Dual Mach 5 Audio FTW 21's - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #1 of 31 Old 08-28-2018, 02:23 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Pradeep2, Jk7.2, DaBateman and 3 others like this.
soccerkid is offline
post #2 of 31 Old 08-28-2018, 05:10 PM
BassThatHz's Avatar
Quoted: 3678 Post(s)
Liked: 4170
You are going to need more sound proofing...
soccerkid likes this.
BassThatHz is offline
post #3 of 31 Old 08-28-2018, 06:17 PM
Samps's Avatar
Quoted: 1220 Post(s)
Liked: 901
I tried to find a "this thread is worthless without text" meme, but surprisingly it doesn't exist.
Welcome to AVS Instagram.
Samps is offline
post #4 of 31 Old 08-28-2018, 07:00 PM
Zarkoff500's Avatar
Quoted: 179 Post(s)
Liked: 138
No words needed. Looking sultry already.
Zarkoff500 is offline
post #5 of 31 Old 08-28-2018, 07:41 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
I'm also strongly considering breaking out the UXL 18's. I already have dual LMS Ultras in the tiny room, now I'm going to insert the FTW's, and perhaps I'll dust off the UXL's and try to fit them in there somewhere.
N8DOGG and uniquepattern like this.
post #6 of 31 Old 08-28-2018, 07:41 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Lol, well it's a big a$$ sub with 21" drivers from Mach 5 Audio. These drivers have been sitting on a shelf for a few years. Originally I was going to go dual opposed and I even had the box 85% done, but then I moved a bunch of times (like 4) and the box went into storage. Cue earlier this year when I finally settled down and I come to find the box got wet and is now full of mold. New build engaged, however even though I have a full basement I won't be able to finish it for at least 3-5 years at least. So I've set up shop in one of the spare bedrooms, but it's tight in there and won't support a dual opposed build, so now I'm lining them up vertically. It's been awhile since I've built any speakers or subs so I'm a little rusty, but it's all coming back to me.
Pradeep2 likes this.
post #7 of 31 Old 08-28-2018, 07:43 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Craig S King likes this.
post #8 of 31 Old 08-29-2018, 04:17 PM
A9X-308's Avatar
Quoted: 1792 Post(s)
Liked: 1483
I don't see a port, so I assume sealed and EQ'd, right? What's the box volume?
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #9 of 31 Old 08-29-2018, 06:11 PM
Craig S King's Avatar
Quoted: 359 Post(s)
Liked: 510
Looking forward to seeing this build progress.
Craig S King is offline
post #10 of 31 Old 08-29-2018, 08:27 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Yup sealed and EQ'ed. Right around 12.5 cuft IIRC
post #11 of 31 Old 08-29-2018, 08:55 PM
Quoted: 141 Post(s)
Liked: 66
Love the pics! Please keep them coming.
By my calcs a few years ago these are the best bang for the buck in as small a sealed enclosure as you can go. For ported some 18s are even better, space wise.
There is some stank from this sub forum that flairs up from time to time that have had issues with coil rub, and this appears to have happened a few times over several years. But from what I have seen the seller has covered this, minus some inconvenience. Hand made stuff should be fully checked before shipment, but shipping happens.... I have had issues with other 15 to 18 mass produced subs, in car audio and home studio. Very different applications, but they may have been from user error or mechanical? This seller seems to back their stuff up more often than the mass sellers...
I have 4 of these purchased over 3 different time periods going in sealed, ported and just finishing a final 4th all sealed arrangement. I've have tried to push them to their limits in a too small a room for their capability with only two and after bowing out, and with another amp and another 2 ftw-21s, which was a bit dumb, have settled into just playing with ultra low dsp boost levels... My cheap bum shakers end up taking over at some point, or the house just wants to give up. On concrete I want to try the Croswans or whatever, but it needs to be balanced with other rabbit holes to follow. Too many wants and toys...
On concrete floors you can only do so much to reproduce big gun shots (50 cal) and larger.... at some point you just end up scaring fellow participants...
cellarnoise is offline
post #12 of 31 Old 08-30-2018, 02:29 AM
BassThatHz's Avatar
Liked: 4170
and a rape whistle!
soccerkid and DaBateman like this.
post #13 of 31 Old 08-30-2018, 08:09 AM
Quoted: 1012 Post(s)
Liked: 1261
and a rape whistle!
