Warrior's Subwoofer Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #91 of 107 Old 10-31-2019, 10:33 AM - Thread Starter
TheWarrior97's Avatar
Quoted: 106 Post(s)
What is my next step after I plug into the nx6000d and Aventage 3070. Do I run ypao? Do I put certain settings in the nx dsp before or after ypao? When do I use the REW software and mic?
Yamaha Aventage 3070
5.1 Surround Sound. (Klipsch RC 62II center, 4 JBL SP8II, HST-18 Vented Subwoofer 12.5)
Sony XBR-55x850b
PS4 Pro
TheWarrior97 is offline
post #92 of 107 Old 10-31-2019, 06:01 PM
jujuman200's Avatar
Quoted: 161 Post(s)
Liked: 136
Originally Posted by michael hurd View Post
Yes, you are correct in that your mileage may vary. Just how deep is the rabbit hole.... that is the question.
Some of us are well on our way to the core of the earth..... CLEAN DEEP BASS is a DRUG..... once you are hooked there is NO GOING BACK.....
You will laugh at yourself for thinking that your HTIB with the 8" sub was bumping.....
Juju
Wish List: 2- Red Five DEVASTATOR MINI, 2- Red Five DEVASTATOR LFE, 1- BOSS platform.
Anthology http://www.speakerdesignworks.com/Anthology_1.html
jujuman200 is offline
post #93 of 107 Old 10-31-2019, 06:22 PM
smcmillan2's Avatar
Quoted: 965 Post(s)
Liked: 825
A HPF at or just under tune. If tune is below 20Hz: https://www.avsforum.com/forum/155-d...z-dcx2496.html
I adjust the PEQ of the sub(s) first based on REW measurements, then run Audyssey. Depending on outcome I may adjust them again.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #94 of 107 Old 11-05-2019, 08:27 PM - Thread Starter
Quoted: 106 Post(s)
so in my winisd file, "Highpass (Butterworth, n=2, fc=13.25 Hz)" and it is tuned to 15hz. Which number should be my highpass filter?
Sony XBR-55x850b
PS4 Pro
post #95 of 107 Old 11-08-2019, 10:12 PM - Thread Starter
Quoted: 106 Post(s)
I did some measurements from this video.
First graph was just the subwoofer. the second graph was after i did YPAO with subwoofer.
Did I do it right?
ID:	2638468   Click image for larger version
Name:	Subwoofer before and After ypao.jpg
Sony XBR-55x850b
PS4 Pro
post #96 of 107 Old 11-10-2019, 12:17 PM - Thread Starter
Quoted: 106 Post(s)
Should I be following this guide for my subwoofer setup?
file:///C:/Users/Little%20Warrior/Downloads/REW%20101%20HTS%20Current%20Version.pdf
First I need to make sure my NX6000D is setup correctly before i run the measurements in REW.
Do these setting images look correct?
Second, for my Yamaha receiver, do I clear all settings and set the YPAO to "through" or flat to get the subwoofer tuned? I am using the UMIK CSL calibrated and HDMI connection to my Yamaha Amp. I have an HST 18 vented.
Thanks everyone for your help in advance!
Name:	NX DSP Filter&Crossover Tab.jpg
ID:	2639100   Click image for larger version
Name:	NX DSP Parametric Tab.jpg
ID:	2639102   Click image for larger version
Name:	NX DSP Configuration Tab.jpg
ID:	2639104   Click image for larger version
Name:	NX DSP Dynamic EQ Tab.jpg
Sony XBR-55x850b
PS4 Pro
post #97 of 107 Old 11-10-2019, 12:31 PM
smcmillan2's Avatar
Quoted: 965 Post(s)
Liked: 825
We can't view files on your computer... This would be a good resource (looks like the one you have on your computer): https://www.dropbox.com/s/zdhq72a1pu...%20Version.pdf
A HPF to start, yes.
I disable Audyssey (YPAO in your case) before taking measurements, tweak the PEQ based on the measurements, then run Audyssey and remeasure. if Audyssey does not give me the FR I was looking for on the subs I will work the PEQ again with Audyssey engaged.
post #98 of 107 Old 11-10-2019, 01:19 PM
Augerhandle's Avatar
Quoted: 1297 Post(s)
Liked: 1281
Notice your High Shelf reduces everything above 20 HZ by 8dB. You'll need to compensate by turning up the Virtual Gain on the Filter/Crossover tab, or the sub may be awfully quiet.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #99 of 107 Old 11-10-2019, 04:30 PM - Thread Starter
Quoted: 106 Post(s)
How much do I turn it up? Till the graph reaches a certain point?
