Ssd neo 18 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #61 of 86 Old 10-01-2018, 07:31 AM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
Originally Posted by michael hurd View Post
You can see from this picture where it came apart:
Motor picture. And, alternate of the basket showing all six fasteners. @michael hurd Looks like you are exactly correct. The motor fell apart.
ID:	2462512   Click image for larger version
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #62 of 86 Old 10-01-2018, 09:20 AM
michael hurd's Avatar
Quoted: 631 Post(s)
Liked: 667
I can not tell from the latest picture, it is too blurry to make out. Are the holes visible threaded or not?
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #63 of 86 Old 10-01-2018, 09:34 AM
mfagains's Avatar
Quoted: 12 Post(s)
Liked: 29
I just don't understand these "men" and this WAF BS....grow some balls...
And yes I am married...
I did. There really wasn't a good place with an acceptable WAF.
Sent from my Moto G (5) Plus using Tapatalk
drewp29 likes this.
mfagains is offline
post #64 of 86 Old 10-01-2018, 09:50 AM
notnyt's Avatar
Quoted: 3724 Post(s)
Liked: 3690
Yes a picture is indeed worth a thousand words. What I can see in the picture is that the bolts were too long. ( look at the threaded hole in the picture, and then again at your other picture linked below. )
The bolts are too short, not too long. They're meant to thread into the motor.
bebb likes this.
notnyt is offline
post #65 of 86 Old 10-01-2018, 11:14 AM
Quoted: 390 Post(s)
Liked: 336
Looks like neither of the bolts got threaded into the motor with one being comically short.
Trimlock is offline
post #66 of 86 Old 10-01-2018, 11:36 AM
Quoted: 631 Post(s)
Liked: 667
And the top plate of the motor is still on the basket, at least half of it.
post #67 of 86 Old 10-01-2018, 11:39 AM
notnyt's Avatar
Liked: 3690
Right, they didn't thread into the rest of it, though they should have.
Could probably scrape off the adhesive and save the sub with some fresh adhesive and/or tacks, but who knows how long it'd last for.
notnyt is offline
post #68 of 86 Old 10-01-2018, 11:43 AM
Quoted: 631 Post(s)
Liked: 667
It is not clear from the picture of the top of the detached motor if the holes are threaded. They would have had to be threaded at the same time in order for the bolts to pass through both pieces that are threaded.
post #69 of 86 Old 10-01-2018, 11:46 AM
notnyt's Avatar
Liked: 3690
Looked threaded, but you're correct. It may or may not be aligned. I'd imagine it should be.
That said, the different length bolts are a bit odd.
notnyt is offline
post #70 of 86 Old 10-01-2018, 12:59 PM
VicTorious1's Avatar
Quoted: 580 Post(s)
Liked: 667
Are there pieces of the threaded screws still remaining in the bottom plate? I can't imagine that the screws sheared off.
VicTorious1 is offline
post #71 of 86 Old 10-03-2018, 12:21 PM
Broke EF's Avatar
Quoted: 235 Post(s)
Liked: 340
So if WAF wont allow for subs in the living room, but you have a basement packed with subs why not put a TV down there?
Sean
Broke EF is offline
post #72 of 86 Old 10-04-2018, 09:41 AM
Quoted: 580 Post(s)
Liked: 667
Sean
I think putting a tv down there would cut into the space for his TBGS (that's tactile below-grade subs for those who don't know).
bebb likes this.
post #73 of 86 Old 10-13-2018, 01:41 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
Threaded.
bebb is offline
post #74 of 86 Old 10-13-2018, 01:42 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
Agreed. After @michael hurd wrote some of his posts, I realized my original assesment was wrong.
bebb is offline
post #75 of 86 Old 10-13-2018, 01:43 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
No.
bebb is offline
post #76 of 86 Old 10-13-2018, 01:44 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
Sorry about that. They are threaded. Yes, it looks like the fasteners are too short.
bebb is offline
post #77 of 86 Old 10-13-2018, 01:45 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
They did not.
bebb is offline
post #78 of 86 Old 10-13-2018, 01:47 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
Sean
Not a bad idea. But two reasons why not.
