03-2018, 05:44 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
test fit , dropped in 4 of them to glimpse of them .
ID:	2424074   Click image for larger version
ID:	2424076   Click image for larger version
ID:	2424078   Click image for larger version
ID:	2424080   Click image for larger version
ID:	2424084   Click image for larger version
bubbrik likes this.
Rcris is offline
post #7 of 53 Old 07-03-2018, 05:46 PM
EndersShadow's Avatar
Quoted: 1186 Post(s)
Liked: 1454
Rock on! I am betting you will be surprised with how good these sound....
I switched my enclosure (4 of them in 6cf) to my new EP4000 and love the combo.
Still working on getting the other 3 subs built....
Rcris likes this.
My Setup | Custom MiniDSP Build | FS: If its For Sale, find it all (here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #8 of 53 Old 07-03-2018, 05:54 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Original plan is to make double baffle, should I really need it. I just have to glue it and 4 more holes, but Do I?
Rcris is offline
post #9 of 53 Old 07-03-2018, 05:54 PM
Nalleh's Avatar
Liked: 3134
Nice job
Now you only need to build the other 3 boxes
Nalleh’s HT
post #10 of 53 Old 07-03-2018, 05:55 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
I will let it sit overnight to air out silicone fumes, will paint it tomorrow
Rcris is offline
post #11 of 53 Old 07-03-2018, 05:57 PM
dTorC4's Avatar
Quoted: 86 Post(s)
Liked: 145
I'm not sure it's absolutely necessary, but it certainly wouldn't hurt anything. Overbuilding is part of this game!
dTorC4 is offline
post #12 of 53 Old 07-03-2018, 06:03 PM
Liked: 1454
Double baffle is normally so you can flush mount the drivers. If you dont care to do that, then you save some wood. And if yours will be hidden, I'd just not do it.
I'm not sure if you need it, but you might want a horizontal brace or two in that box.
post #13 of 53 Old 07-03-2018, 06:18 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Sure, I will add few single sticks in them .
These will go behind the screen
EndersShadow likes this.
Rcris is offline
post #14 of 53 Old 07-03-2018, 06:20 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Gotta to make a trip to Walmart for some pillows
EndersShadow and vn800art like this.
Rcris is offline
post #15 of 53 Old 07-04-2018, 10:03 AM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Rcris is offline
post #16 of 53 Old 07-04-2018, 10:45 AM
smcmillan2's Avatar
Quoted: 819 Post(s)
Liked: 720
https://www.lowes.com/pd/M-D-17-ft-G...rstrip/1096043
will this work for sealing the driver ?
Sure will.
Rcris likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #17 of 53 Old 07-04-2018, 01:19 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
today's progress , added few braces and waiting for paint to dry
ID:	2424408   Click image for larger version
ID:	2424410   Click image for larger version
ID:	2424412   Click image for larger version
ID:	2424414   Click image for larger version
vn800art, johnson636 and bubbrik like this.
Rcris is offline
post #18 of 53 Old 07-04-2018, 01:28 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
I'm not too worried on paint job as they'll be hid anyway
Rcris is offline
post #19 of 53 Old 07-05-2018, 06:38 AM
Quoted: 143 Post(s)
Liked: 71
Found a seller on Ebay here in Italy who could have a batch arriving in a while, 2 cone boxes!
Will go the same route of the OP, for my tiny four cones availability!
Regards
Alessandro
Marantz Sr7011, Galactron Mk10b, Pioneer VsxLx50. Klipsch Cornwall, Wharfedale 9.1, Klipsch CP-6. Sony UbpX800, Lg Up970, Hisense 55M5500. 110 inches rolling screen, excelvan cl720d.
vn800art is online now
post #20 of 53 Old 07-05-2018, 01:48 PM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
One done, replaced with 1262 sealed sub and bass seems to quadrupled. Its insane amount of bass but I need to rerun the audessey I guess.
vn800art and Pradeep2 like this.
Rcris is offline
post #21 of 53 Old 07-18-2018, 05:49 AM
Quoted: 143 Post(s)
Liked: 71
So the title of the thread should be modified? Exact type of this drive? Post Audissey result?
post #22 of 53 Old 07-18-2018, 09:37 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Nice build!
Sony XBR65x900e / STR-DN1080 / original PS4 / WOW! Ultra TV / Quantum Access Mini PC Stick w/Windows 10 / 8 x Rockville SPG88 8“ DJ PA Speakers / Dayton Audio SA1000 / Kicker 08S15L74 in a Tapped-Tapered Quarter Wave Tube (negative flare tapped horn).
BP1Fanatic is offline
post #23 of 53 Old 07-18-2018, 05:05 PM
VegaMan's Avatar
Quoted: 102 Post(s)
Liked: 78
you replaced one with 4.... seems legit.
nice build, look forward to your results with multiples
VegaMan is online now
post #24 of 53 Old 08-16-2018, 09:02 AM - Thread Starter
Rcris's Avatar
Quoted: 89 Post(s)
Liked: 104
Came back from vacation to receive this letter from my new neighbor , just one box did this, can't believe it. There is definitely 50ft from my wall to his bedroom wall.
Setting up to build the second one this weekend
Rcris is offline
post #25 of 53 Old 08-16-2018, 09:40 AM
BP1Fanatic's Avatar
Quoted: 204 Post(s)
Liked: 171
Lol
post #26 of 53 Old 08-16-2018, 09:41 AM
Raylon's Avatar
Quoted: 443 Post(s)
Liked: 583
I find that hard to believe. 50 feet away and using just 4 of those little guys? It can't be that loud outside.
Raylon is offline
post #27 of 53 Old 08-16-2018, 09:52 AM
Liked: 1454
Sounds like you need to invite them over next time to watch the movie . That and potentially look at some bass traps inside (and maybe even build something to help dampen the noise outside)....
post #28 of 53 Old 08-16-2018, 10:43 AM
notfastenough's Avatar
Quoted: 175 Post(s)
Liked: 197
I've had both of my side neighbors text me to tell me their bedroom was rattling from the THT's. I still had more in the tank too
Not sure about you, but aside from a feeling kinda bad for messing with the neighbors, it was a great feeling to get some feedback on the performance of the project lol.
CallingMrBenzo and vn800art like this.
notfastenough is offline
post #29 of 53 Old 08-16-2018, 10:45 AM
iconrl's Avatar
Quoted: 120 Post(s)
Liked: 109
For some reason, my brain automatically filled in the name as Inigo Montoya.
skipford and Chris Popovich like this.
Optoma HD37 on 138" DIY AT Screen | Infinity Beta 40s, Infinity Beta C250, Atlantic Technologies 224 SR
DIY Alpine SWS-15 in Cyclops box (LTD02 ported design) | Old Pioneer VSX-521 | Xbox One S
iconrl is offline
post #30 of 53 Old 08-16-2018, 11:00 AM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
Wow. I'd frame that one and put it on the wall. Kind of a badge of honor wouldn't you say?
vn800art, skipford and Rcris like this.
jcmccorm is offline
