DIY LCR similar to HTM/F15? - AVS Forum | Home Theater Discussions And Reviews
 11Likes
  • 1 Post By ERChicago85
  • 2 Post By notfastenough
  • 1 Post By asarose247
  • 1 Post By 18Hurts
  • 2 Post By strawberry
  • 1 Post By VegaMan
  • 1 Post By 18Hurts
  • 1 Post By jcmccorm
  • 1 Post By notnyt
post #1 of 24 Old 08-19-2018, 08:55 AM - Thread Starter
Liked: 1
Been itching to upgrade my LCR after building a few subs this year. I currently have a mismatch of speakers (def tech/bic) that sound weak for music and movies and looking to replace with something that can keep up with the subs with AVR power.
Subs are 2 VBSS and a full marty UM18 in a 4k cu ft basement running off an inuke 6000dsp
I wanted to build some HTM12 or fusion15 towers but I won $500 to PE so I figure I would try to build something on my own. The problem is I have no clue how to design crossovers so I am looking for a high sensitivity 12-15" woofer/waveguide design with parts I can buy from PE. I was looking at the deltalite woofers but not sure which CD/waveguide to go with it. Also would a prebuilt crossover like this work?
Eminence PXB2:1K6 2-Way Speaker Crossover Board 1,600 Hz
ERChicago85 is offline
post #2 of 24 Old 08-19-2018, 09:19 AM
BassThatHz's Avatar
Quoted: 3777 Post(s)
Liked: 4297
I would just buy from DIYSG, and use the PE credits to get more subs or amps dude.
or perhaps:
Two of these:
https://www.parts-express.com/bc-15f...-ohm--294-5981
Two of these:
https://www.parts-express.com/bc-de5...iver--294-5848
Two of these:
https://www.parts-express.com/bc-me4...-bolt--294-622
and then a crossover...
The SEOS is what brings the magic, you'll be missing out mega...
BassThatHz is offline
post #3 of 24 Old 08-19-2018, 09:30 AM
johnson636's Avatar
Quoted: 1239 Post(s)
Liked: 724
Obviously you haven't performed a forum search about building speakers and trying to use off the shelf crossovers. I agree with BTH on buying from diysg and use your $500 winnings on subs. Unless, you have lots of time, umik, enough amplification, and enough input/outputs from minidsp, you could go active crossovers. Did I mention a lot of time and patience and headache.
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) Stage Right 15" PA- (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune- 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #4 of 24 Old 08-19-2018, 10:02 AM
Quoted: 446 Post(s)
Liked: 364
I think he’s asking for a proven design, there’s tons out there but I don’t think you’ll find one that is cheaper or better performing.
Trimlock is offline
post #5 of 24 Old 08-19-2018, 10:05 AM - Thread Starter
Liked: 1
Thanks all - buying from diysg makes the most sense.
filtor1 likes this.
post #6 of 24 Old 08-19-2018, 10:24 AM
notfastenough's Avatar
Quoted: 190 Post(s)
Liked: 221
You can use that 500 at PE for speakons, minidsp, unmik, duratex, and any other supplies to help with the diysg build or system optimization you desire.
If all else fails, I'll send you my shopping cart and shipping address
moosifee and BassThatHz like this.
notfastenough is offline
post #7 of 24 Old 08-19-2018, 11:33 AM
notnyt's Avatar
Quoted: 3816 Post(s)
Liked: 3771
The 15" 2-way link in my sig fits the bill I think, though it's a bit more expensive than the diysg stuff.
I just finished converting a friends 3677 to something like that, but used hypex fusion plate amps instead of external amps/xover/eq.
2453h-sl cd, stx825 waveguide, 2265hpl woofer, fa252 amp
notnyt is offline
post #8 of 24 Old 08-19-2018, 12:44 PM
Samps's Avatar
Quoted: 1225 Post(s)
Liked: 904
Might be able to sell the PE $500 for like $450. Risky sale for both parties though.
Samps is offline
post #9 of 24 Old 08-19-2018, 01:03 PM
asarose247's Avatar
Quoted: 1246 Post(s)
Liked: 1091
HTH ball park guestimates
$500 . . .
Umik $100
Duratex gallon (?) $70
50 ft spool of O2 free 14 ga. wire (monoprice $15
speakons
grills, magnets, feet,
if the credit has no expiration date . . .
the rabbit hole will consume it . .
strawberry likes this.
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #10 of 24 Old 08-19-2018, 05:37 PM
Quoted: 1297 Post(s)
Liked: 2097
Here is a build using the Dayton PA 12" midwoofer, Selenium compression driver and JBL horn
http://projectgallery.parts-express....1-loudspeaker/
It is based on the Econowave crossover but that is not mentioned--maybe the designer can be emailed or is on PE's forum Tech Talk with the details.
There are plenty of designs at PE so sniff around the site and the forums to get a good idea what is available and at what cost.
Good luck!
VegaMan likes this.
18Hurts is offline
post #11 of 24 Old 08-19-2018, 06:25 PM
tential's Avatar
Quoted: 419 Post(s)
Liked: 279
Now that you know you're getting the speakers from DIYSG, you need to figure out how to best use your $500 on subs.
