Piece by Piece QSC SC-2180 build - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 52Likes
post #31 of 82 Old 08-15-2018, 05:32 PM
Mahuzz13's Avatar
Quoted: 307 Post(s)
Liked: 428
I don’t even have to start a build I getting all the answers here.
Just kidding don’t want to over take this thread like I already have
Mahuzz13 is online now
post #32 of 82 Old 08-15-2018, 05:38 PM - Thread Starter
johnson636's Avatar
Quoted: 1121 Post(s)
Liked: 653
Originally Posted by Mahuzz13 View Post
I am new to all this so please correct me if I am wrong, I think they are tuned to 40hz so does that mean they are crossed at 40 or would it be higher
The 40 Hz tune refers to the enclosure, Your crossover will be set by your AVR. I believe the only way to cross your mains at 40 HZ is to set your them to Large +LFE...don't quote me on that.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #33 of 82 Old 08-15-2018, 05:41 PM
Mahuzz13's Avatar
Quoted: 307 Post(s)
Liked: 428
That makes sense now and I think you are right.
post #34 of 82 Old 08-27-2018, 06:39 PM - Thread Starter
johnson636's Avatar
Liked: 653
Crossover will be here soon
Name:	Xover tracking.jpg
post #35 of 82 Old 08-31-2018, 10:52 PM
rlhaudio's Avatar
Quoted: 330 Post(s)
Liked: 113
[QUOTE=johnson636;56708662]Crossover will be here soon[IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
Did you buy the terminal with the crossover? You wire the tweeter and midrange via neutrik. It allows passive or bi-wire setup. I have 3 2150's and 8 8101s for surrounds and atmos. I have part numbers for a lot of their speakers and subs. I was thinking about selling the parts and building a larger screen array. I DIY all the speakers, no difference between drivers and no serial numbers needed, at least not when I ordered. I ordered online via parts website. My room is 16x24. I have an AT screen and I suggest building a baffle wall. It helps increase midbass. I also added 2 PA460s, 3 15" subs and 4 18" subs. your gonna love these for movies. Be sure to buy the mounting brackets for the waveguides.
Marantz 7702mk2, Panasonic 8000 w/ 130" AT Screen HTPC w/48 tb
DIY QSC SC-2150 L,C,R (10) QSC SR-8101 sides, rears & atmos/dst-x
DIY (4) Fusion Tempest, 88 Special
DIY (6) JBL cx12" UM-15", SI-18" subs, BFM Tuba HT, Dayton MKIII 15", (2) PA460 mbm
rlhaudio is offline
post #36 of 82 Old 09-01-2018, 08:48 AM - Thread Starter
johnson636's Avatar
Liked: 653
[quote=rlhaudio;56733244]
The Crossovers have arrived, but I'll have to post pictures after I get home from WDW I didn't have any plans to purchase the terminal plate because the tweets and mids will remain passive. I see no benefit with active now that I have the passive crossovers. As for the woofers, as I said, I'll be using PA460s in place of the celestion 15s I plan to run the PA460s active and have them play down to 40Hz. Speaking of a larger screen array, wouldn't 3 SC-223's be nice
Jk7.2 likes this.
post #37 of 82 Old 09-01-2018, 10:38 PM
rlhaudio's Avatar
Quoted: 330 Post(s)
Liked: 113
[quote=johnson636;56734674]
the crossovers will remain passive. The Terminal is for connecting the waveguide tweeter and midrange to the terminal with a Neutrik connector. It does have a switch that selects passive or bi-amp although you wont need to bi-amp. They are crazy loud.
I guess you could wire the speakers directly to the crossover but its gonna be more of a PITA. The woofers are in separate boxes, the crossover allows the speaker to continue working IF you blow a single woofer.
Be sure to post pics as you go. They're really good for home theater. I just built new boxes (not as wide as the actual 2150's and used a slot port instead of 4" round ports which eat up alot of cabinet space. You can still here the midbass from the QSC's however a pair of PA460 can produce more SPL.
