Trilithon (Stonehenge Variant) Design & build thread - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #1 of 54 Old 07-01-2018, 09:04 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
trilithon
[trahy-lith-on, trahy-luh-thon]
noun
a prehistoric structure consisting of two upright stones supporting a horizontal stone.
Firstly I would like to thank @LTD02 for designing this subwoofer along w/ helping me through the entire process including answering all questions that I had. Also thank you @Erich H for answering some questions I had about the bracing.
This is a subwoofer based on the designs of @Erich H ‘Stonehenge’ at DIYSG modified by @LTD02
I have always loved the aesthetics of the Stonehenge subwoofer but, slot ports have always been a turn off of mine which is where this journey began.
Designs
Here is the designs for both a single & double baffle using 3/4” MDF.
Single baffle
Double baffle
The dimensions above (double baffle) are 30” x 30” x 19.25” which equals 10.026^3 external volume. Internal volume is approx 8.9 - ~9^3
Ports
(2) flared four inch precision ports w/ a 17” length equals ~19-20Hz port tune.
https://www.parts-express.com/precis...e-kit--268-352
Cut sheet
Here is my cut sheet — (2) 3/4” MDF 4’ x 8’
depending upon your assembly process you may want to add or subtract from the following as I know everyone’s process is different.
Bracing
Bracing will be exactly the same as the Stonehenge pictured below except instead of the slot wall on the left side there will be (2) 2” x 19.25” braces supporting the back wall & left side as shown w/ the right & top plates.
Below you can see how I have marked each brace on the back wall.
Top & side bracing — (6) 2” x 19.25”
Marked 2” inwards each side & top plate will be marked at 8-10” & 20-22” shown below
The “Stonehenge” driver bracing — (8) 2” x 19.25”
Drawing an X as shown below will give you direct center of the back wall
Next you will find the bolt circle diameter of your preferred driver, mine was 17.5” so we’ll use that as an example.
I divided my BCD by 1/2 which equals 8.75. I started directly center & measured 8.75” out from center marking a 2” line at all (8) lines throughout my {T} & {X} drawn above. Therefore giving the structure bracing while also giving extra MDF for the driver screws to bite into.
I hope to see some other AVS members build the Trilithon, if you have any questions please feel free to post below or PM me directly.
Throughout the next week or two I will be posting updates in this thread documenting my build & hopefully inspiring others.
LTD02 and Sekosche like this.
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #2 of 54 Old 07-01-2018, 09:43 PM
Sekosche's Avatar
Quoted: 1380 Post(s)
Liked: 3414
Originally Posted by DaBateman View Post
trilithon
noun
Designs
Single baffle
Double baffle
Ports
Cut sheet
Bracing
What driver you pairing with this one eyed two nostril beast?
bebb likes this.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #3 of 54 Old 07-01-2018, 10:06 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
“One eyed two nostril beast”
I knew I was forgetting something. It is an 18” Dayton Pro woofer. I’ll have to report back w/ the exact model #.
I sourced it locally for relatively nothing compared to it’s MSRP. My plan is in the somewhat near future upgrade to an 18” Ultimax or the 18” FI driver they made per AVS members request.
I’ve already checked & the Pro woofer that I have has a smaller baffle cutout than both of them so after a few hundred dollars & a little sanding I’ll be in ULF bliss.
Sekosche likes this.
post #4 of 54 Old 07-01-2018, 10:25 PM
K9woofer's Avatar
Quoted: 182 Post(s)
Liked: 119
Port velocity will be very high with an Ultimax.
K9woofer is offline
post #5 of 54 Old 07-01-2018, 10:37 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Ah probably so. The port was designed w/ the Pro woofer in mind so I hadn’t considered the negatives of when I upgrade.
What would be the fix when I’m ready? Albeit it’ll be ~6mo away I’d still like to plan for this.
