From 0 to 1299 - AVS Forum | Home Theater Discussions And Reviews
 76Likes
post #1 of 53 Old 07-14-2018, 12:29 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
From 0 to 1299
Background info: 2016 Rough year, lost job, home and most of equipment.
2017 New job, home but 0 equipment.
My plan. Cost list of all items I would need or want. New HTPC, projector, screen, speakers, avr and wiring to support all items. Have all wiring in wall and connected to multiple battery backups.
Lets start. Loaded sketchup with room dimensions and started to figure what I could do.
Wanted seating and projector and screen.
Real pictures.
Room was full of echoes and sounded hollow. That was the first to correct. Started to build and hang sound panels.
This was my plan in sketchup.
And the outcome with an electric screen installed.
A panoramic view of panels in room. Still have 1 to install at this point.
Now onto speaker placement. With the help of @LTD02 , he gave me a good idea of placement I would need.
I started with Volt 6's as mounting would be difficult because of the placement .My finished Volt 6's.
The mounting brackets I used on the Volts.
Wall brackets that I had to build.
Mounted
Over all picture of both Volts.
Continue on next post .
ID:	2428394   Click image for larger version
ID:	2428396   Click image for larger version
ID:	2428398   Click image for larger version
ID:	2428400   Click image for larger version
ID:	2428404   Click image for larger version
ID:	2428406   Click image for larger version
ID:	2428408   Click image for larger version
ID:	2428410   Click image for larger version
ID:	2428422   Click image for larger version
ID:	2428424   Click image for larger version
ID:	2428426   Click image for larger version
ID:	2428428   Click image for larger version
ID:	2428432   Click image for larger version
ID:	2428434   Click image for larger version
ID:	2428436   Click image for larger version
BCRSS is online now
post #2 of 53 Old 07-14-2018, 12:38 PM
asarose247's Avatar
Quoted: 1229 Post(s)
Liked: 1076
and resounding throughout the seemingly endless rabbit hole labyrinthe of HT
a hearty and prolonged applause . .
BCRSS, rukus29 and bebb like this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #3 of 53 Old 07-14-2018, 12:45 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
I now had a game plan for speakers. I bought up sketch up once again. My think was going toward the 1099's and sealed subs. This is what I configured.
Seeing how much room I had switched me to going with ported subs.
But First I needed an equipment rack or stand. So I built one. No nails, screws all dowels and glue.
And painted .
I did not get any pics of my building the subs. They are roughly the same as a Johnny sub, slightly larger. Tune comes in around 18. Using HO18's
Now with the stand and subs done, I focused on the speakers. After measuring once again, I found I could shoehorn the1299's in the space. The 1299 drivers.
I started to cut window braces.
ID:	2428440   Click image for larger version
ID:	2428442   Click image for larger version
ID:	2428444   Click image for larger version
ID:	2428446   Click image for larger version
ID:	2428450   Click image for larger version
ID:	2428452   Click image for larger version
ID:	2428454   Click image for larger version
BCRSS is online now
post #4 of 53 Old 07-14-2018, 01:01 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
With the braces cut I started to dry fit my over braced 1299's
Oh ya I had to build some stands for the 1299's. Picture of stands I built along with my position of crossover.
I used speakon connections on all subs and speakers.
Leftover foam went into the1299 boxes
Boxes finished but needed to check my crossovers. I know they look bad but they all work.
Now that I have confirmed all crossover work, on to paint.
Paint done and happy with the outcome. I stuffed some poly on top of the foam on all boxes on the advise of @tuxedocivic
ID:	2428470   Click image for larger version
ID:	2428472   Click image for larger version
ID:	2428474   Click image for larger version
ID:	2428476   Click image for larger version
ID:	2428480   Click image for larger version
ID:	2428482   Click image for larger version
ID:	2428484   Click image for larger version
ID:	2428486   Click image for larger version
BCRSS is online now
post #5 of 53 Old 07-14-2018, 01:09 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Now the 1299's
All the boxes unwrapped.
Drivers installed.
This is where I am today and still need an avr, projector but have some ideas for my picowreckers in this pic. Will build a counter between them and see how that measure and maybe some nearfield if needed.
Thanks for putting up with all this.
Curt
ID:	2428496   Click image for larger version
ID:	2428498   Click image for larger version
ID:	2428500   Click image for larger version
EarlK, blister64, Pradeep2 and 7 others like this.
BCRSS is online now
post #6 of 53 Old 07-14-2018, 02:19 PM
BassThatHz's Avatar
Quoted: 3715 Post(s)
Liked: 4227
That's far from 0 in just 2 years.