Mahuzz13 likes this.
rlhaudio is offline
post #38 of 82 Old 09-02-2018, 05:22 PM
Quoted: 33 Post(s)
i dont have the QSC SC-223's but i have these.
mh-1063 tops
jbl 2226 in 5 cubic feet, tuned to about 35 hz
each run off an inuke 3000 dsp.
crossed around 300hz with LR24
ID:	2450184   Click image for larger version
johnson636 and VicTorious1 like this.
kuzul is offline
post #39 of 82 Old 09-02-2018, 09:41 PM - Thread Starter
johnson636's Avatar
Liked: 653
mh-1063 tops
If you don't mind me asking, how did you come to acquire the MH-1063 tops?
post #40 of 82 Old 09-02-2018, 10:00 PM
Quoted: 33 Post(s)
ebay
kuzul is offline
post #41 of 82 Old 09-06-2018, 08:12 AM - Thread Starter
johnson636's Avatar
Liked: 653
No turning back now
I finally got around to posting some pics of the crossovers for the 2150s. I'd say they were really well packaged. Ordering these was a pain. QSC has made it darn near impossible for you to order the crossover Luckily I managed to order them My plan is to run the mids and highs on the cross over and run the PA460s actively (I have more than enough channels), but I'm going to test the PA460s with the crossover just to see how they sound
ID:	2451594   Click image for larger version
ID:	2451596   Click image for larger version
ID:	2451598   Click image for larger version
ID:	2451600   Click image for larger version
post #42 of 82 Old 09-25-2018, 03:39 PM
Mahuzz13's Avatar
Quoted: 307 Post(s)
Liked: 428
I see that you got your XO very nice.
I am trying to figure out how to hook up mine to the toggle switch for bi-amp or passive option and it is not are easy as I thought it would be, I even reached out to QSC and they couldn't even help me. I understand almost everything but all the "E"numbers that attach to the toggle switch, there is no where on any thread or on line that I can find the schematics for this. I was hoping some could just say you don't have hook it up just do this and I will be happy. Please someone help me out thanks
post #43 of 82 Old 09-25-2018, 03:50 PM - Thread Starter
johnson636's Avatar
Liked: 653
Well ok I'll say it, you don't have to hook it up. Just run your speaker wire straight from the crossover to your speakers... That's what I'll be doing. That terminal plate is used to simplify the switch between passive and bi amping. If you don't plan on bi-amping, then you don't need it
post #44 of 82 Old 09-25-2018, 04:04 PM
Mahuzz13's Avatar
Quoted: 307 Post(s)
Liked: 428
The problem is I cut the spot where that toggle switch goes can I use part of it for input and the speakon connection to the mids and tweeter or do I have to by-pass the whole thing
post #45 of 82 Old 09-25-2018, 06:42 PM - Thread Starter
johnson636's Avatar
Liked: 653
You can use it; it's your call. I would just bypass it.
post #46 of 82 Old 10-16-2018, 03:52 PM
Mahuzz13's Avatar
Quoted: 307 Post(s)
Liked: 428
Hey where you are with your process in getting all your components to your QSCs?
post #47 of 82 Old 10-17-2018, 02:22 PM - Thread Starter
johnson636's Avatar
Liked: 653
Currently paying down credit card debt I plan to purchase the SP-000085-GP next
post #48 of 82 Old 10-17-2018, 02:27 PM
Mahuzz13's Avatar
Quoted: 307 Post(s)
Liked: 428
Currently paying down credit card debt I plan to purchase the Eminence Alpha-6CBMRA next
That’s an ongoing thing isn’t it debt, can’t wait to see how you complete yours. I am very pleased on how mine turned out, the pictures don’t do the speaker justice, they are big and sound is incredible you will be very pleased when you are done so worth it
post #49 of 82 Old 10-17-2018, 03:55 PM - Thread Starter
johnson636's Avatar
Liked: 653
Man, you did one helluva job on your 2150s. It looks like you went with the single brace/divider as the original, correct?
post #50 of 82 Old 10-17-2018, 04:01 PM
Mahuzz13's Avatar
Quoted: 307 Post(s)
Liked: 428
Yes I did but I did add some extra braces that were probably not needed at all but oh well.