Thanks for bringing that to my attention
Edit: this is my first build so the physics/intricacies surpasses my knowledge
post #6 of 54 Old 07-02-2018, 10:31 AM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Let the build begin.
Here is all my cuts beforehand, I used 2 4’ x 8’ sheets of 3/4” MDF w/ lots of excess.
Getting the first side glued to the bottom plate
LTD02 and bubbrik like this.
post #7 of 54 Old 07-04-2018, 04:03 AM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
First side dried & cured. Now to start the second side. I ended up w/ a much nicer glue line/fit w/ this side.
post #8 of 54 Old 07-05-2018, 09:06 PM
Brazle's Avatar
Quoted: 159 Post(s)
Liked: 196
Sadly there won't be an easy fix for that issue. Basically you'd have to redesign your ports entirely. Bigger diameter or more ports.
I think those issues only arise at very high output levels, so if you won't be pushing it too often you might find that it's not a problem. I would say just swap in the new driver whenever you're ready and try it out. You'll notice port noise at high enough levels most likely and you can decide if it's bearable or not.
HT setup: Vizio 50" 4K | Xbox & PS3 | Pioneer Elite VSX-94TX | Bose 701 towers (V1) | JBL S Center | Def Tech Reference SuperCube & DIY Nearfield cabinet ported UM18 dual ported PA380 ULF+MBM
Brazle is offline
post #9 of 54 Old 07-05-2018, 09:51 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Which dependent upon how well this pro woofer does on the low end is whether I’ll actually add an Ultimax or FI.
My room is only 1200^3 so I’m hoping to get some considerable room gain. I’m assuming output should be sufficient.
But yes I guess if I do upgrade I’ll just test the waters & go from there. Thanks for the input regardless.
Do you like the design?
post #10 of 54 Old 07-05-2018, 10:00 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
After having both sides dry & cure for 24hrs we move to the back plate.
bubbrik likes this.
post #11 of 54 Old 07-06-2018, 04:04 AM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Extra pic of the woofer next to my 85lb Bulloxer
LTD02 and Craig S King like this.
post #12 of 54 Old 07-06-2018, 03:35 PM
Brazle's Avatar
Quoted: 159 Post(s)
Liked: 196
That seems like a good plan.
1200 cubic feet? So, 12x12x10 or so, small office you said right?
Just remember with the iNuke3k you'll only get about 500 watts rms actual into one channel at 4 ohms for the UM18 which would only be half if what it's rated, so you'll only get half the UMs potential output. Again that would be ok in a small room if you're not trying to max it out, but you will be leaving some output on the table.
Of course with that power you're less likely to have issues if you put a UM18 in that box. Port velocity should stay quite a bit lower. You could model it I guess
Yea! I love it. Looks like a really good box. I think the dual round ports look sweet - impressive and menacing. Good job.
Which driver is it again? PA460 or PA465? Or something else?
Brazle is offline
post #13 of 54 Old 07-06-2018, 04:27 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
9x15x8. Spare bedroom.
I’m still yet undecided on an amplifier. I’ve been looking at the Chane 3600
https://www.chanemusiccinema.com/3600
& Behringer KM1700
https://www.amazon.com/Behringer-KM1.../dp/B01MAY7S7W
Realistically I’d like to stay under 300. Unfortunately the woofer is 8ohm so finding an adequate amp is presenting more of a challenge than first thought.
Thanks for the compliments.
Also the driver is Dayton NEO Pro PN470 18”. Not my first choice but, I sourced it locally for $40 so compared to its $349 MSRP I’m happy regardless. That’s actually what started this entire process, I found it so cheap that I couldn’t pass it up, then I needed a box.
post #14 of 54 Old 07-06-2018, 08:24 PM
Brazle's Avatar
Quoted: 159 Post(s)
Liked: 196
Yea those amps look good though I'm not familiar with Chane. Any of the 3 you've mentioned should be fine for your purposes as long as you've got DSP. Or at least aHPF you can set.
