Piece by Piece QSC SC-2180 build - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #1 of 88 Old 08-04-2018, 06:06 PM - Thread Starter
johnson636's Avatar
Quoted: 1146 Post(s)
Liked: 671
My initial intention was to purchase the Titans from ErichH (ordered the flat packs and everything), but I have so many projects going on right now I had to put the Titans purchase on the back burner. I searched and searched for options in which I could piece a build together over time and I finally found one that caught my eye; the QSC 2150 clone. I could order the parts at different times until I eventually have all the pieces to begin the build. Now the reason I mentioned variant in the title is because I'd rather use another 15 than Celestion TF1530. It would be really cool if I could use the PA460. The thought of a dual 18 LCR would definitely be awesome I could use the stock crossover for the tweeter and the mid, leaving me to go active for the PA460s. An alternative to that would be Eminence Deltalite II 2515 Neo 15". Now I know a dual 18 inch speaker is impractical and that's fine, but you only live once
*Edit* Due to the excellent name suggestion by @hd0823 , I've decided to edit the title and name of this build to QSC SC-2180
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 MOFO 15s in 2 dual ported cabs 17Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #2 of 88 Old 08-04-2018, 06:20 PM
Quoted: 174 Post(s)
Liked: 132
Sounds like a very cool project. How does the price point of this set up compare to the Titan? How hard is it to source the wave guide, cross over, and drivers? I am hoping to be able to do a dedicated room in the near future and i love the idea of the titan but would love to see other options. Good luck with the build.
Randy
Randy_J is offline
post #3 of 88 Old 08-04-2018, 06:29 PM - Thread Starter
johnson636's Avatar
Liked: 671
The 2150 would be cheaper by my math. Especially If I'm able to use the PA460s.
The only problem piece would be the crossover because you need to provide a serial number of an actual 2150 If all else fails I go full active. I have more than enough channels of amplification
Randy
I'm sure the titans kick butt, but you gotta love the idea of dual 18 mains
post #4 of 88 Old 08-04-2018, 06:54 PM - Thread Starter
johnson636's Avatar
Liked: 671
According to PE's measured response, the PA460 is only down about 3 or 4db at 500Hz. Any reason it couldn't get the job done?
Name:	PA460 graph.png
post #5 of 88 Old 08-04-2018, 10:40 PM
eng-399's Avatar
Quoted: 2418 Post(s)
Liked: 4963
Dual 18’s would be fun I floated the same idea around for a while debating if I should do the exact build your doing right now. The crossover part will be the issue so just run them off a mini dsp 10/10 for this if you have enough channels. The bass and midbass should be nuts from this.
As for the waveguide from qsc I think I paid around 40$ for one of them. There different than the titans waveguide but close. They have a slight different pattern when putting them next to each other. If you want use the same cd and mid as the Titan Just buy the the adapter piece for that from parts express to fit the qsc waveguide. That was my plan
johnson636, Jk7.2 and Jan3 like this.
eng-399 is offline
post #6 of 88 Old 08-04-2018, 11:25 PM - Thread Starter
johnson636's Avatar
Liked: 671
I actually considered using the CD that the titans use but thought it would be best not to since I had an agreement with Erich to purchase the Titans. He made special concessions for me in regards to the flat pack so I didn't want to burn any bridges. Besides, I've heard mostly great things about the 2150 and the parts they use. I just have an itch for dual 18s. I'm not seeing any reason why not to use the PA460 as a woofer. Maybe someone else has some info in that regard.
post #7 of 88 Old 08-05-2018, 09:40 AM
Lickity Split's Avatar
If your using the QSC WG the Celestion CDX 1730 is the bolt on version of the CDX 1731 used in the Titan
Lickity Split is offline
post #8 of 88 Old 08-05-2018, 12:32 PM - Thread Starter
johnson636's Avatar
Liked: 671
If I were to go full active, then that would be a great idea, but I don't believe the 1730 would work with the stock crossover. Any thoughts on using the PA460 as a woofer?
