Sealed LCR 1299 Build + Questions - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #31 of 35 Old 10-13-2018, 08:42 PM
markg35's Avatar
Quoted: 353 Post(s)
Liked: 282
Originally Posted by MajorTendonitis View Post
Thanks ,that’s very interesting. Are you owner builders happy with the sound of the waveguide tweeters?
I’m debating to buy a 5x5 wood cnc router next summer ,and would be able to make front baffles very easily .
Are you guys sealing the midranges off inside the enclosure? I guess I’m asking if you’ve made a separate enclosure internally,in order to isolate the drivers from the main woofers
There a few threads here about the 99 series(1899,1299,1099 and even the 893's).If you look at DIY Soundgroup website you'll see pictures(and reviews) of the flatpacks(No pictures of the 1299's)all the ported 99's are basically the same box design.
The mid section is sealed.
markg35 is offline
post #32 of 35 Old 10-13-2018, 08:45 PM
markg35's Avatar
Quoted: 353 Post(s)
Liked: 282
Also curious about the driver woofer size . Are those 10” in the centre channel,and 12” in the left and right speakers?
I believe they are twin 6.5" mids in the center along with a 12"Seos waveguide.Twin 12" woofers.
markg35 is offline
post #33 of 35 Old 10-13-2018, 08:51 PM
markg35's Avatar
Quoted: 353 Post(s)
Liked: 282
Originally Posted by WereWolf84 View Post
according to spec, the 12" woofer's depth is 5.35" only, would it ok to have 6" depth enclosure with minimum space behind the woofer? what's the required height if the depth=6" and width=13.25" in order to remain the designed box volume?
There are box volume calculator programs around I'm not familiar with them though.
You could start a thread about what you have in mind.You might get one of the people on here that know the programs to help.
You could also contact the designer of the 99 series and see what he thinks.(I'd start there personally).
markg35 is offline
post #34 of 35 Old 10-13-2018, 09:48 PM
MajorTendonitis's Avatar
Quoted: 457 Post(s)
Liked: 122
12” for a centre channel . That’s interesting,as I thought my cc690 was big. I’d be happy with 4-8” drivers in the centre channel, and 4-10” woofers in each surround . But that’s just me .
I do like tight bass and midbass attack too, and let a couple of 12 or 15 inch woofers do the subwoofer duties
LG OLED65B7P.
Anthem AVM60 , Anthem MCA525 .
Panasonic DP-UB820 UHD player .
Paradigm Studio CC690 V5 centre channel , Studio 100 V5’s front and rear . Paradigm PW-2200 subwoofer
MajorTendonitis is offline
post #35 of 35 Old 10-20-2018, 10:54 PM - Thread Starter
Originally Posted by 1st Cav View Post
@WickedDogs and @Rowan611
Did you use different crossovers for the vertical left and right vs the horizontal center channel?
I have 3 vertical 1299's but want to change the center to a horizontal orientation. I'll be ordering a new baffle but didnt know if I need a new crossover as well.
Sent from my SM-G965U1 using Tapatalk
I used the same crossover for the LR as well as the center. I bought the PCB boards from Matt (who was very helpful) and I just soldered the crossover components onto it. However the Left and right compression drivers were noted as such compared to the center, for apparently they are matched or ever so slightly more similar in their responses.
1st Cav likes this.
WickedDogs is offline
