Cobalt 8 Build. My first build ever... - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #1 of 42 Old 09-06-2018, 05:34 AM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Cobalt 8 Build. My first build ever. PICS
Just got a text from my wife saying my "speakers arrived". As soon as I get home, I will start posting the requisite pictures. A couple of early questions:
Given the dimensions of the MTM as 10" W x 23.5" H x 11.75" D, what size clamps and how many clamps would I need for building one box at a time?
Binding posts generally do NOT come with the kits unless ordered correct?
ratm is offline
post #2 of 42 Old 09-06-2018, 05:58 AM
dtsdig's Avatar
Quoted: 1125 Post(s)
Liked: 1386
I assume you bought flat packs? Do you own a brad nailer? What length clamps will be dependent on which sides go together first. If you have the money for some harbor freight bar clamps, 4-24" and 4-18" should cover whatever you need.
Binding posts do not come with the kits. I prefer to use Speakons for all of my builds.
Good luck and have fun!
dtsdig is offline
post #3 of 42 Old 09-06-2018, 08:24 AM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Yes I bought the flat packs. I don't own a brad nailer. I was planning on glueing everything together as thats what I've seen everyone do. I am headed to HF today for those clamps so thank you! I not sure what Speakons youre referring to. I am using plugs on my speaker cables. Can you show me which one you mean?
ratm is offline
post #4 of 42 Old 09-06-2018, 10:56 AM
dtsdig's Avatar
Liked: 1386
If you’ve already got cables with bananas on them, you might as well stick with binding posts.
dtsdig is offline
post #5 of 42 Old 09-06-2018, 10:59 AM
jcmccorm's Avatar
Quoted: 602 Post(s)
Liked: 449
Then there's binding posts or terminal cups. I put binding posts on my HTM12's but wish I'd done terminal cups. The binding posts stick out, which is fine, but if I ever have to move these (like to another house) it'll be an issue. Terminal cups are pretty much flush with the mounting surface so will be easy to pack and move.
18Hurts likes this.
jcmccorm is offline
post #6 of 42 Old 09-06-2018, 11:19 AM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
^^ That. I've used these with good results: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #7 of 42 Old 09-06-2018, 05:25 PM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
If I use these, what size hole do I need to drill? I'm thinking 2 inches?
ratm is offline
post #8 of 42 Old 09-06-2018, 06:04 PM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
Yep, I used a 2" hole saw and it's almost a perfect fit. Tiny amount of slop, no issues.
post #9 of 42 Old 09-07-2018, 03:44 AM
jcmccorm's Avatar
Quoted: 602 Post(s)
Liked: 449
Same here. 2" hole saw with just a bit of play when done. I avoided these at first (with the HTMs) because I thought I'd need to use a jigsaw or build a jig for my router to cut the hole. I *had* to use these terminal cups when I built the Volt 6's since they are wall-mounted. After I used the 2" hole saw and dropped in the terminal cup, I realized how easy it was and should have done it sooner.
jcmccorm is offline
post #10 of 42 Old 09-07-2018, 12:13 PM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Thanks guys. But I ended up going with the Dayton Binding posts for this one. Starting the build tomorrow.
ratm is offline
post #11 of 42 Old 09-08-2018, 06:59 AM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
It has begun. I skipped the part about everything being meticulously packaged (everyone knows that). Seriously though, I spent more time sweeping styrofoam pieces taking everything out of the box than I've ever done in my life. I dry fit everything to make sure that it all fits smoothly, and like the sun rises, it does. Turns out that I ordered binding posts which was sweet. But holy crap, I am super nervous about building those crossovers, even with the directions. I don't want to mess that up, so they are getting shipped to Matt later this morning.
I already have a few questions:
1. When and where should I drill holes for my binding posts? And what size drill bit should I use?
2. Are the port tubes the last thing that I should put in? They seem to fit super snug, should I glue the flange?
3. The things I am holding in the pics labeled woofer and tweeter. They look like foam gaskets of some sort, but I dont know where they go.
