Speaker settings and calibration - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-06-2018, 10:55 AM - Thread Starter
Liked: 2
Hello everyone,
just finished my HT room and i would require some help in setting up my system. So my room size is 13x 17 x 8 ft and i have a 7.2.4 setup :
- LCR = HTM 12's
- surrounds = volt 8's
- Atmos =volt 6's
- SW = 2 x Dayton RSS460HO -4 18" installed in ported Stonehenge cabinets
receiver = Yamaha RX A-3070
Amp for LCR= Emotiva XPA 3 - Gen 3
SW Amp - Inuke 6000Dsp
I did run YPAO with multiple positioning and angle check . The Inuke i left it at default settings with SW volume turned 3/4 up.
I am getting error on LCR as out of phase . Researching online i find this error pretty common and sometimes considered an YPAO error. I checked my wirring seems fine unless they are inverted in Emotiva or Monoprice cables from receiver to amp.
YPAO also set all my speaker to Large . Researching online i find that people recommend setting them to Small with crossover at 80Hz . Switching to small i noticed they were all at 60Hx and Center at 40Hz.
I understand that settings are not all the same because of the rooms response but can someone suggest some settings based on my speakers and system setup that would be a starter point for me to fine tweak after? Inuke has also a lot of settings and i am not really sure what to tweak in there to get the most of the speaker combination.
ID:	2438182   Click image for larger version
Bravebubu is offline
post #2 of 3 Old 08-06-2018, 05:59 PM
Augerhandle's Avatar
Quoted: 1249 Post(s)
Liked: 1249
Good start. Time to download REW https://www.roomeqwizard.com/
and order a calibration microphone, such as the umik-1 http://cross-spectrum.com/measuremen...ated_umik.html
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #3 of 3 Old 08-06-2018, 07:40 PM
Quoted: 348 Post(s)
Liked: 489
Its a common issue when using separate amps that phase can be off. On the emotiva simply reverse phase of the lcr (all 3) and rerun ypao.
Using a sub or subs set speakers to small and all crossovers to 80 or if you use small surrounds 100 may he as good or better.
I have htm12s fyi so ive been down this road ☺
RoboAVS is offline
