DIY Sound Group Fusion 15 Sentinel build - AVS Forum | Home Theater Discussions And Reviews
 32Likes
  • 6 Post By seth243
  • 3 Post By seth243
  • 5 Post By seth243
  • 2 Post By seth243
  • 2 Post By seth243
  • 3 Post By seth243
  • 3 Post By seth243
  • 5 Post By seth243
  • 3 Post By seth243
post #1 of 29 Old 08-30-2018, 06:29 PM - Thread Starter
Liked: 34
Since I'm in the middle of my build and I didn't find a bunch of threads related, I figured I'd post about my DIY Sound Group Fusion 15 Sentinel build. I will add to this post as the build progresses. Please ask questions along the way and I'll answer to the best of my ability! Thanks for following along!
ID:	2448882   Click image for larger version
ID:	2448884   Click image for larger version
ID:	2448886   Click image for larger version
ID:	2448888   Click image for larger version
seth243 is offline
post #2 of 29 Old 08-30-2018, 06:30 PM - Thread Starter
Liked: 34
Parts Express items:
Binding post- Dayton Audio BPA-38G HD Binding Post Pair Gold
Part # 091-1245
Rubber feet- Penn-Elcom F1687 Rubber Cabinet Foot 1.5" Dia. x 0.375" H
Part # 260-777
1 Gallon roller grade Duratex
2 pack 4" duratex rollers
bubbrik, Pradeep2 and LondonBenji like this.
seth243 is offline
post #3 of 29 Old 08-30-2018, 06:37 PM - Thread Starter
Liked: 34
Progress... Glad there's a Harbor freight close for all those clamps.
ID:	2448910   Click image for larger version
ID:	2448912   Click image for larger version
ID:	2448914   Click image for larger version
ID:	2448916   Click image for larger version
seth243 is offline
post #4 of 29 Old 08-30-2018, 06:38 PM - Thread Starter
Liked: 34
And more progress. Denim insulation arrived and placed in the cabinet with some spray adhesive. Crossover mounted. Time for a good sanding and then the duratex.
ID:	2448922   Click image for larger version
Pradeep2 and bubbrik like this.
seth243 is offline
post #5 of 29 Old 08-30-2018, 07:46 PM
Samps's Avatar
Quoted: 1219 Post(s)
Liked: 901
Looking good so far. Appears that the new xo board has a dedicated spot now for the padding resistor.
Samps is offline
post #6 of 29 Old 08-30-2018, 07:47 PM - Thread Starter
Liked: 34
Correct. It does.
seth243 is offline
post #7 of 29 Old 08-30-2018, 08:02 PM
Quoted: 534 Post(s)
Liked: 124
Thanks for this ! I have been thinking about possibly getting 3 of these myself for my LCR.
Maybe a noob question .. .. but that crossover, do you not have to have wires soldered to it that would go to the drivers ? If so are these already soldered (don't see them in the picture), or you intend to do that while the crossover is already mounted ?
alextr75 is offline
post #8 of 29 Old 08-30-2018, 08:50 PM - Thread Starter
Liked: 34
The wires connect to the crossover with screws on a positive/negative terminal. Soldering is not necessary. Easy easy!
Pradeep2 and alextr75 like this.
seth243 is offline
post #9 of 29 Old 08-30-2018, 08:52 PM - Thread Starter
Liked: 34
Maybe a noob question .. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG] .. but that crossover, do you not have to have wires soldered to it that would go to the drivers ? If so are these already soldered (don't see them in the picture), or you intend to do that while the crossover is already mounted ?
Just an FYI... This is an LCR build as well. All three are the Fusion 15s.
seth243 is offline
post #10 of 29 Old 08-31-2018, 03:27 AM
ratm's Avatar
Quoted: 185 Post(s)
Liked: 95
Looking great so far. 2 noob questions:
1. Is that the dedicated spot for that XO and did you glue it in place?
2. Is Denim preferred? Or polyfill? Or does it matter?
ratm is offline
post #11 of 29 Old 08-31-2018, 04:17 AM
Quoted: 998 Post(s)
Liked: 1247
When you purchase a preassembled crossover from diysoundgroup, it comes with standoffs and screws to allow you to mount it into position, while maintaining adequate spacing on the back of the circuit board. Location of crossover is based on your convenience and physical clearance.
Denim is nice because it retains that flat batt shape and is easy to work with, if you were to use polyfill it would need to be held in place with some netting or other method.
Sent from my SM-N920V using Tapatalk
Pradeep2 is online now
post #12 of 29 Old 08-31-2018, 04:33 AM
ratm's Avatar
Quoted: 185 Post(s)
Liked: 95
Awesome. I will look for that instead of spray tacking something in place.
ratm is offline
post #13 of 29 Old 09-01-2018, 11:22 AM - Thread Starter
Liked: 34
All three are constructed. One sanded and two left to go. Almost time for duratex.
