Southeast Michigan 2019 diy gtg tour - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 763Likes
post #361 of 806 Old 01-10-2019, 06:30 PM
eng-399's Avatar
Quoted: 2418 Post(s)
Liked: 4963
eng-399 is offline
post #362 of 806 Old 01-10-2019, 06:37 PM - Thread Starter
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Heck yeah man I really cant wait for everyone to check out the upgrades
Sent from my SM-N950U using Tapatalk
hd0823 is online now
post #363 of 806 Old 01-10-2019, 06:40 PM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Originally Posted by hd0823 View Post
Man fired the 4 up with the baffle wall being finished and wow spl didnt go up crazy but it's so much more tactile. John wick 2 tunnel scene was awesome every seat feels like it has butt kickers in it and the sound is so clean and distortion free
I am really happy for you that this has turned way better than you thought. My only concern is now will your house withstand your theatre?
Mahuzz13 is online now
post #364 of 806 Old 01-10-2019, 06:41 PM
Quoted: 174 Post(s)
Liked: 132
Originally Posted by eng-399 View Post
Not Jarrod here but I’ve had one setup almost having me beg for mercy which was lukemanamd on avs with his 10-12 21” subs and monster size mains with dual 18” drivers in them. The bass was insane in his room it actually starts hurting your chest.
I could be wrong but i thought i heard that Luke actually blew a wall out of his room because the SPL was so high like in to the 150 plus range. I have sat in cars that could do that and yes your body hurts. That is a awesome experience for sure.
Randy_J is online now
post #365 of 806 Old 01-10-2019, 07:13 PM
philly_03's Avatar
Quoted: 69 Post(s)
Liked: 79
This! + I want to feel the gunshots in your chest! Not to the point where it hurts and you want to vomit. Just a nice thump that let's you feel every gun shots. It seems it is always one or the other but I like both and I do not want to lose that tactile feeling from the horn.
Love that scene!
Phil.
Sent from my SM-N950W using Tapatalk
philly_03 is offline
post #366 of 806 Old 01-10-2019, 07:21 PM
philly_03's Avatar
Quoted: 69 Post(s)
Liked: 79
That is insane!
And sweet at the same time!
Phil.
post #367 of 806 Old 01-11-2019, 05:03 AM
trilkb's Avatar
Quoted: 642 Post(s)
Liked: 324
Thats a great scene!
- 6 BA CR6 array center channel, QSC AD-S82 L/R, 4 jbl 8330a surr , 8 jbl 12" subs w/Inuke 6000. JVC rs420, Denon x4000, Sony x800 -
trilkb is offline
post #368 of 806 Old 01-11-2019, 05:07 AM
Jk7.2's Avatar
Quoted: 1408 Post(s)
Liked: 2571
Originally Posted by philly_03 View Post
That is insane!
Phil.
Mike your system is the only one that ever made me sneeze. Lol it tickled my nose hairs enough I was almost in tears.
eng-399 and Mahuzz13 like this.
Jk7.2 is online now
post #369 of 806 Old 01-11-2019, 05:56 AM
trilkb's Avatar
Quoted: 642 Post(s)
Liked: 324
Love that scene!
Phil.
My 8 12's do that . Another thing that helps me with tactile feel is a hollow foot rest.
Sounds like you need to get REW and umik one out. IF you get that far you can make it easy on yourself and use the REW AUTO EQ function and it will spit out some EQ settings you can input into whatever DSP amp you are running. Ive learned some about REW, not near as much as other people. But you should run tests at listening volume.
The jbls are a bit more involved since they typically have a huge peak at 60-70hz and are weak down low. They need a 10-12db boost from 40hz down minimum. Thats why I like sealed, horns you shouldnt boost, just knock down the peaks, sealed you can do whatever is needed.
Id be interested to see a REW measurement from your setup, mine was UGLY befor I started. Its better, but not perfect. Even with 4 12's in each front corner my seating position isnt the best because of the room.
I kind of hope someone talks about REW, I read in the past sometimes it happens. Theres tons to learn about it.
trilkb is offline
post #370 of 806 Old 01-11-2019, 06:05 AM
Jk7.2's Avatar
Liked: 2571
I’m sure @eng-399 will be happy to run a quick REW sweep in both of our rooms. Mine is extremely convenient to hook up and run. He could then explain what we see with measurements. This is all assuming he doesn’t mind . I can even show measurements of each group of subs adding to the overall spl and flattening of the response at the mlp. I had a blast measuring and seeing the improvement @mtg90 work through did with adding delay.
eng-399 likes this.
Jk7.2 is online now
post #371 of 806 Old 01-11-2019, 06:14 AM
eng-399's Avatar
Liked: 4963
eng-399 is offline
post #372 of 806 Old 01-11-2019, 06:45 AM
philly_03's Avatar
Quoted: 69 Post(s)
Liked: 79
Looking forward to taking some sweeps in both of your rooms. Can’t wait to see what it looks like.
I look forward to learning as much as I can!