post #9 of 88 Old 08-05-2018, 02:33 PM
I have no idea about the woofer. I’m in a similar situation as you. I really wanted 2150’s or titans but can’t afford either option atm. So in the end I picked up 3 QSC KW153’s and found 2 QSC hpr153’s. The HPR’s would be a single woofer, powered 2150. It uses the same WG and Celestion 1425CD. The KW’s use a 1730 CD. Have you considered these as a cheaper alternative?
post #10 of 88 Old 08-05-2018, 05:28 PM - Thread Starter
johnson636's Avatar
Liked: 671
Wow, the KW153's are listed for around $1450 each. 3 of those would be 3 time as much as either the 2150 o the Titans. The hpr153’s are nice, but I'm stuck on dual 18's What are your impressions of the hpr153’s?
post #11 of 88 Old 08-05-2018, 06:17 PM
Lol. USED is the key word here. Took me a while but I managed to acquire 3-kw’s, 2-hpr 153’s 2-hpr151’s and 2-hpr181’s for around $4kCND which is basically free in USD. lol
I didn’t particularly need the hpr subs but it was an all or nothing deals in both cases.
I wish I could give you a decent review of how they sound but I don’t even have a HT room. I have small 12x11 room in my basement that I’ve set all these in along with 2 sealed UXL’s and a EAW double 18 cab. I have them just running through an Onkyo sc886 prepro and minidsp 88a for the subs/mids. Oh yeah I almost forgot. I have a 22” monitor hooked up. Lol
At this point Because I can’t afford to build a room and all the equipment all at once I’ve just started collecting speakers and when I have the time and money I’ll try to get a room together.
Anyway back to your question. How do they sound? I think “good” but keep in mind what I’m dealing with. In my room I have enough room for 1 chair and I’m about 3ft away in either side from the hpr’s. Probably has to do with ground hums because Of everything plugged in that room but they do hiss slightly. Not bad and not loud but I can hear it slightly from 3 ft away. I can’t hear the kw’s until I’m about a foot away. If I had to choose between the kw’s and hpr’s I’m really not sure what I’d pick. The kw’s have a better CD but the hpr’s have fanless amps, both sound “good” but I’ve never a/b’d them in a decent room against a decent speaker... they are pretty decent speakers. If you were set on 2150’s and you found a cheap set of hpr’s you wouldn’t be making a mistake by grabbing them. I emailed qsc to compare them. They told me the hpr is the closest thing to a 2150 they have. He said the biggest difference is the x curve is slightly different than the 2150. And I think I read somewhere that the hpr crosses @ 600hz opposed to the 2150’s 500.
As for right now I’m just playing and trying different stuff out. In the end I may not even use the hpr’s as rears since the space I have allotted for my ht room is only 12-13’ wide x 20 long so idk if I’ll even have the width for them with a couch or theatre chairs. I have another pile of QSC wall mount speakers in the event the 3 way surrounds don’t work.
I’d also like to play around with the hpr by isolating the top chamber as it currently shares it with the woofer and I’d like to sound dampen it.
Idk if I actually answered your question.
johnson636 likes this.
post #12 of 88 Old 08-05-2018, 06:20 PM
Oh yeah. And I also have the hpr 181/151’s running with the kw’s/hpr’s and I’m using the subs 100hz lpf and running it to the 153’s so they only play 100hz and up and 181/151’s down to 50 and UXL up to that and the EAW 50 and up also
post #13 of 88 Old 08-05-2018, 06:26 PM - Thread Starter
johnson636's Avatar
Liked: 671
Well know I'd eventually build my lcr, I purchased 3 of the monoprice PA 15s. My room isn't treated yet, but audyssey does a very good job taming them. they actually sound very good. They allow me to take as much time as I need to complete my build that for sure
post #14 of 88 Old 08-05-2018, 07:28 PM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
I'll be watching this thread I have the oem 2150s and love how they sound. I'm very intrested on how they will sound with dual 18s
Sent from my SM-N950U using Tapatalk
hd0823 is offline
post #15 of 88 Old 08-05-2018, 07:34 PM - Thread Starter
johnson636's Avatar
Liked: 671
I've heard the oem 2150's use a different 15" woofer that has a longer stroke, is this true?