ID:	2449664   Click image for larger version
4fit?, bubbrik and Pradeep2 like this.
seth243 is offline
post #14 of 29 Old 09-01-2018, 02:37 PM
jcmccorm's Avatar
Quoted: 587 Post(s)
Liked: 435
Looking good! Keep us posted!
jcmccorm is online now
post #15 of 29 Old 09-04-2018, 01:59 PM - Thread Starter
Liked: 34
First coat of duratex applied. One more coat should do it.
ID:	2450896   Click image for larger version
ID:	2450898   Click image for larger version
seth243 is offline
post #16 of 29 Old 09-04-2018, 04:36 PM
gixerking's Avatar
Quoted: 294 Post(s)
Liked: 471
👍 looks like you may have done a little on the woofer opening, just be sure to get some black on the side of the waveguide and woofer recesses. Sometimes that can show depending on how good the fit is. I usually just hit it with a shot of black krylon before finishing. I dunno how think duratex is so you may be able to just use that or in a pinch you can use a big black sharpie
gixerking is offline
post #17 of 29 Old 09-04-2018, 04:53 PM
Craig S King's Avatar
Quoted: 351 Post(s)
Liked: 498
Great progress so far!
Craig S King is offline
post #18 of 29 Old 09-04-2018, 04:57 PM
Quoted: 351 Post(s)
Liked: 498
A lot of guys, myself included, choose to use a foam mattress topper from Walmart.
post #19 of 29 Old 09-04-2018, 05:05 PM
smcmillan2's Avatar
Quoted: 775 Post(s)
Liked: 675
Because of the cool psychedelic look...
smcmillan2 is online now
post #20 of 29 Old 09-04-2018, 05:40 PM - Thread Starter
Liked: 34
The black you see in the waveguide and woofer recesses is actually black sharpie! If a little Duratex gets in there, I don't think it'll interfere. If it does, it's easy to remove it.
seth243 is offline
post #21 of 29 Old 09-05-2018, 06:02 PM - Thread Starter
Liked: 34
One done! Two more nearly complete! Woohoo! Can't wait to get them hooked up!
These are paired with a Marantz 6012 with a Sunfire Cinema Grand 200wx5 amp. Accompanied by two 18" Ultimax sealed subs powered by an Inuke 6KDSP and full Atmos.
ID:	2451394   Click image for larger version
ID:	2451396   Click image for larger version
seth243 is offline
post #22 of 29 Old 09-06-2018, 06:52 AM
jcmccorm's Avatar
Quoted: 587 Post(s)
Liked: 435
Nice! You are going to be smiling a lot this weekend.
post #23 of 29 Old 09-06-2018, 11:16 AM
Quoted: 534 Post(s)
Liked: 124
If you don't mind me asking, how do you attach and seal the waveguide and ports to the box ? I intend to do a couple of these in the future but not sure how this is done.
For the waveguide I see screws, so maybe all that is needed is some silicone from inside or gasket tape under the screws to seal it ?
For the ports I don't see screws, how are those attached, are they just glued with something (which I guess takes care of sealing it well) ?
alextr75 is offline
post #24 of 29 Old 09-06-2018, 11:23 AM
Samps's Avatar
Liked: 901
WG uses gasket tape the whole way around. Ports are pressure fit.
Samps is offline
post #25 of 29 Old 09-06-2018, 11:47 AM - Thread Starter
Liked: 34
This is all correct. Gasket tape and pressure fit.
seth243 is offline
post #26 of 29 Old 09-06-2018, 12:26 PM
Quoted: 534 Post(s)
Liked: 124
My apologies for being a noob, but what exactly is a "pressure fit" ?
Do you just use some force to squeeze them in into a very tight cutout for a snug fit, or something else, maybe you need some tools etc ?
I tried to google this, but so far not much luck, lol.
alextr75 is offline
post #27 of 29 Old 09-06-2018, 12:29 PM
Quoted: 204 Post(s)
Liked: 198
You got it, just push the ports in the cutouts. They are CNC cut to make sure they fit snug and won't fall out.
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva LPA-1 (Currently Fried) | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Dayton Ultimax 15 | Crown XPS1000
Living Room Duty- DIY Swope TMWW LCR
Currently Building- (3) Stereo Integrity HS-24 mkiii's
blister64 is online now
post #28 of 29 Old 09-06-2018, 01:57 PM
Samps's Avatar
Liked: 901
The back of the ports have little raised areas that squeeze tight into the cutout. As long as you use a flat pack this works great. If you cut your own it's a bit tricky.
Samps is offline
post #29 of 29 Old 09-08-2018, 11:43 AM - Thread Starter
Liked: 34
All three are done. Should get them calibrated soon. Pre calibration sounds amazing... 11' apart and slightly toed in towards the MLP.
Don't mind the theater build progress. =) Drywall is going up next weekend, painting behind the screen, and some acoustic panels.
Pradeep2, bubbrik and neo_2009 like this.
seth243 is offline
diy , fusion , group , sentinel , sound
