EQ'ing 29 subs... ugh! - AVS Forum | Home Theater Discussions And Reviews
 39Likes
post #1 of 50 Old 09-04-2018, 06:30 PM - Thread Starter
BassThatHz's Avatar
Quoted: 3892 Post(s)
Liked: 4395
I've been eq'ing all day long.
Measure them all, and make sure they sum correctly via phase and timing, and then make sure they are flat-ish.
The red line is the end result for all the subs:
A slight house curve on the LCR's so as not to blow up the tweeters during high SPL.
Just finished, well sort-of... this is just the rough eq'ing in of everything. Now I can make fine adjustments if I want (not sure if I want/need to though...)
Gonna run with this for now and see how this does.
ID:	2450946   Click image for larger version
ID:	2450948   Click image for larger version
BassThatHz is online now
post #2 of 50 Old 09-04-2018, 06:49 PM
Vince_B's Avatar
Quoted: 318 Post(s)
Liked: 214
Down 10 dB at 2 hz? Are you gonna stop there like that’s, acceptable?
Augerhandle and ipca204 like this.
Vince_B is offline
post #3 of 50 Old 09-04-2018, 07:29 PM
Craig S King's Avatar
Quoted: 443 Post(s)
Liked: 545
Glad to see the hzhorn is operational again.
Craig S King is offline
post #4 of 50 Old 09-04-2018, 07:47 PM
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 518
Lol @ 2Hz.
To think I was cutting my graphs off today at 10Hz...
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #5 of 50 Old 09-05-2018, 04:30 AM
Quoted: 59 Post(s)
What does that setup look like?
Soldy is offline
post #6 of 50 Old 09-05-2018, 05:58 AM
trilkb's Avatar
Quoted: 705 Post(s)
Liked: 370
Just curious, apart from the 29 subs, do you run 7.1? 5.1? higher? atmos?
- 6 x Boston Acoustic CR6 Frankencenter, Boston Acoustic CR8 L/R, 4 jbl 8330a surr , 8 x jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #7 of 50 Old 09-05-2018, 07:18 AM
FriscoDTM's Avatar
Quoted: 435 Post(s)
Liked: 392
Why not use MSO?
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One X, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #8 of 50 Old 09-05-2018, 07:24 AM
Quoted: 349 Post(s)
Liked: 491
Vince is so right....I mean a full 10db drop from 6hz down to 2hz? So disappointing BTH!
Lol awesome love 29 subs integration. Can we get a reading at say 125db in the bass range for fun? Any distortion down low?
RoboAVS is offline
post #9 of 50 Old 09-05-2018, 11:17 AM - Thread Starter
BassThatHz's Avatar
Liked: 4395
Right now I'm running 7.1, but in 2019 it will be 7.1.4
All I need to do is build the heights, and then get a 9905 or RMC-1 or whatnot. Already have the amps for the heights in my rack.
biga6761 likes this.
post #10 of 50 Old 09-05-2018, 11:19 AM - Thread Starter
BassThatHz's Avatar
Liked: 4395
Originally Posted by FriscoDTM View Post
Why not use MSO?
Because my Aspie-Aut-OCD only lets me do things the hard way... and I'm a control freak.
post #11 of 50 Old 09-05-2018, 11:24 AM - Thread Starter
BassThatHz's Avatar
Liked: 4395
I know right!
Gonna need MUCH MORE subwoofers for that much headroom at 2hz. LOL!
24 24's it is!
post #12 of 50 Old 09-05-2018, 11:31 AM
trilkb's Avatar
Quoted: 705 Post(s)
Liked: 370
Nice. I found 7.1 wasnt really a huge upgrade from 5.1, but my speakers are placed in such ways that I cant localize the rear surrounds that much. And I dont know if its where I sit or how my denon x4000 upmix's 5.1 to 7.1 but I constantly have to change the amp to 5.1 on 5.1 movies because 7.1 gives me really strange echo's. Hopefully your atmos upgrade is noticeable!
trilkb is offline
post #13 of 50 Old 09-05-2018, 12:51 PM
Iccy's Avatar
Quoted: 45 Post(s)
Liked: 34
Time for a rotary sub to cover that <5hz drop?
Iccy is offline
post #14 of 50 Old 09-05-2018, 02:25 PM - Thread Starter
BassThatHz's Avatar
Liked: 4395
EOT intro is my go-to movie for calibrating my ULF levels.
I'll just leave this here...
mobileES, ipca204 and kaiforce like this.
post #15 of 50 Old 09-05-2018, 02:26 PM - Thread Starter
BassThatHz's Avatar
Liked: 4395
The FP's are -3db @ 2hz.
It's only down 6.7db at 2hz from the target level.
Being flat to 2hz isn't a problem, all i'd have to do is apply a 2hz PEQ boost of 7db.
post #16 of 50 Old 09-05-2018, 02:37 PM - Thread Starter
BassThatHz's Avatar
Liked: 4395
7.1 is a huge deal in my room IMO, I have closer to ideal placement for them.
The rear ambiance really adds a nice touch, especially with horror movies...
Out of all the movies that I recall playing on my system, Man of Steel and Star Trek has been the best recorded beds for overall SQ and bass levels.
A lot of movies have really weak bass or missing bass, or everything is at the wrong levels (screechy dialog).
IMO the levels of the center dialog and LFE are supremely critical.
It's literally the difference between a 100kW system and a Bose module.
Interstellar and Life of PI are also fairly well recorded.
I hate it when I have to re-calibrate my levels to every different movie that I play. Almost makes a person want to rip their hair out, and then rip the movies to PCM/MKV and remaster them properly!
What can't mixer mix properly?