post #16 of 88 Old 08-06-2018, 02:39 AM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
When I was researching buying or diy that's what I came across to. I'm not sure how true it is or if it's QSC saying that so people don't make clones
hd0823 is offline
post #17 of 88 Old 08-06-2018, 08:12 AM - Thread Starter
johnson636's Avatar
Liked: 671
@Mahuzz13 , You are much further along than I am so I'd like to hear your impressions of the 2150s when you're done. Will your 2150's be installed in a dedicated theater room? How large is the room. Like yourself, I decided to use the HF adjustable bracket so that I will have flexibility with my enclosure size. Using 18's may require a slightly taller cab to work in my room configuration.
post #18 of 88 Old 08-06-2018, 08:29 AM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Piece by Piece QSC SC-2150 variant build
My room is not dedicated, I do have a thread build if you want to check it out. The room sized is 17 x 23 then minus 2’ behind the screen so really 17 x 21. I will 4 UM18-22s in 10cu boxes, similar to Mike’s and Jared’s look but with a baffle wall.
https://www.avsforum.com/forum/19-de...2969816?page=9
Not sure why that link I provided says that as the title but the link goes to my build
eng-399 likes this.
Mahuzz13 is offline
post #19 of 88 Old 08-06-2018, 04:42 PM - Thread Starter
johnson636's Avatar
Liked: 671
That room is going to be absolutely awesome
post #20 of 88 Old 08-15-2018, 11:11 AM - Thread Starter
johnson636's Avatar
Liked: 671
Man, wouldn't it be cool to have 3 SC-223
post #21 of 88 Old 08-15-2018, 02:39 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Thanks Johnson
Mahuzz13 is offline
post #22 of 88 Old 08-15-2018, 02:42 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
I’m going to start my build of my QSC2150s
Would you know if there would be double front baffle for the 2 drivers? Just makin a cut list for the boxes and I wasn’t sure if it had a double or not
Mahuzz13 is offline
post #23 of 88 Old 08-15-2018, 02:56 PM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
I think you'll be fine with one.
hd0823 is offline
post #24 of 88 Old 08-15-2018, 03:06 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
I know it would be much difference but wouldn’t it change the internal volume without having the double baffle.
Mahuzz13 is offline
post #25 of 88 Old 08-15-2018, 04:51 PM - Thread Starter
johnson636's Avatar
Liked: 671
Not if you have the baffle attached to the outside of the left and right panels.
post #26 of 88 Old 08-15-2018, 04:57 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Hmmm I think I get it but for some reason I thought I was told or read it somewhere that it is a double baffle, the inside one sits in between the left and right and the one on top sits like you said. But if it is not needed great. Maybe Jeremy could chime in because the person (I think Steve) where he bought his QSCs from can’t remember his AVS name said it was double baffle.
Mahuzz13 is offline
post #27 of 88 Old 08-15-2018, 05:23 PM - Thread Starter
johnson636's Avatar
Liked: 671
You can build a double baffle, but if crossing over at 80 you should be ok with a single.
post #28 of 88 Old 08-15-2018, 05:23 PM
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
I j
I just talked to steve he said single baffle but there is a board between the top and bottom 15s to make them each in there own chamber.
cdy2179 likes this.
hd0823 is offline
post #29 of 88 Old 08-15-2018, 05:30 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
I am new to all this so please correct me if I am wrong, I think they are tuned to 40hz so does that mean they are crossed at 40 or would it be higher
Mahuzz13 is offline
post #30 of 88 Old 08-15-2018, 05:30 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
I jI just talked to steve he said single baffle but there is a board between the top and bottom 15s to make them each in there own chamber.
Perfect thanks for asking Steve and clarifying that
Mahuzz13 is offline
