Sealed LCR 1299 Build + Questions - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1 of 35 Old 08-09-2018, 12:24 PM - Thread Starter
Hi,
I am about to go to HD and begin my new 1299 LCR build (+2 recently done VBSS).
Question- Since it is sealed, per diysg website I should use polyfill. How much polyfill should I use per speaker/total (how much should I go buy?). I noticed walmart has 5 and 10 pound boxes, HD has denim insulation etc. I would love so input/recommendations.
I am also unsure of where/how much to put it. There isn't much info on the page there.
Cheers
WickedDogs is offline
post #2 of 35 Old 08-09-2018, 12:43 PM
dtsdig's Avatar
Quoted: 1125 Post(s)
Liked: 1387
Just pack them nicely from top to bottom. Since these are sealed and the backs of the mids are sealed, there's nothing to worry about. The old rule for subs was ~1 pound of poly per cubic foot of cabinet.
dtsdig is offline
post #3 of 35 Old 08-09-2018, 01:07 PM - Thread Starter
Can I get verification on correct cut sizes, I tried to figure out how it should be using the limited overall dimensions on the site. Attached pdf's
File Type: pdf cutlist-optimizer_2018-08-09_13-04-27.pdf (126.2 KB, 49 views)
File Type: pdf cutlist-optimizer_2018-08-08_14-48-24.pdf (238.4 KB, 40 views)
post #4 of 35 Old 08-09-2018, 03:57 PM
BCRSS's Avatar
Quoted: 513 Post(s)
Liked: 474
This was what I went off of.
BCRSS is online now
post #5 of 35 Old 08-11-2018, 12:42 PM - Thread Starter
Hey thanks for the diagram, I will cut soon with similar overall dimensions.
post #6 of 35 Old 08-19-2018, 01:46 PM - Thread Starter
Quick build update:
Started building the 3 boxes. Bought a circular saw for the cuts, and used jigsaw for the bracing (bracing not yet glued in).
I am concerned about the proper bracing method for the center, any comments on if this was sufficient would be appreciated.
Cheers its looking like an actual speaker box now
ID:	2443696   Click image for larger version
ID:	2443698   Click image for larger version
ID:	2443700   Click image for larger version
ID:	2443702   Click image for larger version
ID:	2443706   Click image for larger version
filtor1 likes this.
post #7 of 35 Old 08-19-2018, 03:02 PM
BCRSS's Avatar
Quoted: 513 Post(s)
Liked: 474
Originally Posted by WickedDogs View Post
Quick build update:
That looks correct as long as the half braces are in the middle of the 12 in. drivers.
BCRSS is online now
post #8 of 35 Old 08-30-2018, 01:03 PM - Thread Starter
Finished! Final result attached, more pics and details to come
ID:	2448742   Click image for larger version
BCRSS, 18Hurts, Jk7.2 and 4 others like this.
post #9 of 35 Old 08-30-2018, 01:39 PM
BCRSS's Avatar
Quoted: 513 Post(s)
Liked: 474
Nice job and the paint job makes the speakers really stick out.
BCRSS is online now
post #10 of 35 Old 08-31-2018, 06:23 AM
chiptouz's Avatar
Quoted: 275 Post(s)
Liked: 338
Nicely done! What are your thoughts on how they sound?
My Movie Library - and still growing!
Family Room: Sony XBR-85x900F + Denon x6500h + Oppo 203, Speakers: LCR: DIYSG Elusive 1099's, S & RH: Polk TC60i, FH: Volt10v2's, Sub: 2x LTD02 Designed UM18-22 Subs w/Nx6000d
Considering: DIYSG Volt8v2 for Surround
chiptouz is offline
post #11 of 35 Old 08-31-2018, 07:16 AM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 711
Nice. A few friendly recommendations:
- I build little box stands for my sealed 1299s to raise them up a bit and bring the waveguide to ear level. Might want to think about that. See attached pic.
- you need to pull them out from the wall a bit and toe them in. This will really help the sweet spot.
- I hope you plan on getting some absorbtion into that room. With the tile floors......your going to have a lot of reverb and echo issues.
Otherwise, nice work.
Sent from my Pixel XL using Tapatalk
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #12 of 35 Old 08-31-2018, 07:54 AM
BCRSS's Avatar
Quoted: 513 Post(s)
Liked: 474
- I hope you an on getting some absorbtion into that room. With the tile floors......your going to have a lot of reverb and echo issues.
Are you running the THT's as your subs with the 1299's? If so what are you crossing at?
Sorry OP for off topic.
BCRSS is online now
post #13 of 35 Old 08-31-2018, 07:59 AM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 711
Yes. I'm running 4 xover at 80hz. I have a 7300cuft sealed room I'm using as my HT.
BCRSS likes this.
Rowan611 is offline
post #14 of 35 Old 08-31-2018, 09:36 AM
dtsdig's Avatar
Liked: 1387
dtsdig is offline
post #15 of 35 Old 08-31-2018, 10:05 AM
BCRSS's Avatar
Quoted: 513 Post(s)
Liked: 474
Originally Posted by dtsdig View Post
Dang you 1299 owners! Makes me want to upgrade for no real reason at all.
Nothing wrong with having a set of 1099's and 1299's.