4. When I am done, should I pre-drill the holes to secure the woofer and tweeter? If so, what size bit.
Thank you to anyone who helps, sorry for all of the noob questions.
ID:	2452564   Click image for larger version
ID:	2452566   Click image for larger version
ID:	2452568   Click image for larger version
ID:	2452570   Click image for larger version
sealmaniac likes this.
ratm is offline
post #12 of 42 Old 09-08-2018, 09:30 AM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
I drill my terminal cup holes prior to assembly. Where is entirely up to you, I tend to put them close to middle of the back. Drill bit size is dictated by the size of the post.
I don't know about the Cobalt kit, but the ports that came with my HTMs were simply a press fit, no glue required. I put them in last (just make sure wherever you mount the crossover isn't going to be in their way).
Those are tape gaskets that go around the respective flange (woofer on woofer, tweeter on tweeter).
I always pre-drill, although I would not consider it a requirement. Again, bit size is dictated by screw size, I typically use a 5/64 bit for # 8 pan head screws.
post #13 of 42 Old 09-08-2018, 10:14 AM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Ok so I glued up the box before I drilled the holes for the binding posts. I dont think it will be that big of a deal. The first pic is everything all clamped up. I got a little overzealous with the glue so I had to spend a few minutes cleaning up the excess. The second pic is looking at the back panel with the ports. I was thinking of to the right or left of that. Also, would the crossover go flat against the back panel on the right or left of the ports? Lastly, how long should I leave the clamps on? I only have whats in the pic and I would like to start on the other boxes.
ID:	2452700   Click image for larger version
ratm is offline
post #14 of 42 Old 09-08-2018, 10:33 AM
smcmillan2's Avatar
Quoted: 855 Post(s)
Liked: 762
Don't get caught up in overthinking it...
Binding posts can go to left or right of ports, yes. Crossover can be mounted anywhere it won't be in the way of the drivers or ports - Back, sides, bottom, top, it doesn't matter.
Clamping time depends on the glue used, I use standard Titebond (not II or III) and 1 hour of clamp time is usually plenty. The bottle should have instructions on it.
post #15 of 42 Old 09-08-2018, 10:57 AM
Audio Pack Rat
sealmaniac's Avatar
Quoted: 44 Post(s)
Liked: 64
I put my binding post wherever I needed or just wanted them! Just like "smcmillan2" said it really does not matter as long as it does not interfere with ports, crossover etc.
Lol, looks like I need some paint touch up on the HTM12.
ID:	2452724   Click image for larger version
ID:	2452728   Click image for larger version
Name:	Alchemy center.jpg
Samsung 82 inch TV, DIYSG HTM12's, Fusion Center, HTM6"s , PSA XS30 X 2, Emotiva XMC-1( soon to be XMC-2), Panasonic DMP-UB200, Roku Ultra, Emotiva XPA5.
Garage: Emotiva UMC-200, Roku2 , Emotiva Airmotiv 5's,Crown XLI 800, HSU TN1225 SUB, Vizio 24" TV.
Computer: Sennheiser GSX1000(outboard soundcard/preamp) & Senn HD598se(wired) & Senn RS185 (wireless) headphones, Antlion Modmic (wireless), Emotiva Airmotiv 5's
sealmaniac is offline
post #16 of 42 Old 09-08-2018, 11:03 AM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Awesome!
Should I put in polyfill and the XO before I glue down my top baffle? Or will should I do that AFTER I completely assemble the box and paint it?
ratm is offline
post #17 of 42 Old 09-08-2018, 11:03 AM
Audio Pack Rat
sealmaniac's Avatar
Quoted: 44 Post(s)
Liked: 64
BTW I am really looking forward to your thoughts of the Cobalt's sound (ability to play either loud or soft and maintain dialogue intelligibility, max volume level before harshness creeps in etc) as I am considering them for my next project.
post #18 of 42 Old 09-08-2018, 11:10 AM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Absolutely. I will post up plenty of impressions once I get them built and set up.
ratm is offline
post #19 of 42 Old 09-08-2018, 11:42 AM
Audio Pack Rat
sealmaniac's Avatar
Quoted: 44 Post(s)
Liked: 64
Awesome!