Is that so the rescue teams can find him in the rubble that was his house?
Sent from my SM-N920V using Tapatalk
Pradeep2 is offline
post #14 of 31 Old 08-30-2018, 08:37 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Getting close
So hard to find good help these days. Lazy [email protected]
post #15 of 31 Old 08-30-2018, 01:55 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Fill and sand and fill and sand...ad nauseam
post #16 of 31 Old 08-30-2018, 04:00 PM
A9X-308's Avatar
Liked: 1483
Thanks, I thought so. Mine are 400L net circa 14.1cf. One dual sub in front of the couch, one behind.
A9X-308 is offline
post #17 of 31 Old 08-31-2018, 12:29 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
NEW SANDER
Some scale pictures
post #18 of 31 Old 08-31-2018, 08:32 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Sanded and with the roundover put on. I was going to go bigger with the roundover, but I couldn't fit the 1.5" and the 1" wasn't in great shape so I didn't want to risk it.
post #19 of 31 Old 09-01-2018, 12:31 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Trying to remember how this whole spraying thing works. In any case, first couple coats of primer applied haphazardly.
DevonDeyholos likes this.
post #20 of 31 Old 09-02-2018, 07:49 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Not sure if it even needs a second coat of black.
post #21 of 31 Old 09-02-2018, 08:14 PM
Quoted: 141 Post(s)
Liked: 66
I don't see no beginner....
Just go easy on the power to begin with as your home may no like the new additions!
They look great.
post #22 of 31 Old 09-02-2018, 09:22 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
They look great.
There's a dedicated 30 amp line in there for the two sub amps. I'm going to run a dedicated 30 amp 240 when I have the funds for a speakerpower amplifier. However, right now the single line will have to do. I think it'll be alright because it's a really small room so it won't take much to hit reference levels.
Thanks, it's been a few years since I've done a speaker or subwoofer build so this was a relearning experience. Now that I'm settled I'm hoping to get back into it.
post #23 of 31 Old 09-03-2018, 01:21 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
post #24 of 31 Old 09-03-2018, 02:56 PM
Quoted: 141 Post(s)
Liked: 66
Watch your back and get some carpet sliders!
That box could mess you up way before it pummels you.
post #25 of 31 Old 09-03-2018, 04:59 PM
Samps's Avatar
Liked: 901
That would fit so nice sideways directly behind a couch. Good job!
Samps is offline
post #26 of 31 Old 09-03-2018, 05:56 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 31
Yea, carrying it up from the basement by myself was no picnic. At least it slid really easily into position.
Well, it's behind a couch. The only problem is that there isn't enough room to lay it down so it's standing up behind the couch. Pretty intimidating if you turn around.
post #27 of 31 Old 09-03-2018, 06:58 PM
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Getting close
As @Craig S King said to me.. that’s some good looking woofers you got there
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #28 of 31 Old 09-08-2018, 11:59 AM
Quoted: 359 Post(s)
Liked: 510
We love our woofers around here.
rukus29, JCJetta and soccerkid like this.
post #29 of 31 Old 09-08-2018, 02:02 PM
Quoted: 212 Post(s)
Liked: 215
that looks excellent sir. very nice build. I'm sure they sound decent too
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva LPA-1 (Currently Fried) | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Dayton Ultimax 15 | Crown XPS1000
Living Room Duty- DIY Swope TMWW LCR
Currently Building- (3) Stereo Integrity HS-24 mkiii's
blister64 is offline
post #30 of 31 Old 09-08-2018, 02:49 PM
Luminated67's Avatar
Quoted: 524 Post(s)
Liked: 326
People tell me everything is bigger in the States..... and I guess they are right. lol
Looks class.
I bet when you are watching a movie the neighbours are looking out their windows for the lightening that accompanies the thunder they just heard.
Epson EH-TW9400 - QualGear Fixed Frame 100” - IPL Acoustics M1TLs & IPL Acoustics AVC Pro Centre, Four KEF surrounds & 2 Sub boxes (10” Sub + 10” Radiator)
Luminated67 is online now