For most people their home is 99% of their total wealth, so straight-up losing a home that you had potentially put years of investment into would be devastating to say the least...
The resulting bankruptcy is never fun either, taking years to recover from.
rukus29 and chadsmith013 like this.
BassThatHz is online now
post #7 of 53 Old 07-14-2018, 02:36 PM
notfastenough's Avatar
Quoted: 181 Post(s)
Liked: 209
Looks like a cool space! Should be fun with picos and ported 18s! Are you going to use DSP on iNuke only? I'm interested how the ported subs will blend with the horns.
What's the chances you'd be interested in a Denon AVR-X4200W? I might be in the market for an upgrade soon
BCRSS likes this.
notfastenough is offline
post #8 of 53 Old 07-14-2018, 02:57 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
My plan is to get a Nad 758v3 for AVR and see how that works with the horns and ported. If problems arise will look into a minidsp. Thanks for the offer on the Denon. Once the Nad gets here, I am looking at 4 Atmos speakers. Going with the Volt 6 but unsure ported or sealed yet.
BCRSS is online now
post #9 of 53 Old 07-14-2018, 03:01 PM
Quoted: 1012 Post(s)
Liked: 1261
Great work there, I'm taking a run to the dump tomorrow myself with all the empty boxes from various diysg speaker projects.
I believe most of the curent receivers will soon be on sale as 2018/2019 models are released in August/September.
BCRSS likes this.
Pradeep2 is offline
post #10 of 53 Old 07-14-2018, 03:21 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Well when I moved into this place, I had 2 suitcases and a 55gal. Rubbermaid container. So yes not 0 but going from This to what I carried into this place could be close to 0.
Jk7.2 likes this.
BCRSS is online now
post #11 of 53 Old 07-14-2018, 04:17 PM
Quoted: 229 Post(s)
Liked: 244
Great write up. Really good use of the space, like all of the posters you have around it. Bet it sounds great too!
BCRSS likes this.
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva LPA-1 (Currently Fried) | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Dayton Ultimax 15 | Crown XPS1000
Living Room Duty- DIY Swope TMWW LCR
Currently Building- (3) Stereo Integrity HS-24 mkiii's
blister64 is offline
post #12 of 53 Old 07-14-2018, 05:01 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Thank you. Room was really bad. Talking on phone people would ask me if I was in a tunnel. Now with the posters up, room is pretty dead. Sound quality I am hoping will be good. I only have a broken receiver with 1 channel working on it, so once the new one comes in, can take some measurements.
BCRSS is online now
post #13 of 53 Old 07-14-2018, 05:06 PM
johnson636's Avatar
Quoted: 1209 Post(s)
Liked: 702
I'm not sure which is more awesome; the come back or the room. Just fantastic!!
Jk7.2, Vital and BCRSS like this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #14 of 53 Old 07-14-2018, 05:14 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
I knew what I wanted since I used to have the 1099's with volt 10 and that just sounded out of this world. So my plan was the 1099's again but then found I could fit the 1299's and said H3ll ya I am going do it. Just playing one channel, I can tell these are going to be explosive with sound and clarity.
Jk7.2, Pradeep2 and Michael Mitten like this.
BCRSS is online now
post #15 of 53 Old 07-14-2018, 05:15 PM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
Echoing johnson636's statement. Congrats on the come back, the setup looks great!
BCRSS and allargon like this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #16 of 53 Old 07-14-2018, 05:39 PM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 902
Very nice! Grills look great.
BCRSS likes this.
Samps is offline
post #17 of 53 Old 07-14-2018, 05:43 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Thanks. I plan to have grills on the 1299's also. I have the fabric and want to follow the same round over as the volts. I was working on that layout today.
BCRSS is online now
post #18 of 53 Old 07-14-2018, 06:35 PM
Quoted: 229 Post(s)
Liked: 244
Hmm... 1.2 channel surround... you may have something there
BCRSS likes this.
post #19 of 53 Old 07-14-2018, 06:51 PM
Quoted: 24 Post(s)
Liked: 6
Wow, excellent job. I especially like the grills on the volts and the custom media stand.
I am interested to hear about how well this works in a non-ideal room. A lot of us don't have the luxury to build or buy a house with an ideal theater room. I ahve a feeling your sysytem is going to be rock-solid.
Sent from my ONEPLUS A3000 using Tapatalk
BCRSS likes this.
dan.john303 is offline
post #20 of 53 Old 07-14-2018, 07:10 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Thanks. The stand took about 5 different shapes before I settled on what was built. Took a while to get general dimensions of AVR's, inukes, cable box, and htpc to fit into what I had in my mind. Then sketchup ti bring that into a visual view help with the design. All shelves are removable if needed, but everything should fit as is.
