VRK Midbass Modules Build - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #1 of 62 Old 07-04-2018, 02:28 PM - Thread Starter
tjcinnamon's Avatar
Quoted: 1798 Post(s)
Liked: 483
The VRK Midbass Modules are named after the initials of my 2nd Daughter. I bought the Magnum 12's on the evening she was born.
The box is 12.5" W x 18" H x 15.5" D with an ID cu ft of 1.47 cuft.
After bracing, port, and driver, I'm looking at 1.2 cuft.
It's tuned to 43Hz with an 11" x 1.5" x 7.5" slot port
HPF is a 2nd order butterworth at 35Hz
Powered by a Crown XLS 2002 at 375W RMS
The box is 3/4" MDF which will be veneered in walnut and stained to match my BDI media console and Paradigm LCR's. I will be experimenting with the impact on sound quality with a wooden grate that matches my media console to cover the driver (see attachment). If it impacts the sound I'll pivot on design and may even need to make a wider box
My Journey into DIY and mid-bass:
I have been annoying people on this DIY forum planning this build since the January of 2017. It's been over 18 months of discovering DIY and harassing people with questions like: "is there a difference in sound between a slot port", "will port placement impact tactile response at 8' away", "does the high excursion HST-11 sound boomy like the youtubes", "will a wood grate impact sound quality"...
You know, all the important things... I learned what I was missing, mid-bass, and heard of these Magnum-12 drivers. I did as much research as I could (primarily bothering folks with highly subjective questions)... Of course I learned about WinISD and T/S parameters (although I still don't know what the curve of transfer function magnitude is...)
On 8/11/2017 my second daughter was born and as my wife and her lay sleeping in the hospital bed, I was up salivating with DIY mania drawing pictures in Microsoft paint about various port placement options.... Out of complete DIY zietgiest, I pulled the trigger on these drivers. I contacted a friend that works at a instrument distributor and got a Crown XLS 2002, I contacted my local hacker space and was going to use their CNC machines because I can't cut a straight line to save my life...
I few months after my daughter was born the owner of the hackerspace got blown up in a propane accident (he's alive and well) but I was left to my own devices to cut straight lines. I got a router, cutting guide, and MDF for Xmas that year. I then waited for it to warm up and got busy, and then waited for it to cool down and had a day off.
Predictably, the cutting went terrible. I sold all of my battery operated tools on Craigslist and bought corded ones. Once again I wait for a cool day that I can take off which leads me to Monday July 2nd...
johnson636, tiger8mush and eng-399 like this.
NAD 758 v3 with Dirac 7.4.4 + Rotel 976 + Panamax M5300-PM
Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
DIY MBMs: VRK Build thread + 2x Rotel 981 (bridged)
Sub: 2x Rythmik LVX12 + MiniDSP
DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #2 of 62 Old 07-04-2018, 02:36 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
Straight cuts! I used a Kreg Cutting Guide and the key for me was using a corded circular saw vs a battery operated one.
ID:	2424464   Click image for larger version
post #3 of 62 Old 07-04-2018, 02:54 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
Other tool notes: Don't over tighten the jig (I cracked mine already!), use the interior screw holes for a Ryobi (I made 3 trips to menards trying to get the right screws), I got a guide for a jigsaw to do a pocket cut for the port, I'll use a flush trim router bit to clean that up. I practiced cuts, straight routing, and roundovers as well. Given that I'm veneering, I don't think I'll be using and roundovers. Next simulation is going to be cutting with the circle jig but it's too dang hot!
ID:	2424470   Click image for larger version
post #4 of 62 Old 07-04-2018, 03:49 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
Originally Posted by Trimlock View Post
I remember you starting this a while ago around the same time as mine. My boxes are larger than yours, tune ended up around 42hz and I limit power to 300 Watts each with EQ. My model showed (with higher power) I shouldn’t go below 38hz at max power or i toast them, but I’m kind of starving them so I won’t hit excursion limits. Also I found around 35hz that I get some distortion. Ended up setting a 35hz filter and it’s been rock solid since.
My null around 55hz is still their though 😕
What volumes do you listen to them at? I’ll listen at -20db (85dB) + 10dB LFE + 9dB hot
Max 104dB.
post #5 of 62 Old 07-04-2018, 07:33 PM
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 671
Looking forward to this build coming together
tjcinnamon likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #6 of 62 Old 07-04-2018, 11:31 PM
Quoted: 398 Post(s)
Liked: 342
Max 104dB.
Typical is -15, but that’s not pushing the inuke very hard. Eric told me these can go much higher. I look forward to eventually crossing them at 200+ and seeing how that goes.
Trimlock is online now
post #7 of 62 Old 07-05-2018, 04:19 AM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
When you say you cross them at 200Hz, does that mean you set the crossover in your AVR to 200Hz? Or are you splitting the mains signal from the AVR and using DSP to low-pass that for the midbass? Thanks...
jcmccorm is offline
post #8 of 62 Old 07-05-2018, 06:56 AM - Thread Starter
tjcinnamon's Avatar
Liked: 483
+1
That’s a really high crossover. My plan is to do the LR Surround and tops at 100Hz and my center at 80hz. I may even try them at 120Hz.
