Tall and skinny 18” build, Thank you LTD02 - AVS Forum | Home Theater Discussions And Reviews
 44Likes
post #1 of 49 Old 09-30-2018, 10:53 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Back in June I reached out to LTD02 for his help and knowledge in designing new enclosures for my SId4’s. They have been in Marty cubes since 2014. In my old livingroom they were fine as I had plenty of space to put them. Now moving forward to our new house and dedicated theater build. My new room was smaller than I wished but that’s ok. So in order to fit in a AT screen, false wall, and stage I had limited depth behind my screen wall, 19”. So I knew the cubes would not fit so time to rebuild. So that is where LTD02 comes in to help as always, plus many other fellow AVSers. That’s what makes this community so great.
So the maximum size I gave him was 24” W x 16”-18” D x 76 H. But let him know I would prefer as shallow as possible with my limited space. He came back with 22”W x 14”D x 75”H, perfect. They are 8.5 cf and 17hz tune.
Seeing my theater is almost to the screen wall I better start the new enclosures build. So made up a cut list and off to Home Depot I go. I had them make a 2 cut per sheet so I can get the wood home and manage in the table saw. Here is the wood after getting it home.
So after running the boards thru the table saw and using my crosscut jig we have all the boards ready to assemble.
Does not look like much but there is 4 big panels there too.
Cut sheets and plans ready to go.
Got both enclosure shells built and that’s enough for now.
How they sit now in garage, no the port rails are not in yet, just sitting there.
bluer101 is offline
post #2 of 49 Old 09-30-2018, 11:08 AM
asarose247's Avatar
Quoted: 1178 Post(s)
Liked: 1041
subbed . . .
space constraints can be a bug-a-boo, especially when looking for a good deep FR dig,
placement issues notwithstanding
that size would work very well in my mancave , tho the 2 THTLP's do manage about 95%+ of what there is to listen to. .
can you post any of the modeling graphs?
how will you power them?
DIY FAN Denon X4400 , ATI A 2000 for 7.4.6 SCATMOS Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS V2, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
asarose247 is offline
post #3 of 49 Old 09-30-2018, 01:08 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Originally Posted by asarose247 View Post
subbed . . .
I would have to ask LTD02 for the graphs. I gave him my space specs, subwoofers ( si18d4’s), and still using my inuke 3000dsp.
If I can get another si, already have a spare, I will buy a new inuke 6000dsp and use the 2 cubes for nearfield instead.
bluer101 is offline
post #4 of 49 Old 10-01-2018, 06:43 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Got a question. What if I added a another layer of mdf at the bottom of the subwoofer? Basically it will be a double baffle at the bottom. This would let me flush the subwoofer into the box and add strength to the woofer area. I’m still doing all the bracing but would like to flush the subwoofer. If I make the extra layer the size piece would be roughly 20” x 29” x 3/4”. This is my math is correct is less than a 1/4 cubic feet. Would this be an issue taking away from the volume? Also thinking of window bracing instead.
Here is a crude image.
bluer101 is offline
post #5 of 49 Old 10-01-2018, 07:22 AM
michael hurd's Avatar
Quoted: 631 Post(s)
Liked: 667
My rough estimate is around 9 ft^3 after port so if you take off a 1/4 cubic foot with the same port length, WinISD predicts a shift of 0.25 hz upwards. No big deal.
Ask your doctor if DIY is right for you. Side effects of DIY may include anxiety, elevated blood pressure, lightheadedness, rapid heartbeat, skeletal muscle flaccidity, euphoria, psychological dependence, insomnia, confusion, blurred vision, implusivity, uncontrolled or repeated movements.
michael hurd is offline
post #6 of 49 Old 10-01-2018, 08:01 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Thank you, I need to learn winsid.
bluer101 is offline
post #7 of 49 Old 10-01-2018, 08:07 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
subbed . . .
This is what LTD02 ( John ) wrote when he designed it for me,
“This one is ported out the top side, so that you can take full advantage of your available height. It doesn't have to be exactly 75", half inch or 1 less won't matter. Tuning is about 17hz, internal volume is around 8.5 cubic feet net. I wouldn't go much smaller than that with that driver.
Your room is very small, so if you wanted to go with sealed, that would probably work fine too. Cabs would be pretty much the same concept, just without the port.
The ported cab will provide about 4dB more output on the low end relative to sealed, but in your room you will probably have a lot of room gain.
