Ssd neo 18 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #1 of 86 Old 07-31-2018, 08:43 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
Ssd neo 18
Finally, after a month and a half, shipment coming! I can soon replace the blown UM 18's!
I plan to port the 10 cubic ft sealed boxes I had the UM 18's in. WinISD shows a good response with that enclosure and a 3/4" long 4" port. What a coincidence, MDF is 3/4" thick!
No REW for measurements, but that's OK because I have them in the basement under the living room where we watch movies. Mostly for tactile response. Will update with my impression after installed in case anyone on here decides to try the Ficar SSD neo 18's.
ID:	2435660   Click image for larger version
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #2 of 86 Old 07-31-2018, 08:58 PM
Quoted: 3946 Post(s)
Liked: 16295
What does port velocity look like?
Take the Red Pill (BassEQ) BassEQ Demo Clips TR Curves
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #3 of 86 Old 07-31-2018, 09:14 PM
corradizo's Avatar
Quoted: 1554 Post(s)
Liked: 1638
corradizo is offline
post #4 of 86 Old 08-01-2018, 05:07 AM
johnson636's Avatar
Quoted: 1753 Post(s)
Liked: 1281
https://www.avsforum.com/forum/155-d...to-ported.html
Just as a visual
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #5 of 86 Old 08-01-2018, 07:00 AM
Samps's Avatar
Quoted: 1338 Post(s)
Liked: 1009
Do not use a single 4" port.
That driver needs much more port area.
Three 4" ports might work.
Erich H likes this.
Samps is online now
post #6 of 86 Old 08-01-2018, 09:00 AM
BassThatHz's Avatar
Quoted: 4052 Post(s)
Liked: 4571
You aren't really a true basshead until you've fried at least 1 DIY sub...
BassThatHz is online now
post #7 of 86 Old 08-01-2018, 02:04 PM
Quoted: 569 Post(s)
Liked: 474
It’s not a good feeling either
Trimlock is offline
post #8 of 86 Old 08-02-2018, 08:39 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
Good question. I don't see where WinISD specifies. I do question the 9099 Hz resonance.
bebb is offline
post #9 of 86 Old 08-02-2018, 08:39 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
Originally Posted by corradizo View Post
30hz tune?
Just about. WinISD lists 29.xx Hz.
bebb is offline
post #10 of 86 Old 08-02-2018, 08:41 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
Well, since I had to return two FTW-21's and fried 3 UM 18's, I's say I qualify.
bebb is offline
post #11 of 86 Old 08-02-2018, 08:42 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
Why do you say it need more than a single 4"?
bebb is offline
post #12 of 86 Old 08-02-2018, 08:50 PM
VegaMan's Avatar
Quoted: 106 Post(s)
Liked: 81
you don't "need" more than a single 4" port, but intuition tells me, after the first 100 watts you are going to suffer from port chuffing strong enough to put out the flame on a gas stove; nevermind a candle.
VegaMan is offline
post #13 of 86 Old 08-02-2018, 08:50 PM
Liked: 16295
Did you look at port velocity?
post #14 of 86 Old 08-02-2018, 08:53 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
No. I do not see where that is displayed in WinISD.
bebb is offline
post #15 of 86 Old 08-02-2018, 08:59 PM
Liked: 16295
Please don't take this the wrong way, but you really need to study up on WinISD before you go any further designing and building subs.
Key Items:
Maximum SPL
Cone Excursion
Port Velocity
First Port Resonance
Until all of those are optimized, it is not a viable build.
post #16 of 86 Old 08-02-2018, 09:31 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
Key Items:
Maximum SPL
Cone Excursion
Port Velocity
Actually, the way I look at it, building from modeling is the way to learn. I guess that's how I study up on it? Your point is taken, though. Don't try building something until you know what you are doing.
Looking further, I now see the port velocity graph. Way too high. Need to rethink some.
And, thank you to all who posted and asked about the port velocity. I didn't realize how to find that (now I do). More to come...
bebb is offline
post #17 of 86 Old 08-03-2018, 03:05 AM
BassThatHz's Avatar
Liked: 4571
The general rule of thumb is that you need to 4x it.
So... you really need 16 or 32 18's, not 3.
A subwoofer-array basically gets twice as efficient for each doubling of cone area.
So eventually it will either:
Get loud enough...
or
you'll run out of space/breakers/money trying to...
(whichever comes first!!! )
I've been told that 1 24 is about as loud as 2 or 3 18's.
Back in 2010 I "only" had 9 subs, and I was STILL blowing up woofers trying to get... "enough-bass"
Now that I have 29 subs I'm starting to reach limits of my personal-preference. So I think this is "almost-enough" at this point... FINALLY!