Brazle is offline
post #15 of 54 Old 07-06-2018, 08:43 PM
Brazle's Avatar
Quoted: 159 Post(s)
Liked: 196
That PN470 looks like a great driver BTW. nice score!
DaBateman likes this.
Brazle is offline
post #16 of 54 Old 07-10-2018, 10:43 AM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
I’ve been busy the past few days so I’ve had to take a break in my build.
After letting the back plate dry & cure we start on the bracing.
post #17 of 54 Old 07-12-2018, 07:54 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Time to start on the front baffle. I’m doing a double recessed baffle of 3/4” MDF.
Edit: Recessed baffle.
I oiled my jigsaw before using it & found out the hard way I used too much. Left plenty of sanding to be done.
LTD02 and Red Five like this.
post #18 of 54 Old 07-13-2018, 07:16 AM
smcmillan2's Avatar
Quoted: 820 Post(s)
Liked: 721
Time to start on the front baffle. I’m doing double baffle; not entirely sure of the terminology regarding my design but the top piece will be cut around the driver leaving it mounted flush. Infinite baffle?
No, you are creating what is commonly referred to as a recessed baffle. Infinite baffle is explained here http://www.ibsubwoofers.com/, completely different things.
Build is looking good!
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #19 of 54 Old 07-13-2018, 12:00 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Makes total sense after seeing the name hence one part being recessed. I’ll edit my post.
Thanks for the compliment! It’s been more work than I had originally thought but, I’ve learned quite a bit invaluable information. I cannot wait to start on my next build already. I’m thinking either an LCR of HTM 12’s or a MartyCube. As long as this driver has sufficient extension it’ll probably be the HTM’s.
post #20 of 54 Old 07-13-2018, 12:24 PM
smcmillan2's Avatar
Quoted: 820 Post(s)
Liked: 721
You should absolutely do both!
I finished a VBSS variant a few months ago, now working on a L/R HTM-10 build. Can't wait to hear them.
post #21 of 54 Old 07-16-2018, 01:24 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Let me know your impressions! I was debating fusions vs HTM’s for the longest time but, I like the size of the HTM more. Also that you can get all sizes for fronts and sides is what pushed me over.
post #22 of 54 Old 07-16-2018, 01:51 PM
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
Two good looking woofers you've got there!
Craig S King is online now
post #23 of 54 Old 07-16-2018, 02:39 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
“Woofers”
Thank you kind sir! He’s a big ass baby.
post #24 of 54 Old 07-16-2018, 02:53 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Finishing the internal bracing. This is what gives the “Stonehenge” it’s iconic look.
post #25 of 54 Old 07-18-2018, 01:44 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Front double baffle (recessed)
post #26 of 54 Old 07-18-2018, 03:00 PM
bebb's Avatar
Quoted: 223 Post(s)
Liked: 161
I think those issues only arise at very high output levels, so if you won't be pushing it too often you might find that it's not ...
...worth building in the first place!
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #27 of 54 Old 07-19-2018, 06:41 AM
brireeves629's Avatar
Quoted: 201 Post(s)
Liked: 83
Great job!
brireeves629 is offline
post #28 of 54 Old 07-19-2018, 06:27 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Originally Posted by brireeves629 View Post
Great job!
Thank you!
It has been quite an experience w/ this build. I’m glad I decided to take it on.
post #29 of 54 Old 07-19-2018, 07:39 PM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
I forgot to take pictures of the top plate being braces but, I have made a mistake during the assembly process. I should have put the front baffle on last. Instead I put the top on last.
Doing so left some pieces not totally in-line. This left some body work w/ wood filler & a lot of sanding to be done.
Preparation
Came back out to this SOB sitting on my glove. He ended up splattered. Left more sanding to do.
post #30 of 54 Old 07-21-2018, 05:57 AM - Thread Starter
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Sanding process getting all edges & lines even & smooth.