Phil.
eng-399 and Kevin4730 like this.
post #373 of 806 Old 01-11-2019, 06:46 AM
philly_03's Avatar
Quoted: 69 Post(s)
Liked: 79
I just for home from work. I will reset my AVR and start hooking up my mic. Should I take measurements before running MCACC?
phil.
post #374 of 806 Old 01-11-2019, 07:20 AM
trilkb's Avatar
Quoted: 642 Post(s)
Liked: 324
no, youll run mcacc, then youll have to get a laptop and open REW and hookup the umik1 and go through that process. Definitely dont take a measurement at listen level unless you know what freq you are starting at.
That was a good one I stumbled across. I need visual to learn.
trilkb is offline
post #375 of 806 Old 01-11-2019, 11:19 AM
Rgb
Rgb's Avatar
Quoted: 502 Post(s)
Liked: 642
Haven't read the whole thread, but have fun with the GTG's through mid Feb.
Going on a cruise first week of Feb- my first one.
https://cruisetotheedge.com/the-bands/
Prog Rock theme
I think my HT got Brian H's sign off, so I should be good to go for a gtg after I install my first 4 Atmos ceiling speakers.
Kevin4730 likes this.
Rgb is offline
post #376 of 806 Old 01-11-2019, 03:01 PM
philly_03's Avatar
Quoted: 69 Post(s)
Liked: 79
https://www.youtube.com/watch?v=1NPOQw04NtQ
My asio4all decided not to work....I had to uninstall everything and reload it.
Phil.
post #377 of 806 Old 01-13-2019, 10:38 AM
Jk7.2's Avatar
Liked: 2571
I’m getting setup for the gtg. Looking pretty good......rack and rear substhis seat is fun
imrf, femi, OJ Bartley and 2 others like this.
Jk7.2 is online now
post #378 of 806 Old 01-13-2019, 10:42 AM
philly_03's Avatar
Quoted: 69 Post(s)
Liked: 79
The beam me up scotty Seat!
Phil.
Jk7.2 and Mahuzz13 like this.
post #379 of 806 Old 01-13-2019, 10:46 AM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
Looking real good Jared
Jk7.2 likes this.
post #380 of 806 Old 01-13-2019, 10:55 AM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
If anyone is interested (little excited)
OJ Bartley, eng-399, Jk7.2 and 3 others like this.
post #381 of 806 Old 01-15-2019, 08:24 AM
Jk7.2's Avatar
Liked: 2571
I’ve now got 2 in my carpool. Looking for 1 more.
Jk7.2 is online now
post #382 of 806 Old 01-15-2019, 08:59 AM
trilkb's Avatar
Quoted: 642 Post(s)
Liked: 324
Did anyone pick a hotel yet? Looks like we are getting more snow next weekend. Car had a flat this morning, sidewall puncture grrrr, but I need a new center channel and would like to hear some!
trilkb is offline
post #383 of 806 Old 01-15-2019, 09:01 AM
Jk7.2's Avatar
Liked: 2571
I still haven’t seen any snow this winter.
Jk7.2 is online now
post #384 of 806 Old 01-15-2019, 09:01 AM
Quoted: 158 Post(s)
Liked: 88
Let me check what my friend’s plan is. He might want to tag along for Jeremy’s house too
TV: Panasonic 60" VT60 Plasma Surround: Yamaha RXA3050 5.1.2 Definitive Technology BP7006 (front), DefTech studio 350's (rear), Def Tech Di6.5r (ceiling) Players: Raspberry Pi running OpenElec/Kodi, Roku, Sony Blu-ray Control: Control4, whole house automation
Kevin4730 is offline
post #385 of 806 Old 01-15-2019, 09:01 AM
Jk7.2's Avatar
Liked: 2571
Ok cool
Jk7.2 is online now
post #386 of 806 Old 01-15-2019, 09:11 AM
Mahuzz13's Avatar
Quoted: 319 Post(s)
Liked: 475
There is a few of us staying at the Holiday Inn
1150 ROBERT T. LONGWAY BLVD
FLINT MI 48503
1-810-238-7744
Our plan is to leave our car at the hotel after Jared’s and Uber over to Jeremy’s and Uber back, if there is anyone that can fit 4 guys in their vehicle to take us to Jeremy’s that would be awesome.
Let us know
Duane
OJ Bartley and eng-399 like this.
post #387 of 806 Old 01-15-2019, 09:15 AM
philly_03's Avatar
Quoted: 69 Post(s)
Liked: 79
Did somebody say snow!
Phil.
Jk7.2 likes this.
post #388 of 806 Old 01-15-2019, 09:16 AM
Jk7.2's Avatar
Liked: 2571
Phil.
That’s nice! If it’s gonna be cold and grey, I prefer snow.
Jk7.2 is online now
post #389 of 806 Old 01-15-2019, 09:24 AM
philly_03's Avatar
Quoted: 69 Post(s)
Liked: 79
Me too! It is usually warmer when it snows.
Jk7.2 likes this.
post #390 of 806 Old 01-15-2019, 01:08 PM - Thread Starter
hd0823's Avatar
Quoted: 716 Post(s)
Liked: 1311
Forget that I'll take the cold and grey and no snow lol
louisdamani likes this.