Well it depends on if you have enough room to access the space the crossover will sit and stuff the polyfill in. I did everything after glueing and painting with the HTM12's due to the huge waveguide and woofer openings.
With the HTM6's and Alchemy center I placed everything in the cabinet before gluing the top baffle as it was pretty tight quarters.
As to which I would suggest? Well if I did it all over again I would install everything BEFORE gluing the front baffle on since access is wide open.
post #20 of 42 Old 09-08-2018, 12:00 PM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
I already mailed the XO to Matt to build, so I cant see if it will "fit" through the woofer. With an 8 inch opening, I would like to think that I have enough room to place the XO. I was planning on using hot glue to secure it to the back of the speaker, unless thats frowned upon.
ratm is offline
post #21 of 42 Old 09-08-2018, 12:10 PM
Falonious's Avatar
Quoted: 88 Post(s)
Liked: 74
Why original and not II or III?
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
T. E. Lawrence
Falonious is offline
post #22 of 42 Old 09-08-2018, 12:50 PM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
I'm using Titebond 2 and letting the clamps stay on one hour. FWIW
ratm is offline
post #23 of 42 Old 09-08-2018, 01:44 PM
corradizo's Avatar
Quoted: 1530 Post(s)
Liked: 1587
Put it on after, you don't want to get your crossover dusty etc from the finishing process. I do the entire cabinet first then install everything.
corradizo is offline
post #24 of 42 Old 09-08-2018, 02:04 PM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Thanks! Thats the plan.
ratm is offline
post #25 of 42 Old 09-08-2018, 04:55 PM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Cabinets are built. If I had triple the clamps, I could have had it all done in an hour. The flat packs are that easy. Sanding and filling will start tomorrow. 150 grit > filler > 150 grit again > filler > 220 grit filler.
Stlll trying to decide if I want to go Duratex or try for a different kind of black paint.
ratm is offline
post #26 of 42 Old 09-08-2018, 05:14 PM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Clamps all done. 42 pound bags of cat litter on overnight. If it’s not sealed after this, I quit. Had a blast building the cabinets.
ID:	2452948   Click image for larger version
ratm is offline
post #27 of 42 Old 09-09-2018, 04:10 AM
jcmccorm's Avatar
Quoted: 602 Post(s)
Liked: 449
How often do you have to change the cat litter?
Ok, bad joke.
What do you fill with? On my HTM12's, I used a flush trim bit to get the overhang and then sanded so much that I didn't really need much filler to speak of. Just a couple of dabs of spackle here and there. Then I used "Filler Primer" that did well at filling the really minor imperfections. If there's a way to reduce the amount of sanding (ie. filler), I'm curious about it).
impreza276 likes this.
jcmccorm is offline
post #28 of 42 Old 09-09-2018, 04:44 AM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Ok, bad joke.
Ugh. 2 pits and 5 cats. My wife loves the Chewy website and has things delivered "just because". I bought DAP's Plastic Wood. This is my first time buiding anything like this so I am not expecting finish carpentry. But I am sure it will turn out ok.
ratm is offline
post #29 of 42 Old 09-09-2018, 05:42 AM
jcmccorm's Avatar
Quoted: 602 Post(s)
Liked: 449
Consider using a flush trim bit with a router. The front baffle *should* overhang slightly on all sides (if it's like the DIYSG kits I'm familiar with). You can use the trim bit to shave the baffle flush with the sides, top, and bottom. Saves a lot of sanding. Other than that, I hope you have a palm sander
jcmccorm is offline
post #30 of 42 Old 09-09-2018, 11:30 AM - Thread Starter
ratm's Avatar
Quoted: 186 Post(s)
Liked: 96
Thankfully I did. So here are the cabinets all done. I def have a new found respect for anyone who is good at woodworking. Im hoping and thinking that Duratex will hide some if not most of the imperfections in my sanding.
ID:	2453260   Click image for larger version
ID:	2453262   Click image for larger version
ID:	2453264   Click image for larger version
ID:	2453266   Click image for larger version
ratm is offline