I really wanted a 7.x.4 setup but room would not allow for that, so ending at 5.x.4 is what I will settle for. I think everyone wishes for that ideal home theater but compromises have to be met. I live alone so no WAF but still wanted wiring hidden and a clean look.
Once I finish grills for the 1299's will update this thread with more pictures.
BCRSS is online now
post #21 of 53 Old 07-14-2018, 07:55 PM
chrapladm's Avatar
Quoted: 1106 Post(s)
Liked: 448
Really awesome change of events. Also really like the way those 18HO's look. Reminds me of the NS18 cones a little bit. Happy things are shaping up for you.
BCRSS likes this.
chrapladm is online now
post #22 of 53 Old 07-15-2018, 08:27 AM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Thank you,
I really like the looks of the HO's and they had better response in the 50hz on up compared to the UM's. Not looking at chasing single digits with this setup but should play good with music or movies.
BCRSS is online now
post #23 of 53 Old 07-15-2018, 08:33 AM
tential's Avatar
Quoted: 413 Post(s)
Liked: 276
1899s would have been better for this space.
BCRSS likes this.
tential is offline
post #24 of 53 Old 07-15-2018, 10:15 AM
bgtighe23's Avatar
Quoted: 1846 Post(s)
Liked: 1231
Are the 1299s normally this tall or did you build a base for them?
BTW, those grills on the volts look great.
BCRSS likes this.
Receiver : Denon x5200
Front Stage : L/R - Statements by Jim Holtz
Surround Speakers : Klipsch RF-82II x 4 / RP-280F x 2
Subwooferage : 6 UM18/4 HT18 Subwoofer Log
bgtighe23 is offline
post #25 of 53 Old 07-15-2018, 10:20 AM
johnson636's Avatar
Liked: 702
I think @BCRSS made a wonderful choice with choosing the 1299s
BCRSS likes this.
post #26 of 53 Old 07-15-2018, 11:47 AM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Thank you.
These are the sealed 1299's and height wise are 40 inches. Ti bring the waveguide up to 36-38 inches I needed a base for then. The base is 12inches tall and waveguide is now at 36 inches. Almost perfect to ear height in my seating.
Thank You
I spent numerous hours in sketchup with different speaker/sub dimensions to find what would work. Not only in the space I had but also with the height I had with my screen. The subs I built could be turned down and would match up perfectly with my equipment stand. This thinking was in the line of using the subs as a stand along with the HTM or Fusion line. I could then run all three straight across. With those DIY lines I was having problems with the height from stand to screen. So it was either the 1099's or the 1299's. I had the 1099's and loved them , so got the 1299's for extra mid punch with the 12's.
johnson636 likes this.
BCRSS is online now
post #27 of 53 Old 07-15-2018, 05:59 PM
tk123's Avatar
Quoted: 168 Post(s)
Liked: 138
Why sealed ?
BCRSS likes this.
tk123 is offline
post #28 of 53 Old 07-15-2018, 07:34 PM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Originally Posted by tk123 View Post
Why sealed ?
This is an excellent question. My first thoughts on the 1299's were to go ported. With ported default dimensions would have been 12 inches taller for L/R channels and 12 wider for center. I could handle the L/R taller but if I went 12 wider on center, meant I would need to rotate the subs down to match the height of my equipment stand. The subs and the stand would match up height wise at that point, but would then limit me on the L/R speakers. I would not be able to toe them in and would need to move everything off center which then would put my right speaker into the doorway of my bedroom. So the logical choice was to go sealed. I thought with my picowreckers I could take up that lack of extension from the 1299's. If I am not satisfied after I get everything tuned in, I can still add more.
BCRSS is online now
post #29 of 53 Old 07-16-2018, 01:39 AM
tk123's Avatar
Quoted: 168 Post(s)
Liked: 138
Ok, makes sense then. Nice looking setup you have there. I really like the panels on the walls. Do you have a thread about them - What you used, how you built them, etc ?
BCRSS likes this.
tk123 is offline
post #30 of 53 Old 07-16-2018, 04:17 AM - Thread Starter
BCRSS's Avatar
Quoted: 502 Post(s)
Liked: 471
Thank you.
I do not have a thread on the posters. I followed general guides from this thread. https://www.avsforum.com/forum/19-de...els-cheap.html
The panels have made a BIG improvement with taming all the echoes and hollow sound. I am really looking forward to some measurements to confirm this once I get my Nad 758v3.
BCRSS is online now