Take Thor Ragnarok for example, you can literally hear that they used crappy mics for some actors and scenes, and good ones for the main characters. Some scenes have no bass in it, where there should be boat-loads...
post #17 of 50 Old 09-05-2018, 05:26 PM
notnyt's Avatar
Quoted: 3873 Post(s)
Liked: 3816
29 subs and the response isn't even flat?
You'd likely have better luck EQing as a whole after you've time aligned and applied any filtering you need, otherwise you're going to have subs canceling each other due to phase issues.
Luke Kamp likes this.
notnyt is offline
post #18 of 50 Old 09-05-2018, 05:49 PM
brettus's Avatar
Quoted: 51 Post(s)
Liked: 30
I have a better idea....move every speaker/sub cab in as close as possible to one recliner then kick back and have your internal organs and eardrums destroyed! It'll be like wearing headphones on your whole body.
This will require that you either have to climb over cabs to fall into the recliner or move cabs and crawl into position.
Did I mention that you'll need a 3D headset to watch the movie!
brettus is offline
post #19 of 50 Old 09-05-2018, 05:52 PM
brettus's Avatar
Quoted: 51 Post(s)
Liked: 30
https://www.youtube.com/watch?v=bGDSu45AU7s
https://www.youtube.com/watch?v=6BpDHigsGkQ
That's not much excursion going on! My subs with PR's jump out of their skins from start to finish on that scene....you need to EQ it for total destruction (or close to it).
brettus is offline
post #20 of 50 Old 09-05-2018, 06:31 PM
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 518
Phase cancellation is the bane of my existence and I only have 3 subs in my setup.
post #21 of 50 Old 09-05-2018, 06:33 PM
derrickdj1's Avatar
Quoted: 1005 Post(s)
Liked: 767
Bass, most of us can't even get 29 subs in the HT, lol. I have enough trouble EQ'ing 8, you are the man!
Hoodcom likes this.
derrickdj1 is offline
post #22 of 50 Old 09-05-2018, 06:36 PM
trilkb's Avatar
Quoted: 705 Post(s)
Liked: 370
I'll just leave this here... [IMG class=inlineimg]/forum/images/smilies/biggrin.gif[/IMG]
Consider 29 subs with that excursion all at once. That's how you get high output with low distortion. He's not overworking anything, I can relate to that mind set.
trilkb is offline
post #23 of 50 Old 09-05-2018, 06:56 PM
mobileES's Avatar
Quoted: 86 Post(s)
Liked: 49
On the bolded, they desperately need your help over at Disney for the Marvel releases on BD and 4K, lol. I just subscribed to you YouTube channel. That setup is insane!!
Dolby Atmos 7.1.4 | Samsung 65" 4K KS8000 Series | Samsung UBD-K8500 UHD Player | Sony DVP-S7700 DVD Player | Onkyo TX-NR3030 Atmos Network Receiver | Energy Veritas 6.3 mains | Energy C-C1 center | Energy C-R100 surround sides and backs | (4) Energy Take Classic satellites heights | Velodyne VA 1215 XII Sub
mobileES is offline
post #24 of 50 Old 09-06-2018, 12:57 AM
eng-399's Avatar
Quoted: 2457 Post(s)
Liked: 5115
Why so many different boxes? Just make them all ported or all sealed, have 20 up front and the other 9 in the back to make the eq process a little easier. do you have room in the back of your HT for that. Maybe build a baffle wall with all the drivers and mains in the front to save some space take it to the ceiling with the subs
Mike Butny likes this.
eng-399 is offline
post #25 of 50 Old 09-06-2018, 06:39 AM
Quoted: 140 Post(s)
Liked: 51
This. Sometimes I watch a movie and everything sounds awesome. Then I pop in the next one and I'm like wtf do I need to turn up the LFE here? Why? And eventually realize that some scenes just have NO bass, and they should have tons, like explosions etc.
And then in others, like Jurassic World, every dino footstep or door slam shakes my house and it gets annoying lol
Spectre55 is offline
post #26 of 50 Old 09-06-2018, 08:27 AM
trilkb's Avatar
Quoted: 705 Post(s)
Liked: 370
Which star trek movie are you referring to? Beyond has some good lfe.
Infinity war was better then I expected. The donut ship crash shook me.
I went to all sealed subs from my horn and haven't looked back. Sealed and horn and ported really don't play nice together.
trilkb is offline
post #27 of 50 Old 09-06-2018, 09:27 AM
Quoted: 22 Post(s)
Show us some Waterfall Graphs or a Spectogram.
HerbertThePervert is offline
post #28 of 50 Old 09-06-2018, 09:37 AM
Jedi940's Avatar
Quoted: 295 Post(s)
Liked: 214
I'm curious why we have to watch the movie on a 24" computer monitor on the floor Did all that bass make your projector fall off the ceiling an break?
Jedi940 is offline
post #29 of 50 Old 09-06-2018, 10:40 AM
Hoodcom's Avatar
Quoted: 160 Post(s)
Liked: 163
12 is my limit, and like you I've found that to be enough trouble as it is. I can't imagine all the struggles BassThatHz has to go through for 29 of them, let alone the time involved to do each and every necessary process correctly.
Just think of what he'd have to do when he makes it an even 30.
Hoodcom is offline
post #30 of 50 Old 09-06-2018, 11:48 AM
Rowan611's Avatar
Quoted: 623 Post(s)
Liked: 718
Beyond is awful bass wise. I think there's only one or two semi decent scenes. He's talking about the first Star Trek. The only one with a well done score.
You can get horns and sealed and ported to play nicely together. All it takes is time and the ability to set delays. @lukeamdman has gotten his Othorns to play nicely with sealed, and now with ported. It can be done, it just takes work.
Sent from my Pixel XL using Tapatalk
lukeamdman likes this.
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is online now