You "only" had 3 in your OP.
Looks like you can do another Full Marty
tential is offline
post #12 of 24 Old 08-19-2018, 06:33 PM
strawberry's Avatar
Quoted: 163 Post(s)
Liked: 371
This, right here.
Soloact and 18Hurts like this.
strawberry is online now
post #13 of 24 Old 08-20-2018, 02:52 AM
VegaMan's Avatar
Quoted: 103 Post(s)
Liked: 79
the econowave is a viable option here, only problem being age and sourcing the waveguides. there are designs and measurements (I believe) for the waveguide notnyt used in his pictured retrofit. there also is a work up on the Dayton audio waveguides. not quite the easy button diysg offers and since photobucket pulled their nonsense it's left quite a few threads hacked to pieces, but pete schumacher (DIYSG designer) and Zilch both posted design details publicly.
crossover example attached
VegaMan is offline
post #14 of 24 Old 08-20-2018, 02:54 AM
VegaMan's Avatar
Quoted: 103 Post(s)
Liked: 79
not sure what happened to attachments
Name:	econowave for pa310 schematic.jpg
ID:	2443930   Click image for larger version
Name:	econowave for pa310 shopping list.jpg
18Hurts likes this.
VegaMan is offline
post #15 of 24 Old 08-20-2018, 03:45 AM
rjyap's Avatar
Quoted: 87 Post(s)
Liked: 44
I just bought 3 units of FA503 amp. My understanding is the amp is not airtight so if you mount it at the back of your speaker, it might interfere with your ported or sealed design. Did your build sealed up the back of the amplifier so that it is in it's own compartment? I'm going to start my DIY 3 way speakers soon. Still waiting for Beyma TPL-150H tweeter.
rjyap is offline
post #16 of 24 Old 08-20-2018, 04:45 AM
jcmccorm's Avatar
Quoted: 611 Post(s)
Liked: 461
+1 for buy something from DIYSG and spend the money at PE on other stuff. You know you will spend that $500 there anyway no matter what
jcmccorm is online now
post #17 of 24 Old 08-20-2018, 06:29 AM
Liked: 2097
The "sledgehammer of reality" quote
True, I've never spent so much money "saving money" in my entire life! However, there is the illusion of saving money--my wife only tracks the driver costs and I nickle and dime my way by with glue, screws, tools, test equipment, wire, grill cloth, duratex and other odds and ends. A friend asked how much my mains cost, my wife jumps in with the exact cost of just the kit without the wood costs, grills, terminal strips and everything else required to actually build out the kit.
My subs are really cheap, she looks at just the driver cost with the wood, veneers, tops and PA amplifier not included in the mix. Everybody wins!
I'd look at the $500 as my amp, grill cloth, wire, cables, test equipment, handles, input terminals, glue, screws and DIY bits fund. Might as well get all the goodies you need to make it more accurate, quicker and less tedious as we always forget something.
If you still don't know what to spend it on, we can help you with that problem. It's what we do.
tential likes this.
18Hurts is offline
post #18 of 24 Old 08-20-2018, 07:11 AM
STL D's Avatar
Quoted: 426 Post(s)
Liked: 514
$500 from PE you say?
Sounds like a good excuse to build a UM18.
Or, if you haven't done so, room treatments.
STL D is online now
post #19 of 24 Old 08-20-2018, 08:16 AM
jcmccorm's Avatar
Quoted: 611 Post(s)
Liked: 461
Well there's another sledgehammer for ya!
That's my situation to a tee. I've told my wife what the drivers and flatpacks cost. I might have mentioned the amp in passing (as not to draw too much attention to it). But between PE, Amazon, and Home Depot....well, I feel a little guilty I guess
18Hurts likes this.
post #20 of 24 Old 08-20-2018, 08:59 AM
Jedi940's Avatar
Quoted: 287 Post(s)
Liked: 202
Umik-1 and a minidsp HD would take a good chunk out of that. Invaluable tools for tweaking subs and measuring everything if you don't already have them. They also allow for us to help you out better if you have any questions down the road in regards to setup and performance.
Jedi940 is offline
post #21 of 24 Old 08-20-2018, 09:06 AM - Thread Starter
Liked: 1
I've decided to buy room treatments from PE since I have a umik and extra duratex/ cables etc. Wife would be less than thrilled to see another full marty in the basement...unless, of course, I finish it as a table/entertainment center as some other members have done.
Going with some of the new 24x24" panels PE put up. Hoping for some improvement - getting a lots of echo with a handclap....
post #22 of 24 Old 08-20-2018, 09:12 AM
notnyt's Avatar
Liked: 3771
notnyt is offline
post #23 of 24 Old 08-20-2018, 09:00 PM
rjyap's Avatar
Quoted: 87 Post(s)
Liked: 44
Thanks for the photo. Where you get the cover or DIY?
rjyap is offline
post #24 of 24 Old 08-20-2018, 09:04 PM
notnyt's Avatar
Liked: 3771
diy. printed it since there was a support in the enclosure in the way, otherwise I just would have used MDF.
Erich H likes this.
notnyt is offline