On the other hand, if you build the ported, you can always experiment between sealed and ported by simply stuffing the last foot of the port with something to block off the air flow or even building a, air tight cover door for the port.”
bluer101 is offline
post #8 of 49 Old 10-01-2018, 01:46 PM
psyvision's Avatar
Quoted: 25 Post(s)
Liked: 51
Something like this would be great for me too! The 14" depth would do-able for my baffle wall nicely.
bluer101 likes this.
psyvision is offline
post #9 of 49 Old 10-01-2018, 03:03 PM
Craig S King's Avatar
Quoted: 351 Post(s)
Liked: 498
Another great design, thanks to LTD02!
curtisG and bluer101 like this.
Craig S King is offline
post #10 of 49 Old 10-01-2018, 03:48 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
I decided not to do the extra baffle to flush the woofer. The extra wood and time would not be worth it. So I went home and ripped 2x4’s down to 2x2 or 1.5 x 1.5 seeing I had the wood on hand and normally you can’t find them in store straight enough. I glued and clamped about half of them in one cab after work.
bluer101 is offline
post #11 of 49 Old 10-02-2018, 05:15 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Quick layout.
Bracing put in that is not dependent on the subwoofer location. Will cut sub hole first then install sub bracing.
Ripped 2x4 for bracing. Made extras incase I want to add a few more around the woofer seeing I already had my stop blocks setup on the saws.
asarose247 and bubbrik like this.
bluer101 is offline
post #12 of 49 Old 10-02-2018, 10:10 AM
teester9484's Avatar
I think I need to do that very thing. What was your room cu ft? Mine is around 3300. I could stand two of them up like columns beside the sofa or in corners. I'm still pretty clueless about placement, room gain etc. I just want killer low base for movie effects.
What's the estimated weight? Understand a sheet of 3/4 MDF is around 100lbs.
teester9484 is offline
post #13 of 49 Old 10-02-2018, 10:18 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
I don’t know the weight yet but I will weigh them after their done. My room cu ft is 1025, lol. It’s a dedicated theater build, you can see my build thread in my signature. I had the 2 si18’s in Marty cubes but they would not fit behind my proposed false wall so I needed to slim them down. One other benefit is I’m almost doubling the internal volume with these over the cubes.
bluer101 is offline
post #14 of 49 Old 10-02-2018, 11:35 AM
Quoted: 20 Post(s)
Liked: 9
teester9484 do you really need to quote the whole thing with all the images? ...
You might want to add dampening material to one side since there will be quite "deep" standing waves inside. Depending on the crossover those will have a negative impact.
HerbertThePervert is offline
post #15 of 49 Old 10-02-2018, 11:55 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Directly from LTD02 when I asked him about lining the cabs with like I did my cubes wth eggcrate.
“1-2 polyester "Walmart" pillows placed toward the center of each cab would be best.”
So a couple of pillows it is. Will slip those up in before mounting the driver.
bluer101 is offline
post #16 of 49 Old 10-02-2018, 03:58 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Worked on one cab when I got home. Ran into an issue. While glueing in the port somehow with some clamps and the glue the back moved a little bit. To explain the photos the port is crooked. The one side is in 1/8” and other is out 1/8”. If I’m thinking correctly the port volume did not change do to give and take, right? Will it still be ok or should I build another cab seeing trying to remove wood glue and brad nails will be impossible without destroying the wood?
Here are some photos.
You can see the bottom is to the left and top is to the right.
Here is a square piece of wood for reference, total is about 1/4 inch from top to bottom, hence 1/8 on each side.
bluer101 is offline
post #17 of 49 Old 10-02-2018, 04:13 PM
[QUOTE=bluer101;56897284]
Didn't realize I was doing that Perv.
post #18 of 49 Old 10-02-2018, 04:28 PM
Quoted: 631 Post(s)
Liked: 667
Not to fear, PL Premium ( PL3X ) will bridge that gap no problem. Get yourself a tube or two for a caulking gun and fill that gap up. Home Depot / Lowes / pretty much any home improvement / hardware store.
bluer101 and smcmillan2 like this.
post #19 of 49 Old 10-02-2018, 04:34 PM
smcmillan2's Avatar
Quoted: 776 Post(s)
Liked: 679
Port volume hasn't changed so that's not an issue. The possible issue is the side that hasn't been glued yet - Will that side sit flat on the port board? If only 1/8" off you should be good.
A little extra glue on that edge to help cover the slight gap should be fine. I would run a few extra brad nails on that line as well.
One trick I use for a "T" style piece like that is to cut blocks the same depth of the center and place those in between the port panel and whatever it's sitting on. Won't rock on you that way, remove right after gluing so they don't get stuck.