I’ve considered making my 3 way LR a 4 way with these and may try that. However, I wanted the center channel FR too as well as LFE... I guess “double bass”
Using MSO will help. I may use the HPF on the amp and let MSO set my miniDSP filters between my full range subs (RythmikLVX 12’s) and these MBM’s
Then after that it’s Dirac
post #9 of 62 Old 07-05-2018, 10:16 AM
Quoted: 398 Post(s)
Liked: 342
Splitting mains signal
post #10 of 62 Old 07-05-2018, 10:22 AM
jcmccorm's Avatar
Quoted: 597 Post(s)
Liked: 444
Got it. Thank you. Is it a pain to get the MBM mixed with the mains? I'd imagine you'd want to try and get the phase lined up as much as possible since essentially they are reproducing some of the same material.
Trimlock likes this.
jcmccorm is offline
post #11 of 62 Old 07-07-2018, 02:40 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
Painfully slow progressm (but I learned a bunch)
I finally finished my "experiments" on scrap wood with the router and the jig saw. Today I was cutting into my production rips.
A few tips:
1) take off your circle jig if you're having problems getting the bit router off
2) you can tighten your jig saw so it won't make angled cuts. I think my jigsaw guide would have worked better.
Experimental cut with the circle jig was clean. I used a 3/4 bit. However, in attempting to get the bit off so make my interior cut, I broke the already cracked jig.... The super glue is still drying.
I used a cut guide for my jig-saw to help cut a straight line for the slot port. Unfortunately, I didn't realize I could tighten my jig so I think it cut angles mid-way through. Also, I'm not sure why but the guide didn't seem completely straight either. I question the marks on my T-Square because when I stacked MDF to simulate the port the marks were much different...
Here's the final product! My slot port roughed in ready for the flush trim bit, a circle jig drying, and a trip to Menards to get more clamps that will fit. I only have 2 clamps that fit!
ID:	2425512   Click image for larger version
ID:	2425514   Click image for larger version
Name:	finished product.jpg
ID:	2425516   Click image for larger version
Name:	cut guide.jpg
ID:	2425518   Click image for larger version
post #12 of 62 Old 07-07-2018, 03:02 PM
johnson636's Avatar
Liked: 671
Just think of it this way, you'll earn master status when you're done
post #13 of 62 Old 07-07-2018, 03:03 PM
smcmillan2's Avatar
Quoted: 816 Post(s)
Liked: 711
A tip - I cut out the slot port when the cab is assembled (minus the top). Drill a 3/4" hole, run my router with a 1/2" straight flush trim bit around the walls of the port. You can sort of see the process in my 1260 builds in my sig. Easy peasy, although there's more MDF to clean up inside the cab afterward.
Of course, YMMV.
smcmillan2 is offline
post #14 of 62 Old 07-07-2018, 07:24 PM
Quoted: 398 Post(s)
Liked: 342
It was very simple, didn’t even take an evening.
post #15 of 62 Old 07-21-2018, 01:53 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
Always hang on to the router!
My dried circle jig worked BUT I didn't anticipate that I could easily be off 1/16" on the center point for my jig. My plan was to have the circle cut just eclipse the sides and I'd put a grill over it. Well I was a 1/16" or more off and it looked terrible. While trying to fix it, I was monkeying with something and took my hands off the router it spun around the wood, and flew off the table!
Once again, I had to glue the jig for the second time!
ID:	2431244   Click image for larger version
post #16 of 62 Old 07-21-2018, 01:59 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
First box glued!
I changed my dimensions to 13" to accommodate having a little of leeway around the driver. I had to cut a new port, and 66% of my panels. Luckily I bought an extra sheet of 4x4 MDF in preparation for being terrible.
I carefully used my twice glued jig and my hand never left the router. I also decided to use a flush trim bit method on the port instead of terribly jig sawing it. Nevertheless, in spite of my lack of skill the jig worked!
The gluing was a mess! it was everywhere. I should have checked the forum how to glue. My strategy was to lay down the interior piece and put glue on all of the sides and fold it up. It was messy and I'm worried some of the glue scraped off. I tried to fill it via the outside. There's only 1 side (the "bottom") that is not flatly aligned. I THINK I can sand that down to make it 'normal'
After this dries, it's bracing and port. Then I'll glue the other box.
ID:	2431248   Click image for larger version
post #17 of 62 Old 07-21-2018, 02:01 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
Any suggestions on how to glue
Anyone have any strategies on how to glue the next box?
Given that I'm veneering this, could I use screws for the bracing?