BCRSS is online now
post #16 of 35 Old 08-31-2018, 12:52 PM
dtsdig's Avatar
Liked: 1387
When people come over and ask, I'll just say one set is for music and the other set is for movies! lol
Rowan611 and BCRSS like this.
dtsdig is offline
post #17 of 35 Old 08-31-2018, 05:11 PM
markg35's Avatar
Quoted: 353 Post(s)
Liked: 282
I'm sure 1099's would make great surrounds!
Jrunr likes this.
markg35 is offline
post #18 of 35 Old 09-14-2018, 03:57 PM
Jrunr's Avatar
Quoted: 177 Post(s)
Liked: 37
Have you ever compared the 1299's to the 1099's as far as sound quality and impact?
Jrunr is offline
post #19 of 35 Old 09-14-2018, 07:45 PM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 711
I've listened to both. Not back to back it even in the same room. The 1099 is what pushed into DIY. To me, the 1299 has a bigger sound. Which, shouldn't be surprising. But, the 1099s are truly amazing speakers.
Rowan611 is offline
post #20 of 35 Old 09-15-2018, 01:08 AM
Luminated67's Avatar
Quoted: 674 Post(s)
Liked: 381
My lord, if this is your intended room for these with the subs then you either live alone or have the most understand wife imaginable.
Really nice job you did on them.
Epson EH-TW9400 - QualGear Fixed Frame 100” - Sony x700 BRP & Panasonic 420 BRP - Sony 1080 AVR - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Passive Radiator)
Luminated67 is offline
post #21 of 35 Old 10-12-2018, 02:59 PM
1st Cav's Avatar
Quoted: 300 Post(s)
Liked: 146
@WickedDogs and @Rowan611
Did you use different crossovers for the vertical left and right vs the horizontal center channel?
I have 3 vertical 1299's but want to change the center to a horizontal orientation. I'll be ordering a new baffle but didnt know if I need a new crossover as well.
Sent from my SM-G965U1 using Tapatalk
1st Cav is offline
post #22 of 35 Old 10-12-2018, 03:07 PM
Rowan611's Avatar
Quoted: 615 Post(s)
Liked: 711
As far as I know it's the same. But, @mtg90 built mine. So, I cant say for 100% certainty.
1st Cav likes this.
Rowan611 is offline
post #23 of 35 Old 10-12-2018, 03:19 PM
1st Cav's Avatar
Quoted: 300 Post(s)
Liked: 146
Great point, @mtg90 built mine too, I should've thought to PM him. Thanks for the reminder
1st Cav is offline
post #24 of 35 Old 10-13-2018, 04:30 AM
WereWolf84's Avatar
Quoted: 413 Post(s)
Liked: 175
can I build this 1299 with shallow depth of 6" and width remain at original 13.25"?
WereWolf84 is offline
post #25 of 35 Old 10-13-2018, 08:41 AM
markg35's Avatar
Quoted: 353 Post(s)
Liked: 282
You can build them that way depending on the driver depth.
They are designed for a certain box volume.You can adjust the size a little bit without sacrificing much.Cutting the box down to less than half the size would not be good.
Just my .02
markg35 is offline
post #26 of 35 Old 10-13-2018, 09:32 AM
WereWolf84's Avatar
Quoted: 413 Post(s)
Liked: 175
Just my .02
according to spec, the 12" woofer's depth is 5.35" only, would it ok to have 6" depth enclosure with minimum space behind the woofer? what's the required height if the depth=6" and width=13.25" in order to remain the designed box volume?
post #27 of 35 Old 10-13-2018, 09:46 AM
MajorTendonitis's Avatar
Quoted: 457 Post(s)
Liked: 122
Wow I’m impressed . I have a plethora of wood tools,and sometimes kick myself for not building my own speakers .
I still haven’t heard any remarks regarding how they sound ? Although you may be biased lol .
I’ve never seen these before . Is this a kit you buy ,and just build the enclosure to the recommended volume?
LG OLED65B7P.
Anthem AVM60 , Anthem MCA525 .
Panasonic DP-UB820 UHD player .
Paradigm Studio CC690 V5 centre channel , Studio 100 V5’s front and rear . Paradigm PW-2200 subwoofer
MajorTendonitis is offline
post #28 of 35 Old 10-13-2018, 11:57 AM
Quoted: 457 Post(s)
Liked: 122
Also curious about the driver woofer size . Are those 10” in the centre channel,and 12” in the left and right speakers?
LG OLED65B7P.
post #29 of 35 Old 10-13-2018, 04:38 PM
4fit?'s Avatar
Quoted: 77 Post(s)
Liked: 48
diysoundgroup.com
Sent from my SM-G935V using Tapatalk
MajorTendonitis likes this.
4fit? is offline
post #30 of 35 Old 10-13-2018, 07:02 PM
Quoted: 457 Post(s)
Liked: 122
Originally Posted by 4fit? View Post
diysoundgroup.com
Thanks ,that’s very interesting. Are you owner builders happy with the sound of the waveguide tweeters?
I’m debating to buy a 5x5 wood cnc router next summer ,and would be able to make front baffles very easily .
Are you guys sealing the midranges off inside the enclosure? I guess I’m asking if you’ve made a separate enclosure internally,in order to isolate the drivers from the main woofers
LG OLED65B7P.