ETA: PL3, As Michael mentioned, will fill pretty large gaps, but I took the plywood in the last pic to be a scrap piece that wouldn't be part of the cab. Just there to show the offset. If that's not the case, use the PL3 to fill the gaps.
smcmillan2 is offline
post #20 of 49 Old 10-02-2018, 05:52 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Thanks guys. The board is there only to show the offset. There is no gap at the glued joints. It’s just crooked as you can see in the first photo. There should be no gap either when I put the front baffle on the cab.
So for safe measure I could put a bead or caulk line of PL3 on those joints just incase? I’m just a perfectionist and this normally does not happen, lol. I was about to scrap the cab and build another.
bluer101 is offline
post #21 of 49 Old 10-02-2018, 06:00 PM
Quoted: 631 Post(s)
Liked: 667
If you want, yes you can use a fillet of PL Premium on the joints. Using fillets on adhesive joints are common in the boating world.
post #22 of 49 Old 10-02-2018, 06:02 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Thank you. I will carry on with the build.
bluer101 is offline
post #23 of 49 Old 10-02-2018, 10:58 PM
asarose247's Avatar
Liked: 1041
Having been properly educated building the BFM subs,
(IITP!)
PL3 for the WIN
If joy of the LF chase be the food of HT love, then build on.
That original fleetwood Mac album , which I still play, never sounded better with those F15's and subs . .
get that PL3 bead working for you . .
post #24 of 49 Old 10-04-2018, 04:52 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Work a little tonight. I decided to do the recessed with baffle. So cut the baffle to fit and added a 45 cutoff where the port is. Cut out the new baffle and the cab front. Did test fits with my spare si18. Looks good and hope to get them both fully assembled by weekends end.
Cut the recessed baffle.
Cutting the front of the cab.
Backer board for cutting the circles.
Both are done.
Test fit.
LTD02, 4fit?, brettus and 1 others like this.
bluer101 is offline
post #25 of 49 Old 10-08-2018, 05:51 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Got both boxes glued up and assembled this weekend.
Bracing glued in.
Both recessed baffles are in. I’m glad I decided to add this back in after being undecided. Plus make the cab much stronger.
You can see the extra wood blocks for the subwoofer mounting screws.
No pictures of flush trimming edges or filling all the brad holes. But after a close up of the woofer hole.
Both sitting in the garage after finished for the day. Got one cab doneready for Duratex. I’m going to visit Acry-Tech Coatings Inc that makes Duratex. They are about 15-20 minuted from my place, so figuredthis time I will go directly to them.
bluer101 is offline
post #26 of 49 Old 10-08-2018, 06:24 AM
thesamarai's Avatar
Quoted: 87 Post(s)
Liked: 59
do u think this cab would work seamlessly with a Dayton rss490ho 18 inch driver. I already have two of these drivers up front in marty cubes and this design would surely fill in the gap behind my seats for near field effect.
thesamarai is offline
post #27 of 49 Old 10-08-2018, 07:10 AM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
I would think so but that question should be asked to the guys that model the woofers.
I have to cubes also that currently house my 2 si18”s. The reason for building these new cabs is my limited space behind my false wall.
I thought about adding to Dayton or ultimax to the cubes as nearfield or vise versa.
bluer101 is offline
post #28 of 49 Old 10-09-2018, 05:39 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Today I decided to take a ride to pickup the Duratex. I live close to the company that makes it, Acry-Tech Coatings. Very polite people and asked where I heard about the product. Had to tell them AVS forums. After a little chat and payment head back home. Here is the business.
The product we all know.
Had too still drill and flush mount the neutrik connectors on the cabs, no picture. Got them all dusted off and wheeled into the theater. This is where I will hang and put down plastic to coat them, to hot and humid outside. So while they were in the room decided to throw them up on the stage to see. Wow they are large.
bluer101 is offline
post #29 of 49 Old 10-10-2018, 05:57 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
One cab done. Did not do bottom or back. No reason too.
LTD02 and 4fit? like this.
bluer101 is offline
post #30 of 49 Old 10-11-2018, 05:00 PM - Thread Starter
bluer101's Avatar
Quoted: 612 Post(s)
Liked: 681
Thanks guys, I was also looking at those gym style interlocking floor tiles. The other isssue is I’m going to need the ability to remove the tower speakers and slide or move the 2 subwoofers to the right so I can access the back of the rack. I would rather not have to lift those off each time. They are very heavy even without the drivers mounted yet.
Painted the other cab tonight and just got back from Walmart for some pillows. I got 4 pillows 2 per cab to put in the center.
bluer101 is offline