1.Stereo receiver and all the other speakers are upstairs.
2.Basement is unfinished and there is not furniture to speak of.
bebb is offline
post #79 of 86 Old 10-13-2018, 02:05 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
Final Update (I hope!!!)
Props to Scott, Brian, and Ficar Audio in general! Replacement speaker arrived today as promised (with a pre-printed shipping label to send the old one back.) Installed and tested with ALL my bass woofer test tracks. Had a couple tracks clipping the inuke 6k into the red. But speakers survived. Movies should be no problem. The original UM18s survived multiple movies but bass tracks killed 'em pretty quick. Remember, this was after running a dedicated 20 amp circuit and bass torture test trecks (like Bass I Love You, DJ Magic Mike, etc.) The subs got hot, and they have the electronic smell that electronics like amps get when hot so playing for long extended time with these tracks is not smart. But they survived all my test tracks. (Hear that @BassThatHertz ? I need some more tracks to test!)
Lessons? I don't know. Maybe that an inuke 6k kills subs rated for 1000 watts when a 20amp circuit is supplied to the amp, but a sub rated 1750 watts is OK, even when pushed. A Mach 5 Audio FTW-21 rated at 1200 watts RMS will probably not survive either. Two had the leads seperate from the coil when connected to my inuke 3k bridged. (The 6k is two bridged 3k's from what I understand.) When up close to the Ficar's in the ported cabs, my eyeballs even felt a little like @eng-399 's GTG when he cranked up the John Wick 2 underground scene. I was feeling as much as seeing. Hopefully these subs last a while.
bebb is offline
post #80 of 86 Old 10-13-2018, 02:26 PM
johnson636's Avatar
Quoted: 1122 Post(s)
Liked: 653
I,ve had 2 UM18 connected to an 6000dsp without any issues. Clipping an amp is never healthy for the amp or the subs.
Trimlock likes this.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #81 of 86 Old 10-13-2018, 03:53 PM
notfastenough's Avatar
Quoted: 162 Post(s)
Liked: 191
The lesson? Nothing is foolproof because fools are ingenious?
bebb likes this.
notfastenough is online now
post #82 of 86 Old 10-13-2018, 05:16 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
I did not have any issues until I played the bass tracks that torture subs. Music an movies were OK at first and I never tripped my 15amp breaker, either. Once I tried to play the bass torture test tracks, I was tripping my breaker in a couple seconds. I ran a dedicated 20 amp breaker. Then, I stopped tripping breakers but started frying subs.
bebb is offline
post #83 of 86 Old 10-13-2018, 05:17 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
I resemble that remark.
bebb is offline
post #84 of 86 Old 10-13-2018, 07:41 PM
johnson636's Avatar
Liked: 653
clipping is bad no matter how you slice it. If proper limiters were set, I seriously doubt you would have burned those UM18s
post #85 of 86 Old 10-14-2018, 05:10 PM - Thread Starter
bebb's Avatar
Quoted: 218 Post(s)
Liked: 156
Quite possibly. I did NOT have a mini DSP at the time and did not set the amp limiters. But, sealed so figured it was OK. With the Ficar SSD neo subs, I have three 6 inch vents. So I now use a mini DSP, set from modeling to limit xmax at lower frequencies. MiniDSP set as high pass 4th order Butterworth at 22Hz now.
Movies and music were fine with the UM 18s. It is the woofer torture tests that initially tripped the breaker. With a dedicated circuit that did not trip, the UM 18 subs burned up. With the replacement Ficars all is good (so far).
bebb is offline
post #86 of 86 Old 10-15-2018, 06:58 AM
johnson636's Avatar
Liked: 653
A clipped signal will eventually burn up a 24. Just saying.