Adding another 32 subs and 16 amps just to gain 6 MOAR DeeBee's seems highly-impractical at this point. To say the least...
stegen, 18Hurts and bebb like this.
post #18 of 86 Old 08-03-2018, 10:26 AM
Quoted: 569 Post(s)
Liked: 474
I like to compare with max power, RMS and my targeted power to see what I can get away with the port. Once you start raising air velocity port compression robs your LF too.
http://www.subwoofer-builder.com/port-compression.htm
I couldn’t find the chart that details port compression to air velocity.
bebb likes this.
Trimlock is offline
post #19 of 86 Old 08-04-2018, 09:04 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
unpackaged
Well, the Ficar SSD Neo 18's were unboxed. Interestingly, the baskets are THE SAME as the UM18's!
Also, this design has the voice coil visible. Interesting.
ID:	2437432   Click image for larger version
ID:	2437434   Click image for larger version
bebb is offline
post #20 of 86 Old 09-11-2018, 04:44 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
old thread new issue
Well, after thoroughly enjoying my new speakers, a magnet fell off of one. There is a cabinet brace right below that the magnet was sitting on. So it still mostly worked. Because something seemed wrong, I removed the (much lighter) speaker. WTF?
Hello! Am going to contact Ficar and tell them the screws are too short, with one not even through the hole. They did not back off based on the fact that the screw heads do not have any visible space below them.
bebb is offline
post #21 of 86 Old 09-12-2018, 05:11 AM
johnson636's Avatar
Liked: 1281
Man that's crazy! Seems as if you're having some incredibly bad luck when it comes to drivers.
post #22 of 86 Old 09-12-2018, 06:32 AM
Quoted: 569 Post(s)
Liked: 474
I think there is a higher power that just doesn’t want you to enjoy bass.
bebb likes this.
Trimlock is offline
post #23 of 86 Old 09-12-2018, 06:16 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
Agreed. Makes me think I should give up.
@Trimlock -had the same thought.
bebb is offline
post #24 of 86 Old 09-12-2018, 06:20 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
Got a response from Ficar. Scott will get back to me about making it right.
Will continue to update the saga as it unfolds.
@BassThatHz -Does this one count as #4 or not because a manufacturing defect? Personally, I would say not, but you never know.
bebb is offline
post #25 of 86 Old 09-22-2018, 03:51 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
patience
Brian responded back this week. He said Scott is making another and it will be shipped when done. If that is the case, then wow, awesome customer service. I can't complain overall.
bebb is offline
post #26 of 86 Old 09-22-2018, 05:58 PM
DaBateman's Avatar
Quoted: 722 Post(s)
Liked: 521
Glad you’ve had a good experience with them. How do you think the sound signature compares to the UM18?
I’m wanting to get one of their HT1 18’s when they’re released
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #27 of 86 Old 09-29-2018, 03:24 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
well...
I like them. They have not blown up from the inuke6k like the Daytom UM18s did. However, I am still waiting for the replacement sub. It has not arrived yet. If it does, then it will be a good experience.
As far as the sound signature, I am not sure I understand what that is? I can say I like the subs. However, I have them in the basement, below the living room where we watch movies. So the sound signature is not somoething I can comment on. I use them for tactile feel for the house. In that regard, they do well. With only one sub right now, it still vibrates the house. So I like them in my application.
bebb is offline
post #28 of 86 Old 09-29-2018, 04:03 PM
michael hurd's Avatar
Quoted: 660 Post(s)
Liked: 714
Huh? So you do not have the subwoofers in the room that you use to watch movies? That's going to be part of your problem with short lifespan, if you are over drivng them in order to get levels that are satisfying.
bscool and notfastenough like this.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, impulsivity, uncontrolled or repeated movements.
michael hurd is offline
post #29 of 86 Old 09-29-2018, 04:12 PM
Quoted: 660 Post(s)
Liked: 714
Huh? So you do not have the subwoofers in the room that you use to watch movies? That may be part of your problem with short lifespan, if you are over drivng them in order to get levels that are satisfying.
post #30 of 86 Old 09-29-2018, 11:28 PM - Thread Starter
bebb's Avatar
Quoted: 232 Post(s)
Liked: 167
The ultimax's were initially fine for movies and my music. So not overdriving because in a different room. Overdriving and frying three UM18s with dedicated bass tracks AFTER I added a dedicated 20 amp circuit. Prior to that, I never tripped the breaker. The bass tracks (Bass I love you, Bass Mekanik - Bass Ballin' (Feat. Tec, Gangsta Big And G.I.) etc) kept tripping the original breaker after a few seconds. Added the dedicated 20 amp circuit, stopped tripping the breaker. Instead, killed subs. Went to the Ficar SSD neos because they have a higher RMS rating. They have been good so far.
The Ficar issue is one had the magnet fall off because 5 of the 6 fasteners too short with only what appears to be a partial thread engaged into the magnet. The sixth fastener is WAY too short as it does not even protrude through the frame. So, I contacted Ficar. They responded back through email that another will be/has been sent.
bebb is offline