Sony XBR-55x850b
PS4 Pro
post #100 of 107 Old 11-10-2019, 04:32 PM - Thread Starter
Quoted: 106 Post(s)
We can't view files on your computer... [IMG class=inlineimg]/forum/images/smilies/wink.gif[/IMG] This would be a good resource (looks like the one you have on your computer): https://www.dropbox.com/s/zdhq72a1pu...%20Version.pdf
That's the document I was posting. Great thanks.
What about under configuration tab...am I suppose to change the box to 4 ohm and make the peak show 3020 watts? Anything I need to do on that tab?
Also, does it look like I am achieving around 13.5 hz with the filter?
Sony XBR-55x850b
PS4 Pro
post #101 of 107 Old 11-11-2019, 06:35 AM
Liked: 1281
Technically, as much as you used for the High Shelf (8dB). The two settings balance out to 0dB, while maintaining the slope of the High Pass.
post #102 of 107 Old 11-12-2019, 11:24 PM - Thread Starter
Quoted: 106 Post(s)
The following settings were applied in REW preferences. Do they look correct?
HST-18 mounted in a 12.5cu ft cabinet ported. WINISD tuned to 15hz.
Set as 7.1 in windows 10. Microphone level at +5.3db. HDMI connection to Aventage 3070 with YPAO set to "through". Utilizing NX6000D through one channel, Butterworth 12db @ 20hz and applied filter -7db gain at 20hz for HS12 to get 13.5hz HPF and increased main gain +7db to counteract this. UMIK CSL. 90 degree. 7 measurements. Left, Right, Center seat of couch. Then center had 5 measurements, slightly left, right, up, & down.
Sony XBR-55x850b
PS4 Pro
post #103 of 107 Old 11-12-2019, 11:37 PM - Thread Starter
Quoted: 106 Post(s)
Set as 7.1 in windows 10. Microphone level at +10.9db. HDMI connection to Aventage 3070 with YPAO set to "through". Utilizing NX6000D through one channel, Butterworth 12db @ 20hz and applied filter -7db gain at 20hz for HS12 to get 13.5hz HPF and increased main gain +7db to counteract this. UMIK CSL. 90 degree. 7 measurements. Left, Right, Center seat of couch. Then center had 5 measurements, slightly left, right, up, & down.
Placed these results in the NX Edit Software
Sony XBR-55x850b
PS4 Pro
post #104 of 107 Old 11-16-2019, 09:23 AM
Quoted: 2910 Post(s)
Liked: 12386
When doing AutoEQ in REW, I wouldn't set the LF cutoff the way you did. You have the HPF in place in the NX6000D to protect the sub, so the signal will have that cutoff, but that doesn't mean you want the response to. Use a flat target response instead.
Since you can't EQ <20Hz in the NX6000D, you may want to try changing your negative HS to -6dB or -5dB. That should flatten your response a bit <20Hz where you can't EQ and give you a better starting point to EQ from. It will effectively raise the frequency of your HPF so it will certainly be safe. Alternatively, keep that hump in the teens and EQ everything above.
jujuman200 likes this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #105 of 107 Old 11-16-2019, 11:18 PM - Thread Starter
Quoted: 106 Post(s)
Thank you so much for responding! I have very little idea what I am doing. I just followed the guide; Getting Started with REW.
Just tell me what numbers and where. Use autoeq or not? Change the LF cutoff from the 13hz I have to what? Where do I select flat target response?
I changed the gain to -6db. YPAO keeps making my speakers LARGE
Sony XBR-55x850b
PS4 Pro
post #106 of 107 Old 11-17-2019, 08:30 AM
Aural_Sex's Avatar
Quoted: 36 Post(s)
I haven't used the auto-eq and I just started my tuning yesterday, so I won't have all the answers. That said I may have some pointers.
First I'd make sure you're happy with your phase in the amp because you could lose hours of tweaking by finding that you were happier at 180.
Next I'd do two things to the REW graph before diving in - first remove your smoothing since you're just eq'ing the bass, you want the nitty gritty; second, tighten the Limits so you can get a better view of your peaks/valleys - in your case I'd start with your LPF for the bottom of the range and put the top at 105ish so you can get a feel for the variance in db. From your low end to your high you've got about 25 db range that you'll want to smooth to within 5 db.
The rest is going to be the fun part - tweaking and testing. I spent 4 hours playing with the PEQ and running sweeps until I was happy and in a 4 db range from 20 to 100 hz. You'll find some of your peaks need to be brought in check with your Quality up to 10 - sniping the rogue spike. Others you'll want to smooth in order to calm the hump and you may go as low as .5. It's all about the process so take your time and enjoy playing with your toys.
Once you've reset your graph run another sweep and post here - I'd be happy to help you dial it in.
Aural_Sex is offline
post #107 of 107 Old 11-17-2019, 03:16 PM
Liked: 12386
You can use AutoEQ, just set the LF cutoff to 1Hz and it will stay flat.
After you change the gain, run another sweep and see if you like it better as your starting point for AutoEQ.