If I scraped off too much glue in the chaos that was the first box, what are my options? I filled the gaps manually. I could use screws and caulk the inside too.
post #18 of 62 Old 07-22-2018, 01:41 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
USE A PLANER: Box 1 is braced (lessons learned); Box 2 gluing
With Box 1 I glued all sides with the exception of a panel that fits within all of the other sides which was a mistake. It's going to be very difficult to glue and I needed to plane the panel down to make it fit in the gap. It's proved to make some of the bracing more difficult
USE A PLANER INSTEAD OF SANDING OR JIGGING IF YOU HAVE ONE. I'll be recutting my port because it was too wide, so then I sanded unevenly, and cut too much with my jig saw trying to even it out. I own a planer, I should have planed it.
Consequently I needed to screw my port in which was not ideal. I would have rather glued it. Where stuff wasn't cut flush I needed to fill the gaps with glue. I think my circular saw is bent and tilted. Its a very small box so there's not a ton of room for bracing. I need to pick out a stuffing. I may go polyfill or I have some left over auralex... Seems like it'd be costly.
Here's my box and the bracing
Box 1 is nearing stuffing, porting, and wiring
With Box 2, I'm gluing it in a proper order. The last panel to be put on will be resting on the top of the sides and not fitting within the sides. I also have been using a foam roller to spread the glue and then use a bead of glue down the sides to fill if there are gaps. I think box 2 will be much smoother to build. Maybe I'll send up scraping box 1 and rebuilding it.
Name:	Box 1 .jpg
ID:	2431620   Click image for larger version
ID:	2431622   Click image for larger version
Name:	Bracing Box 1.JPG
post #19 of 62 Old 07-22-2018, 03:01 PM
Quoted: 398 Post(s)
Liked: 342
One thing to never do with a router is release your hands. I’ve seen a router launch and smack a dude in the mid section when he took his hands off a router.
smcmillan2 likes this.
post #20 of 62 Old 07-22-2018, 03:04 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
No doubt! I lucked out big time! I’ve screwed up on every turn of this build! After I get done, presumably I’ll be better but won’t be building any more subs for quite some time 😞
post #21 of 62 Old 07-22-2018, 03:30 PM
smcmillan2's Avatar
Quoted: 816 Post(s)
Liked: 711
Just a tip for next time:
It looks to me that your front/back are full sized, and everything fits between them? If so, for assembly, I would start with the back and attach bottom (or top). Then attach the sides, then the top (or bottom). And lastly, the front.
This way you are only gluing 2 edges at any given time, allowing for a little wiggle room. And then the last piece simply lays over all the other 4 edges.
post #22 of 62 Old 07-22-2018, 03:39 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
I like that. I’m doing something similar with full size (back) last. The reason I’m afixing the front first is so I can install the slot port and use a flush trim bit to make the cut.
There’s a chance I may need to rebuild one or both of these boxes...
post #23 of 62 Old 07-22-2018, 03:48 PM
smcmillan2's Avatar
Quoted: 816 Post(s)
Liked: 711
I missed that part, sorry. Put the slot port in before the other side. The whole idea is that you only have 2 new edges gluing at any given time, that way you're not trying to fit 3+ edges inside boundaries (and thus not getting the glue where it needs to be).
The port can be cut out any time after all the port's pieces are affixed. I typically hog it out before I put the last piece on (in your case, the back or front). Easier to clean the mess out.
post #24 of 62 Old 07-22-2018, 03:54 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
That makes perfect sense! Dang! I hope I have enough glue on these. Especially where I needed to “slide” things into place.
post #25 of 62 Old 07-24-2018, 01:04 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
How much clearance do I need for my slot port?
I'm getting ready to stuff with denim insulation. How much clearance do I need to give to my slot port?
post #26 of 62 Old 07-24-2018, 03:47 PM
smcmillan2's Avatar
Quoted: 816 Post(s)
Liked: 711
I usually try to keep it ~2 - 3 inches away from the port end. Don't know if there some sort of standard calculation based on port size...
post #27 of 62 Old 07-24-2018, 05:36 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
The port is 1.5 tall x 11.5 wide x 7 deep
post #28 of 62 Old 07-27-2018, 02:03 PM - Thread Starter
tjcinnamon's Avatar
Liked: 483
Denim Insulation, pre-drilling, screw size
I'm using denim insulation instead of poly-fill. Can I have the insulation touch the metal basket of the woofer? I don't have much room in my box.
The screws appear to go in slightly diagonal. Should I drill them at a slight angle?
What size screws should I use for the DIYSG magnum 12?
ID:	2433688   Click image for larger version
post #29 of 62 Old 07-27-2018, 09:51 PM
bebb's Avatar
Quoted: 221 Post(s)
Liked: 156
Screw, turn, good one! Oh, no pun meant? Sorry my bad.
Seriously, if you learn from the mistakes then you are still getting something positive out of it.
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #30 of 62 Old 07-27-2018, 09:53 PM
bebb's Avatar
Quoted: 221 Post(s)
Liked: 156
FWIW I use 1-5/8" drywall screws for all my speakers. Just because they are cheap when you buy a 5 lb container.
bebb is offline
