Speakon bridge wiring - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By rhodesj
  • 2 Post By markmon1
post #1 of 4 Old 08-18-2018, 09:14 AM - Thread Starter
evilbeaver's Avatar
Just recently bought a Behringer NX3000 and it only has Speakon type connections which I've never used before.
Now I understand that the wiring is +1 and +2 but does it absolutely have to be a 4 pole connector to the A output?
I only have two pole connectors right now so I wired one to +1 and the other to +2 and connected them to both outputs, kind of similar to how you would bridge banana jack outputs.
So I just want to confirm that this is basically the same as using 1 4 pole connector. I assume it is, its working without issue.
evilbeaver is offline
post #2 of 4 Old 08-18-2018, 06:38 PM
BassThatHz's Avatar
Quoted: 3777 Post(s)
Liked: 4294
In theory, that "should" work...
BassThatHz is offline
post #3 of 4 Old 08-18-2018, 07:16 PM
rhodesj's Avatar
Quoted: 1010 Post(s)
Liked: 600
Yeah, should work. I'd still swap out for a 4-pole. This is basically why I only buy 4-pole Speakons. There's no meaningful price difference, and greater flexibility.
bscool and DaBateman like this.
rhodesj is offline
post #4 of 4 Old 08-19-2018, 01:59 AM
markmon1's Avatar
Quoted: 5212 Post(s)
Liked: 3381
You don't need a 4 pole connector for the amp. That's only there for assistance in case you have 2 speakers on a single 4 pole speakon. The diagram on the back is sort of confusing. But the output A is a 4 pole and the output B is a 2 pole.
On output A, 1+ and 1- run Channel A.
On output A, 2+ and 2- run Channel B. <-- This setup is in case you have a 4 pole single speakon to run your 2 sets of speakers.
On output B, 1+ and 1- run Channel B. <-- This is the same as the above but for standard 2 pin speakons 1 per speaker set.
The way you've wired it is the only way you should wire it if you're bridging your amp into 1 channel. In this case, Channel A and Channel B are combined, and you use output A 1+ and 2+.
Standard 2 pole speakon connections for 2 channels on the amp would use 2 2-pole speakons where:
Speaker1 goes to output A, 1+ 1-.
Speaker2 goes to output B, 1+ 1-.
Hope that helps.
vn800art and evilbeaver like this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