What are you planning for ports slotted or what I did? If you go with the precision ports you do not need the whole kit from PE, the perfect length is the two ports connected with the connection ring it is 6” exactly in length by 4” in diameter
post #51 of 82 Old 10-17-2018, 04:14 PM - Thread Starter
johnson636's Avatar
Liked: 653
I plan to go round ports. My build won't be based off the original design, I plan to steal @Jk7.2 design, but run dual PA460s
Jk7.2 likes this.
post #52 of 82 Old 10-17-2018, 04:16 PM
Mahuzz13's Avatar
Quoted: 307 Post(s)
Liked: 428
Nice I was going that route but decided I will have enough mid bass and bass in my room so I didn’t want to change the original set up
post #53 of 82 Old 02-07-2019, 10:31 AM - Thread Starter
johnson636's Avatar
Liked: 653
Finally got around to purchasing the mid and CD. Amazingly, I was able to snag the CDX1-1425's (promotional discount) for $33 each from Newark Element14. Ended up costing me $109.16 shipped for all 3 It looks like the only thing left to purchase is another minidsp, and the PA460s.
ID:	2521606   Click image for larger version
Jk7.2 likes this.
post #54 of 82 Old 02-07-2019, 05:22 PM
hd0823's Avatar
Quoted: 679 Post(s)
Liked: 1251
Looking good it's crazy how good these things sound for such cheap components.
Sent from my SM-N950U using Tapatalk
johnson636 likes this.
hd0823 is online now
post #55 of 82 Old 02-07-2019, 05:48 PM - Thread Starter
johnson636's Avatar
Liked: 653
Did you end up building a baffle wall for your 2150s? I won't be utilizing one. I believe I'll be ok given I'll be using a different woofer and active crossover via minidsp.
post #56 of 82 Old 02-07-2019, 06:58 PM
hd0823's Avatar
Quoted: 679 Post(s)
Liked: 1251
Yeah with you using the external dsp you should be fine but yeah mine are in a dedicated baffle wall.
post #57 of 82 Old 04-02-2019, 04:28 PM - Thread Starter
johnson636's Avatar
Liked: 653
Finally began to build the boxes. I was reluctant to post pics of the boxes as I went along because they are just VBSS's and everyone has seen these a time or two...but what the hell. I had a good mind to adjust the parameters to a smaller size as these are some big boxes. Oh, my granddaughter has put her mark on this build as well by redesigning my dust caps. She got what was coming to her sure enough...Hugs and kisses
ID:	2548016   Click image for larger version
ID:	2548018   Click image for larger version
ID:	2548020   Click image for larger version
ID:	2548022   Click image for larger version
post #58 of 82 Old 04-02-2019, 06:18 PM
VicTorious1's Avatar
Quoted: 580 Post(s)
Liked: 667
You can vacuum those dust caps out.
johnson636 and Jk7.2 like this.
VicTorious1 is offline
post #59 of 82 Old 04-03-2019, 05:28 AM - Thread Starter
johnson636's Avatar
Liked: 653
I saw a vid of some guy doing that. I was too much of a scaredy cat to try it. I ended up using duct tape. I lost some of the material doing so, but you can't notice it unless you're right up on them.
post #60 of 82 Old 04-03-2019, 06:36 AM
dasa2131's Avatar
Quoted: 53 Post(s)
Liked: 57
Beautiful work, sir! Based on your comments above, you have the patience of a saint. I look forward to seeing more pictures of your build.
Dave
dasa2131 is online now
